Je n'arrive pas à installer les dépendances sur un RPI 3 en 3.3.24 . Le chargement s'arrête à 20% et passe en NOK. J'ai visiblement un pb de hash, ce RPI n'est accessible qu'en 3G avec les DNS Jeedom, est-ce que cela pourrait être la cause du pb ?
Merci de votre aide,
Lancement de l'installation/mise à jour des dépendances openzwave
Get:1 http://archive.raspberrypi.org/debian stretch InRelease [21.4 kB]
Err:1 http://archive.raspberrypi.org/debian stretch InRelease
Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
Get:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [21.4 kB]
Err:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Fetched 42.8 kB in 1s (26.4 kB/s)
Reading package lists...
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/stretch/InRelease Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
E: Failed to fetch http://archive.raspberrypi.org/debian/dists/stretch/InRelease Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
E: Some index files failed to download. They have been ignored, or old ones used instead.
Installation des dependances
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.3).
g++ is already the newest version (4:6.3.0-4).
g++ set to manually installed.
gcc is already the newest version (4:6.3.0-4).
gcc set to manually installed.
git is already the newest version (1:2.11.0-3+deb9u4).
make is already the newest version (4.1-9.1).
make set to manually installed.
python-dev is already the newest version (2.7.13-2).
python-dev set to manually installed.
python-pyudev is already the newest version (0.21.0-1).
python-requests is already the newest version (2.12.4-1).
python-serial is already the newest version (3.2.1-1).
python-setuptools is already the newest version (33.1.1-1).
python-setuptools set to manually installed.
unzip is already the newest version (6.0-21).
python-pip is already the newest version (9.0.1-2+rpt2).
The following additional packages will be installed:
libjpeg62-turbo-dev python-bs4 python-html5lib python-nose
python-webencodings
Suggested packages:
python-genshi python-twisted python-qt3 python-lxml-dbg python-lxml-doc
python-coverage python-nose-doc
libjpeg-dev libjpeg62-turbo-dev libudev-dev python-bs4 python-html5lib
python-louie python-lxml python-nose python-webencodings
0 upgraded, 9 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,461 kB of archives.
After this operation, 5,503 kB of additional disk space will be used.
Get:1 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libudev-dev armhf 232-25+deb9u9 [91.9 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libjpeg62-turbo-dev armhf 1:1.5.1-2 [181 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libjpeg-dev all 1:1.5.1-2 [56.1 kB]
Get:4 http://raspbian.raspberrypi.org/raspbian stretch/main armhf python-bs4 all 4.5.3-1 [86.7 kB]
Get:5 http://raspbian.raspberrypi.org/raspbian stretch/main armhf python-webencodings all 0.5-2 [10.3 kB]
Get:6 http://raspbian.raspberrypi.org/raspbian stretch/main armhf python-html5lib all 0.999999999-1 [88.0 kB]
Get:7 http://raspbian.raspberrypi.org/raspbian stretch/main armhf python-nose all 1.3.7-2 [132 kB]
Get:8 http://raspbian.raspberrypi.org/raspbian stretch/main armhf python-louie all 1.1-2.1 [21.2 kB]
Get:9 http://raspbian.raspberrypi.org/raspbian stretch/main armhf python-lxml armhf 3.7.1-1 [793 kB]
Err:1 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libudev-dev armhf 232-25+deb9u9
Hash Sum mismatch
Hashes of expected file:
- SHA256:efc6922d0c864156fc1f550e808bfe13f8f200fd665a6dd13439e2a969c9c238
- SHA1:65f5dc5357373df72a4896f13e39e7bf4d910ef6 [weak]
- MD5Sum:969397a224ab4eccb3ee226642dc513f [weak]
- Filesize:91926 [weak]
Hashes of received file:
- SHA256:c2664f35f79f7616f4b87d2d5a21259bbe49dfdbd411cddbac13f839fa968a9e
- SHA1:a93f3302a5c0449fde8ea087b0ba81d2c193e549 [weak]
- MD5Sum:831172ec76ca223d740e8503a4dcfea4 [weak]
- Filesize:21413 [weak]
Last modification reported: Wed, 01 May 2019 07:45:14 +0000
Err:2 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libjpeg62-turbo-dev armhf 1:1.5.1-2
Hash Sum mismatch
- SHA256:4a277dd85ec638914b65e91fa4fd1917ddb7108944f01b77d5cdd883f976189d
- SHA1:7fc2bb2d33eb5a67fda022bcc76985d8e615e006 [weak]
- MD5Sum:ae60a539373c57cdd724816a457acb34 [weak]
- Filesize:180714 [weak]
Err:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libjpeg-dev all 1:1.5.1-2
Hash Sum mismatch
- SHA256:9236227a4ddab4eb81e9c76fd8f2bb1ff392e8aa039f87f005bec849fb26b855
- SHA1:f4230b8921e725aa54a978a35d217145f48a7212 [weak]
- MD5Sum:b2784c648268df0976d9312412efa436 [weak]
- Filesize:56150 [weak]
Err:4 http://raspbian.raspberrypi.org/raspbian stretch/main armhf python-bs4 all 4.5.3-1
Hash Sum mismatch
- SHA256:f466450bbc86e1b772b5c6b0f596b1979b944b2f02f50609cf8aa40956c4a21e
- SHA1:5f4b392723af5df91246747f4fc7e2cf2579bc30 [weak]
- MD5Sum:aee8772217cc8cce3737c0e4a6d5a6d5 [weak]
- Filesize:86666 [weak]
Err:5 http://raspbian.raspberrypi.org/raspbian stretch/main armhf python-webencodings all 0.5-2
Hash Sum mismatch
- SHA256:ef38183f830c3d46e76a97ecd7dc54d3fae893dbacb7648ded14378c665c21f9
- SHA1:4595dae325aad5a9bb489b0004f2014a7d24c762 [weak]
- MD5Sum:2cb277ea43e0355bedaf2bb8d7c3e582 [weak]
- Filesize:10254 [weak]
Err:6 http://raspbian.raspberrypi.org/raspbian stretch/main armhf python-html5lib all 0.999999999-1
Hash Sum mismatch
- SHA256:a2e1e56f9c60f5995627f3558c958fac11b65c797e51e3257be9eb3bb1ba02e4
- SHA1:a9ba1a36ccdf12b26ecade8ec734128abcff2f4c [weak]
- MD5Sum:c9982323d5d8a022a85c3401a13243a0 [weak]
- Filesize:88034 [weak]
Err:7 http://raspbian.raspberrypi.org/raspbian stretch/main armhf python-nose all 1.3.7-2
Hash Sum mismatch
- SHA256:7ce100c640ab694a8f7e840793fb046af4cb7d0c3580248c06390fae866bd01a
- SHA1:5007e24291f7b1c0e2b66a63e04ac6fffb4e89ed [weak]
- MD5Sum:538a248ef5b9f99b7a310e7c1d137043 [weak]
- Filesize:132204 [weak]
Err:8 http://raspbian.raspberrypi.org/raspbian stretch/main armhf python-louie all 1.1-2.1
Hash Sum mismatch
- SHA256:504578fcd9b46eb874572da46377951a57859674f64180a59400e17684062aa5
- SHA1:c4b0654dbd25733ca62686a6ddb615837871c4e2 [weak]
- MD5Sum:8918c5daaa29f5985a2e2d5f1cf574c4 [weak]
- Filesize:21152 [weak]
Err:9 http://raspbian.raspberrypi.org/raspbian stretch/main armhf python-lxml armhf 3.7.1-1
Hash Sum mismatch
- SHA256:0250ac3f90fb316cc33f35c32d88e7790976d74165751323217006f6130c346e
- SHA1:a20f7fb6b9965e1bf72704e2964b034dc981cb30 [weak]
- MD5Sum:c9a9c5c77d5eb4a2dba21edbe96c900d [weak]
- Filesize:793486 [weak]
Fetched 21.4 kB in 1s (15.6 kB/s)
E: Failed to fetch http://192.168.1.1/html/index.html?url=raspbian.raspberrypi.org Hash Sum mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
could not install git - abort
