Nouveau plugin zwave/openzwave
(anciennement dénommé plugin OpenZwave)
loic
Administrateur
Re: Nouveau plugin zwave/openzwave
Message par loic » 02 juin 2015, 10:32
Tu as une petite flèche a coté de générale qui fait deja ca
Masterfion
Message par Masterfion » 02 juin 2015, 10:34
loic a écrit :Peux tu me donner le retour de :
cat /etc/nginx/sites-available/default
J'ignore si c'est à moi que tu parle Loic mais je peux malgré tout te donner ça oui :D
jeedom@Jeedom ~ $ cat /etc/nginx/sites-available/default
server {
        #listen   80; ## listen for ipv4; this line is default and implied
        #listen   [::]:80 default_server ipv6only=on; ## listen for ipv6
        root /usr/share/nginx/www/jeedom;
        index index.html index.htm index.php;
        access_log off;
        error_log /usr/share/nginx/www/jeedom/log/nginx.error;
        client_max_body_size 100M;
        location /jeedom/ {
                try_files $uri $uri/ /index.html /index.php;
        location ~ ^/jeedom/tmp/(.*)$ {
                deny all;
        location ~ ^/jeedom/log/(.*)$ {
                deny all;
        location ~ ^/jeedom/backup/(.*)$ {
                deny all;
        location ~ \.sql$ {
                 deny all;
        location ~ \.tar$ {
                 deny all;
        location ~ \.gz$ {
                 deny all;
        location ~ ^/(.*)ini$ {
                deny all;
        include sites-available/jeedom_dynamic_rule;
        location /socket.io/ {
                proxy_pass http://127.0.0.1:8070/socket.io/;
                proxy_http_version 1.1;
                proxy_set_header Upgrade $http_upgrade;
                proxy_set_header Connection "Upgrade";
                proxy_set_header Host $host;
                proxy_redirect off;
                proxy_read_timeout 6000;
        location ~ ^(.+?\.php)(/.*)?$ {
                try_files $uri =404;
                fastcgi_param SCRIPT_FILENAME $document_root$1;
                fastcgi_param PATH_INFO $2;
                fastcgi_pass unix:/var/run/php5-fpm.sock;
                fastcgi_index index.php;
                include fastcgi_params;
                fastcgi_buffer_size 128k;
                fastcgi_buffers 4 256k;
                fastcgi_busy_buffers_size 256k;
                fastcgi_read_timeout 300;
                if ($request_method = 'GET') {
                        add_header 'Access-Control-Allow-Origin' '*';
                        add_header 'Access-Control-Allow-Credentials' 'true';
                        add_header 'Access-Control-Allow-Methods' 'GET, POST, OPTIONS';
                        add_header 'Access-Control-Allow-Headers' 'DNT,X-Mx-ReqToken,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type';
Beta-Testeur JEEDOM
Proxmox Core i5 Raid1 mSATA | Synology 916+
Masterfion
Message par Masterfion » 02 juin 2015, 10:35
loic a écrit :Tu as une petite flèche a coté de générale qui fait deja ca
Roh, j'ai honte !!!!
Je l'ai toujours vu cette flèche mais tu crois qu'il aurait cliqué dessus ? Ben non :oops:
Beta-Testeur JEEDOM
domomat
Message par domomat » 02 juin 2015, 10:35
Personne, n'a une idée sur comment configurer openzwave sur un jeedom en déporté avec un razberry ?
Je me sens seul...
Jeedom --> Depuis Juillet 2014
VM Debian (NUC i5) - 100% Xiaomi Aqara & Yeelight
Détails ici
skyline-ch
Contact :
Message par skyline-ch » 02 juin 2015, 10:35
loic a écrit :C'est normale que sur 8083 ca marche pas on va changer la page on ne passera plus par la a l'avenir.
server {
        root /usr/share/nginx/www;
        access_log off;
        location /jeedom/ {
                deny all;
                deny all;
                deny all;
        location ~ \.sql$ {
                 deny all;
        location ~ \.tar$ {
                 deny all;
        location ~ \.gz$ {
                 deny all;
                proxy_redirect off;
        location ~ \.php$ {
Ok souf que sur le maitre j'ai les même manque d'info dans la config des module :
Compétence :
- Prog : HTML5, CSS3, JS, JQuery, SQL, PHP
Masterfion
Message par Masterfion » 02 juin 2015, 10:41
Je dispose de 2 archi et mon ancienne est constituée d'un cubie et d'une Jeedom Mini pour Zwave déporté... 60% de mes modules sont encore dessus et bien que cette Jeedom Mini n'a plus Jeedom et qu'il y a un peu de travail pour la mettre en condition, je veux bien poursuivre ma migration pour n'y laisser que quelques modules "secondaires" et faire des tests de migration Zwave > OpenZwave si vous le souhaitez.
Beta-Testeur JEEDOM
domomat
Message par domomat » 02 juin 2015, 10:42
Merci @sarakha63,
Effectivement, il était tard et j'ai mis à jour openzwave sur le maître. Puis je me suis dit (comme un c*n) tiens je vais le faire aussi pour le razberry.
Je vais essayer de revenir en arrière.
En dehors du port l'installation marche bien et il est bien vu sur le maître.
Désolé d'avoir fais le boulet.
Détails ici
nechry
Contact :
Message par nechry » 02 juin 2015, 10:42
@skyline-ch dans admin reseau si tu sélectionne ton esclave, tu vois bien le plugin openzwave ?
Sent from my iPad using Tapatalk
As-tu consulté la documentation avant de poser ta question?
Les demandes de support en MP ne seront pas traité mais j'accepte les dons paypal.me/nechry
Visiter mon blog http://nechry-automation.ch/
mnementh
Message par mnementh » 02 juin 2015, 10:43
mnementh a écrit : Quoiqu'il en soit lorsque je désactive le CRON openzwave et que je lance la migration des équipement à partir du plugin j'ai ce message :
"sudo : no tty present and no askpass programm specified"
Une idée ?
Quelqu'un ?
Serveur HP N54L - Ubuntu - Clè Zstick AEON - OpenZwave
FGRM 222 - Oeil Fibaro - Siréne AEON - Clavier Zipato
Philips Living Colors - Kodi
alientouch
Message par alientouch » 02 juin 2015, 10:44
sarakha63 a écrit :Il faut que ton widget gere les commandes Montet et descendre et pas haut bas par exemple. Tu peux le voir dans le code du widget
Ok merci Sarakha63
Raspberry Pi 3 + SSD : Jeedom 3.3.19
Dongle Z-Wave : Aeotec Z-Stick Gen 5
Passerrelle 433 Mhz : RFXcom RFXtrx433
Mon matériel
skyline-ch
Contact :
Message par skyline-ch » 02 juin 2015, 10:47
nechry a écrit :@skyline-ch dans admin reseau si tu sélectionne ton esclave, tu vois bien le plugin openzwave ?
Oui et les commande ON et OFF passe bien mais pas les valeur ni état, ni les config de modul
Compétence :
Masterfion
Message par Masterfion » 02 juin 2015, 10:50
Ça fuse les messages ici, heureusement que le Forum a été migré :mrgreen:
Beta-Testeur JEEDOM
nechry
Contact :
Message par nechry » 02 juin 2015, 10:51
@skyline-ch J'avais eux similaire sur ma migration en alpha, je dois dépoussiérer ma mémoire. Le cron openzwave est présent et tourne? Sur ton master
skyline-ch
Contact :
Message par skyline-ch » 02 juin 2015, 10:54
se sera plus simple si je te donne les accès au 2 machines, je t'envoie par MP les infos, confirme moi que tu a accès, après je dois m'absenter 1-2h
Compétence :
cedric02
Message par cedric02 » 02 juin 2015, 10:59
de mon coté, après avoir tout migré de zwave a openzwave, la majorité des notes reste en dead
Jeedom sur Nuc Intel | Jeedom esclace sur pi/Piface | Zwave thermometre / Qubino 6 ordres pour gerstion chauffage | rfxcom vers des prises low-cost, pour avoir que trucs simples, comme allumer mon sapin de noel le matin ! | OWL 160 pour la consommation
RoadRunner
Message par RoadRunner » 02 juin 2015, 11:02
Pour ma part, la migration s'est faite dans la douleur, les modules récupérés dans OpenZwave n'ayant plus le même nom et visiblement un ID Jeedom différent, j'ai dû me résoudre à modifier tous mes virtuels, scenario, etc.
J'ai bien essayé de faire un rollback en restaurant en date du 31/05 puis de repasser la mise à jour mais sans plus de chance.
Globalement tout (re)fonctionne correctement mais beaucoup de temps perdu hier, heureusement que je n'ai que 7 modules Zwave ;)
Par contre, est-ce normal que je n'ai plus du tout accès aux paramètres des modules ?
Jeedom DIY - RFXtrx433E - UZB1 - Asus Brix
Rfxcom: 2 THN132N - 2 THGR328N - 2 module ON/OFF + diode FP - 2 Dio 54790
Openzwave: 1 FGK-101 - 2 FGMS-001 - 1 FGS-211 - 1 FGWPE-101 - 1 FGSS-001 - 1 FGRM-222
Autre: Philips Hue - LaMetric Time - Arlo - Harmony Hub
skyline-ch
Contact :
Message par skyline-ch » 02 juin 2015, 11:05
J'ai le même souci pour les para, ils sont dessus
Compétence :
cedric02
Message par cedric02 » 02 juin 2015, 11:06
sarakha63 a écrit :Tu peux sur la page de config d'un noeud dead aller cliquer sur le bouton qui t'est proposé ?
Ou cela ?
loic
Administrateur
Message par loic » 02 juin 2015, 11:09
@RoadRunner : as tu bien cliqué sur le bouton migration ?
Je viens de mettre a jour le premier poste en vous détaillant plus la marche a suivre.
Pour ceux qui ont des 404 :
- jeedom a bien les droits sudo ?
- que vous donne : cat /etc/nginx/sites-available/default, avez vous bien la ligne : include sites-available/jeedom_dynamic_rule; si non il faut l'ajouter
- avez vous bien la version 1.190 de jeedom ?
Masterfion
Message par Masterfion » 02 juin 2015, 11:10
loic a écrit :avez vous bien la version 1.190 de jeedom ?
Elle est sortie quand ????
Beta-Testeur JEEDOM
Revenir vers « Plugin Z-Wave »
