Nouveau plugin zwave/openzwave
Re: Nouveau plugin zwave/openzwave
Bon j'essaie de remettre la razerry sur le cubie
J'ai desinstallé le plugin, desactiver le plugin sur le slave, reinstallé le plugin sur le cubie et la j'ai cette erreur :
Lancement de l'installation/mise à jour des dépendances openzwave
Stopping system nodejs Daemon:
Get:1 http://security.debian.org wheezy/updates Release.gpg [1554 B]
Get:2 http://repo.ajenti.org main Release.gpg [473 B]
Hit http://ftp.debian.org wheezy Release.gpg
Get:3 http://security.debian.org wheezy/updates Release [102 kB]
Get:4 http://repo.ajenti.org main Release [11.1 kB]
Hit http://packages.cubian.org wheezy Release.gpg
Get:5 http://repo.ajenti.org main/main armhf Packages [6481 B]
Get:6 http://repo.ajenti.org main/debian armhf Packages [1468 B]
Hit http://ftp.debian.org wheezy/main Sources
Hit http://ftp.debian.org wheezy/contrib Sources
Get:7 http://security.debian.org wheezy/updates/main armhf Packages [311 kB]
Hit http://packages.cubian.org wheezy/main armhf Packages
Hit http://ftp.debian.org wheezy/non-free Sources
Hit http://packages.cubian.org wheezy/non-free armhf Packages
Hit http://ftp.debian.org wheezy/main armhf Packages
Hit http://packages.cubian.org wheezy/main Translation-en
Hit http://ftp.debian.org wheezy/contrib armhf Packages
Hit http://packages.cubian.org wheezy/main Translation-en_US
Hit http://packages.cubian.org wheezy/non-free Translation-en
Hit http://ftp.debian.org wheezy/non-free armhf Packages
Hit http://packages.cubian.org wheezy/non-free Translation-en_US
Hit http://ftp.debian.org wheezy/contrib Translation-en
Hit http://ftp.debian.org wheezy/main Translation-en
Hit http://ftp.debian.org wheezy/non-free Translation-en
Get:8 http://security.debian.org wheezy/updates/contrib armhf Packages [14 B]
Get:9 http://security.debian.org wheezy/updates/non-free armhf Packages [14 B]
Get:10 http://security.debian.org wheezy/updates/contrib Translation-en [523 B]
Get:11 http://security.debian.org wheezy/updates/main Translation-en [183 kB]
Get:12 http://security.debian.org wheezy/updates/non-free Translation-en [14 B]
Ign http://repo.ajenti.org main/debian Translation-en
Ign http://repo.ajenti.org main/debian Translation-en_US
Ign http://repo.ajenti.org main/main Translation-en
Ign http://repo.ajenti.org main/main Translation-en_US
Fetched 618 kB in 28s (21.6 kB/s)
Reading package lists...
W: There is no public key available for the following key IDs:
7638D0442B90D010
9D6D8F6BC857C906
Installation des dependances
Building dependency tree...
Reading state information...
python-setuptools is already the newest version.
g++ is already the newest version.
gcc is already the newest version.
git is already the newest version.
python-louie is already the newest version.
python-lxml is already the newest version.
make is already the newest version.
mercurial is already the newest version.
python-pip is already the newest version.
python-sphinx is already the newest version.
libudev-dev is already the newest version.
unzip is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 93 not upgraded.
Installation des dependances Python
Requirement already satisfied (use --upgrade to upgrade): sphinxcontrib-blockdiag in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied (use --upgrade to upgrade): blockdiag>=1.5.0 in /usr/local/lib/python2.7/dist-packages (from sphinxcontrib-blockdiag)
Requirement already satisfied (use --upgrade to upgrade): Sphinx>=0.6 in /usr/lib/pymodules/python2.7 (from sphinxcontrib-blockdiag)
Requirement already satisfied (use --upgrade to upgrade): distribute in /usr/lib/python2.7/dist-packages (from blockdiag>=1.5.0->sphinxcontrib-blockdiag)
Requirement already satisfied (use --upgrade to upgrade): funcparserlib in /usr/local/lib/python2.7/dist-packages (from blockdiag>=1.5.0->sphinxcontrib-blockdiag)
Downloading/unpacking Pillow (from blockdiag>=1.5.0->sphinxcontrib-blockdiag)
Running setup.py egg_info for package Pillow
Downloading/unpacking webcolors (from blockdiag>=1.5.0->sphinxcontrib-blockdiag)
Downloading webcolors-1.5.tar.gz
Running setup.py egg_info for package webcolors
Requirement already satisfied (use --upgrade to upgrade): Pygments>=1.2 in /usr/lib/python2.7/dist-packages (from Sphinx>=0.6->sphinxcontrib-blockdiag)
Requirement already satisfied (use --upgrade to upgrade): Jinja2>=2.3 in /usr/lib/python2.7/dist-packages (from Sphinx>=0.6->sphinxcontrib-blockdiag)
Requirement already satisfied (use --upgrade to upgrade): docutils>=0.7 in /usr/lib/pymodules/python2.7 (from Sphinx>=0.6->sphinxcontrib-blockdiag)
Installing collected packages: Pillow, webcolors
Running setup.py install for Pillow
File "<string>", line 1, in <module>
File "/usr/share/nginx/www/jeedom/plugins/openzwave/core/ajax/build/Pillow/setup.py", line 767, in <module>
zip_safe=not debug_build(),
File "/usr/lib/python2.7/distutils/core.py", line 152, in setup
dist.run_commands()
File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
self.run_command(cmd)
File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
cmd_obj.run()
File "/usr/lib/python2.7/dist-packages/setuptools/command/install.py", line 53, in run
return _install.run(self)
File "/usr/lib/python2.7/distutils/command/install.py", line 601, in run
self.run_command('build')
File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/lib/python2.7/distutils/command/build.py", line 128, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/usr/lib/python2.7/distutils/command/build_ext.py", line 339, in run
self.build_extensions()
File "/usr/share/nginx/www/jeedom/plugins/openzwave/core/ajax/build/Pillow/setup.py", line 515, in build_extensions
% (f, f))
ValueError: --enable-jpeg requested but jpeg not found, aborting.
Complete output from command /usr/bin/python -c "import setuptools;__file__='/usr/share/nginx/www/jeedom/plugins/openzwave/core/ajax/build/Pillow/setup.py';exec(compile(open(__file__).read().replace('
'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-aAIGK_-record/install-record.txt:
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-2.7
creating build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageTransform.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/TiffImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/PdfImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/Hdf5StubImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageOps.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/OleFileIO.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/CurImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/XbmImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/PaletteFile.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/IcnsImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/PalmImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/PsdImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/GimpPaletteFile.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/WebPImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageFile.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageTk.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageMode.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageFilter.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageDraw.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImtImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageDraw2.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/BdfFontFile.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/FitsStubImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageChops.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/TiffTags.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/XVThumbImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/SunImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/PixarImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageEnhance.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/GbrImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/TgaImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/PpmImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/EpsImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageMath.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/__init__.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageCms.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageStat.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/GimpGradientFile.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/PngImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/PyAccess.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/JpegPresets.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/SgiImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/DcxImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/FpxImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/FliImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImagePath.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ContainerIO.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/XpmImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageGrab.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/_util.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/GribStubImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/GdImageFile.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageSequence.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/BmpImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageShow.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/MspImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/WalImageFile.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageFont.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/IcoImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/McIdasImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/FontFile.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/MicImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/WmfImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageQt.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImagePalette.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/JpegImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/features.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/BufrStubImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageWin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ExifTags.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/_binary.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/GifImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/IptcImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/PSDraw.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/Image.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/TarIO.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/PcfFontFile.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/PcdImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/PcxImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageColor.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/MpegImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/SpiderImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/MpoImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/Jpeg2KImagePlugin.py -> build/lib.linux-armv7l-2.7/PIL
copying PIL/ImageMorph.py -> build/lib.linux-armv7l-2.7/PIL
running egg_info
writing Pillow.egg-info/PKG-INFO
writing top-level names to Pillow.egg-info/top_level.txt
writing dependency_links to Pillow.egg-info/dependency_links.txt
warning: manifest_maker: standard file '-c' not found
reading manifest file 'Pillow.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
writing manifest file 'Pillow.egg-info/SOURCES.txt'
copying PIL/OleFileIO-README.md -> build/lib.linux-armv7l-2.7/PIL
running build_ext
dist.run_commands()
cmd_obj.run()
cmd_obj.run()
cmd_obj.run()
% (f, f))
Command /usr/bin/python -c "import setuptools;__file__='/usr/share/nginx/www/jeedom/plugins/openzwave/core/ajax/build/Pillow/setup.py';exec(compile(open(__file__).read().replace('
'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-aAIGK_-record/install-record.txt failed with error code 1 in /usr/share/nginx/www/jeedom/plugins/openzwave/core/ajax/build/Pillow
Storing complete log in /root/.pip/pip.log
Starting system nodejs Daemon:.
could not install - abort
7638D0442B90D010
9D6D8F6BC857C906
dist.run_commands()
cmd_obj.run()
cmd_obj.run()
cmd_obj.run()
% (f, f))
running install
running build
running build_py
creating build
running egg_info
running build_ext
dist.run_commands()
cmd_obj.run()
cmd_obj.run()
cmd_obj.run()
% (f, f))
Gerandhal
Bêta-Testeur
Box Cubie v2 avec Jeedom en stable
Raspberry déporté pour Enocean et ZWave
Clé 3G Huawei
iPhone, iPad
Karotz
KODI sur BRIX
NAS Synology DS213
Bêta-Testeur
Clé 3G Huawei
iPhone, iPad
Karotz
KODI sur BRIX
NAS Synology DS213
@gerandhal peux tu lettres tes logs entre des balises code car c'est vraiment long à scroler.
Merci bien
Merci bien
Développement script:
- ssh_commande.php
- ip_public.sh
- BackupSamba.sh
- ssh_commande.php
- ip_public.sh
- BackupSamba.sh
j'ai reçu la notification de mise à jour de Z-Wave cette nuit, mise à jour faite ce matin.
La mise à jour m'indique qu'il faut que je mette aussi à jour le démon local, opération que je lance dans la foulée.
Mon soucis est que rien ne se passe et qu'au out d'un moment j'ai un écran d'erreur :
Jeedom est paramétré sur des ports HTTP (6080) et HTTPS (6083) personnalisés : est-ce la raison ?
Comment puis-je corriger cela ?
Jeedom maître (Docker sur Synology DSM6 + téléinfo)
Jeedom esclave (Raspberry Pi 2 B + Z-Wave + MySensors)
récit
récit
Il faudrait faire F12 puis network pour voir ou va la demande mais il est possible que ca soit du a ton changement de port (qui n'est pas officiellement supporté)
Je vais regarder ça, j'ai redémarré la box (RPi2) voir si ça donne quelque chose, j'attends son retour ^^
L'écran Général > Administration -> Configuration -> Configuration réseaux est correctement paramétré en phase avec le paramétrage des ports appliqué pour raisons de sécurité.
EDIT : après le reboot l'opération se lance correctement, MAJ du démon en cours
récit
récit
Mise à jour (stable) Ok : "dans le doute -> reboot" :p
Rien à signaler tout est Ok pour moi ^^
récit
récit
La chance !
Je lance un appel a témoin !
Quelqu'un a t il jeedom sur un cubie avec une razberry dessus (ou en déporté sur un raspberry)?
Gerandhal
Bêta-Testeur
Clé 3G Huawei
iPhone, iPad
Karotz
KODI sur BRIX
NAS Synology DS213
Bêta-Testeur
Clé 3G Huawei
iPhone, iPad
Karotz
KODI sur BRIX
NAS Synology DS213
J'également le souci de ValueError: --enable-jpeg requested but jpeg not found, aborting. :
/usr/bin/pip run on Fri Oct 30 04:20:11 2015
skipping extra rst
skipping extra pdf
skipping extra testing
running egg_info
writing pip-egg-info/Pillow.egg-info/PKG-INFO
writing top-level names to pip-egg-info/Pillow.egg-info/top_level.txt
writing dependency_links to pip-egg-info/Pillow.egg-info/dependency_links.txt
reading manifest file 'pip-egg-info/Pillow.egg-info/SOURCES.txt'
writing manifest file 'pip-egg-info/Pillow.egg-info/SOURCES.txt'
Source in ./build/Pillow has version 3.0.0, which satisfies requirement Pillow (from blockdiag>=1.5.0->sphinxcontrib-blockdiag)
running egg_info
writing pip-egg-info/webcolors.egg-info/PKG-INFO
writing top-level names to pip-egg-info/webcolors.egg-info/top_level.txt
writing dependency_links to pip-egg-info/webcolors.egg-info/dependency_links.txt
reading manifest file 'pip-egg-info/webcolors.egg-info/SOURCES.txt'
writing manifest file 'pip-egg-info/webcolors.egg-info/SOURCES.txt'
Source in ./build/webcolors has version 1.5, which satisfies requirement webcolors (from blockdiag>=1.5.0->sphinxcontrib-blockdiag)
skipping extra i18n
Running command /usr/bin/python -c "import setuptools;__file__='/usr/share/nginx/www/jeedom/plugins/openzwave/core/ajax/build/Pillow/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-c06c2z-record/install-record.txt
running install
running build
running build_py
running egg_info
running build_ext
dist.run_commands()
cmd_obj.run()
cmd_obj.run()
cmd_obj.run()
% (f, f))
Complete output from command /usr/bin/python -c "import setuptools;__file__='/usr/share/nginx/www/jeedom/plugins/openzwave/core/ajax/build/Pillow/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-c06c2z-record/install-record.txt:
running install
running build
running build_py
running egg_info
running build_ext
dist.run_commands()
cmd_obj.run()
cmd_obj.run()
cmd_obj.run()
% (f, f))
Command /usr/bin/python -c "import setuptools;__file__='/usr/share/nginx/www/jeedom/plugins/openzwave/core/ajax/build/Pillow/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-c06c2z-record/install-record.txt failed with error code 1 in /usr/share/nginx/www/jeedom/plugins/openzwave/core/ajax/build/Pillow
Exception information:
File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 104, in main
status = self.run(options, args)
File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 250, in run
requirement_set.install(install_options, global_options)
File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1133, in install
requirement.install(install_options, global_options)
File "/usr/lib/python2.7/dist-packages/pip/req.py", line 577, in install
cwd=self.source_dir, filter_stdout=self._filter_install, show_stdout=False)
File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 256, in call_subprocess
% (command_desc, proc.returncode, cwd))
InstallationError: Command /usr/bin/python -c "import setuptools;__file__='/usr/share/nginx/www/jeedom/plugins/openzwave/core/ajax/build/Pillow/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-c06c2z-record/install-record.txt failed with error code 1 in /usr/share/nginx/www/jeedom/plugins/openzwave/core/ajax/build/Pillow
Je me sens moins seul du coup !
@nevaram
Tu as quelle configuration (box, deporté ou pas etc ... stable ou pas, version )
@nevaram
Gerandhal
Bêta-Testeur
Clé 3G Huawei
iPhone, iPad
Karotz
KODI sur BRIX
NAS Synology DS213
Bêta-Testeur
Clé 3G Huawei
iPhone, iPad
Karotz
KODI sur BRIX
NAS Synology DS213
J'ai eu une notification sur une mise à jour openzwave ce matin.
Je m'execute. la mise semble bien se passer, sauf que mes modules ne répondent plus.
Ce n'est pas grave, je redémarre Jeedom.
les modules répondent de nouveau par contre j'ai OpenZwave (1.3.414) Nok
Est ce normal ? (Rien dans les log)
NUC avec VM jeedom sur Debian (maître)
jeedom mini + (esclave)
@gerandhal je suis en stable, j'ai installer sur l'esclave, ça s'est bien passé, et là le problème est sur le maître.
Pour la config :
Kernel Version 3.2.0-4-amd64 (SMP) x86_64
Distro Name Debian GNU/Linux 7.9 (wheezy)
Pour la config :
J'ai trouvé une solution ici:
sudo apt-get install python-dev python-setuptools
sudo apt-get install libtiff4-dev libjpeg8-dev zlib1g-dev libfreetype6-dev liblcms2-dev libwebp-dev tcl8.5-dev tk8.5-dev python-tk
@geoblack faire la mise a jour des dépendances
Sent from my finger
Sent from my finger
Ce matin, notification mise à jour OpenZwave, je lance.
Message : "Il faut absolument mettre à jour le plugin..."
Je m'exécute : la page de log s'ouvre, avec le message , attention, opération longue..20 minutes....
Je laisse tourner, je reviens, erreur 504....
Je lis ici qu'il faut reboot, puis relancer la mise à jour du plugin. reboot ok....mise à jour.....pareil....504
Je vais pour revenir sur le dashboard, et là c'est la fin, sniff.....jeedom ne répond plus...504.
SSH ok, mais rien sur son URL...
J'ai loupé un truc ? Il faut que j'attende encore ?
Je suis en tout stable sauf TV orange.
merci.
Edit, Jeedom est relançé, mais OpenZwave est toujours en NOK...
merci.
elembee
@nevaram bien joué.
Grace à tes 2 lignes de code j'ai pu réinstaller les dépendances tout est ok j'ai pu vois les modules branchés sur secteur.
Pour les autres il faudra les réveiller.
Merci encore.
Merci encore.
Gerandhal
Bêta-Testeur
Clé 3G Huawei
iPhone, iPad
Karotz
KODI sur BRIX
NAS Synology DS213
Bêta-Testeur
Clé 3G Huawei
iPhone, iPad
Karotz
KODI sur BRIX
NAS Synology DS213
@elembee installe a nouveau le plugin en passant par le market, j'ai eux le problème sur ma prod et ça avait réglé mon problème
Sent from my finger
Sent from my finger
Merci @nechry.
Pour ma part tout semble être rentré dans l'ordre
Vace la réinstall du plugin ou autrement? Juste pour bien aiguiller d'autres utilisateur qui auraient ce problème
Sent from my finger
Sent from my finger
Ha oui en effet ce matin j'ai rippé et suis passé par le market "Installer stable" au lieu de passer par le centre de MAJ !
récit
récit
Elle fait quoi la mise à jour openzwave ? J'ai bien vu le log de la mise à jour du plugin en lui même (qui indique la mise à jour de openzwave , mais on passe en quelle vesion d'openzwave?)
Jeedomien bidouilleur depuis 2015
Jeedom sur RPI 2 et Odroid C2
