I tried to move the 'template' folder to 'plugin' folder.
But it seems always, after the template is under plugin, website does not response anything .
How to solve this problem? I just want to preview the code and understand which part gonna be appear at which section on the website...
How can I preview a plugin template
- Actif
Re: How can I preview a plugin template
If i correctly understood your need, Just take a look on the jeedom github, you can DL the .zip of the plugin template
Envoyé depuis mon Mobicarte (Si Si jvous jure !!!)
Mon Matos
Mon Blog où vous trouverez des astuces et tutos Tasker/Jeedom
Mon alarme sous Jeedom
Tuto pour la Gestion de la présence
I simply cloned that repository to local and then copy all the contents to 'template' folder under the /var/www/html/plugin.extrapitou a écrit : ↑24 mai 2018, 23:09If i correctly understood your need, Just take a look on the jeedom github, you can DL the .zip of the plugin template
Or there is another way allows me install the template by a zip package?
