Plugin Z-Wave Version 2016-05-30 Stable
Re: Plugin Z-Wave Version 2016-05-30 Stable
Oui je les ai lancées au moins 2 fois aujourd'hui et une fois hier.
Jeedom Maître sur VM Debian sur ESXi (N54L) + Z-Stick 2 (non fonctionnel) + RFXCOM
Jeedom déporté Z-Wave sur Jeedom mini avec JeeLink
Antenne RPI3 BLEA, Netatmo, Philips Hue, Xiaomi Home, Yeelight, Dash Button, ...
merci de l'info effectivement cela fonctionne
voici mon log vous y voyer quelque chose d'etrange ?
01-06-2016 13:57:34 | info | Check flask dependency
01-06-2016 13:57:34 | info | --> pass
01-06-2016 13:57:34 | info | Check other dependency
01-06-2016 13:57:40 | info | --> pass
01-06-2016 13:57:40 | info | Check Openzwave
01-06-2016 13:57:40 | info | Validate startup arguments
01-06-2016 13:57:40 | info | Validate callback configuration
01-06-2016 13:57:40 | info | ...try to get response from: http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php
01-06-2016 13:57:40 | info | Check if the port REST server available
01-06-2016 13:57:40 | info | Validate zwcfg configuration file(s)
01-06-2016 13:57:40 | info | ... check: /usr/share/nginx/www/jeedom/plugins/openzwave/core/class/../../data/zwcfg_0xe11c1527.xml
01-06-2016 13:57:40 | info | ... check: /usr/share/nginx/www/jeedom/plugins/openzwave/core/class/../../data/zwcfg_0xeae35e14.xml
01-06-2016 13:57:40 | debug | Push data to jeedom
01-06-2016 13:57:40 | info | ******** The ZWave network is being started ********
01-06-2016 13:57:40 | info | OpenZwave Library Version 1.4.248
01-06-2016 13:57:40 | info | Python-OpenZwave Wrapper Version 0.3.0
01-06-2016 13:57:40 | info | Waiting for network to become ready
01-06-2016 13:57:41 | info | Openzwave network are started with homeId e11c1527.
01-06-2016 13:57:41 | info | A node has been added to OpenZWave list id:[1] model:[RaZberry Controller ZWave+].
01-06-2016 13:57:41 | debug | The essential queries on a node have been completed. id:[1] model:[RaZberry Controller ZWave+].
01-06-2016 13:57:41 | info | A node has been added to OpenZWave list id:[4] model:[FGSD002 Smoke Sensor].
01-06-2016 13:57:41 | debug | The essential queries on a node have been completed. id:[4] model:[FGSD002 Smoke Sensor].
01-06-2016 13:57:41 | debug | Push data to jeedom
01-06-2016 13:57:41 | info | A node has been added to OpenZWave list id:[5] model:[FGSD002 Smoke Sensor].
01-06-2016 13:57:41 | debug | The essential queries on a node have been completed. id:[5] model:[FGSD002 Smoke Sensor].
01-06-2016 13:57:41 | info | A node has been added to OpenZWave list id:[8] model:[FGSD002 Smoke Sensor].
01-06-2016 13:57:41 | debug | The essential queries on a node have been completed. id:[8] model:[FGSD002 Smoke Sensor].
01-06-2016 13:57:41 | info | A node has been added to OpenZWave list id:[9] model:[FGFS101 Flood Sensor].
01-06-2016 13:57:41 | debug | The essential queries on a node have been completed. id:[9] model:[FGFS101 Flood Sensor].
01-06-2016 13:57:41 | info | A node has been added to OpenZWave list id:[14] model:[ZMNHJD1 Flush Dimmer Fil Pilote].
01-06-2016 13:57:41 | debug | The essential queries on a node have been completed. id:[14] model:[ZMNHJD1 Flush Dimmer Fil Pilote].
01-06-2016 13:57:41 | info | A node has been added to OpenZWave list id:[15] model:[FGWPE Wall Plug].
01-06-2016 13:57:41 | debug | The essential queries on a node have been completed. id:[15] model:[FGWPE Wall Plug].
01-06-2016 13:57:42 | info | A node has been added to OpenZWave list id:[16] model:[ZMNHJD1 Flush Dimmer Fil Pilote].
01-06-2016 13:57:42 | debug | The essential queries on a node have been completed. id:[16] model:[ZMNHJD1 Flush Dimmer Fil Pilote].
01-06-2016 13:57:42 | info | A node has been added to OpenZWave list id:[17] model:[ZMNHJD1 Flush Dimmer Fil Pilote].
01-06-2016 13:57:42 | debug | The essential queries on a node have been completed. id:[17] model:[ZMNHJD1 Flush Dimmer Fil Pilote].
REST server starting in Debug mode
01-06-2016 13:57:42 | info | A node has been added to OpenZWave list id:[18] model:[ZMNHJD1 Flush Dimmer Fil Pilote].
01-06-2016 13:57:42 | debug | The essential queries on a node have been completed. id:[18] model:[ZMNHJD1 Flush Dimmer Fil Pilote].
01-06-2016 13:57:42 | info | A node has been added to OpenZWave list id:[19] model:[FGSD002 Smoke Sensor].
01-06-2016 13:57:42 | debug | The essential queries on a node have been completed. id:[19] model:[FGSD002 Smoke Sensor].
01-06-2016 13:57:42 | info | A node has been added to OpenZWave list id:[23] model:[Strips].
01-06-2016 13:57:42 | debug | The essential queries on a node have been completed. id:[23] model:[Strips].
01-06-2016 13:57:42 | info | A node has been added to OpenZWave list id:[25] model:[Strips].
01-06-2016 13:57:42 | debug | The essential queries on a node have been completed. id:[25] model:[Strips].
01-06-2016 13:57:42 | info | A node has been added to OpenZWave list id:[26] model:[Strips].
01-06-2016 13:57:42 | debug | The essential queries on a node have been completed. id:[26] model:[Strips].
01-06-2016 13:57:42 | info | A node has been added to OpenZWave list id:[30] model:[ZMNHSDx Din Dimmer].
01-06-2016 13:57:42 | debug | The essential queries on a node have been completed. id:[30] model:[ZMNHSDx Din Dimmer].
01-06-2016 13:57:42 | info | A node has been added to OpenZWave list id:[31] model:[FGSD002 Smoke Sensor].
01-06-2016 13:57:42 | debug | The essential queries on a node have been completed. id:[31] model:[FGSD002 Smoke Sensor].
01-06-2016 13:57:42 | debug | NodeId 14 send a notification: NoOperation
01-06-2016 13:57:42 | debug | NodeId 15 send a notification: NoOperation
01-06-2016 13:57:42 | debug | NodeId 16 send a notification: NoOperation
01-06-2016 13:57:42 | debug | NodeId 17 send a notification: NoOperation
01-06-2016 13:57:42 | debug | NodeId 18 send a notification: NoOperation
01-06-2016 13:57:42 | debug | NodeId 30 send a notification: NoOperation
01-06-2016 13:57:42 | debug | The command is starting. (Starting)
01-06-2016 13:57:42 | debug | Controller is busy: True
01-06-2016 13:57:42 | debug | Controller command is on a sleep queue wait for device. (Sleeping)
01-06-2016 13:57:42 | debug | Controller is busy: False
01-06-2016 13:57:43 | debug | The command is starting. (Starting)
01-06-2016 13:57:43 | debug | Controller is busy: True
01-06-2016 13:57:43 | debug | The controller is communicating with the other device to carry out the command. (InProgress)
01-06-2016 13:57:43 | debug | The command has completed successfully. (Completed)
01-06-2016 13:57:43 | debug | Controller is busy: False
01-06-2016 13:57:44 | debug | The controller is communicating with the other device to carry out the command. (InProgress)
01-06-2016 13:57:44 | debug | Controller is busy: True
01-06-2016 13:57:45 | debug | The command has completed successfully. (Completed)
01-06-2016 13:57:45 | debug | Controller is busy: False
01-06-2016 13:57:45 | debug | The command is starting. (Starting)
01-06-2016 13:57:45 | debug | Controller is busy: True
01-06-2016 13:57:45 | debug | The controller is communicating with the other device to carry out the command. (InProgress)
01-06-2016 13:57:47 | debug | The command has completed successfully. (Completed)
01-06-2016 13:57:47 | debug | Controller is busy: False
01-06-2016 13:57:47 | debug | The command is starting. (Starting)
01-06-2016 13:57:47 | debug | Controller is busy: True
01-06-2016 13:57:47 | debug | The controller is communicating with the other device to carry out the command. (InProgress)
01-06-2016 13:57:48 | debug | The controller is communicating with the other device to carry out the command. (InProgress)
01-06-2016 13:57:48 | debug | Controller is busy: True
01-06-2016 13:57:51 | debug | The command has completed successfully. (Completed)
01-06-2016 13:57:51 | debug | Controller is busy: False
01-06-2016 13:57:51 | debug | The command is starting. (Starting)
01-06-2016 13:57:51 | debug | Controller is busy: True
01-06-2016 13:57:51 | debug | The controller is communicating with the other device to carry out the command. (InProgress)
01-06-2016 13:57:53 | debug | The command has completed successfully. (Completed)
01-06-2016 13:57:53 | debug | Controller is busy: False
01-06-2016 13:57:53 | debug | The command is starting. (Starting)
01-06-2016 13:57:53 | debug | Controller is busy: True
01-06-2016 13:57:53 | debug | Controller command is on a sleep queue wait for device. (Sleeping)
01-06-2016 13:57:53 | debug | The controller is communicating with the other device to carry out the command. (InProgress)
01-06-2016 13:57:55 | debug | The command has completed successfully. (Completed)
01-06-2016 13:57:55 | debug | Controller is busy: False
01-06-2016 13:57:55 | debug | The command is starting. (Starting)
01-06-2016 13:57:55 | debug | Controller is busy: True
01-06-2016 13:57:55 | debug | Controller command is on a sleep queue wait for device. (Sleeping)
01-06-2016 13:57:55 | info | All the initialisation queries on a node have been completed. id:[1] model:[RaZberry Controller ZWave+].
01-06-2016 13:57:55 | info | write configuration file
01-06-2016 13:58:00 | debug | Received Sensor multilevel report from node 8: Temperature=20.1C
01-06-2016 13:58:00 | debug | Push data to jeedom
01-06-2016 13:58:16 | debug | NodeId 17 send a notification: Timeout
01-06-2016 13:58:20 | debug | Received Sensor multilevel report from node 8: Temperature=20.2C
01-06-2016 13:58:21 | debug | Push data to jeedom
01-06-2016 13:58:26 | debug | NodeId 17 send a notification: Timeout
01-06-2016 13:58:30 | debug | Received Sensor multilevel report from node 8: Temperature=20.1C
01-06-2016 13:58:30 | debug | Push data to jeedom
01-06-2016 13:58:38 | debug | NodeId 18 send a notification: Timeout
01-06-2016 13:58:40 | debug | Received Sensor multilevel report from node 8: Temperature=20.2C
01-06-2016 13:58:40 | debug | Push data to jeedom
01-06-2016 13:58:48 | debug | NodeId 18 send a notification: Timeout
01-06-2016 13:58:50 | info | All the initialisation queries on a node have been completed. id:[14] model:[ZMNHJD1 Flush Dimmer Fil Pilote].
01-06-2016 13:58:50 | info | write configuration file
01-06-2016 13:58:51 | debug | Received Sensor multilevel report from node 8: Temperature=20.1C
01-06-2016 13:58:51 | info | All the initialisation queries on a node have been completed. id:[15] model:[FGWPE Wall Plug].
01-06-2016 13:58:51 | info | write configuration file
01-06-2016 13:58:51 | debug | Push data to jeedom
01-06-2016 13:58:52 | info | All the initialisation queries on a node have been completed. id:[16] model:[ZMNHJD1 Flush Dimmer Fil Pilote].
01-06-2016 13:58:52 | info | write configuration file
01-06-2016 13:58:53 | info | All the initialisation queries on a node have been completed. id:[17] model:[ZMNHJD1 Flush Dimmer Fil Pilote].
01-06-2016 13:58:54 | info | write configuration file
01-06-2016 13:58:55 | info | All the initialisation queries on a node have been completed. id:[18] model:[ZMNHJD1 Flush Dimmer Fil Pilote].
01-06-2016 13:58:55 | info | write configuration file
01-06-2016 13:58:56 | info | All the initialisation queries on a node have been completed. id:[30] model:[ZMNHSDx Din Dimmer].
01-06-2016 13:58:56 | info | write configuration file
01-06-2016 13:58:57 | info | Refresh configuration parameters will starting in 360 sec
01-06-2016 13:58:57 | info | Refresh user values will starting in 120 sec
01-06-2016 13:58:57 | info | Validate association groups will starting in 45 sec
01-06-2016 13:58:57 | info | write configuration file
01-06-2016 13:58:57 | debug | Push data to jeedom
01-06-2016 13:59:00 | debug | Received Sensor multilevel report from node 8: Temperature=20.2C
01-06-2016 13:59:00 | debug | Push data to jeedom
01-06-2016 13:59:42 | debug | Check association
01-06-2016 13:59:42 | debug | validate_association_groups for nodeId: 1
01-06-2016 13:59:42 | debug | validate_association_groups for nodeId: 14
01-06-2016 13:59:42 | debug | validate_association_groups for nodeId: 15
01-06-2016 13:59:42 | debug | validate_association_groups for nodeId: 16
01-06-2016 13:59:42 | debug | validate_association_groups for nodeId: 17
01-06-2016 13:59:42 | debug | validate_association_groups for nodeId: 18
01-06-2016 13:59:42 | debug | validate_association_groups for nodeId: 30
01-06-2016 14:00:20 | debug | Received Sensor multilevel report from node 8: Temperature=20.1C
01-06-2016 14:00:20 | debug | Push data to jeedom
01-06-2016 14:00:30 | debug | Received Sensor multilevel report from node 8: Temperature=20.2C
01-06-2016 14:00:30 | debug | Push data to jeedom
01-06-2016 14:00:38 | debug | Perform network sanity test/check
01-06-2016 14:00:38 | debug | => Do a test on node 17
01-06-2016 14:00:38 | debug | NodeId 17 send a notification: NoOperation
01-06-2016 14:00:39 | debug | NodeId 17 send a notification: NoOperation
01-06-2016 14:00:40 | debug | Received Sensor multilevel report from node 8: Temperature=20.1C
01-06-2016 14:00:40 | debug | Push data to jeedom
01-06-2016 14:00:48 | debug | => Do a test on node 18
01-06-2016 14:00:49 | debug | NodeId 18 send a notification: NoOperation
01-06-2016 14:00:50 | debug | Received Sensor multilevel report from node 8: Temperature=20.2C
01-06-2016 14:00:50 | debug | Push data to jeedom
01-06-2016 14:00:57 | debug | Refresh User Values of powered devices
01-06-2016 14:00:57 | debug | Refresh User Values for nodeId: 1
01-06-2016 14:00:57 | debug | Refresh User Values for nodeId: 14
01-06-2016 14:00:57 | debug | BackgroundWorker is waiting others tasks has be completed before proceeding
01-06-2016 14:00:57 | debug | Received Switch binary report from node 14: Switch=True
01-06-2016 14:00:57 | debug | Received Switch multilevel report from node 14: Level=20
01-06-2016 14:00:57 | debug | Push data to jeedom
01-06-2016 14:00:57 | debug | Received Sensor binary report from node 14: Sensor=False
01-06-2016 14:00:57 | debug | Received Sensor multilevel report from node 14: Temperature=-999.9C
01-06-2016 14:00:58 | debug | Received Sensor binary report from node 14: Sensor=False
01-06-2016 14:00:58 | debug | Push data to jeedom
01-06-2016 14:00:58 | debug | Network sanity test/check completed!
01-06-2016 14:01:27 | debug | Refresh User Values for nodeId: 15
01-06-2016 14:01:27 | debug | BackgroundWorker is waiting others tasks has be completed before proceeding
01-06-2016 14:01:27 | debug | Received Switch binary report from node 15: Switch=True
01-06-2016 14:01:27 | debug | Received Meter report from node 15: Exporting=False
01-06-2016 14:01:27 | debug | Received Meter report from node 15: Energy=128.28kWh
01-06-2016 14:01:28 | debug | Received Meter report from node 15: Power=2.2W
01-06-2016 14:01:28 | debug | Push data to jeedom
01-06-2016 14:01:28 | debug | Received Sensor multilevel report from node 15: Power=2.2W
01-06-2016 14:01:30 | debug | Received Sensor multilevel report from node 8: Temperature=20.1C
01-06-2016 14:01:30 | debug | Push data to jeedom
01-06-2016 14:01:40 | debug | Received Sensor multilevel report from node 8: Temperature=20.2C
01-06-2016 14:01:40 | debug | Push data to jeedom
01-06-2016 14:01:57 | debug | Refresh User Values for nodeId: 16
01-06-2016 14:01:57 | debug | BackgroundWorker is waiting others tasks has be completed before proceeding
01-06-2016 14:01:57 | debug | Received Switch binary report from node 16: Switch=True
01-06-2016 14:01:57 | debug | Received Switch multilevel report from node 16: Level=20
01-06-2016 14:01:58 | debug | Push data to jeedom
01-06-2016 14:01:58 | debug | Received Sensor binary report from node 16: Sensor=False
01-06-2016 14:01:58 | debug | Received Sensor multilevel report from node 16: Temperature=-999.9C
01-06-2016 14:02:27 | debug | Refresh User Values for nodeId: 17
01-06-2016 14:02:27 | debug | BackgroundWorker is waiting others tasks has be completed before proceeding
01-06-2016 14:02:27 | debug | Received Switch binary report from node 17: Switch=True
01-06-2016 14:02:27 | debug | Push data to jeedom
01-06-2016 14:02:27 | debug | Received Switch multilevel report from node 17: Level=20
01-06-2016 14:02:28 | debug | Push data to jeedom
01-06-2016 14:02:28 | debug | Received Sensor binary report from node 17: Sensor=False
01-06-2016 14:02:28 | debug | Received Sensor multilevel report from node 17: Temperature=-999.9C
01-06-2016 14:02:29 | debug | Push data to jeedom
@shinji99 de ce que je vois tous semble en ordre maintenant as-tu encore un problème?
As-tu consulté la documentation avant de poser ta question?
Les demandes de support en MP ne seront pas traité mais j'accepte les dons paypal.me/nechry
Visiter mon blog http://nechry-automation.ch/
@DenisPac regarde les log d'update/market a mon avis c'est pas bon. sinon force l'installe su plugin tu compile l'ancienne version donc c'est le vieux plugin.
Dois je laisser le mode automatique desactivé ? car je l'ai réactivé âpres le lognechry a écrit :@shinji99 de ce que je vois tous semble en ordre maintenant as-tu encore un problème?
par contre j'ai toujours des remontées de température de plusieurs smoke sensors réglés pour remonter les valeur en cas de changement de 0.1° (peu être trop )qui ne ce fait plus alors qu'il fonctionnais bien depuis plusieurs mois
les strips qui sont dans les mémé pièces 0 problèmes .
Une idées ?
Tu peux eventuellement re activer le mode auto et revenir en mode normal comme il n'y a pas de probleme avec le plugin. Pour les remontées regarde la santée zwave et tout est ok. Probablement l'interview non complete
Sent from my iPhone using Tapatalk
je teste en rentrant .
merci
merci
j'ai refais l'install avec une restauration mais je n'arrive pas à faire passer cette nouvelle version ou revenir à la précédente, par contre sur une µsd tout a fonctionner mais cette mise a jour ne veux pas s'installer avec le disque ssd
@vortex31 je pense pas que le problème est le plugin comme tel, mais dans ton installation SSD. essais d'installer un autre plugin juste pour voir. sinon regarde les log d'installation il doit y avoir un problème de droit, ça sera pas le log plugin mais le update ou market
hello
Pour info mise a jour tout ok pour moi sur jeedom mini+, merci nechry
MERCI À L'ÉQUIPE POUR LE TAF
MAJ faite hier sur Rpi3 - tout s'est très bien passé !!
Merci à toute l'équipe et à @nechry pour cette mise à jour sans encombre !!
Jeedom 3.3.31 - OpenZwave dernière version
NUC avec Dongle ZWave AEOTEC AEOEZW090 et RFXCom
20 modules RFXCom
50 modules ZWave
20 modules RFXCom
50 modules ZWave
Plugin noténechry a écrit :je me répète mais, si vous n'avez pas noté le plugin sur le market et ou que votre opinion a changé en bien (en moins bien vous pouvez vous abstenir...lol), n'hésité pas a donner une note au plugin. C'est aussi un élément motivateur pour moi.
RPI3 / RFXCOM RFXtrx433E / Z-Stick gen5
Ciao, les amigos: mise a jour, faite : impecc, encore 1 ou 2 modules qui doivent se réveiller...j'aurais pas du les titulariser, mdr...
JEEDOM sur ODROID C2 & Clé AEON Gen 5 depuis 20/03/2016, strecth
90 modules zwave, 3 Squeezebox, 3 BOOM, 1 DUET, 1 Controler, 3 picoreplayer
Modules infrarouges, etc......
Bonjour Nechry, bonjour à tous,
Il est vrai que ce sont des FGMS-001 1ère génération, mais à 55€ pas envie de m'en racheter d'autres
En fait à chaque fois que je fais la mise à jour Z-wave j'ai ce problème qui revientnechry a écrit :@NonoM45 pour que je comprenne bien, tu as plus de remonté battery depuis la mise à jour ou tu avais déjà ce problème avant.
j'ai eux le cas chez moi d'un FGMS-001 qui ne me remontait plus sont état de pile, même après avoir remplacé. ma seul solution à été d'exclure.
sinon faut juste attendre 24h que le refresh ce fait
Raspberry Pi 3 avec une raZberry
Linux raspberrypi 4.9.41-v7+ #1023 - armv7l GNU/Linux [9.1]
PHP : 7.0.19-1 - Jeedom : 3.2.16
Version database : 10.1.23-MariaDB-9+deb9u1
Bien vu @nechry. C'était bien ça ! J'avais zappé une mise à jour du plugin sur le Jeedom déporté.nechry a écrit :@DenisPac regarde les log d'update/market a mon avis c'est pas bon. sinon force l'installe su plugin tu compile l'ancienne version donc c'est le vieux plugin.
A présent j'ai bien la version 1.4.428
Du coup j'aurais une suggestion à faire pour le core : On n'a qu'à un seul endroit la visibilité de mises à jour de plugin à faire sur les Jeedom déportés.
La page santé ne vérifie que la version du Core. Je suggère donc d'ajouter une ligne indiquant si les Jeedom déportés ont bien tous leur plugins à jour.
Sinon dans la page configuration du plugin Z-Wave tu peux aussi rajouter cette info.
Merci pour ton aide en tout cas.
Il ne me reste plus qu'à comprendre pourquoi mon Z-Stick S2 reste en Driver initialised...
Salut @nechry,
mise à jour lancée hier sur Odroid C2, compil ok lancée en automatique après l'install (j'adore!), tout fonctionne
Merci pour le taf !!!
EDIT:j'en ai aussi profité pour noter tous les plugins que j'utilise
Odroid C2 / Jeedom stable
Zwave.me UZB1 / RFXtrx433E / HEM2 / Orvibo / Connexoon / Netatmo
Synology DS1512+ / FBX6
Un grand MERCI à l'équipe Jeedom !
Hello Nechry
Mise à jour faite ce matin (un jeedom maitre et 4 RPI2 esclave). tout s'est très bien passé. J'ai même l'impression que le réseau est plus réactif.
Nickel. Comme d'habitude.
Bravo
Bravo
Mise à jour effectuée chez moi hier.
Zéro problème, pas mal de petits ajouts bien pensés. Ce plugin a vraiment bien évolué depuis l'année dernière. Bravo!
Jeedom sous UpBoard
Jeedom sous UpBoard
Salut à tous. Et bien me concernant, impossible de faire la mise a jour des dépendances. Je viens d'y passer la matinée sans résultats. Une idée ?
Voici les logs
J'ai bien laissé tourner plus de 2h, mais quoi qu'il arrive au bout d'un certain temps, jeedom ne répond plus, ni en http, ni en ssh ni avec un ping
Voici les logs
Lancement de l'installation/mise à jour des dépendances openzwave
Ign http://repo.r00t.website ./ InRelease
Hit http://repo.r00t.website ./ Release.gpg
Hit http://repo.r00t.website ./ Packages
Ign http://ftp.de.debian.org jessie InRelease
Hit http://ftp.de.debian.org jessie Release.gpg
Ign http://repo.r00t.website ./ Translation-en
Hit http://ftp.de.debian.org jessie/main Sources
Hit http://ftp.de.debian.org jessie/contrib Sources
Hit http://ftp.de.debian.org jessie/non-free Sources
Hit http://ftp.de.debian.org jessie/main armhf Packages
Hit http://ftp.de.debian.org jessie/contrib armhf Packages
Hit http://ftp.de.debian.org jessie/non-free armhf Packages
Hit http://ftp.de.debian.org jessie/contrib Translation-en
Hit http://ftp.de.debian.org jessie/main Translation-en
Hit http://ftp.de.debian.org jessie/non-free Translation-en
Get:1 http://ftp.debian.org jessie-updates InRelease [142 kB]
Get:2 http://ftp.debian.org jessie-updates/main Sources [14.1 kB]
Get:3 http://ftp.debian.org jessie-updates/contrib Sources [32 B]
Get:4 http://ftp.debian.org jessie-updates/non-free Sources [920 B]
Get:5 http://ftp.debian.org jessie-updates/main armhf Packages/DiffIndex [3472 B]
Get:6 http://ftp.debian.org jessie-updates/contrib armhf Packages [32 B]
Get:7 http://ftp.debian.org jessie-updates/non-free armhf Packages/DiffIndex [736 B]
Get:8 http://ftp.debian.org jessie-updates/contrib Translation-en [14 B]
Get:9 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [1720 B]
Get:10 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
Hit http://security.debian.org jessie/updates InRelease
Hit http://security.debian.org jessie/updates/main Sources
Hit http://security.debian.org jessie/updates/contrib Sources
Hit http://security.debian.org jessie/updates/non-free Sources
Hit http://security.debian.org jessie/updates/main armhf Packages
Hit http://security.debian.org jessie/updates/contrib armhf Packages
Hit http://security.debian.org jessie/updates/non-free armhf Packages
Hit http://security.debian.org jessie/updates/contrib Translation-en
Hit http://security.debian.org jessie/updates/main Translation-en
Hit http://security.debian.org jessie/updates/non-free Translation-en
Fetched 164 kB in 54s (2997 B/s)
Reading package lists...
Installation des dependances
Building dependency tree...
Reading state information...
build-essential is already the newest version.
g++ is already the newest version.
gcc is already the newest version.
git is already the newest version.
libjpeg-dev is already the newest version.
python-louie is already the newest version.
python-lxml is already the newest version.
make is already the newest version.
python-dev is already the newest version.
python-pip is already the newest version.
python-setuptools is already the newest version.
python-sphinx is already the newest version.
libudev-dev is already the newest version.
unzip is already the newest version.
mercurial is already the newest version.
The following package was automatically installed and is no longer required:
rlwrap
Use 'apt-get autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 46 not upgraded.
Installation des dependances Python
Requirement already satisfied (use --upgrade to upgrade): sphinxcontrib-blockdiag in /usr/local/lib/python2.7/dist-packages
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): sphinxcontrib-actdiag in /usr/local/lib/python2.7/dist-packages
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): sphinxcontrib-nwdiag in /usr/local/lib/python2.7/dist-packages
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): sphinxcontrib-seqdiag in /usr/local/lib/python2.7/dist-packages
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): urwid in /usr/local/lib/python2.7/dist-packages
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): louie in /usr/lib/python2.7/dist-packages
Requirement already satisfied (use --upgrade to upgrade): nose>=0.8.3 in /usr/lib/python2.7/dist-packages (from louie)
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): flask in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied (use --upgrade to upgrade): Werkzeug>=0.7 in /usr/local/lib/python2.7/dist-packages (from flask)
Requirement already satisfied (use --upgrade to upgrade): Jinja2>=2.4 in /usr/lib/python2.7/dist-packages (from flask)
Requirement already satisfied (use --upgrade to upgrade): itsdangerous>=0.21 in /usr/local/lib/python2.7/dist-packages (from flask)
Requirement already satisfied (use --upgrade to upgrade): markupsafe in /usr/lib/python2.7/dist-packages (from Jinja2>=2.4->flask)
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): flask-restful in /usr/local/lib/python2.7/dist-packages
Cleaning up...
mkdir: cannot create directory '/opt': File exists
Désinstallation de la version précédente
Installation de Python-OpenZwave
Cloning into 'python-openzwave'...
HEAD is now at 1ca17ac Update version
Not uninstalling Cython at /usr/lib/python2.7/dist-packages, owned by OS
apt-get install --force-yes -y cython
cython is already the newest version.
rlwrap
Installing dependencies for python : 2 7 9
apt-get install --force-yes -y python-pip python-dev python-docutils python-setuptools python-louie
python-docutils is already the newest version.
rlwrap
apt-get install --force-yes -y build-essential libudev-dev g++
rlwrap
rlwrap
pip install nose-html
Requirement already satisfied (use --upgrade to upgrade): nose-html in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied (use --upgrade to upgrade): nose>=0.11.1 in /usr/lib/python2.7/dist-packages (from nose-html)
Cleaning up...
pip install nose-progressive
Requirement already satisfied (use --upgrade to upgrade): nose-progressive in /usr/local/lib/python2.7/dist-packages
Cleaning up...
pip install coverage
Requirement already satisfied (use --upgrade to upgrade): coverage in /usr/local/lib/python2.7/dist-packages
Cleaning up...
pip install nose
Requirement already satisfied (use --upgrade to upgrade): nose in /usr/lib/python2.7/dist-packages
Cleaning up...
pip install pylint
Requirement already satisfied (use --upgrade to upgrade): pylint in /usr/local/lib/python2.7/dist-packages
Cleaning up...
#pip install docutils
#pip install setuptools
#The following line crashes with a core dump
#pip install "Cython==0.22"
Dependencies for users installed (python 2 7 9)
Cloning into 'openzwave'...
HEAD is now at 2e25b5d update changelog
sed -i -e '253s/.*//' openzwave/cpp/src/value_classes/ValueID.h
cd openzwave && make
make[1]: Entering directory '/opt/python-openzwave/openzwave'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/build/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/build'
Building OpenZWave Version 1.4-248-g2e25b5d-dirty
Building tinystr.o
Building tinyxmlerror.o
Building tinyxml.o
Building tinyxmlparser.o
Building hid.o
Building aeskey.o
Building aescrypt.o
Building aestab.o
Building aes_modes.o
Building Security.o
Building Proprietary.o
Building UserCode.o
Building SensorMultilevel.o
Building EnergyProduction.o
Building Language.o
Building CommandClass.o
Building ZWavePlusInfo.o
Building Indicator.o
Building MultiInstance.o
Building MeterPulse.o
Building SensorBinary.o
Building SwitchBinary.o
Building Configuration.o
Building Battery.o
Building ThermostatMode.o
Building Hail.o
Building SwitchToggleBinary.o
Building TimeParameters.o
Building Lock.o
Building DeviceResetLocally.o
Building Association.o
Building Color.o
Building ManufacturerSpecific.o
Building ThermostatSetpoint.o
Building ClimateControlSchedule.o
Building ApplicationStatus.o
Building SwitchToggleMultilevel.o
Building DoorLockLogging.o
Building Protection.o
Building ThermostatOperatingState.o
Building NodeNaming.o
Building WakeUp.o
Building BasicWindowCovering.o
Building MultiCmd.o
Building MultiInstanceAssociation.o
Building Clock.o
Building SceneActivation.o
Building CentralScene.o
Building Powerlevel.o
Building AssociationCommandConfiguration.o
Building SwitchMultilevel.o
Building ThermostatFanMode.o
Building CRC16Encap.o
Building Version.o
Building SensorAlarm.o
Building Meter.o
Building Alarm.o
Building CommandClasses.o
Building ThermostatFanState.o
Building NoOperation.o
Building SwitchAll.o
Building Basic.o
Building ControllerReplication.o
Building DoorLock.o
Building Value.o
Building ValueList.o
Building ValueButton.o
Building ValueInt.o
Building ValueStore.o
Building ValueDecimal.o
Building ValueRaw.o
Building ValueString.o
Building ValueByte.o
Building ValueBool.o
Building ValueSchedule.o
Building ValueShort.o
Building Controller.o
Building Wait.o
Building Thread.o
Building Stream.o
Building Log.o
Building HidController.o
Building Mutex.o
Building SerialController.o
Building Event.o
Building FileOps.o
Building TimeStamp.o
Building FileOpsImpl.o
Building TimeStampImpl.o
Building WaitImpl.o
Building ThreadImpl.o
Building LogImpl.o
Building MutexImpl.o
Building SerialControllerImpl.o
Building EventImpl.o
Building Options.o
Building Scene.o
Building Utils.o
Building Driver.o
Building ZWSecurity.o
Building Group.o
Building Node.o
Building Manager.o
Building Msg.o
Building Notification.o
Creating vers.cpp
Building vers.o
Linking Static Library
Linking Shared Library
Making ozw_config file
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/build'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/examples/MinOZW/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
Building Main.o
Linking /opt/python-openzwave/openzwave/.lib/MinOZW
g++ -o /opt/python-openzwave/openzwave/.lib/MinOZW /opt/python-openzwave/openzwave/.lib/Main.o /opt/python-openzwave/openzwave/libopenzwave.so -pthread
Creating Temporary Shell Launch Script
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
make[1]: Leaving directory '/opt/python-openzwave/openzwave'
python setup-lib.py build
running build
running build_ext
cythoning src-lib/libopenzwave/libopenzwave.pyx to src-lib/libopenzwave/libopenzwave.cpp
building 'libopenzwave' extension
creating build
creating build/temp.linux-armv7l-2.7
creating build/temp.linux-armv7l-2.7/src-lib
creating build/temp.linux-armv7l-2.7/src-lib/libopenzwave
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DPY_SSIZE_T_CLEAN=1 -Iopenzwave/cpp/src/ -Iopenzwave/cpp/src/value_classes/ -Iopenzwave/cpp/src/platform/ -Iopenzwave/cpp/build/linux/ -I/usr/include/python2.7 -c src-lib/libopenzwave/libopenzwave.cpp -o build/temp.linux-armv7l-2.7/src-lib/libopenzwave/libopenzwave.o
cc1plus: warning: command line option '-Wstrict-prototypes' is valid for C/ObjC but not for C++
src-lib/libopenzwave/libopenzwave.cpp:3:0: warning: "PY_SSIZE_T_CLEAN" redefined
#define PY_SSIZE_T_CLEAN
<command-line>:0:0: note: this is the location of the previous definition
In file included from openzwave/cpp/src/aes/aescpp.h:26:0,
from openzwave/cpp/src/Driver.h:42,
from src-lib/libopenzwave/libopenzwave.cpp:249:
openzwave/cpp/src/aes/aes.h:75:0: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( disable : 4324 )
openzwave/cpp/src/aes/aes.h:93:0: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( default : 4324 )
src-lib/libopenzwave/libopenzwave.cpp: In function 'PyObject* __pyx_pf_12libopenzwave_9PyManager_268beginControllerCommand(__pyx_obj_12libopenzwave_PyManager*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*)':
src-lib/libopenzwave/libopenzwave.cpp:27540:204: warning: 'bool OpenZWave::Manager::BeginControllerCommand(uint32, OpenZWave::Driver::ControllerCommand, OpenZWave::Driver::pfnControllerCallback_t, void*, bool, uint8, uint8)' is deprecated (declared at openzwave/cpp/src/Manager.h:1731) [-Wdeprecated-declarations]
__pyx_t_6 = __Pyx_PyBool_FromLong(__pyx_v_self->manager->BeginControllerCommand(__pyx_t_1, __pyx_t_2, __pyx_f_12libopenzwave_ctrl_callback, ((void *)__pyx_v_pythonfunc), __pyx_t_3, __pyx_t_4, __pyx_t_5)); if (unlikely(!__pyx_t_6)) {__pyx_filename = __pyx_f[0]; __pyx_lineno = 4119; __pyx_clineno = __LINE__; goto __pyx_L1_error;}
src-lib/libopenzwave/libopenzwave.cpp:329:36: note: in definition of macro '__Pyx_PyBool_FromLong'
#define __Pyx_PyBool_FromLong(b) ((b) ? (Py_INCREF(Py_True), Py_True) : (Py_INCREF(Py_False), Py_False))
Désolé, après une nième tentative, la mise a jour est passé
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 20 invités
