Hier soir, j'ai tenté une migration vers openZwave. Maintenant, je n'ai plus acces à jeedom via le web.
En ssh, quand je regarde les process, j'ai le Z-way server, la base, et des process www-data.
root@jeedom:~# tail -f /usr/share/nginx/www/jeedom/log/nginx.error
2015/06/15 21:37:25 [error] 493#0: *2882 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 192.168.1.1, server: , request: "GET /plugins/Clock/core/template/dashboard/images/weather/index.php?v=d& HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "fcna.ddns.net", referrer: "http://fcna.ddns.net/index.php?v=d&p=dashboard"
2015/06/15 21:56:33 [error] 494#0: *2970 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: 192.168.1.1, server: , request: "POST /core/ajax/jeedom.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "fcna.ddns.net", referrer: "http://fcna.ddns.net/index.php?v=d&p=plugin"
2015/06/15 22:12:55 [error] 496#0: *1 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 192.168.1.1, server: , request: "GET /plugins/Clock/core/template/dashboard/images/weather/index.php?v=d& HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "fcna.ddns.net", referrer: "http://fcna.ddns.net/index.php?v=d&p=dashboard"
2015/06/15 22:26:04 [error] 3069#0: *199 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: 192.168.1.1, server: , request: "POST /core/ajax/jeedom.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "fcna.ddns.net", referrer: "http://fcna.ddns.net/index.php?v=d&p=plugin"
1970/01/01 01:18:43 [error] 481#0: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.1.1, server: , request: "GET /socket.io/?EIO=3&transport=polling&t=1434400000457-7 HTTP/1.1", upstream: "http://127.0.0.1:8070/socket.io/?EIO=3&transport=polling&t=1434400000457-7", host: "fcna.ddns.net", referrer: "http://fcna.ddns.net/index.php?v=d&p=plugin"
2015/06/15 22:26:44 [error] 481#0: *1 FastCGI sent in stderr: "PHP message: PHP Fatal error: Class 'log' not found in /usr/share/nginx/www/jeedom/core/class/DB.class.php on line 45" while reading response header from upstream, client: 192.168.1.1, server: , request: "GET /index.php?v=d&p=plugin HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "fcna.ddns.net"
2015/06/15 22:38:21 [error] 2725#0: *205 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 192.168.1.1, server: , request: "GET /plugins/Clock/core/template/dashboard/images/weather/index.php?v=d& HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "fcna.ddns.net", referrer: "http://fcna.ddns.net/index.php?v=d&p=dashboard"
2015/06/15 22:38:31 [error] 2725#0: *205 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 192.168.1.1, server: , request: "GET /plugins/openzwave/ressources/zwaveserver/static/index.php?v=d& HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "fcna.ddns.net", referrer: "http://fcna.ddns.net/index.php?v=d&m=openzwave&p=openzwave"
2015/06/15 22:38:31 [error] 2725#0: *205 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.1.1, server: , request: "GET /openzwave_0_9j7xn7bgjt30trgv56lrab86xyqeq7/ZWaveAPI/Run/GetZWConfig() HTTP/1.1", upstream: "http://127.0.0.1:8083/ZWaveAPI/Run/GetZWConfig()", host: "fcna.ddns.net", referrer: "http://fcna.ddns.net/index.php?v=d&m=openzwave&p=openzwave"
2015/06/15 23:09:42 [error] 3047#0: *5107 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: 192.168.1.1, server: , request: "POST /core/ajax/jeedom.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "fcna.ddns.net", referrer: "http://fcna.ddns.net/index.php?v=d&p=plugin"
