suite a mon plantage j'ai relancé une installation de mon jeedom ( RPI2 ) en version 2.3.16 pour voir si je pouvais restaurer mon backup en 2.2.6
avant de restaurer ma sauvegarde j'ai relancé les dependance mais elles se lance en boucle elle arrive a 100 % et redemarre.
voici les logs.
openzwave/cpp/src/aes/aes.h:93:0: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( default : 4324 )
src-lib/libopenzwave/libopenzwave.cpp: In function ‘PyObject* __pyx_pf_12libopenzwave_9PyManager_268beginControllerCommand(__pyx_obj_12libopenzwave_PyManager*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*)’:
src-lib/libopenzwave/libopenzwave.cpp:27540:204: warning: ‘bool OpenZWave::Manager::BeginControllerCommand(uint32, OpenZWave::Driver::ControllerCommand, OpenZWave::Driver::pfnControllerCallback_t, void*, bool, uint8, uint8)’ is deprecated (declared at openzwave/cpp/src/Manager.h:1731) [-Wdeprecated-declarations]
__pyx_t_6 = __Pyx_PyBool_FromLong(__pyx_v_self->manager->BeginControllerCommand(__pyx_t_1, __pyx_t_2, __pyx_f_12libopenzwave_ctrl_callback, ((void *)__pyx_v_pythonfunc), __pyx_t_3, __pyx_t_4, __pyx_t_5)); if (unlikely(!__pyx_t_6)) {__pyx_filename = __pyx_f[0]; __pyx_lineno = 4119; __pyx_clineno = __LINE__; goto __pyx_L1_error;}
src-lib/libopenzwave/libopenzwave.cpp:329:36: note: in definition of macro ‘__Pyx_PyBool_FromLong’
#define __Pyx_PyBool_FromLong(b) ((b) ? (Py_INCREF(Py_True), Py_True) : (Py_INCREF(Py_False), Py_False))
creating build/lib.linux-armv7l-2.7
c++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wl,-z,relro -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security build/temp.linux-armv7l-2.7/src-lib/libopenzwave/libopenzwave.o openzwave/libopenzwave.a -ludev -lstdc++ -o build/lib.linux-armv7l-2.7/libopenzwave.so
python setup-lib.py install
running install
running bdist_egg
running egg_info
creating src-lib/libopenzwave.egg-info
writing requirements to src-lib/libopenzwave.egg-info/requires.txt
writing src-lib/libopenzwave.egg-info/PKG-INFO
writing top-level names to src-lib/libopenzwave.egg-info/top_level.txt
writing dependency_links to src-lib/libopenzwave.egg-info/dependency_links.txt
writing manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
reading manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-armv7l/egg
running install_lib
running build_ext
skipping 'src-lib/libopenzwave/libopenzwave.cpp' Cython extension (up-to-date)
creating build/bdist.linux-armv7l
creating build/bdist.linux-armv7l/egg
copying build/lib.linux-armv7l-2.7/libopenzwave.so -> build/bdist.linux-armv7l/egg
creating stub loader for libopenzwave.so
byte-compiling build/bdist.linux-armv7l/egg/libopenzwave.py to libopenzwave.pyc
installing package data to build/bdist.linux-armv7l/egg
running install_data
creating build/bdist.linux-armv7l/egg/config
copying openzwave/config/manufacturer_specific.xml -> build/bdist.linux-armv7l/egg/config
copying openzwave/config/device_classes.xml -> build/bdist.linux-armv7l/egg/config
copying openzwave/config/options.xml -> build/bdist.linux-armv7l/egg/config
creating build/bdist.linux-armv7l/egg/config/mcohome
copying openzwave/config/mcohome/mhs312.xml -> build/bdist.linux-armv7l/egg/config/mcohome
copying openzwave/config/mcohome/mhs314.xml -> build/bdist.linux-armv7l/egg/config/mcohome
copying openzwave/config/mcohome/mhs513.xml -> build/bdist.linux-armv7l/egg/config/mcohome
copying openzwave/config/mcohome/mhs412.xml -> build/bdist.linux-armv7l/egg/config/mcohome
copying openzwave/config/mcohome/mhs311.xml -> build/bdist.linux-armv7l/egg/config/mcohome
copying openzwave/config/mcohome/mhs411.xml -> build/bdist.linux-armv7l/egg/config/mcohome
creating build/bdist.linux-armv7l/egg/config/leviton
copying openzwave/config/leviton/vrcpg.xml -> build/bdist.linux-armv7l/egg/config/leviton
copying openzwave/config/leviton/vrf01.xml -> build/bdist.linux-armv7l/egg/config/leviton
copying openzwave/config/leviton/vri10.xml -> build/bdist.linux-armv7l/egg/config/leviton
copying openzwave/config/leviton/vri06.xml -> build/bdist.linux-armv7l/egg/config/leviton
copying openzwave/config/leviton/rzi10.xml -> build/bdist.linux-armv7l/egg/config/leviton
creating build/bdist.linux-armv7l/egg/config/northq
copying openzwave/config/northq/nq9121.xml -> build/bdist.linux-armv7l/egg/config/northq
copying openzwave/config/northq/nq92021.xml -> build/bdist.linux-armv7l/egg/config/northq
creating build/bdist.linux-armv7l/egg/config/greenwave
copying openzwave/config/greenwave/powernode6.xml -> build/bdist.linux-armv7l/egg/config/greenwave
copying openzwave/config/greenwave/powernode1.xml -> build/bdist.linux-armv7l/egg/config/greenwave
creating build/bdist.linux-armv7l/egg/config/merten
copying openzwave/config/merten/50x5xx.xml -> build/bdist.linux-armv7l/egg/config/merten
copying openzwave/config/merten/507801.xml -> build/bdist.linux-armv7l/egg/config/merten
creating build/bdist.linux-armv7l/egg/config/popp
copying openzwave/config/popp/123580.xml -> build/bdist.linux-armv7l/egg/config/popp
copying openzwave/config/popp/solar-siren.xml -> build/bdist.linux-armv7l/egg/config/popp
copying openzwave/config/popp/smoke-detector.xml -> build/bdist.linux-armv7l/egg/config/popp
copying openzwave/config/popp/009105.xml -> build/bdist.linux-armv7l/egg/config/popp
copying openzwave/config/popp/123601.xml -> build/bdist.linux-armv7l/egg/config/popp
copying openzwave/config/popp/123658.xml -> build/bdist.linux-armv7l/egg/config/popp
copying openzwave/config/popp/zweather.xml -> build/bdist.linux-armv7l/egg/config/popp
copying openzwave/config/popp/009303.xml -> build/bdist.linux-armv7l/egg/config/popp
creating build/bdist.linux-armv7l/egg/config/domitech
copying openzwave/config/domitech/zb22uk.xml -> build/bdist.linux-armv7l/egg/config/domitech
copying openzwave/config/domitech/ze27eu.xml -> build/bdist.linux-armv7l/egg/config/domitech
creating build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/ad146.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/ad147.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/an180.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/hsp02.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/st814.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/st815.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/sm103.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/se812.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/tse03.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/sp814.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/sf812.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/an158.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/st812.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/an179.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/hac01.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/an145.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/sp103.xml -> build/bdist.linux-armv7l/egg/config/everspring
copying openzwave/config/everspring/an181.xml -> build/bdist.linux-armv7l/egg/config/everspring
creating build/bdist.linux-armv7l/egg/config/waynedalton
copying openzwave/config/waynedalton/WDTC-20.xml -> build/bdist.linux-armv7l/egg/config/waynedalton
creating build/bdist.linux-armv7l/egg/config/nodon
copying openzwave/config/nodon/crc3100OctanRemote.xml -> build/bdist.linux-armv7l/egg/config/nodon
copying openzwave/config/nodon/asp3100SmartPlug.xml -> build/bdist.linux-armv7l/egg/config/nodon
copying openzwave/config/nodon/crc360xSofremote.xml -> build/bdist.linux-armv7l/egg/config/nodon
copying openzwave/config/nodon/cws3101wallswitch.xml -> build/bdist.linux-armv7l/egg/config/nodon
creating build/bdist.linux-armv7l/egg/config/thermofloor
copying openzwave/config/thermofloor/heatit021.xml -> build/bdist.linux-armv7l/egg/config/thermofloor
creating build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw056.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsb05.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc10.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsd37.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsb28.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc08101.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsb45.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc14104.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsb54.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw088.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc26103.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsb29.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw079.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc18103.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsb09104.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc27103.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw100.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc13104.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsb04100.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw095.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw090.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc24.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw096.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw062.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw098.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw075.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw074.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc11.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw112.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsa22.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc12104.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw078.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc06106.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw120.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw089.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw080.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc35103.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsa03202.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsc19103.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/dsa38.xml -> build/bdist.linux-armv7l/egg/config/aeotec
copying openzwave/config/aeotec/zw099.xml -> build/bdist.linux-armv7l/egg/config/aeotec
creating build/bdist.linux-armv7l/egg/config/frostdale
copying openzwave/config/frostdale/fdn2nxx.xml -> build/bdist.linux-armv7l/egg/config/frostdale
creating build/bdist.linux-armv7l/egg/config/evolve
copying openzwave/config/evolve/lsm-15.xml -> build/bdist.linux-armv7l/egg/config/evolve
copying openzwave/config/evolve/lrm-as.xml -> build/bdist.linux-armv7l/egg/config/evolve
copying openzwave/config/evolve/ltm-5.xml -> build/bdist.linux-armv7l/egg/config/evolve
creating build/bdist.linux-armv7l/egg/config/schlagelink
copying openzwave/config/schlagelink/minikeypad.xml -> build/bdist.linux-armv7l/egg/config/schlagelink
copying openzwave/config/schlagelink/itemp.xml -> build/bdist.linux-armv7l/egg/config/schlagelink
creating build/bdist.linux-armv7l/egg/config/qees
copying openzwave/config/qees/reto-dimmer-plus.xml -> build/bdist.linux-armv7l/egg/config/qees
copying openzwave/config/qees/reto-plugin-switch.xml -> build/bdist.linux-armv7l/egg/config/qees
creating build/bdist.linux-armv7l/egg/config/cooper
copying openzwave/config/cooper/RF9540-N.xml -> build/bdist.linux-armv7l/egg/config/cooper
copying openzwave/config/cooper/RF9505-T.xml -> build/bdist.linux-armv7l/egg/config/cooper
creating build/bdist.linux-armv7l/egg/config/horstmann
copying openzwave/config/horstmann/ses302.xml -> build/bdist.linux-armv7l/egg/config/horstmann
copying openzwave/config/horstmann/scsc17.xml -> build/bdist.linux-armv7l/egg/config/horstmann
copying openzwave/config/horstmann/sir321.xml -> build/bdist.linux-armv7l/egg/config/horstmann
copying openzwave/config/horstmann/asrzw.xml -> build/bdist.linux-armv7l/egg/config/horstmann
copying openzwave/config/horstmann/ses303.xml -> build/bdist.linux-armv7l/egg/config/horstmann
copying openzwave/config/horstmann/srt323.xml -> build/bdist.linux-armv7l/egg/config/horstmann
copying openzwave/config/horstmann/hrt4zw.xml -> build/bdist.linux-armv7l/egg/config/horstmann
creating build/bdist.linux-armv7l/egg/config/polycontrol
copying openzwave/config/polycontrol/polylock.xml -> build/bdist.linux-armv7l/egg/config/polycontrol
copying openzwave/config/polycontrol/doorlock.xml -> build/bdist.linux-armv7l/egg/config/polycontrol
copying openzwave/config/polycontrol/keypad.xml -> build/bdist.linux-armv7l/egg/config/polycontrol
creating build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgwpe.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgms.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgd212.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgbs001.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgr221.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgrgbwm441.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgss101.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgs211.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgrm222.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fggc001.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgd211.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgsd002.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgfs101.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgr222.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgk001.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgs221.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgfs101zw5.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgs212.xml -> build/bdist.linux-armv7l/egg/config/fibaro
copying openzwave/config/fibaro/fgs222.xml -> build/bdist.linux-armv7l/egg/config/fibaro
creating build/bdist.linux-armv7l/egg/config/dragontech
copying openzwave/config/dragontech/wd-100.xml -> build/bdist.linux-armv7l/egg/config/dragontech
creating build/bdist.linux-armv7l/egg/config/fortrezz
copying openzwave/config/fortrezz/ssa2.xml -> build/bdist.linux-armv7l/egg/config/fortrezz
copying openzwave/config/fortrezz/mimolite.xml -> build/bdist.linux-armv7l/egg/config/fortrezz
copying openzwave/config/fortrezz/ssa3.xml -> build/bdist.linux-armv7l/egg/config/fortrezz
creating build/bdist.linux-armv7l/egg/config/nexia
copying openzwave/config/nexia/db100z.xml -> build/bdist.linux-armv7l/egg/config/nexia
creating build/bdist.linux-armv7l/egg/config/eurotronic
copying openzwave/config/eurotronic/eur_cometz.xml -> build/bdist.linux-armv7l/egg/config/eurotronic
copying openzwave/config/eurotronic/eur_stellaz.xml -> build/bdist.linux-armv7l/egg/config/eurotronic
creating build/bdist.linux-armv7l/egg/config/vitrum
copying openzwave/config/vitrum/vitrumBS.xml -> build/bdist.linux-armv7l/egg/config/vitrum
creating build/bdist.linux-armv7l/egg/config/zipato
copying openzwave/config/zipato/RGBBulb.xml -> build/bdist.linux-armv7l/egg/config/zipato
copying openzwave/config/zipato/MiniKeypad.xml -> build/bdist.linux-armv7l/egg/config/zipato
creating build/bdist.linux-armv7l/egg/config/honeywell
copying openzwave/config/honeywell/th8320zw1000.xml -> build/bdist.linux-armv7l/egg/config/honeywell
creating build/bdist.linux-armv7l/egg/config/assa_abloy
copying openzwave/config/assa_abloy/RealLivingCapTouch.xml -> build/bdist.linux-armv7l/egg/config/assa_abloy
creating build/bdist.linux-armv7l/egg/config/BeNext
copying openzwave/config/BeNext/EnergySwitch.xml -> build/bdist.linux-armv7l/egg/config/BeNext
copying openzwave/config/BeNext/BuiltinDimmer.xml -> build/bdist.linux-armv7l/egg/config/BeNext
copying openzwave/config/BeNext/AlarmSound.xml -> build/bdist.linux-armv7l/egg/config/BeNext
copying openzwave/config/BeNext/PluginDimmer.xml -> build/bdist.linux-armv7l/egg/config/BeNext
copying openzwave/config/BeNext/DoorSensor.xml -> build/bdist.linux-armv7l/egg/config/BeNext
copying openzwave/config/BeNext/Molite.xml -> build/bdist.linux-armv7l/egg/config/BeNext
copying openzwave/config/BeNext/SceneController.xml -> build/bdist.linux-armv7l/egg/config/BeNext
copying openzwave/config/BeNext/TagReader.xml -> build/bdist.linux-armv7l/egg/config/BeNext
copying openzwave/config/BeNext/2poleswitch.xml -> build/bdist.linux-armv7l/egg/config/BeNext
copying openzwave/config/BeNext/1poleswitch.xml -> build/bdist.linux-armv7l/egg/config/BeNext
copying openzwave/config/BeNext/PanicButton.xml -> build/bdist.linux-armv7l/egg/config/BeNext
copying openzwave/config/BeNext/HeatingControl.xml -> build/bdist.linux-armv7l/egg/config/BeNext
creating build/bdist.linux-armv7l/egg/config/remotec
copying openzwave/config/remotec/zrc-90.xml -> build/bdist.linux-armv7l/egg/config/remotec
copying openzwave/config/remotec/zxt-120.xml -> build/bdist.linux-armv7l/egg/config/remotec
copying openzwave/config/remotec/zts-110.xml -> build/bdist.linux-armv7l/egg/config/remotec
copying openzwave/config/remotec/zfm-80.xml -> build/bdist.linux-armv7l/egg/config/remotec
copying openzwave/config/remotec/zurc.xml -> build/bdist.linux-armv7l/egg/config/remotec
creating build/bdist.linux-armv7l/egg/config/dlink
copying openzwave/config/dlink/dch-z120.xml -> build/bdist.linux-armv7l/egg/config/dlink
copying openzwave/config/dlink/dch-z110.xml -> build/bdist.linux-armv7l/egg/config/dlink
copying openzwave/config/dlink/dch-z510.xml -> build/bdist.linux-armv7l/egg/config/dlink
creating build/bdist.linux-armv7l/egg/config/homeseer
copying openzwave/config/homeseer/ezmotionplus.xml -> build/bdist.linux-armv7l/egg/config/homeseer
copying openzwave/config/homeseer/hsm200.xml -> build/bdist.linux-armv7l/egg/config/homeseer
copying openzwave/config/homeseer/hsm100.xml -> build/bdist.linux-armv7l/egg/config/homeseer
copying openzwave/config/homeseer/ztroller.xml -> build/bdist.linux-armv7l/egg/config/homeseer
creating build/bdist.linux-armv7l/egg/config/rcs
copying openzwave/config/rcs/em52-zw.xml -> build/bdist.linux-armv7l/egg/config/rcs
copying openzwave/config/rcs/therm0005.xml -> build/bdist.linux-armv7l/egg/config/rcs
copying openzwave/config/rcs/therm0007.xml -> build/bdist.linux-armv7l/egg/config/rcs
copying openzwave/config/rcs/therm0009.xml -> build/bdist.linux-armv7l/egg/config/rcs
copying openzwave/config/rcs/pm12-zw.xml -> build/bdist.linux-armv7l/egg/config/rcs
creating build/bdist.linux-armv7l/egg/config/ge
copying openzwave/config/ge/dimmer_module.xml -> build/bdist.linux-armv7l/egg/config/ge
copying openzwave/config/ge/dimmer.xml -> build/bdist.linux-armv7l/egg/config/ge
copying openzwave/config/ge/12724-dimmer.xml -> build/bdist.linux-armv7l/egg/config/ge
copying openzwave/config/ge/relay.xml -> build/bdist.linux-armv7l/egg/config/ge
creating build/bdist.linux-armv7l/egg/config/trane
copying openzwave/config/trane/TZEMT400AB32MAA.xml -> build/bdist.linux-armv7l/egg/config/trane
copying openzwave/config/trane/TZEMT400BB32MAA.xml -> build/bdist.linux-armv7l/egg/config/trane
creating build/bdist.linux-armv7l/egg/config/kwikset
copying openzwave/config/kwikset/smartcode.xml -> build/bdist.linux-armv7l/egg/config/kwikset
creating build/bdist.linux-armv7l/egg/config/intermatic
copying openzwave/config/intermatic/ca8900.xml -> build/bdist.linux-armv7l/egg/config/intermatic
creating build/bdist.linux-armv7l/egg/config/wenzhou
copying openzwave/config/wenzhou/tz66d.xml -> build/bdist.linux-armv7l/egg/config/wenzhou
copying openzwave/config/wenzhou/tz67.xml -> build/bdist.linux-armv7l/egg/config/wenzhou
copying openzwave/config/wenzhou/tz88.xml -> build/bdist.linux-armv7l/egg/config/wenzhou
copying openzwave/config/wenzhou/tz65d.xml -> build/bdist.linux-armv7l/egg/config/wenzhou
copying openzwave/config/wenzhou/sm103.xml -> build/bdist.linux-armv7l/egg/config/wenzhou
copying openzwave/config/wenzhou/tz68.xml -> build/bdist.linux-armv7l/egg/config/wenzhou
copying openzwave/config/wenzhou/tsp01.xml -> build/bdist.linux-armv7l/egg/config/wenzhou
creating build/bdist.linux-armv7l/egg/config/everspringct
copying openzwave/config/everspringct/hsm02.xml -> build/bdist.linux-armv7l/egg/config/everspringct
creating build/bdist.linux-armv7l/egg/config/duwi
copying openzwave/config/duwi/ZWESJ300.xml -> build/bdist.linux-armv7l/egg/config/duwi
copying openzwave/config/duwi/05458.xml -> build/bdist.linux-armv7l/egg/config/duwi
copying openzwave/config/duwi/zwfb.xml -> build/bdist.linux-armv7l/egg/config/duwi
copying openzwave/config/duwi/ZWES1000.xml -> build/bdist.linux-armv7l/egg/config/duwi
creating build/bdist.linux-armv7l/egg/config/2gig
copying openzwave/config/2gig/ct101.xml -> build/bdist.linux-armv7l/egg/config/2gig
copying openzwave/config/2gig/ct50e.xml -> build/bdist.linux-armv7l/egg/config/2gig
copying openzwave/config/2gig/ct30.xml -> build/bdist.linux-armv7l/egg/config/2gig
copying openzwave/config/2gig/ct100.xml -> build/bdist.linux-armv7l/egg/config/2gig
creating build/bdist.linux-armv7l/egg/config/electronicsolutions
copying openzwave/config/electronicsolutions/dbmz.xml -> build/bdist.linux-armv7l/egg/config/electronicsolutions
creating build/bdist.linux-armv7l/egg/config/devolo
copying openzwave/config/devolo/mt02648.xml -> build/bdist.linux-armv7l/egg/config/devolo
creating build/bdist.linux-armv7l/egg/config/iris
copying openzwave/config/iris/rangeextender.xml -> build/bdist.linux-armv7l/egg/config/iris
copying openzwave/config/schlage/BE469NXCEN.xml -> build/bdist.linux-armv7l/egg/config/schlage
creating build/bdist.linux-armv7l/egg/config/swiid
copying openzwave/config/swiid/swiidplug.xml -> build/bdist.linux-armv7l/egg/config/swiid
copying openzwave/config/swiid/swiidinter.xml -> build/bdist.linux-armv7l/egg/config/swiid
creating build/bdist.linux-armv7l/egg/config/sensative
copying openzwave/config/sensative/strips.xml -> build/bdist.linux-armv7l/egg/config/sensative
creating build/bdist.linux-armv7l/egg/config/fakro
copying openzwave/config/fakro/zws12.xml -> build/bdist.linux-armv7l/egg/config/fakro
copying openzwave/config/fakro/zws230.xml -> build/bdist.linux-armv7l/egg/config/fakro
creating build/bdist.linux-armv7l/egg/config/zwave.me
copying openzwave/config/zwave.me/iTemp.xml -> build/bdist.linux-armv7l/egg/config/zwave.me
copying openzwave/config/zwave.me/ZME_06436.xml -> build/bdist.linux-armv7l/egg/config/zwave.me
copying openzwave/config/zwave.me/ZME_05431.xml -> build/bdist.linux-armv7l/egg/config/zwave.me
copying openzwave/config/zwave.me/zweather.xml -> build/bdist.linux-armv7l/egg/config/zwave.me
copying openzwave/config/zwave.me/popp_kfob-c.xml -> build/bdist.linux-armv7l/egg/config/zwave.me
copying openzwave/config/zwave.me/ZME_WCD2.xml -> build/bdist.linux-armv7l/egg/config/zwave.me
copying openzwave/config/zwave.me/ZME_RC2.xml -> build/bdist.linux-armv7l/egg/config/zwave.me
copying openzwave/config/zwave.me/ZME_064435.xml -> build/bdist.linux-armv7l/egg/config/zwave.me
copying openzwave/config/zwave.me/ZME_06433.xml -> build/bdist.linux-armv7l/egg/config/zwave.me
copying openzwave/config/zwave.me/ZME_WALLC-S.xml -> build/bdist.linux-armv7l/egg/config/zwave.me
copying openzwave/config/zwave.me/ZME_KFOB-S.xml -> build/bdist.linux-armv7l/egg/config/zwave.me
copying openzwave/config/zwave.me/kfob.xml -> build/bdist.linux-armv7l/egg/config/zwave.me
creating build/bdist.linux-armv7l/egg/config/enerwave
copying openzwave/config/enerwave/zw500d.xml -> build/bdist.linux-armv7l/egg/config/enerwave
copying openzwave/config/enerwave/zwn-bpc.xml -> build/bdist.linux-armv7l/egg/config/enerwave
copying openzwave/config/enerwave/zw15s.xml -> build/bdist.linux-armv7l/egg/config/enerwave
copying openzwave/config/enerwave/zwn-sc7.xml -> build/bdist.linux-armv7l/egg/config/enerwave
copying openzwave/config/enerwave/zw20rm.xml -> build/bdist.linux-armv7l/egg/config/enerwave
copying openzwave/config/enerwave/zw20r.xml -> build/bdist.linux-armv7l/egg/config/enerwave
creating build/bdist.linux-armv7l/egg/config/stelpro
copying openzwave/config/stelpro/stzw402.xml -> build/bdist.linux-armv7l/egg/config/stelpro
creating build/bdist.linux-armv7l/egg/config/act
copying openzwave/config/act/zrw103.xml -> build/bdist.linux-armv7l/egg/config/act
copying openzwave/config/act/zdw232.xml -> build/bdist.linux-armv7l/egg/config/act
copying openzwave/config/act/zdw103.xml -> build/bdist.linux-armv7l/egg/config/act
copying openzwave/config/act/zrp110.xml -> build/bdist.linux-armv7l/egg/config/act
copying openzwave/config/act/zdm230.xml -> build/bdist.linux-armv7l/egg/config/act
copying openzwave/config/act/zir010.xml -> build/bdist.linux-armv7l/egg/config/act
copying openzwave/config/act/lfm20.xml -> build/bdist.linux-armv7l/egg/config/act
creating build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHLAx.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHJD1.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHCA2.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHTDx.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHCDx.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHAA2.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHSDx.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHNDx.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHIDx.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHZDx.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHADx.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHODx.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHBA2.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHDDx.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHDA2.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHBDx.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHJA2.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHIA2.xml -> build/bdist.linux-armv7l/egg/config/qubino
copying openzwave/config/qubino/ZMNHUD1.xml -> build/bdist.linux-armv7l/egg/config/qubino
creating build/bdist.linux-armv7l/egg/config/widom
copying openzwave/config/widom/UME304C_S.xml -> build/bdist.linux-armv7l/egg/config/widom
copying openzwave/config/widom/UBS104.xml -> build/bdist.linux-armv7l/egg/config/widom
creating build/bdist.linux-armv7l/egg/config/linear
copying openzwave/config/linear/WD500Z-1.xml -> build/bdist.linux-armv7l/egg/config/linear
copying openzwave/config/linear/PD300Z-2.xml -> build/bdist.linux-armv7l/egg/config/linear
creating build/bdist.linux-armv7l/egg/config/danfoss
copying openzwave/config/danfoss/living.xml -> build/bdist.linux-armv7l/egg/config/danfoss
copying openzwave/config/danfoss/rsroom.xml -> build/bdist.linux-armv7l/egg/config/danfoss
copying openzwave/config/danfoss/z.xml -> build/bdist.linux-armv7l/egg/config/danfoss
creating build/bdist.linux-armv7l/egg/config/philio
copying openzwave/config/philio/pse02.xml -> build/bdist.linux-armv7l/egg/config/philio
copying openzwave/config/philio/pst02.xml -> build/bdist.linux-armv7l/egg/config/philio
copying openzwave/config/philio/psr04.xml -> build/bdist.linux-armv7l/egg/config/philio
copying openzwave/config/philio/pst02-1c.xml -> build/bdist.linux-armv7l/egg/config/philio
copying openzwave/config/philio/pan03.xml -> build/bdist.linux-armv7l/egg/config/philio
copying openzwave/config/philio/pst02-b.xml -> build/bdist.linux-armv7l/egg/config/philio
copying openzwave/config/philio/phpat02.xml -> build/bdist.linux-armv7l/egg/config/philio
copying openzwave/config/philio/pan04.xml -> build/bdist.linux-armv7l/egg/config/philio
copying openzwave/config/philio/pan08.xml -> build/bdist.linux-armv7l/egg/config/philio
copying openzwave/config/philio/psm02.xml -> build/bdist.linux-armv7l/egg/config/philio
copying openzwave/config/philio/phpsg01.xml -> build/bdist.linux-armv7l/egg/config/philio
creating build/bdist.linux-armv7l/egg/config/vision
copying openzwave/config/vision/zm1602eu.xml -> build/bdist.linux-armv7l/egg/config/vision
copying openzwave/config/vision/zp3111.xml -> build/bdist.linux-armv7l/egg/config/vision
copying openzwave/config/vision/zg8101.xml -> build/bdist.linux-armv7l/egg/config/vision
copying openzwave/config/vision/zs5101eu.xml -> build/bdist.linux-armv7l/egg/config/vision
copying openzwave/config/vision/zp3102.xml -> build/bdist.linux-armv7l/egg/config/vision
copying openzwave/config/vision/zd2201.xml -> build/bdist.linux-armv7l/egg/config/vision
copying openzwave/config/vision/zd2102.xml -> build/bdist.linux-armv7l/egg/config/vision
copying openzwave/config/vision/zm1601eu5.xml -> build/bdist.linux-armv7l/egg/config/vision
copying openzwave/config/zwcfg.xsd -> build/bdist.linux-armv7l/egg/config
copying openzwave/config/manufacturer_specific.xsd -> build/bdist.linux-armv7l/egg/config
copying openzwave/config/device_configuration.xsd -> build/bdist.linux-armv7l/egg/config
copying openzwave/config/options.xsd -> build/bdist.linux-armv7l/egg/config
creating build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/not-zip-safe -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/requires.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
writing build/bdist.linux-armv7l/egg/EGG-INFO/native_libs.txt
creating dist
creating 'dist/libopenzwave-0.3.0-py2.7-linux-armv7l.egg' and adding 'build/bdist.linux-armv7l/egg' to it
removing 'build/bdist.linux-armv7l/egg' (and everything under it)
Processing libopenzwave-0.3.0-py2.7-linux-armv7l.egg
creating /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.0-py2.7-linux-armv7l.egg
Extracting libopenzwave-0.3.0-py2.7-linux-armv7l.egg to /usr/local/lib/python2.7/dist-packages
Adding libopenzwave 0.3.0 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.0-py2.7-linux-armv7l.egg
Processing dependencies for libopenzwave==0.3.0
Searching for six==1.8.0
Best match: six 1.8.0
six 1.8.0 is already the active version in easy-install.pth
Using /usr/lib/python2.7/dist-packages
Finished processing dependencies for libopenzwave==0.3.0
Installation of lib finished.
python setup-api.py install
running install
running bdist_egg
running egg_info
creating src-api/openzwave.egg-info
writing requirements to src-api/openzwave.egg-info/requires.txt
writing src-api/openzwave.egg-info/PKG-INFO
writing top-level names to src-api/openzwave.egg-info/top_level.txt
writing dependency_links to src-api/openzwave.egg-info/dependency_links.txt
writing manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
reading manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
running install_lib
running build_py
creating build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/value.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/scene.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/network.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/command.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/group.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/singleton.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/option.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/controller.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/node.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/object.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/__init__.py -> build/lib.linux-armv7l-2.7/openzwave
creating build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/value.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/scene.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/network.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/command.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/group.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/singleton.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/option.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/controller.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/node.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/object.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/__init__.py -> build/bdist.linux-armv7l/egg/openzwave
byte-compiling build/bdist.linux-armv7l/egg/openzwave/value.py to value.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/scene.py to scene.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/network.py to network.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/command.py to command.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/group.py to group.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/singleton.py to singleton.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/option.py to option.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/controller.py to controller.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/node.py to node.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/object.py to object.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/__init__.py to __init__.pyc
copying src-api/openzwave.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/not-zip-safe -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/requires.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
creating 'dist/openzwave-0.3.0-py2.7.egg' and adding 'build/bdist.linux-armv7l/egg' to it
Processing openzwave-0.3.0-py2.7.egg
creating /usr/local/lib/python2.7/dist-packages/openzwave-0.3.0-py2.7.egg
Extracting openzwave-0.3.0-py2.7.egg to /usr/local/lib/python2.7/dist-packages
Adding openzwave 0.3.0 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/openzwave-0.3.0-py2.7.egg
Processing dependencies for openzwave==0.3.0
Searching for libopenzwave==0.3.0
Best match: libopenzwave 0.3.0
libopenzwave 0.3.0 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.0-py2.7-linux-armv7l.egg
Searching for Louie==1.1
Best match: Louie 1.1
Louie 1.1 is already the active version in easy-install.pth
Searching for nose==1.3.4
Best match: nose 1.3.4
nose 1.3.4 is already the active version in easy-install.pth
Installing nosetests script to /usr/local/bin
Installing nosetests-2.7 script to /usr/local/bin
Finished processing dependencies for openzwave==0.3.0
Installation of API finished.
sed: can't read /etc/inittab: No such file or directory
Everything is successfully installed!
