Re: [Tuto] Installation de Jeedom sur Synology avec docker en mode Host
Publié : 12 juil. 2019, 15:38
Forum sur Jeedom
https://www.jeedom.com/forum/
Tu as bien les droits SUDOGlloQ a écrit : ↑13 juil. 2019, 17:05j'ai rien en vert, je me trompe???
root@jeedom:/# sudo
usage: sudo -h | -K | -k | -V
usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command]
usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-g group] [-h host] [-p prompt] [-u user] [VAR=value] [-i|-s] [<command>]
usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-g group] [-h host] [-p prompt] [-u user] file ...
edit: zut je suis con
root@jeedom:/#
Arrête et Supprime complétement le conteneur
root@jeedom:/# apt-get install nano
Reading package lists... Done
Building dependency tree
Suggested packages:
spell
nano
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 485 kB of archives.
After this operation, 2092 kB of additional disk space will be used.
Get:1 http://deb.debian.org/debian stretch/main amd64 nano amd64 2.7.4-1 [485 kB]
Fetched 485 kB in 0s (1728 kB/s)
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 1.
Selecting previously unselected package nano.
(Reading database ... 48534 files and directories currently installed.)
Preparing to unpack .../nano_2.7.4-1_amd64.deb ...
Unpacking nano (2.7.4-1) ...
Setting up nano (2.7.4-1) ...
update-alternatives: using /bin/nano to provide /usr/bin/editor (editor) in auto mode
update-alternatives: using /bin/nano to provide /usr/bin/pico (pico) in auto mode
Processing triggers for man-db (2.7.6.1-2) ...
