chown www-data:www-data /tmp/jeedom/snips
Merci, ça à marché pour mon castoufou a écrit : ↑01 sept. 2018, 00:14cool arnog23.
Je poste le miens ici, je suis pas pro du code propre alors n'hesite pas à mixer avec le tiens.
J'ai modifié l'install.sh pour le rendre compatible rpi3 jessie:
#! /bin/bash echo "Start to install dependances" touch /tmp/SNIPS_dep echo 0 > /tmp/SNIPS_dep apt-get -y install lsb-release php-pear archi=`lscpu | grep Architecture | awk '{ print $2 }'` if [ "$archi" == "x86_64" ] || [ "$archi" == "armv7l" ]; then if [ `lsb_release -i -s` == "Debian" ] || [ `lsb_release -i -s` == "Raspbian" ]; then rm mosquitto-repo.gpg.key* -f wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key apt-key add mosquitto-repo.gpg.key cd /etc/apt/sources.list.d/ if [ `lsb_release -c -s` == "jessie" ]; then rm mosquitto-repo.gpg.key rm mosquitto-jessie.list* -f sudo wget http://repo.mosquitto.org/debian/mosquitto-jessie.list fi if [ `lsb_release -c -s` == "stretch" ]; then wget http://repo.mosquitto.org/debian/mosquitto-stretch.list rm /etc/apt/sources.list.d/mosquitto-stretch.list cp -r mosquitto-stretch.list /etc/apt/sources.list.d/mosquitto-stretch.list fi fi fi echo 10 > /tmp/SNIPS_dep apt-get update echo 30 > /tmp/SNIPS_dep echo "Installing mqtt dependances" apt-get -y install mosquitto mosquitto-clients libmosquitto-dev echo 80 > /tmp/SNIPS_dep if [[ -d "/etc/php5/" ]]; then apt-get -y install php5-dev if [[ -d "/etc/php5/cli/" ]]; then echo "" | pecl install Mosquitto-alpha echo 80 > /tmp/SNIPS_dep if [[ ! `cat /etc/php5/cli/php.ini | grep "mosquitto"` ]]; then echo "extension=mosquitto.so" | tee -a /etc/php5/cli/php.ini fi fi if [[ -d "/etc/php5/fpm/" && ! `cat /etc/php5/fpm/php.ini | grep "mosquitto"` ]]; then echo "extension=mosquitto.so" | tee -a /etc/php5/fpm/php.ini service php5-fpm restart fi if [[ -d "/etc/php5/apache2/" && ! `cat /etc/php5/apache2/php.ini | grep "mosquitto"` ]]; then echo "extension=mosquitto.so" | tee -a /etc/php5/apache2/php.ini rm /tmp/SNIPS_dep echo "Dependances installation is done" service apache2 restart fi else apt-get -y install php7.0-dev if [[ -d "/etc/php/7.0/cli/" && ! `cat /etc/php/7.0/cli/php.ini | grep "mosquitto"` ]]; then echo "" | pecl install Mosquitto-alpha echo 80 > /tmp/SNIPS_dep echo "extension=mosquitto.so" | tee -a /etc/php/7.0/cli/php.ini fi if [[ -d "/etc/php/7.0/fpm/" && ! `cat /etc/php/7.0/fpm/php.ini | grep "mosquitto"` ]]; then echo "extension=mosquitto.so" | tee -a /etc/php/7.0/fpm/php.ini service php5-fpm restart fi if [[ -d "/etc/php/7.0/apache2/" && ! `cat /etc/php/7.0/apache2/php.ini | grep "mosquitto"` ]]; then echo "extension=mosquitto.so" | tee -a /etc/php/7.0/apache2/php.ini rm /tmp/SNIPS_dep echo "Dependances installation is done" service apache2 restart fi fi rm /tmp/SNIPS_dep mkdir /tmp/jeedom/snips chmod 777 /tmp/jeedom/snips echo "Dependances installation is done"
✖ Error setting up virtualenv, one or more actions might not be able to run. Reason :
Could not find a version that satisfies the requirement hermes_python>=0.1 (from -r requirements.txt (line 1)) (from versions: )
No matching distribution found for hermes_python>=0.1 (from -r requirements.txt (line 1))
je suis sous debian 9.5 net install en fresh install avec systeme de base et mode ssh.
Tu as quoi dans ton assistant Snips (la console snips), juste Jeedom ? non forké ? (quoi que ça doit marché en forké)
Problème résolu en faisant une mise à jour de mon install jeedom, sudo apt-get update && sudo apt-get dist-upgradeLaregie a écrit : ↑01 sept. 2018, 15:48Grave à votre aide, je peux faire maintenant mumuse avec snips et jeedom.
J'ai juste un dernier bug, j'ai un message d'erreur 500 : Internal Server Error quand je fais un test de TTS avec le player #[Snips-Intents][Snips-TTS-default][say]# dans un action binding.
Si quelqu’un à une idée, je suis preneur, merci.
oui j'avais d'autre applications de selecionné, queje me suis empresser de supprimé et laissé uniquement jeedom sans fork. je relancé l'installation mais toujour la même erreur. faut il relancé une autre commande pour "purger" les assistant ?chsalmon a écrit : ↑01 sept. 2018, 18:14Tu as quoi dans ton assistant Snips (la console snips), juste Jeedom ? non forké ? (quoi que ça doit marché en forké)
Tu as ajouté une autre application ?
(il me semble avoir eu cette erreur en ajouter une application heure ou meteo je ne sais plus..)
J'ai le meme serveur et uniquement l'appli JeedomOfficiel et j'ai pas d'erreur.
j'ai l'erreur lorsque je relance l'install.
sam update assistan
