[RESOLU] Après migration sur stretch et niveau 3.3.30, install des dépendances KO pour clé EnOcean USB300
Après avoir migré l'OS de ma jeedom smart, je n'arrive plus à installer le plugin EnOcean, la mise à jour des dépendances est KO.
J'ai mis le port EnOcean en "AUTO", ne sachant pas quoi mettre d'autre
J'obtiens la log suivante:
* Installation des dépendances *
Hit:1 http://repo.jeedom.com/odroid stable InRelease
Hit:2 http://security.debian.org stretch/updates InRelease
Ign:3 http://repo.jeedom.com/odroid dists/stable/main/binary-arm64/ InRelease
Hit:4 http://repo.jeedom.com/odroid dists/stable/main/binary-arm64/ Release
Ign:5 http://repo.jeedom.com/odroid dists/stable/main/binary-arm64/ Release.gpg
Ign:6 http://ftp.debian.org/debian stretch InRelease
Ign:7 http://repo.jeedom.com/odroid dists/stable/main/binary-arm64/ Packages
Ign:8 http://repo.jeedom.com/odroid dists/stable/main/binary-arm64/ Translation-en_US
Ign:9 http://repo.jeedom.com/odroid dists/stable/main/binary-arm64/ Translation-en
Hit:10 http://ftp.debian.org/debian stretch-updates InRelease
Get:7 http://repo.jeedom.com/odroid dists/stable/main/binary-arm64/ Packages [545 B]
Hit:11 http://ftp.debian.org/debian stretch-backports InRelease
Hit:12 http://ftp.debian.org/debian stretch-proposed-updates InRelease
Hit:13 http://ftp.debian.org/debian stretch Release
Get:14 http://repo.jeedom.com/odroid stable/main arm64 Packages [545 B]
Hit:15 http://www.deb-multimedia.org stretch InRelease
Hit:17 https://oph.mdrjr.net/meveric all InRelease
Hit:18 https://oph.mdrjr.net/meveric stretch InRelease
Fetched 545 B in 4s (112 B/s)
Reading package lists...
W: The repository 'http://repo.jeedom.com/odroid dists/stable/main/binary-arm64/ Release' is not signed.
W: No Hash entry in Release file /var/lib/apt/lists/repo.jeedom.com_odroid_dists_stable_main_binary-arm64_Release
W: Invalid 'Date' entry in Release file /var/lib/apt/lists/repo.jeedom.com_odroid_dists_stable_main_binary-arm64_Release
W: Conflicting distribution: http://repo.jeedom.com/odroid dists/stable/main/binary-arm64/ Release (expected dists/stable/main/binary-arm64/ but got )
E: Failed to stat /var/lib/apt/lists/partial/repo.jeedom.com_odroid_dists_stable_main_binary-arm64_Packages - pkgAcqTransactionItem::TransactionState-stat (2: No such file or directory)
Building dependency tree...
Reading state information...
Package 'python-enum' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 159 not upgraded.
python-serial is already the newest version (3.2.1-1).
python-pyudev is already the newest version (0.21.0-1).
python-requests is already the newest version (2.12.4-1).
/var/www/html/plugins/openenocean/core/class/../../resources/install_apt.sh: line 16: pip: command not found
/var/www/html/plugins/openenocean/core/class/../../resources/install_apt.sh: line 18: pip: command not found
* Installation terminée *
SI quelqu'un avait une idée pour me débloquer...
Ca marchait avant mise à jour
Re: Après migration sur stretch et niveau 3.3.30, install des dépendances KO pour clé EnOcean USB300
Essayes en ssh :
sudo apt install -y python-pip (tu peux le faire depuis configration -> OS/DB puis systeme)
Essayes en ssh :
Merci beaucoup @loic
Ca a résolu mon pb
Je devais avoir une install python bancale
encore merci !
Ca a résolu mon pb
encore merci !
au cas ou dans la prochaine stable j'ai rajouté l'installation automatique de package ca evitera les soucis
je voudrais tagger ce fil "résolu" mais je ne trouve pas comment faire
Faut editer le titre et mettre résolu devant
Re: [RESOLU] Après migration sur stretch et niveau 3.3.30, install des dépendances KO pour clé EnOcean USB300
Je pense avoir un problème proche de celui-ci.
Je viens de recevoir une clé officielle Enocean, avec port SMA. Après avoir installé le plugin ENOCEAN et l'avoir activé, j'ai les dépendances qui ne s'installent pas (NOK).
J'ai exécuté: "sudo apt install -y python-pip" mais rien de plus...
Log:
Hit:1 http://security.debian.org stretch/updates InRelease
Hit:2 https://apt.armbian.com stretch InRelease
Ign:3 http://cdn-fastly.deb.debian.org/debian stretch InRelease
Hit:4 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease
Hit:5 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease
Hit:6 http://cdn-fastly.deb.debian.org/debian stretch Release
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Collecting enum-compat
Using cached https://files.pythonhosted.org/packages ... 0.2.tar.gz
Complete output from command python setup.py egg_info:
File "<string>", line 1, in <module>
ImportError: No module named setuptools
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-GrzZ3x/enum-compat/
Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied: soupsieve>=1.2 in /usr/local/lib/python2.7/dist-packages (from beautifulsoup4)
Requirement already satisfied: backports.functools-lru-cache; python_version < "3" in /usr/local/lib/python2.7/dist-packages (from soupsieve>=1.2->beautifulsoup4)
Pouvez vous m'aider s'il vous plait ?
Log:
BREAKING NEWS... Je partage car ça fait 48 heures que je craque sur ce problème.
J'ai résolu mon problème en (ré)installant DISTRIBUTE via:
wget https://bootstrap.pypa.io/ez_setup.py -O - | sudo python
ça a l'air de fonctionner maintenant !
Utilisateurs parcourant ce forum : Bing [Bot] et 1 invité
