A très bientôt !
Dépendances NO OK
Retrouvez ici des sujets concernant le protocole RFXcom et les modules domotiques compatibles RFXcom (Chacon, DI-O, Oregon, Blyss, etc...) utilisés avec JEEDOM
slashers
Dépendances NO OK
Message par slashers » 23 déc. 2019, 00:24
Suite à une réinstallation de jeedom suite à un problème de carte SD, les dépendances de mon plugin RFXCOM ne veulent plus s'installer. Le problème c'est que mon RFXCOM gère mon chauffage, donc pas cool.
une première installation m'indique ceci
* Installation des dépendances *
Reading package lists...
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
* Installation terminée *
et après un second essai cela
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Hit:3 https://deb.nodesource.com/node_12.x stretch InRelease
Building dependency tree...
Reading state information...
Suggested packages:
python-gobject python-qt4 python-pyside.qtcore python-socks python-wxgtk3.0
| python-wxgtk
python-pyudev python-requests python-serial
debconf: unable to initialize frontend: Dialog
debconf: (TERM is not set, so the dialog frontend is not usable.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/222 kB of archives.
After this operation, 1205 kB of additional disk space will be used.
Selecting previously unselected package python-pyudev.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
dpkg: unrecoverable fatal error, aborting:
files list file for package 'libavcodec57:armhf' contains empty filename
E: Sub-process /usr/bin/dpkg returned an error code (2)
Quelqu'un aurait'il une idée.
Par avance, merci.
Bonne soirée
PrFalKeN
Re: Dépendances NO OK
Message par PrFalKeN » 23 déc. 2019, 13:59
'Jour,
Tu es en quelle version de Jeedom et du plugin ?
Après l'installation de linux, tu l'as bien mis a jour avec apt-get update et upgrade ?
Revenir vers « [Plugin Officiel] RFXcom »
