Is it possible to disable authentication for the internal network .
Thanks,
Web authentication
Re: Web authentication
This has been asked before, and if I'm right the answer is no, it's not possible.
And it's not a planned feature too, for security reason. Whatever you are on your internal network, this one can be shared for exemple with guest (maybe not your case, but still very common)
With planned mobile applications, saving your credentials will save you the auth page maybe. Or like me, use a SSO for all your self-hosted apps
Mon Blog | Xiaomi Home
You can also in desktop (like mobile) check the cas "Enregistrer cet ordinateur" in connection page
Hello.loic a écrit :You can also in desktop (like mobile) check the cas "Enregistrer cet ordinateur" in connection page
Can you help me with some information, please?
I have installed the Jeedom in my Rasberry Pi 2 but I have not succed to conect to Jeedom.
Is there a sprecial request to connect?
Thanks.
I don't understand, to connect into jeedom you juste have in web browser to type : IP_JEEDOM (or IP_JEEDOM/jeedom if you don't install it with jeedom image)
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 13 invités
