Salut Lunarok.
Voila les logs (Je n'y ai rien vu d'extraordinaire)
Jeedom Maitre (DIY ESXi, Debian 8)
mySensors
4-11-2015 17:08:19 | debug | 192.168.1.13
24-11-2015 17:08:19 | info | 156,2,1,1,2,1
24-11-2015 17:08:55 | debug | Vérification des dépéndances installées
24-11-2015 17:08:59 | info | Installation des dépéndances nodejs
24-11-2015 17:48:28 | debug | 192.168.1.13
24-11-2015 17:48:28 | info | 156,1,1,1,2,1
24-11-2015 18:06:11 | debug | Vérification des dépéndances installées
25-11-2015 20:22:20 | debug | 192.168.1.13
25-11-2015 20:22:20 | info | 156,1,1,1,2,1
25-11-2015 20:22:24 | debug | test node_.png
25-11-2015 20:22:24 | debug | test node_temp.png
25-11-2015 20:22:24 | debug | test node_contact.png
25-11-2015 20:22:24 | debug | test node_motion.png
25-11-2015 21:31:52 | debug | test node_.png
25-11-2015 21:31:52 | debug | test node_temp.png
25-11-2015 21:31:52 | debug | test node_contact.png
25-11-2015 21:31:52 | debug | test node_motion.png
25-11-2015 21:54:53 | debug | 192.168.1.13
25-11-2015 21:54:53 | info | 156,1,1,1,2,1
mySensors_dep
Début de l'installtion
Reading package lists...
Building dependency tree...
Reading state information...
build-essential is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 68 not upgraded.
mkdir: cannot create directory '/var/www': File exists
rm: cannot remove 'package.json': No such file or directory
> serialport@2.0.5 install /usr/share/nginx/www/jeedom/plugins/mySensors/node/node_modules/serialport
> node-pre-gyp install --fallback-to-build
[serialport] Success: "/usr/share/nginx/www/jeedom/plugins/mySensors/node/node_modules/serialport/build/Release/node-v14-linux-x64/serialport.node" is installed via remote
serialport@2.0.5 node_modules/serialport
├── bindings@1.2.1
├── sf@0.1.7
├── async@0.9.0
├── nan@2.0.9
├── debug@2.2.0 (ms@0.7.1)
└── optimist@0.6.1 (wordwrap@0.0.3, minimist@0.0.10)
request@2.67.0 node_modules/request
├── is-typedarray@1.0.0
├── aws-sign2@0.6.0
├── forever-agent@0.6.1
├── caseless@0.11.0
├── stringstream@0.0.5
├── tunnel-agent@0.4.1
├── oauth-sign@0.8.0
├── isstream@0.1.2
├── json-stringify-safe@5.0.1
├── extend@3.0.0
├── node-uuid@1.4.7
├── combined-stream@1.0.5 (delayed-stream@1.0.0)
├── qs@5.2.0
├── tough-cookie@2.2.1
├── mime-types@2.1.7 (mime-db@1.19.0)
├── form-data@1.0.0-rc3 (async@1.5.0)
├── bl@1.0.0 (readable-stream@2.0.4)
├── http-signature@1.1.0 (assert-plus@0.1.5, jsprim@1.2.2, sshpk@1.7.0)
├── har-validator@2.0.3 (pinkie-promise@2.0.0, commander@2.9.0, chalk@1.1.1, is-my-json-valid@2.12.3)
└── hawk@3.1.2 (cryptiles@2.0.5, sntp@1.0.9, boom@2.10.1, hoek@2.16.3)
Fin de l'installtion
Satellite (Raspberry DIY, Debain 7)
Logs mySensors
25-11-2015 18:49:17 | info | Installation des dépéndances nodejs
25-11-2015 19:00:18 | info | Installation des dépéndances nodejs
25-11-2015 19:00:58 | debug | Vérification des dépéndances installées
25-11-2015 19:15:26 | debug | Vérification des dépéndances installées
25-11-2015 19:16:23 | info | Vérification du statut du service
25-11-2015 19:16:28 | info | Installation dépendances
25-11-2015 19:16:28 | info | Installation des dépéndances nodejs
25-11-2015 19:30:26 | debug | Vérification des dépéndances installées
25-11-2015 19:45:25 | debug | Vérification des dépéndances installées
25-11-2015 20:00:30 | debug | Vérification des dépéndances installées
25-11-2015 20:13:38 | info | Vérification du statut du service
25-11-2015 20:15:27 | debug | Vérification des dépéndances installées
25-11-2015 20:30:28 | debug | Vérification des dépéndances installées
25-11-2015 20:45:26 | debug | Vérification des dépéndances installées
25-11-2015 21:00:32 | debug | Vérification des dépéndances installées
25-11-2015 21:15:28 | debug | Vérification des dépéndances installées
25-11-2015 21:30:28 | debug | Vérification des dépéndances installées
25-11-2015 21:45:27 | debug | Vérification des dépéndances installées
25-11-2015 22:00:34 | debug | Vérification des dépéndances installées
25-11-2015 22:15:28 | debug | Vérification des dépéndances installées
25-11-2015 22:30:27 | debug | Vérification des dépéndances installées
25-11-2015 22:45:28 | debug | Vérification des dépéndances installées
25-11-2015 23:00:38 | debug | Vérification des dépéndances installées
25-11-2015 23:15:30 | debug | Vérification des dépéndances installées
25-11-2015 23:30:30 | debug | Vérification des dépéndances installées
25-11-2015 23:45:32 | debug | Vérification des dépéndances installées
26-11-2015 00:00:45 | debug | Vérification des dépéndances installées
26-11-2015 00:15:32 | debug | Vérification des dépéndances installées
26-11-2015 00:30:33 | debug | Vérification des dépéndances installées
26-11-2015 00:45:35 | debug | Vérification des dépéndances installées
26-11-2015 01:00:39 | debug | Vérification des dépéndances installées
26-11-2015 01:15:34 | debug | Vérification des dépéndances installées
mySensors_dep
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
mkdir: cannot create directory `/var/www': File exists
rm: cannot remove `package.json': No such file or directory
> serialport@2.0.5 install /usr/share/nginx/www/jeedom/plugins/mySensors/node_modules/serialport
make: Entering directory '/usr/share/nginx/www/jeedom/plugins/mySensors/node_modules/serialport/build'
CXX(target) Release/obj.target/serialport/src/serialport.o
CXX(target) Release/obj.target/serialport/src/serialport_unix.o
CXX(target) Release/obj.target/serialport/src/serialport_poller.o
SOLINK_MODULE(target) Release/obj.target/serialport.node
COPY Release/serialport.node
COPY /usr/share/nginx/www/jeedom/plugins/mySensors/node_modules/serialport/build/Release/node-v14-linux-arm/serialport.node
TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/mySensors/node_modules/serialport/build'
serialport@2.0.5 ../node_modules/serialport
├── bindings@1.2.1
├── sf@0.1.7
├── async@0.9.0
├── optimist@0.6.1 (wordwrap@0.0.3, minimist@0.0.10)
└── nan@2.0.9
request@2.67.0 ../node_modules/request
├── aws-sign2@0.6.0
├── caseless@0.11.0
├── isstream@0.1.2
├── extend@3.0.0
├── node-uuid@1.4.7
├── qs@5.2.0
sante du maitre
- santemaitre.PNG (37.47 Kio) Consulté 1535 fois
EDIT
Parc ontre nginx.error
2015/11/24 16:34:49 [error] 13409#0: *211635 FastCGI sent in stderr: "PHP message: PHP Warning: fsockopen(): unable to connect to 192.168.1.13:8019 (Connection refused) in /usr/share/nginx/www/jeedom/plugins/mySensors/core/class/mySensors.class.php on line 381" while reading response header from upstream, client: 192.168.1.254, server: , request: "POST /jeedom/core/ajax/cmd.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "78.xxx.xxx.xxx", referrer: "https://78.xxx.xxx.xxx/jeedom/index.php?v=d&p=dashboard"
2015/11/24 16:34:52 [error] 13409#0: *211636 FastCGI sent in stderr: "PHP message: PHP Warning: fsockopen(): unable to connect to 192.168.1.13:8019 (Connection refused) in /usr/share/nginx/www/jeedom/plugins/mySensors/core/class/mySensors.class.php on line 381" while reading response header from upstream, client: 192.168.1.254, server: , request: "POST /jeedom/core/ajax/cmd.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "78.xxx.xxx.xxx", referrer: "https://78.xxx.xxx.xxx/jeedom/index.php?v=d&p=dashboard"
2015/11/24 16:37:09 [error] 13410#0: *211633 FastCGI sent in stderr: "PHP message: PHP Warning: fsockopen(): unable to connect to 192.168.1.13:8019 (Connection refused) in /usr/share/nginx/www/jeedom/plugins/mySensors/core/class/mySensors.class.php on line 381" while reading response header from upstream, client: 192.168.1.254, server: , request: "POST /jeedom/core/ajax/cmd.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "78.xxx.xxx.xxx", referrer: "https://78.xxx.xxx.xxx/jeedom/index.php?v=d&p=dashboard"
2015/11/24 16:57:57 [error] 13409#0: *212489 FastCGI sent in stderr: "PHP message: PHP Warning: fsockopen(): unable to connect to 192.168.1.13:8019 (Connection refused) in /usr/share/nginx/www/jeedom/plugins/mySensors/core/class/mySensors.class.php on line 381" while reading response header from upstream, client: 192.168.1.254, server: , request: "POST /jeedom/core/ajax/cmd.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "78.xxx.xxx.xxx", referrer: "https://78.xxx.xxx.xxx/jeedom/index.php?v=d&p=dashboard"
2015/11/24 16:58:46 [error] 13409#0: *212490 FastCGI sent in stderr: "PHP message: PHP Warning: fsockopen(): unable to connect to 192.168.1.13:8019 (Connection refused) in /usr/share/nginx/www/jeedom/plugins/mySensors/core/class/mySensors.class.php on line 381" while reading response header from upstream, client: 192.168.1.254, server: , request: "POST /jeedom/core/ajax/cmd.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "78.xxx.xxx.xxx", referrer: "https://78.xxx.xxx.xxx/jeedom/index.php?v=d&p=dashboard"
2015/11/24 16:59:34 [error] 13410#0: *212890 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 192.168.1.254, server: , request: "GET /jeedom/plugins/camera/core/config/devices/.jpg HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "78.xxx.xxx.xxx", referrer: "https://78.xxx.xxx.xxx/jeedom/index.php?v=d&p=camera&m=camera&id=161"
2015/11/24 17:08:19 [error] 13407#0: *213446 FastCGI sent in stderr: "PHP message: PHP Warning: fsockopen(): unable to connect to 192.168.1.13:8019 (Connection refused) in /usr/share/nginx/www/jeedom/plugins/mySensors/core/class/mySensors.class.php on line 381" while reading response header from upstream, client: 192.168.1.254, server: , request: "POST /jeedom/core/ajax/cmd.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "78.xxx.xxx.xxx", referrer: "https://78.xxx.xxx.xxx/jeedom/index.php?v=d&p=dashboard"
2015/11/24 17:48:28 [error] 13408#0: *214284 FastCGI sent in stderr: "PHP message: PHP Warning: fsockopen(): unable to connect to 192.168.1.13:8019 (Connection refused) in /usr/share/nginx/www/jeedom/plugins/mySensors/core/class/mySensors.class.php on line 381" while reading response header from upstream, client: 192.168.1.254, server: , request: "POST /jeedom/core/ajax/cmd.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "78.xxx.xxx.xxx", referrer: "https://78.xxx.xxx.xxx/jeedom/index.php?v=d&p=dashboard"
2015/11/24 17:59:14 [error] 13409#0: *215318 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 188.132.217.108, server: , request: "GET /admin/config.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "78.xxx.xxx.xxx"
2015/11/25 20:22:20 [error] 13408#0: *217353 FastCGI sent in stderr: "PHP message: PHP Warning: fsockopen(): unable to connect to 192.168.1.13:8019 (Connection refused) in /usr/share/nginx/www/jeedom/plugins/mySensors/core/class/mySensors.class.php on line 381" while reading response header from upstream, client: 192.168.1.254, server: , request: "POST /jeedom/core/ajax/cmd.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "78.xxx.xxx.xxx", referrer: "https://78.xxx.xxx.xxx/jeedom/index.php?v=d&p=dashboard"
2015/11/25 21:54:53 [error] 13408#0: *218505 FastCGI sent in stderr: "PHP message: PHP Warning: fsockopen(): unable to connect to 192.168.1.13:8019 (Connection refused) in /usr/share/nginx/www/jeedom/plugins/mySensors/core/class/mySensors.class.php on line 381" while reading response header from upstream, client: 192.168.1.254, server: , request: "POST /jeedom/core/ajax/cmd.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "78.xxx.xxx.xxx", referrer: "https://78.xxx.xxx.xxx/jeedom/index.php?v=d&p=dashboard"
2015/11/26 06:37:20 [error] 13407#0: *221716 directory index of "/usr/share/nginx/www/" is forbidden, client: 205.213.255.74, server: , request: "GET / HTTP/1.1", host: "78.xxx.xxx.xxx"
