Plugin OpenZwave
Re: Plugin OpenZwave [version BETA à vos risques et périls]
Pour l'include core tu peux le laisser par contre faut enlever le isConnect et authentification oui (sinon seule l'installation et la mise a jour unitaire fonctionne)
bonjour l equipe
je viens d installer le plugin
cependant comment le configurer , j ai bien renseigner le port USB correspondant a ma clé USB mais que faire apres
voici mon log
cordialement
voici mon log
Openzwave is installed.
***** Waiting for network to become ready :
.Hello from network : I'm started : homeid 014d0cc7 - 1 nodes were found.
.........Openzwave is installed.
..........Exception AttributeError: "'ZWaveNetwork' object has no attribute 'STATE_RESET'" in 'libopenzwave.notif_callback' ignored
File "/usr/share/nginx/www/jeedom/plugins/openzwave/ressources/zwaveserver/rest-server.py", line 653, in <module>
app.run(host='0.0.0.0',port=8083,debug = False)
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 772, in run
run_simple(host, port, self, **options)
File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 710, in run_simple
inner()
File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 692, in inner
passthrough_errors, ssl_context).serve_forever()
File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 486, in make_server
File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 410, in __init__
HTTPServer.__init__(self, (host, int(port)), handler)
File "/usr/lib/python2.7/SocketServer.py", line 419, in __init__
self.server_bind()
File "/usr/lib/python2.7/BaseHTTPServer.py", line 108, in server_bind
SocketServer.TCPServer.server_bind(self)
File "/usr/lib/python2.7/SocketServer.py", line 430, in server_bind
self.socket.bind(self.server_address)
File "/usr/lib/python2.7/socket.py", line 224, in meth
return getattr(self._sock,name)(*args)
socket.error: [Errno 98] Address already in use
Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored
Hello from network : I'm ready : 0 nodes were found.
Hello from network : my controller is : home_id: [0x014d0cc7] id: [1] name: [] product: [Z-Stick S2] capabilities: set(['primaryController', 'staticUpdateController']) library: [Static Controller version Z-Wave 2.78]
SQLite version: 3.7.13
You killed Openzwave-server!
..........SQLite version: 3.7.13
Exception happened during processing of request from ('127.0.0.1', 53367)
File "/usr/lib/python2.7/SocketServer.py", line 295, in _handle_request_noblock
self.process_request(request, client_address)
File "/usr/lib/python2.7/SocketServer.py", line 321, in process_request
self.finish_request(request, client_address)
File "/usr/lib/python2.7/SocketServer.py", line 334, in finish_request
self.RequestHandlerClass(request, client_address, self)
File "/usr/lib/python2.7/SocketServer.py", line 651, in __init__
self.finish()
File "/usr/lib/python2.7/SocketServer.py", line 704, in finish
self.wfile.flush()
File "/usr/lib/python2.7/socket.py", line 303, in flush
self._sock.sendall(view[write_offset:write_offset+buffer_size])
error: [Errno 32] Broken pipe
inner()
File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 436, in serve_forever
HTTPServer.serve_forever(self)
File "/usr/lib/python2.7/SocketServer.py", line 236, in serve_forever
poll_interval)
File "/usr/lib/python2.7/SocketServer.py", line 155, in _eintr_retry
return func(*args)
File "/usr/share/nginx/www/jeedom/plugins/openzwave/ressources/zwaveserver/rest-server.py", line 55, in signal_handler
network.stop()
File "/usr/local/lib/python2.7/dist-packages/python_openzwave_api-0.2.6-py2.7.egg/openzwave/network.py", line 321, in stop
if self.controller.send_queue_count <= 0:
File "/usr/local/lib/python2.7/dist-packages/python_openzwave_api-0.2.6-py2.7.egg/openzwave/controller.py", line 401, in send_queue_count
return self._network.manager.getSendQueueCount(self.home_id)
File "libopenzwave.pyx", line 926, in libopenzwave.PyManager.getSendQueueCount (lib/libopenzwave.cpp:5753)
TypeError: an integer is required
..Hello from network : I'm started : homeid 014d0cc7 - 1 nodes were found.
........Traceback (most recent call last):
inner()
self.server_bind()
Hello from network : I'm ready : 2 nodes were found.
Plugins Jeedom :
- Plugin 1-Wire
- Plugin GPIO
- Plugin 1-Wire
- Plugin GPIO
@tmartinez :
Voici le message de mise à jour :
Je ne sais pas si c'est bon signe par contre la version du plugin reste à l'identique on dirait.
***************Mise à jour des plugins***************
Début de la mise de : openzwave
Téléchargement de l'objet...OK
Décompression de l'archive...OK
Installation de l'objet...OK
sh: 1: kill: No such process
***************Mise à jour des plugins réussie***************
[END UPDATE SUCCESS]
Vm vbox Jeedom + 1 rpi2 razberry/rfxcom/sms déporté + 1 rpib+ rfxcom/1wire déporté.
30 modules zwave, 9 sondes 1wire, 13 modules chacon, 12 volets ematronic, Karotz, 5 squeezebox, 1 rpi squeezeplug, 2 nas n40l, etc.
Salut, la clé semble bien installée et un objet zwave est déjà associé.mickeys a écrit :bonjour l equipe
voici mon log
cordialementCode : Tout sélectionner
Openzwave is installed. ***** Waiting for network to become ready : .Hello from network : I'm started : homeid 014d0cc7 - 1 nodes were found. .........Openzwave is installed. ***** Waiting for network to become ready : ..........Exception AttributeError: "'ZWaveNetwork' object has no attribute 'STATE_RESET'" in 'libopenzwave.notif_callback' ignored Exception AttributeError: "'ZWaveNetwork' object has no attribute 'STATE_RESET'" in 'libopenzwave.notif_callback' ignored Traceback (most recent call last): File "/usr/share/nginx/www/jeedom/plugins/openzwave/ressources/zwaveserver/rest-server.py", line 653, in <module> app.run(host='0.0.0.0',port=8083,debug = False) File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 772, in run run_simple(host, port, self, **options) File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 710, in run_simple inner() File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 692, in inner passthrough_errors, ssl_context).serve_forever() File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 486, in make_server passthrough_errors, ssl_context) File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 410, in __init__ HTTPServer.__init__(self, (host, int(port)), handler) File "/usr/lib/python2.7/SocketServer.py", line 419, in __init__ self.server_bind() File "/usr/lib/python2.7/BaseHTTPServer.py", line 108, in server_bind SocketServer.TCPServer.server_bind(self) File "/usr/lib/python2.7/SocketServer.py", line 430, in server_bind self.socket.bind(self.server_address) File "/usr/lib/python2.7/socket.py", line 224, in meth return getattr(self._sock,name)(*args) socket.error: [Errno 98] Address already in use Exception AttributeError: "'ZWaveNetwork' object has no attribute 'STATE_RESET'" in 'libopenzwave.notif_callback' ignored Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored Hello from network : I'm ready : 0 nodes were found. Hello from network : my controller is : home_id: [0x014d0cc7] id: [1] name: [] product: [Z-Stick S2] capabilities: set(['primaryController', 'staticUpdateController']) library: [Static Controller version Z-Wave 2.78] SQLite version: 3.7.13 You killed Openzwave-server! Openzwave is installed. ***** Waiting for network to become ready : ..........SQLite version: 3.7.13 ---------------------------------------- Exception happened during processing of request from ('127.0.0.1', 53367) Traceback (most recent call last): File "/usr/lib/python2.7/SocketServer.py", line 295, in _handle_request_noblock self.process_request(request, client_address) File "/usr/lib/python2.7/SocketServer.py", line 321, in process_request self.finish_request(request, client_address) File "/usr/lib/python2.7/SocketServer.py", line 334, in finish_request self.RequestHandlerClass(request, client_address, self) File "/usr/lib/python2.7/SocketServer.py", line 651, in __init__ self.finish() File "/usr/lib/python2.7/SocketServer.py", line 704, in finish self.wfile.flush() File "/usr/lib/python2.7/socket.py", line 303, in flush self._sock.sendall(view[write_offset:write_offset+buffer_size]) error: [Errno 32] Broken pipe ---------------------------------------- Traceback (most recent call last): File "/usr/share/nginx/www/jeedom/plugins/openzwave/ressources/zwaveserver/rest-server.py", line 653, in <module> app.run(host='0.0.0.0',port=8083,debug = False) File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 772, in run run_simple(host, port, self, **options) File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 710, in run_simple inner() File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 692, in inner passthrough_errors, ssl_context).serve_forever() File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 436, in serve_forever HTTPServer.serve_forever(self) File "/usr/lib/python2.7/SocketServer.py", line 236, in serve_forever poll_interval) File "/usr/lib/python2.7/SocketServer.py", line 155, in _eintr_retry return func(*args) File "/usr/share/nginx/www/jeedom/plugins/openzwave/ressources/zwaveserver/rest-server.py", line 55, in signal_handler network.stop() File "/usr/local/lib/python2.7/dist-packages/python_openzwave_api-0.2.6-py2.7.egg/openzwave/network.py", line 321, in stop if self.controller.send_queue_count <= 0: File "/usr/local/lib/python2.7/dist-packages/python_openzwave_api-0.2.6-py2.7.egg/openzwave/controller.py", line 401, in send_queue_count return self._network.manager.getSendQueueCount(self.home_id) File "libopenzwave.pyx", line 926, in libopenzwave.PyManager.getSendQueueCount (lib/libopenzwave.cpp:5753) TypeError: an integer is required Openzwave is installed. ***** Waiting for network to become ready : .Hello from network : I'm started : homeid 014d0cc7 - 1 nodes were found. .........Openzwave is installed. ***** Waiting for network to become ready : ..Hello from network : I'm started : homeid 014d0cc7 - 1 nodes were found. ........Traceback (most recent call last): File "/usr/share/nginx/www/jeedom/plugins/openzwave/ressources/zwaveserver/rest-server.py", line 653, in <module> app.run(host='0.0.0.0',port=8083,debug = False) File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 772, in run run_simple(host, port, self, **options) File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 710, in run_simple inner() File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 692, in inner passthrough_errors, ssl_context).serve_forever() File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 486, in make_server passthrough_errors, ssl_context) File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 410, in __init__ HTTPServer.__init__(self, (host, int(port)), handler) File "/usr/lib/python2.7/SocketServer.py", line 419, in __init__ self.server_bind() File "/usr/lib/python2.7/BaseHTTPServer.py", line 108, in server_bind SocketServer.TCPServer.server_bind(self) File "/usr/lib/python2.7/SocketServer.py", line 430, in server_bind self.socket.bind(self.server_address) File "/usr/lib/python2.7/socket.py", line 224, in meth return getattr(self._sock,name)(*args) socket.error: [Errno 98] Address already in use Hello from network : I'm ready : 2 nodes were found. Hello from network : my controller is : home_id: [0x014d0cc7] id: [1] name: [] product: [Z-Stick S2] capabilities: set(['primaryController', 'staticUpdateController']) library: [Static Controller version Z-Wave 2.78]
Par contre les logs disent que l'adresse est déjà utilisée, as-tu installé Z-way ? car si c'est le cas il faut le désinstaller, mon plugin émule Z-way et utilise donc le même port.
Peux-tu vérifier que tu n'aies plus les messages d'erreur dans les logs ?alexzen a écrit :@tmartinez :
Je ne sais pas si c'est bon signe par contre la version du plugin reste à l'identique on dirait.Code : Tout sélectionner
***************Mise à jour des plugins*************** Début de la mise de : openzwave Téléchargement de l'objet...OK Décompression de l'archive...OK Installation de l'objet...OK sh: 1: kill: No such process ***************Mise à jour des plugins réussie*************** [END UPDATE SUCCESS]
touché je le désinstalle !!!
C est marqué d installer Zwave lors de l installation de openZwave
Plugins Jeedom :
- Plugin 1-Wire
- Plugin GPIO
- Plugin 1-Wire
- Plugin GPIO
ok j ai supprimé le module.
Le dernier log se trouve en haut ou en bas ?
Si c est en bas alors j ai toujours le problème ,même après avoir désactivé puis activé le demon
le module associé a la clé est le ZXT-120
inner()
self.server_bind()
self.finish()
self.wfile.flush()
inner()
poll_interval)
return func(*args)
network.stop()
inner()
self.server_bind()
Plugins Jeedom :
- Plugin 1-Wire
- Plugin GPIO
- Plugin 1-Wire
- Plugin GPIO
tu as supprimé le plugin Zwave ou le serveur Z-way ?
Le plugin z-wave est nécessaire, toute la config se fait dedans. C'est le serveur z-way qu'il faut supprimer.
il ne propose pas de nouvelle mise à jour ...
et j'ai beau attendre je n'ai jamais dans mon interface la validation fonctionnelle de mon réseau :
.Hello from network : I'm started : homeid 0161e0d2 - 1 nodes were found.
Hello from network : I'm ready : 5 nodes were found.
Hello from network : my controller is : home_id: [0x0161e0d2] id: [1] name: [] product: [Z-Stick S2] capabilities: set(['primaryController', 'staticUpdateController']) library: [Static Controller version Z-2.78]
Pour supprimer proprement Z-Way, les commandes sont normalement les suivantes :mickeys a écrit :ok j ai supprimé le module.
Openzwave is installed. ***** Waiting for network to become ready : .Hello from network : I'm started : homeid 014d0cc7 - 1 nodes were found. .........Openzwave is installed. ***** Waiting for network to become ready : ..........Exception AttributeError: "'ZWaveNetwork' object has no attribute 'STATE_RESET'" in 'libopenzwave.notif_callback' ignored Exception AttributeError: "'ZWaveNetwork' object has no attribute 'STATE_RESET'" in 'libopenzwave.notif_callback' ignored Traceback (most recent call last): File "/usr/share/nginx/www/jeedom/plugins/openzwave/ressources/zwaveserver/rest-server.py", line 653, in <module> app.run(host='0.0.0.0',port=8083,debug = False) File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 772, in run run_simple(host, port, self, **options) File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 710, in run_simple inner() File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 692, in inner passthrough_errors, ssl_context).serve_forever() File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 486, in make_server passthrough_errors, ssl_context) File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 410, in __init__ HTTPServer.__init__(self, (host, int(port)), handler) File "/usr/lib/python2.7/SocketServer.py", line 419, in __init__ self.server_bind() File "/usr/lib/python2.7/BaseHTTPServer.py", line 108, in server_bind SocketServer.TCPServer.server_bind(self) File "/usr/lib/python2.7/SocketServer.py", line 430, in server_bind self.socket.bind(self.server_address) File "/usr/lib/python2.7/socket.py", line 224, in meth return getattr(self._sock,name)(*args) socket.error: [Errno 98] Address already in use Exception AttributeError: "'ZWaveNetwork' object has no attribute 'STATE_RESET'" in 'libopenzwave.notif_callback' ignored Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored Exception KeyError: (7,) in 'libopenzwave.notif_callback' ignored Hello from network : I'm ready : 0 nodes were found. Hello from network : my controller is : home_id: [0x014d0cc7] id: [1] name: [] product: [Z-Stick S2] capabilities: set(['primaryController', 'staticUpdateController']) library: [Static Controller version Z-Wave 2.78] SQLite version: 3.7.13 You killed Openzwave-server! Openzwave is installed. ***** Waiting for network to become ready : ..........SQLite version: 3.7.13 ---------------------------------------- Exception happened during processing of request from ('127.0.0.1', 53367) Traceback (most recent call last): File "/usr/lib/python2.7/SocketServer.py", line 295, in _handle_request_noblock self.process_request(request, client_address) File "/usr/lib/python2.7/SocketServer.py", line 321, in process_request self.finish_request(request, client_address) File "/usr/lib/python2.7/SocketServer.py", line 334, in finish_request self.RequestHandlerClass(request, client_address, self) File "/usr/lib/python2.7/SocketServer.py", line 651, in __init__ self.finish() File "/usr/lib/python2.7/SocketServer.py", line 704, in finish self.wfile.flush() File "/usr/lib/python2.7/socket.py", line 303, in flush self._sock.sendall(view[write_offset:write_offset+buffer_size]) error: [Errno 32] Broken pipe ---------------------------------------- Traceback (most recent call last): File "/usr/share/nginx/www/jeedom/plugins/openzwave/ressources/zwaveserver/rest-server.py", line 653, in <module> app.run(host='0.0.0.0',port=8083,debug = False) File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 772, in run run_simple(host, port, self, **options) File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 710, in run_simple inner() File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 692, in inner passthrough_errors, ssl_context).serve_forever() File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 436, in serve_forever HTTPServer.serve_forever(self) File "/usr/lib/python2.7/SocketServer.py", line 236, in serve_forever poll_interval) File "/usr/lib/python2.7/SocketServer.py", line 155, in _eintr_retry return func(*args) File "/usr/share/nginx/www/jeedom/plugins/openzwave/ressources/zwaveserver/rest-server.py", line 55, in signal_handler network.stop() File "/usr/local/lib/python2.7/dist-packages/python_openzwave_api-0.2.6-py2.7.egg/openzwave/network.py", line 321, in stop if self.controller.send_queue_count <= 0: File "/usr/local/lib/python2.7/dist-packages/python_openzwave_api-0.2.6-py2.7.egg/openzwave/controller.py", line 401, in send_queue_count return self._network.manager.getSendQueueCount(self.home_id) File "libopenzwave.pyx", line 926, in libopenzwave.PyManager.getSendQueueCount (lib/libopenzwave.cpp:5753) TypeError: an integer is required Openzwave is installed. ***** Waiting for network to become ready : .Hello from network : I'm started : homeid 014d0cc7 - 1 nodes were found. .........Openzwave is installed. ***** Waiting for network to become ready : ..Hello from network : I'm started : homeid 014d0cc7 - 1 nodes were found. ........Traceback (most recent call last): File "/usr/share/nginx/www/jeedom/plugins/openzwave/ressources/zwaveserver/rest-server.py", line 653, in <module> app.run(host='0.0.0.0',port=8083,debug = False) File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 772, in run run_simple(host, port, self, **options) File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 710, in run_simple inner() File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 692, in inner passthrough_errors, ssl_context).serve_forever() File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 486, in make_server passthrough_errors, ssl_context) File "/usr/local/lib/python2.7/dist-packages/werkzeug/serving.py", line 410, in __init__ HTTPServer.__init__(self, (host, int(port)), handler) File "/usr/lib/python2.7/SocketServer.py", line 419, in __init__ self.server_bind() File "/usr/lib/python2.7/BaseHTTPServer.py", line 108, in server_bind SocketServer.TCPServer.server_bind(self) File "/usr/lib/python2.7/SocketServer.py", line 430, in server_bind self.socket.bind(self.server_address) File "/usr/lib/python2.7/socket.py", line 224, in meth return getattr(self._sock,name)(*args) socket.error: [Errno 98] Address already in use Hello from network : I'm ready : 2 nodes were found. Hello from network : my controller is : home_id: [0x014d0cc7] id: [1] name: [] product: [Z-Stick S2] capabilities: set(['primaryController', 'staticUpdateController']) library: [Static Controller version Z-Wave 2.78] You killed Openzwave-server!
sudo /etc/init.d/z-way-server stop
sudo /etc/init.d/mongoose stop
sudo update-rc.d -f z-way-server remove
sudo update-rc.d -f mongoose remove
sudo rm -Rf /opt/z-way-server
sudo rm /etc/init.d/z-way-server
sudo rm /etc/init.d/mongoose
j ai supprimer le plugin zwave
je dois donc supprimer le serveur Z-way via ssh ?
Plugins Jeedom :
- Plugin 1-Wire
- Plugin GPIO
- Plugin 1-Wire
- Plugin GPIO
Là il n'y a plus de message d'erreur, le reseau z-wave démarre normalement, les retours d'état ne sont toujours pas ok ?alexzen a écrit :il ne propose pas de nouvelle mise à jour ...
***** Waiting for network to become ready : .Hello from network : I'm started : homeid 0161e0d2 - 1 nodes were found. .........SQLite version: 3.7.13 Hello from network : I'm ready : 5 nodes were found. Hello from network : my controller is : home_id: [0x0161e0d2] id: [1] name: [] product: [Z-Stick S2] capabilities: set(['primaryController', 'staticUpdateController']) library: [Static Controller version Z-2.78]
Oui tu peux réinstaller le plugin zwave par contre tu ne lances pas la commande "wget -q -O - jeedom.fr/ressources/z-way/install.sh | sudo bash" à la fin.mickeys a écrit :j ai supprimer le plugin zwave
En ssh, tu peux taper les commandes pour supprimer le serveur z-way.
J ai supprimer z-way et reinstaller zwave plugin sans ajouter le serveur
voici le nouveau log
inner()
self.server_bind()
self.finish()
self.wfile.flush()
inner()
poll_interval)
return func(*args)
network.stop()
inner()
self.server_bind()
.................Traceback (most recent call last):
inner()
self.server_bind()
inner()
self.server_bind()
Plugins Jeedom :
- Plugin 1-Wire
- Plugin GPIO
- Plugin 1-Wire
- Plugin GPIO
L'adresse est déjà utilisée
Quel est l adresse ?
je peux peut être trouver ce qui utilise cette adresse avec la commande lsof
Plugins Jeedom :
- Plugin 1-Wire
- Plugin GPIO
- Plugin 1-Wire
- Plugin GPIO
@tmartinez : je n'ai tjs aucun retour d'état ... que ce soit sur les fgd ou les wallplugs. Pire j'ai toujours des ordres qui passent une fois sur deux.
bizarre qd même
pour tester ma clé, est ce que tu penses que je peux mettre sur jeedom sur mon rpi avec la clé et récupérer la config via le jeedom de ma vm ?
bizarre qd même
Le port est le 8083mickeys a écrit :L'adresse est déjà utilisée
Envoyé de mon iPhone à l'aide de Tapatalk
Penses-tu que tu peux m'ouvrir temporairement l'accès à ta machine ?alexzen a écrit :@tmartinez : je n'ai tjs aucun retour d'état ... que ce soit sur les fgd ou les wallplugs. Pire j'ai toujours des ordres qui passent une fois sur deux.
bizarre qd même
Bien sur
Envoyé eud min niphone avec tartetalk.
tmartinez a écrit :Le port est le 8083mickeys a écrit :L'adresse est déjà utilisée
root@raspberrypi:/etc/z-way# lsof -i :8083
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
python 15475 www-data 7u IPv4 4452918 0t0 TCP *:8083 (LISTEN)
Plugins Jeedom :
- Plugin 1-Wire
- Plugin GPIO
- Plugin 1-Wire
- Plugin GPIO
