A très bientôt !
installer les dépendances
(anciennement dénommé plugin OpenZwave)
Yves
Message par Yves » 12 févr. 2016, 08:42
voilà je n'ai que des NOK dans les dépendances vpn et zwave
Voici la log:
Lancement de l'installation/mise à jour des dépendances openzwave
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
Reading package lists...
Installation des dependances
Building dependency tree...
Reading state information...
build-essential is already the newest version.
g++ is already the newest version.
gcc is already the newest version.
git is already the newest version.
libudev-dev is already the newest version.
make is already the newest version.
mercurial is already the newest version.
python-dev is already the newest version.
python-louie is already the newest version.
python-lxml is already the newest version.
python-pip is already the newest version.
python-setuptools is already the newest version.
python-sphinx is already the newest version.
unzip is already the newest version.
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
libjpeg-dev : Depends: libjpeg62-turbo-dev (>= 1:1.3.1-12) but it is not going to be installed
php5-cli : Depends: php5-common (= 5.6.17+dfsg-0+deb8u1) but 5.6.13+dfsg-0+deb8u1 is to be installed
php5-curl : Depends: php5-common (= 5.6.17+dfsg-0+deb8u1) but 5.6.13+dfsg-0+deb8u1 is to be installed
php5-fpm : Depends: php5-common (= 5.6.17+dfsg-0+deb8u1) but 5.6.13+dfsg-0+deb8u1 is to be installed
php5-ldap : Depends: php5-common (= 5.6.17+dfsg-0+deb8u1) but 5.6.13+dfsg-0+deb8u1 is to be installed
php5-mysql : Depends: php5-common (= 5.6.17+dfsg-0+deb8u1) but 5.6.13+dfsg-0+deb8u1 is to be installed
php5-readline : Depends: php5-common (= 5.6.17+dfsg-0+deb8u1) but 5.6.13+dfsg-0+deb8u1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
could not install mercurial - abort
Que dois-je faire pour remédier à ce problème?
par avance merci
Yves
Santé de Jeedom
Résultat
Conseil
Système à jour OK
Lancement des crons OK
Cron actif OK
Scénario actif OK
Démarré OK
Date système OK
Authentification par défaut OK
Droits sudo OK
Version Jeedom 2.0.1
Version PHP 5.6.13-0+deb8u1
Espace disque libre 83 %
Configuration réseaux interne OK
Configuration réseaux externe NOK Allez sur Administration -> Configuration puis configurez correctement la partie réseaux
Commande info en non evènement seulement 0
Santé Monitoring
Résultat
Conseil
Dépendance OK
Santé Openvpn
Résultat
Conseil
Dépendance NOK
Santé RFXcom
Résultat
Conseil
Configuration démon OK
Status démon OK
Santé SMS
Résultat
Conseil
Status démon OK
Santé Z-Wave
Résultat
Conseil
Dépendance NOK
Configuration démon NOK Dépendances non installées
Status démon OK
Sshafi
Re: installer les dépendances
Message par Sshafi » 12 févr. 2016, 08:55
Déjà je tenterai de faire ce qu'il te dis de faire, en ssh :
sudo apt-get -f install
et avant de re-lancer l'install des dépendances :
sudo apt-get update
sudo apt-get upgrade
??? Menfin ...
VM ESXi # Aeon Lab Gen5 | RFXtrx433E | ...
Trucs & Astuces
Yves
Message par Yves » 12 févr. 2016, 09:24
@Sshafi
Merci j'avais essayé sans sudo et ça ne marchais pas.
pour l'instant un blocage sur sudo apt-get ugrade
"L'opération ugrade n'est pas valabble "est la réponse en ssh
Merci encore
Yves
Sshafi
Message par Sshafi » 12 févr. 2016, 09:39
Pardon, j'ai tapé trop vite, il fallait lire :
??? Menfin ...
Trucs & Astuces
Yves
Message par Yves » 12 févr. 2016, 09:54
@Sshafi
Ok je viens de taper la commande.
doit-on faire un reboot de jeedom ? ou relancer directement les dépendances dans le plugin zwave.
Voila l'upgrade viens de se terminer.
Merci beaucoup Sshafi.
Yves
Sshafi
Message par Sshafi » 12 févr. 2016, 10:04
Non pas besoin de reboot, c'est linux ;)
Relance la màj des dépendances un plugin après l'autre et regarde les logs ;)
??? Menfin ...
Trucs & Astuces
Yves
Message par Yves » 12 févr. 2016, 14:16
@Sshafi
Encore merci de m'avoir sorti des dépendances.
j'ai une mini et le temps pour installer les dépendances openzwave = 3heures et 2 mn.
maintenant tout est Ok pour les dépendances.
Seul l' accès externe est nok avec vpn.
Voilà j' arrête pour aujourd'hui.
Demain est un autre jour car déjà presque 6 heures d'informatique c'est trop pour les quelques neurones qu' il me reste.
Yves
Sshafi
Message par Sshafi » 12 févr. 2016, 14:24
:lol:
Avec plaisir ;)
Et oui la compilation super longue des dépendances openzwave sur le pi je connais :) Heureusement c'est pas tous les jours... ;)
??? Menfin ...
Trucs & Astuces
Revenir vers « Plugin Z-Wave »
