Erreurs dans les logs http.error et openzwave
j'ai constaté des erreurs très régulières dans les logs http.error et openzwave.
Je ne suis pas certain du lien mais les erreurs semblent être synchronisées: j'ai tenté de refaire le build des dépendances du plugin zwave et pendant ce temps les erreurs se sont arrêtées.
http.error:
[Mon Sep 16 18:47:57.444334 2019] [:error] [pid 545] [client 127.0.0.1:33164] PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95
[Mon Sep 16 18:48:00.221625 2019] [:error] [pid 3753] [client 127.0.0.1:33165] PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95
[Mon Sep 16 18:48:06.736998 2019] [:error] [pid 31235] [client 127.0.0.1:33190] PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95
[Mon Sep 16 18:48:09.527140 2019] [:error] [pid 7357] [client 127.0.0.1:33192] PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95
[Mon Sep 16 18:49:55.750717 2019] [:error] [pid 31242] [client 127.0.0.1:33385] PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95
[Mon Sep 16 18:49:58.491865 2019] [:error] [pid 7357] [client 127.0.0.1:33386] PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95
[Mon Sep 16 18:50:01.190364 2019] [:error] [pid 3753] [client 127.0.0.1:33388] PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95
[Mon Sep 16 18:50:26.403383 2019] [:error] [pid 6132] [client 127.0.0.1:33436] PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95
[Mon Sep 16 18:50:34.267313 2019] [:error] [pid 3049] [client 127.0.0.1:33438] PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95
[Mon Sep 16 18:50:36.987338 2019] [:error] [pid 29799] [client 127.0.0.1:33439] PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95
[Mon Sep 16 18:50:39.663724 2019] [:error] [pid 29598] [client 127.0.0.1:33440] PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95
openzwave:
[2019-09-16 18:47:04][ERROR] : Error on send request to jeedom, return code 500
[2019-09-16 18:48:00][ERROR] : Error on send request to jeedom, return code 500
[2019-09-16 18:50:01][ERROR] : Error on send request to jeedom, return code 500
[2019-09-16 18:50:39][ERROR] : Error on send request to jeedom, return code 500
Jeedom tourne sur une Jeedom Smart, Linux 9.4, Jeedom 4.0.11 et plugin zwave 3.2.12.
La page santé indique que tout est ok et hormis ces logs inquiétants, tout fonctionne apparement.
Je n'ai rien trouvé sur le forum en cherchant ces messages d'erreur.
Quelqu'un aurait-il une idée du soucis ?
Merci d'avance.
http.error:
openzwave:
Merci d'avance.
Re: Erreurs dans les logs http.error et openzwave
Problème toujours présent avec le plugin zwave du 20/09
Vu le soucis je dirais que tu as du faire une boucle infini a un moment. En tout cas c'est sur c'est un soucis de configuration et pas un bug
Zut, j'ai ouvert un ticket juste avant
Je ne vois pas trop comment j'ai pu créer une boucle, je vais chercher dans mes modifications récentes.
Merci pour ton aide
Merci pour ton aide
Comme ça je dirais soit action sur valeur soit scénario en synchrone
J'avais justement rajouté une action sur valeur récemment et c'est la première fois que je l'utilise.
Je l'ai supprimé pour voir.
(Pourtant cela fonctionnait: sur l'état d'une prise Fibaro Wall Plug, si elle était allumée pendant plus de 30mn alors je l'éteins.)
J'ai redémarré la smart pour être sur, il n'y a plus qu'a attendre.
Grâce au support (merci Loïc) , le soucis semble identifié, avec une prise connectée qubino qui semble être devenue trop bavarde.
Configurée sur envoi de message sur variation de plus de 70% de consommation, elle envoie des milliers de messages par jour (même sans aucune charge !).
J'ai réglé sur 99% pour le moment et le problème a disparu.
A voir si le scénario de détection d'état de la machine a laver va fonctionner comme ça.
En fait le souci est revenu, après recherche je pense avoir résolu le problème mais sans explication finale :
Mes détecteurs de présence z-wave mettent à jour un virtuel d'indication de présence. Ce virtuel avait un soucis: il déclenchait une erreur 500 quand je le sauvais. Je n'ai pas trouvé de problème dans sa configuration alors je l'ai dupliqué et le duplicat ne montre aucun problème lui.
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 6 invités
