Tout comme Bipbip41, j'ai :
sed -i '253s/.*//' openzwave/cpp/src/value_classes/ValueID.h
cd openzwave && make
make[1]: Entering directory '/opt/python-openzwave/openzwave'
make -C /opt/python-openzwave/openzwave/cpp/build/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/build'
Building OpenZWave Version 1.3-414-g0432f68-dirty
Building tinystr.o
Building tinyxmlerror.o
Building tinyxml.o
Building tinyxmlparser.o
Building hid.o
Building aeskey.o
Building aescrypt.o
Building aestab.o
Building aes_modes.o
Building Security.o
Building Proprietary.o
Building MultiCmd.o
Building SensorBinary.o
Building Language.o
Building Meter.o
Building Indicator.o
Building CRC16Encap.o
Building MeterPulse.o
Building SwitchBinary.o
Building Clock.o
Building Configuration.o
Building CommandClass.o
Building SwitchToggleBinary.o
Building MultiInstance.o
Building TimeParameters.o
Building UserCode.o
Building CentralScene.o
Building Color.o
Building Lock.o
Building ThermostatSetpoint.o
Building DoorLock.o
Building ApplicationStatus.o
Building Hail.o
Building NodeNaming.o
Building DoorLockLogging.o
Building ClimateControlSchedule.o
Building Protection.o
Building ThermostatOperatingState.o
Building WakeUp.o
Building SwitchAll.o
Building ThermostatMode.o
Building MultiInstanceAssociation.o
Building Association.o
Building ManufacturerSpecific.o
Building SceneActivation.o
Building SensorAlarm.o
Building Powerlevel.o
Building AssociationCommandConfiguration.o
Building SensorMultilevel.o
Building BasicWindowCovering.o
Building SwitchMultilevel.o
Building Battery.o
Building ThermostatFanMode.o
Building ZWavePlusInfo.o
Building Version.o
Building Alarm.o
Building CommandClasses.o
Building ThermostatFanState.o
Building NoOperation.o
Building EnergyProduction.o
Building Basic.o
Building DeviceResetLocally.o
Building ControllerReplication.o
Building SwitchToggleMultilevel.o
Building Value.o
Building ValueList.o
Building ValueButton.o
Building ValueInt.o
Building ValueStore.o
Building ValueDecimal.o
Building ValueRaw.o
Building ValueString.o
Building ValueByte.o
Building ValueBool.o
Building ValueSchedule.o
Building ValueShort.o
Building Controller.o
Building Wait.o
Building Thread.o
Building Stream.o
Building Log.o
Building HidController.o
Building Mutex.o
Building SerialController.o
Building Event.o
Building FileOps.o
Building TimeStamp.o
Building FileOpsImpl.o
Building TimeStampImpl.o
Building WaitImpl.o
Building ThreadImpl.o
Building LogImpl.o
Building MutexImpl.o
Building SerialControllerImpl.o
Building EventImpl.o
Building Options.o
Building Scene.o
Building Utils.o
Building Driver.o
Building ZWSecurity.o
Building Group.o
Building Node.o
Building Manager.o
Building Msg.o
Building Notification.o
Creating vers.cpp
Building vers.o
Linking Static Library
Linking Shared Library
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/build'
make -C /opt/python-openzwave/openzwave/cpp/examples/MinOZW/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
Building Main.o
Linking /opt/python-openzwave/openzwave/.lib/MinOZW
g++ -o /opt/python-openzwave/openzwave/.lib/MinOZW /opt/python-openzwave/openzwave/.lib/Main.o /opt/python-openzwave/openzwave/libopenzwave.so -pthread
Creating Temporary Shell Launch Script
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
make[1]: Leaving directory '/opt/python-openzwave/openzwave'
python setup-lib.py build --build-base build/lib
running build
running build_ext
cythoning src-lib/libopenzwave/libopenzwave.pyx to src-lib/libopenzwave/libopenzwave.cpp
building 'libopenzwave' extension
creating build
creating build/lib
creating build/lib/temp.linux-armv7l-2.7
creating build/lib/temp.linux-armv7l-2.7/src-lib
creating build/lib/temp.linux-armv7l-2.7/src-lib/libopenzwave
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -Iopenzwave/cpp/src/ -Iopenzwave/cpp/src/value_classes/ -Iopenzwave/cpp/src/platform/ -Iopenzwave/cpp/build/linux/ -I/usr/include/python2.7 -c src-lib/libopenzwave/libopenzwave.cpp -o build/lib/temp.linux-armv7l-2.7/src-lib/libopenzwave/libopenzwave.o
cc1plus: warning: command line option ‘-Wstrict-prototypes’ is valid for C/ObjC but not for C++
In file included from openzwave/cpp/src/aes/aescpp.h:26:0,
from openzwave/cpp/src/Driver.h:42,
from src-lib/libopenzwave/libopenzwave.cpp:248:
openzwave/cpp/src/aes/aes.h:75:0: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( disable : 4324 )
openzwave/cpp/src/aes/aes.h:93:0: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( default : 4324 )
src-lib/libopenzwave/libopenzwave.cpp: In function ‘PyObject* __pyx_pf_12libopenzwave_9PyManager_250beginControllerCommand(__pyx_obj_12libopenzwave_PyManager*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*)’:
src-lib/libopenzwave/libopenzwave.cpp:24326:204: warning: ‘bool OpenZWave::Manager::BeginControllerCommand(uint32, OpenZWave::Driver::ControllerCommand, OpenZWave::Driver::pfnControllerCallback_t, void*, bool, uint8, uint8)’ is deprecated (declared at openzwave/cpp/src/Manager.h:1715) [-Wdeprecated-declarations]
__pyx_t_6 = __Pyx_PyBool_FromLong(__pyx_v_self->manager->BeginControllerCommand(__pyx_t_1, __pyx_t_2, __pyx_f_12libopenzwave_ctrl_callback, ((void *)__pyx_v_pythonfunc), __pyx_t_3, __pyx_t_4, __pyx_t_5)); if (unlikely(!__pyx_t_6)) {__pyx_filename = __pyx_f[0]; __pyx_lineno = 3834; __pyx_clineno = __LINE__; goto __pyx_L1_error;}
src-lib/libopenzwave/libopenzwave.cpp:328:36: note: in definition of macro ‘__Pyx_PyBool_FromLong’
#define __Pyx_PyBool_FromLong(b) ((b) ? (Py_INCREF(Py_True), Py_True) : (Py_INCREF(Py_False), Py_False))
arm-linux-gnueabihf-gcc: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.9/README.Bugs> for instructions.
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 4
Makefile:257: recipe for target 'build' failed
make: *** [build] Error 1
Bien sûr, que ce soit install via Jeedom ou à la mano sur une jeedomboard (Mini+). Mais dans le plugin j'ai :
OpenZwave (1.3.414/0.3.0b4) : OK Compilation: OK
BC
