Mise à jour RFXCOM, enOcean, Edisio
Retrouvez les informations officielles de Jeedom (nouvelle version, nouveaux lancements, tutos...)
tegretol
Re: Mise à jour RFXCOM, enOcean, Edisio
Message par tegretol » 03 juin 2015, 21:46
en fait le démon en debug ne détecte pas la télécommande. j'ai trouvé cela sur internet mais je ne sais pas quoi en faire...
Lighting 5
from rfxcom.protocol.base import BasePacketHandler
SUB_TYPE_COMMANDS = {
0x00: {
0x00: "Off",
0x01: "On",
0x02: "Group Off",
0x03: "mood1",
0x04: "mood2",
0x05: "mood3",
0x06: "mood4",
0x07: "mood5",
0x08: "reserved",
0x09: "reserved",
0x0A: "unlock",
0x0B: "lock",
0x0C: "all lock",
0x0D: "close (inline relay)",
0x0E: "stop (inline relay)",
0x0F: "open (inline relay)",
0x10: "set level",
0x11: "colour Palette",
0x12: "Colour Tone",
0x13: "Colour Cycle",
0x01: {
0x00: "Off",
0x01: "On",
0x02: "Learn",
0x02: {
0x00: "Off",
0x01: "On",
0x02: "Group Off",
0x03: "Group On",
0x03: {
0x00: "Power",
0x01: "Light",
0x02: "Bright",
0x03: "dim",
0x04: "100%",
0x05: "50%",
0x06: "25%",
0x07: "Mode+",
0x08: "Speed-",
0x09: "Speed+",
0x0A: "Mode-",
0x04: {
0x00: "Off",
0x01: "On",
0x02: "Group Off",
0x03: "Group On",
0x05: {
0x00: "Group Off",
0x01: "On/Off dinner or Gang1",
0x02: "Dim+ or Gang2 on/off",
0x03: "Dim- or Gang3 on/off",
0x06: {
0x00: "Off",
0x01: "On",
0x02: "Bright",
0x03: "Dim",
0x04: "Colour+",
0x05: "Colour-",
0x06: "Select color",
[docs]class Lighting5(BasePacketHandler):
"""The Lighting5 protocol is a 10 byte packet used by a number of lighting
systems. For example Lightwave devices use this protocol.
Byte Meaning
0 Packet Length, 0x0A (excludes this byte)
1 Packet Type, 0x14
2 Sub Type
3 Sequence Number
4 ID 1
5 ID 2
6 ID 3
7 Unit Code
8 Command
9 Level
10 Filler and RSSI
def __init__(self, *args, **kwargs):
super().__init__(*args, **kwargs)
self.PACKET_TYPES = {
0x14: "Lighting5"
self.SUB_TYPES = {
0x00: "LightwaveRF, Siemens",
0x01: "EMW100 GAO/Everflourish",
0x02: "BBSB new types",
0x03: "MDREMOTE LED dimmer",
0x04: "Conrad RSL2",
0x05: "Livolo",
0x06: "RGB TRC02",
[docs] def parse(self, data):
"""Parse a 10 byte packet in the Lighting5 format and return a
dictionary containing the data extracted. An example of a return value
would be
.. code-block:: python
'id': "0xF394AB",
'packet_length': 10,
'packet_type': 20,
'sequence_number': 173,
'sub_type': 0,
'sub_type_name': "LightwaveRF, Siemens",
'unit_code': 1,
'command': 1,
'command_text': "On",
'level': 0,
'rssi': 96,
:param data: bytearray to be parsed
:type data: bytearray
:return: Data dictionary containing the parsed values
:rtype: dict
self.validate_packet(data)
packet_length = data[0]
packet_type = data[1]
sub_type = data[2]
sequence_number = data[3]
id_ = self.dump_hex(data[4:7])
unit_code = data[7]
command = data[8]
command_text = SUB_TYPE_COMMANDS.get(sub_type, {}).get(command)
level = data[9]
rssi = data[10]
return {
'packet_length': packet_length,
'packet_type': packet_type,
'packet_type_name': self.PACKET_TYPES.get(packet_type),
'sequence_number': sequence_number,
'sub_type': sub_type,
'sub_type_name': self.SUB_TYPES.get(sub_type),
'id': id_,
'unit_code': unit_code,
'command': command,
'command_text': command_text,
'level': level,
'rssi': rssi,
loic
Administrateur
Message par loic » 03 juin 2015, 22:23
Tant que le démon détecte pas de message c'est que le protocole qui correspond est pas actif, je peux mettre tout le code du monde tant que c'est pas actif je pense rien faire
Fr3d
Message par Fr3d » 04 juin 2015, 22:29
loic a écrit :Tu peux me donner le retour de :
Ping 127.0.0.1
Voici le résultat : http://imgur.com/LwFHvUx
(Pour rappel, es sondes Oregon dialoguent bien avec mon RFXCom car je vios les messages passer, les ID sont bon sur mes objets RFXCom mais les valeurs sont bloquées depuis le dernier update)
loic
Administrateur
Message par loic » 05 juin 2015, 08:29
Pourtant c'est bon, c'est un soucis de conf c'est sur sinon tu ne serais pas le seul tu peux revoir tous ce que je dit dans le 1er poste ?
nightfever
Message par nightfever » 06 juin 2015, 14:18
Merci pour la procédure, cela a fonctionné pour moi (suivi du premier post)
Rasp PI3+jeedom+RFXcom+ clé 3G huawei E3531
6 x Oregon THGR122NX + 1 capteur DIO + installation knx
NAS DS213 + D-Link DCS4622
RPI 1 & 2 + clé Z-stick S2 (placard pour le moment)
clé 3G X220L (fonctionne pas)
tegretol
Message par tegretol » 06 juin 2015, 17:05
En fait le rfxcom ne reçoit pas les messages de la télécommande. Juste les interrupteurs peuvent enregistrer les ordres du rfxcom cela marche avec le logiciel pc et domoticz mais je ne sais pas comment faire avec jeedom...
loic
Administrateur
Message par loic » 06 juin 2015, 18:43
Tu as suivie la procédure du premier poste ?
Fr3d
Message par Fr3d » 08 juin 2015, 00:33
loic a écrit :Pourtant c'est bon, c'est un soucis de conf c'est sur sinon tu ne serais pas le seul tu peux revoir tous ce que je dit dans le 1er poste ?
J'ai tout essayé ...
De changer les ID d'un équipement (pour ne pas perdre l'historique) et de recréer un nouvel équipement avec le bon ID.
Idem, il ne donne pas les valeurs. Pourtant dans le journal des messages du RFXCom ... je vois bien passer les informations de mes sondes ...
2015-06-07 15:23:07 Message : 0A520252D30100AE550369
Subtype			= THGR810, THGN800
Seqnbr			= 52
Id			= D301
Temperature		= 17.4 C
Humidity		= 85%
Humidity Status		= Wet
Battery			= 9
Signal level		= 6
Time between message	= 53
2015-06-07 15:23:16 Message : 08500453820400D759
Subtype			= RTHN318
Seqnbr			= 53
Id			= 8204
Temperature		= 21.5 C
Battery			= 9
Signal level		= 5
Time between message	= 67
2015-06-07 15:23:19 Message : 105602546A00009D000000003159000049
Subtype			= WGR800
Seqnbr			= 54
Id			= 6A00
Wind direction		= 157 degrees
Average wind		= 0.0 mtr/sec
Windgust		= 0.0 mtr/sec
Battery			= 9
Signal level		= 4
Time between message	= 14
2015-06-07 15:23:33 Message : 105602556A00009D000000003159000049
Subtype			= WGR800
Seqnbr			= 55
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:23:38 Message : 0A520256860301093E0069
Seqnbr			= 56
Id			= 8603
Temperature		= 26.5 C
Humidity		= 62%
Humidity Status		= Dry
Battery			= 9
Signal level		= 6
Time between message	= 122
2015-06-07 15:23:47 Message : 105602576A00009D000000003159000049
Subtype			= WGR800
Seqnbr			= 57
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:23:48 Message : 09570258C200009D0049
Subtype			= UVN800
Seqnbr			= 58
Id			= C200
UV			= 0
Battery			= 9
Signal level		= 4
Time between message	= 73
2015-06-07 15:23:53 Message : 0B5502596D000000001B8E59
Subtype			= PCR800
Seqnbr			= 59
Id			= 6D00
Rain rate		= 0.0 mm/hr
Raintotal:		= 705.4 mm
Battery			= 9
Signal level		= 5
Time between message	= 47
2015-06-07 15:24:00 Message : 0A52025AD30100AE550359
Seqnbr			= 5A
Id			= D301
Humidity		= 85%
Battery			= 9
Signal level		= 5
2015-06-07 15:24:01 Message : 1056025B6A00009D000000003159000049
Subtype			= WGR800
Seqnbr			= 5B
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:24:23 Message : 0850045C820400D759
Subtype			= RTHN318
Seqnbr			= 5C
Id			= 8204
Battery			= 9
Signal level		= 5
2015-06-07 15:24:29 Message : 1056025D6A00009D000000003159000049
Subtype			= WGR800
Seqnbr			= 5D
Id			= 6A00
Battery			= 9
Signal level		= 4
Time between message	= 28
2015-06-07 15:24:39 Message : 0A52025E860301093E0069
Seqnbr			= 5E
Id			= 8603
Humidity		= 62%
Battery			= 9
Signal level		= 6
Time between message	= 61
2015-06-07 15:24:40 Message : 0B55025F6D000000001B8E59
Subtype			= PCR800
Seqnbr			= 5F
Id			= 6D00
Battery			= 9
Signal level		= 5
2015-06-07 15:24:43 Message : 105602606A00009D000000003159000049
Subtype			= WGR800
Seqnbr			= 60
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:24:53 Message : 0A520261D30100AE550369
Seqnbr			= 61
Id			= D301
Humidity		= 85%
Battery			= 9
Signal level		= 6
2015-06-07 15:24:57 Message : 105602626A00009D000000003159000049
Subtype			= WGR800
Seqnbr			= 62
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:25:01 Message : 09570263C200009D0059
Subtype			= UVN800
Seqnbr			= 63
Id			= C200
UV			= 0
Battery			= 9
Signal level		= 5
2015-06-07 15:25:11 Message : 105602646A00009D000000003159000049
Subtype			= WGR800
Seqnbr			= 64
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:25:25 Message : 105602656A00009D000000003159000049
Subtype			= WGR800
Seqnbr			= 65
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:25:27 Message : 0B5502666D000000001B8E59
Subtype			= PCR800
Seqnbr			= 66
Id			= 6D00
Battery			= 9
Signal level		= 5
2015-06-07 15:25:30 Message : 0D58016782000F06080200191E59
Subtype			= RTGR328N
Seqnbr			= 67
Id			= 8200
Time			= 0:25:30
Date (yy-mm-dd)		= 2015-06-08
Day of week (1-7)	= 2
Battery			= 9
Signal level		= 5
2015-06-07 15:25:31 Message : 0D58016882000F06080200191F59
Subtype			= RTGR328N
Seqnbr			= 68
Id			= 8200
Time			= 0:25:31
Battery			= 9
Signal level		= 5
2015-06-07 15:25:39 Message : 105602696A00009D000000001F59000049
Subtype			= WGR800
Seqnbr			= 69
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:25:40 Message : 0A52026A860301093E0069
Seqnbr			= 6A
Id			= 8603
Humidity		= 62%
Battery			= 9
Signal level		= 6
2015-06-07 15:25:46 Message : 0A52026BD30100AE550369
Seqnbr			= 6B
Id			= D301
Humidity		= 85%
Battery			= 9
Signal level		= 6
2015-06-07 15:25:53 Message : 1056026C6A00009D000000001F59000049
Subtype			= WGR800
Seqnbr			= 6C
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:26:07 Message : 1056026D6A00009D000000001F59000049
Subtype			= WGR800
Seqnbr			= 6D
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:26:14 Message : 0B55026E6D000000001B8E59
Subtype			= PCR800
Seqnbr			= 6E
Id			= 6D00
Battery			= 9
Signal level		= 5
2015-06-07 15:26:14 Message : 0957026FC20000000059
Subtype			= UVN800
Seqnbr			= 6F
Id			= C200
UV			= 0
Battery			= 9
Signal level		= 5
2015-06-07 15:26:21 Message : 105602706A00009D000000001F59000049
Subtype			= WGR800
Seqnbr			= 70
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:26:35 Message : 105602716A00009D000000001F59000049
Subtype			= WGR800
Seqnbr			= 71
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:26:37 Message : 08500472820400D759
Subtype			= RTHN318
Seqnbr			= 72
Id			= 8204
Battery			= 9
Signal level		= 5
Time between message	= 134
2015-06-07 15:26:40 Message : 0A520273D30100AE550369
Seqnbr			= 73
Id			= D301
Humidity		= 85%
Battery			= 9
Signal level		= 6
Time between message	= 54
2015-06-07 15:26:41 Message : 0A520274860301093E0069
Seqnbr			= 74
Id			= 8603
Humidity		= 62%
Battery			= 9
Signal level		= 6
2015-06-07 15:26:49 Message : 105602756A00009D000000001F59000049
Subtype			= WGR800
Seqnbr			= 75
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:27:01 Message : 0B5502766D000000001B8E59
Subtype			= PCR800
Seqnbr			= 76
Id			= 6D00
Battery			= 9
Signal level		= 5
2015-06-07 15:27:03 Message : 105602776A00009D000000001F59000049
Subtype			= WGR800
Seqnbr			= 77
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:27:17 Message : 105602786A00009D000000001F59000049
Subtype			= WGR800
Seqnbr			= 78
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:27:27 Message : 09570279C200009D0059
Subtype			= UVN800
Seqnbr			= 79
Id			= C200
UV			= 0
Battery			= 9
Signal level		= 5
2015-06-07 15:27:31 Message : 1056027A6A00009D000000001F59000049
Subtype			= WGR800
Seqnbr			= 7A
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:27:32 Message : 0A52027BD30100AE550359
Seqnbr			= 7B
Id			= D301
Humidity		= 85%
Battery			= 9
Signal level		= 5
Time between message	= 52
2015-06-07 15:27:42 Message : 0A52027C860301093E0069
Seqnbr			= 7C
Id			= 8603
Humidity		= 62%
Battery			= 9
Signal level		= 6
2015-06-07 15:27:44 Message : 0850047D820400D759
Subtype			= RTHN318
Seqnbr			= 7D
Id			= 8204
Battery			= 9
Signal level		= 5
2015-06-07 15:27:45 Message : 1056027E6A00009D000000001F59000049
Subtype			= WGR800
Seqnbr			= 7E
Id			= 6A00
Battery			= 9
Signal level		= 4
2015-06-07 15:27:48 Message : 0B55027F6D000000001B8E59
Subtype			= PCR800
Seqnbr			= 7F
Id			= 6D00
Battery			= 9
Signal level		= 5
2015-06-07 15:27:59 Message : 105602806A00009D000000001F59000049
Subtype			= WGR800
Seqnbr			= 80
Id			= 6A00
Battery			= 9
Signal level		= 4
C'est bien la valeur "Id" qu'il faut mettre dans le champ "ID" de notre équipement RFXCom ? Mis à part ça et sélectionner le type d'équipement, il n'y a rien d'autre à faire. Je devrais voir mes valeurs ...
loic
Administrateur
Message par loic » 08 juin 2015, 08:18
Le soucis c'est que le démon envoi à jeedom mais le chemin d'envoi est pas bon... Tu peux par mp m'envoyer ce qu'il faut pour les accès ssh à ton jeedom pour que je regarde ?
djlud
Message par djlud » 23 juin 2015, 00:30
Seqnbr			= 52
Id			= D301
Humidity		= 85%
Battery			= 9
Signal level		= 6
Subtype			= RTHN318
Seqnbr			= 53
Id			= 8204
Battery			= 9
Signal level		= 5
Subtype			= WGR800
Seqnbr			= 54
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= WGR800
Seqnbr			= 55
Id			= 6A00
Battery			= 9
Signal level		= 4
Seqnbr			= 56
Id			= 8603
Humidity		= 62%
Battery			= 9
Signal level		= 6
Subtype			= WGR800
Seqnbr			= 57
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= UVN800
Seqnbr			= 58
Id			= C200
UV			= 0
Battery			= 9
Signal level		= 4
Subtype			= PCR800
Seqnbr			= 59
Id			= 6D00
Battery			= 9
Signal level		= 5
Seqnbr			= 5A
Id			= D301
Humidity		= 85%
Battery			= 9
Signal level		= 5
Subtype			= WGR800
Seqnbr			= 5B
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= RTHN318
Seqnbr			= 5C
Id			= 8204
Battery			= 9
Signal level		= 5
Subtype			= WGR800
Seqnbr			= 5D
Id			= 6A00
Battery			= 9
Signal level		= 4
Seqnbr			= 5E
Id			= 8603
Humidity		= 62%
Battery			= 9
Signal level		= 6
Subtype			= PCR800
Seqnbr			= 5F
Id			= 6D00
Battery			= 9
Signal level		= 5
Subtype			= WGR800
Seqnbr			= 60
Id			= 6A00
Battery			= 9
Signal level		= 4
Seqnbr			= 61
Id			= D301
Humidity		= 85%
Battery			= 9
Signal level		= 6
Subtype			= WGR800
Seqnbr			= 62
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= UVN800
Seqnbr			= 63
Id			= C200
UV			= 0
Battery			= 9
Signal level		= 5
Subtype			= WGR800
Seqnbr			= 64
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= WGR800
Seqnbr			= 65
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= PCR800
Seqnbr			= 66
Id			= 6D00
Battery			= 9
Signal level		= 5
Subtype			= RTGR328N
Seqnbr			= 67
Id			= 8200
Time			= 0:25:30
Battery			= 9
Signal level		= 5
Subtype			= RTGR328N
Seqnbr			= 68
Id			= 8200
Time			= 0:25:31
Battery			= 9
Signal level		= 5
Subtype			= WGR800
Seqnbr			= 69
Id			= 6A00
Battery			= 9
Signal level		= 4
Seqnbr			= 6A
Id			= 8603
Humidity		= 62%
Battery			= 9
Signal level		= 6
Seqnbr			= 6B
Id			= D301
Humidity		= 85%
Battery			= 9
Signal level		= 6
Subtype			= WGR800
Seqnbr			= 6C
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= WGR800
Seqnbr			= 6D
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= PCR800
Seqnbr			= 6E
Id			= 6D00
Battery			= 9
Signal level		= 5
Subtype			= UVN800
Seqnbr			= 6F
Id			= C200
UV			= 0
Battery			= 9
Signal level		= 5
Subtype			= WGR800
Seqnbr			= 70
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= WGR800
Seqnbr			= 71
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= RTHN318
Seqnbr			= 72
Id			= 8204
Battery			= 9
Signal level		= 5
Seqnbr			= 73
Id			= D301
Humidity		= 85%
Battery			= 9
Signal level		= 6
Seqnbr			= 74
Id			= 8603
Humidity		= 62%
Battery			= 9
Signal level		= 6
Subtype			= WGR800
Seqnbr			= 75
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= PCR800
Seqnbr			= 76
Id			= 6D00
Battery			= 9
Signal level		= 5
Subtype			= WGR800
Seqnbr			= 77
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= WGR800
Seqnbr			= 78
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= UVN800
Seqnbr			= 79
Id			= C200
UV			= 0
Battery			= 9
Signal level		= 5
Subtype			= WGR800
Seqnbr			= 7A
Id			= 6A00
Battery			= 9
Signal level		= 4
Seqnbr			= 7B
Id			= D301
Humidity		= 85%
Battery			= 9
Signal level		= 5
Seqnbr			= 7C
Id			= 8603
Humidity		= 62%
Battery			= 9
Signal level		= 6
Subtype			= RTHN318
Seqnbr			= 7D
Id			= 8204
Battery			= 9
Signal level		= 5
Subtype			= WGR800
Seqnbr			= 7E
Id			= 6A00
Battery			= 9
Signal level		= 4
Subtype			= PCR800
Seqnbr			= 7F
Id			= 6D00
Battery			= 9
Signal level		= 5
Subtype			= WGR800
Seqnbr			= 80
Id			= 6A00
Battery			= 9
Signal level		= 4
J'ai exactement le même soucis, ça fonctionnait très bien au départ (mise à jour à chaque réception de trame) mais maintenant la mise à jour se fait de manière très aléatoire mais en général une mise à jour toutes les 3-4h alors que toutes les trames sont bien reçues.
J'ai fait les dernières mise à jour et je suis sur une JEEDOM mini+ ultimate
loic
Administrateur
Message par loic » 23 juin 2015, 08:06
Vous regardez la date au survole de la souris ? Si c'est le cas tout marche très bien chez vous juste cette date est mise à jour sur changement de valeur et plus sur réception de la valeur
djlud
Message par djlud » 23 juin 2015, 10:55
J'ai suivi le tuto sur l'installation du thermostat avec alerte lorsque la température n'est pas mise à jour par les relevés de la sonde de température depuis le délais paramétrable. Du coup j'ai du désactiver l'alerte car j'étais spamé en permanence de SMS. Est-ce la même variable qui gère les 2, l'affichage sur le dashboard et le déclenchement des alertes? La température affichée dans l'historique jeedom est constante plusieurs heures et ne correspond pas à celle affichée sur la sonde qui elle varie dans cet intervalle de temps
loic
Administrateur
Message par loic » 23 juin 2015, 11:34
Oui il y a actuellement un bug avec le plugin thermostat et la detection de defaillance des sondes. Je cherche comment le corriger
chamalo
Message par chamalo » 24 juin 2015, 11:56
je suis de loin le sujet, juste une remarque très positif, la réactivité du RFXCOM maintenant est juste impressionnante, maintenant je peut éteindre/allumer en un double clique alors qu'avant fallait attendre la fin de la première action
Dev: Plugins Thèmes - JeeRemote
Module Widget Facile dans le plugin Widget
loic
Administrateur
Message par loic » 24 juin 2015, 13:07
Oui c'était le but de cette modification pour une raison que je comprend pas trop quand je passe par le serveur web au lieu d'un appels a un script la réactivité et nettement meilleurs
djlud
Message par djlud » 24 juin 2015, 23:17
loic a écrit :Oui il y a actuellement un bug avec le plugin thermostat et la detection de defaillance des sondes. Je cherche comment le corriger
Le problème de la gestion de la défaillance des sondes, ne vient-elle pas justement des problèmes de relevé de température ou de stockage en base de ces derniers? Car quand je regarde l'historique des sondes, il manque beaucoup de valeur et je suppose que le plug-in thermostat ce sert de cet historique en base pour alerter d'un dysfonctionnement?
loic
Administrateur
Message par loic » 24 juin 2015, 23:21
Oui et non toujours est il que la dernière beta corrigé la régression à ce niveau la
zeftp
Message par zeftp » 25 juin 2015, 00:56
loic a écrit :la dernière beta corrige la régression
Ca me rappelle un T shirt ca... (ou presque)
Jeedom Smart, Mini+ + RFXCom + Clé 3g, onduleur, qqs trucs z wave, Keycode RFID Zipato + Flower Power + Téléc RFX chinoises x 4 + Caméra vidéo Foscam FI9821P + Détecteur ouverture de garage ZG8101 + Xiaomi & magic cube + SoundTab
loic
Administrateur
Message par loic » 25 juin 2015, 08:23
Oui c'est vrai mais c'est aussi vrai que la beta corrige
stouille
Message par stouille » 02 juil. 2015, 09:23
Salut. J'ai un problème de remonté de température sur toutes mes sondes RFXCOM.
J'ai essayé de suivre la procédure de reconfiguration de la partie réseau, mais il semble que mes modifications ne soient pas prises en compte.
J'ai essayé de remplir correctement les champs (protocole, adresse ip, complément et port), de faire enregistrer, mais lorsque je rafraichi la page, mes valeur modifiées reviennent à HTTP, jeedom rien et 80.
J'ai essayé de ne rien mettre mais idem.
J'ai suivi le reste de la procédure sans problèmes.
D'ailleurs, la partie IP externe, n'est plus accessible, elle est grisée
Revenir vers « Annonces officielles »
