bonjour
Meme probleme
Suite a la mise a jour du plugin , ja i le message 502 Bad gateway nginx au démarrage de jeedom puis en essayant de rentrer sur la configuration du plugin
sur l'update si je vérifie les mise à jour: 500:internal server error ( ceci sur tous les plugin)
je tente de refaire la mise à jour du core:
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20131226/curl.so' - /usr/lib/php5/20131226/curl.so: undefined symbol: zend_unset_property in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20131226/ldap.so' - /usr/lib/php5/20131226/ldap.so: undefined symbol: _safe_emalloc_string in Unknown on line 0
****Install/update jeedom from 3.1.3 (2017-09-28 14:18:04)****
Configuration : level : -1, mode : , version : , onlyThisVersion :
Send begin of update event...OK
Check rights...
OK
[START BACKUP]
***************Start of Jeedom backup at 2017-09-28 14:18:08***************
Send begin backup event...OK
Check database...
OK
Backup database...
OK
Persist cache :
OK
Create archive...
OK
Clean old backup...OK
Limit the total size of backups to 256 Mo...
Remove : /usr/share/nginx/www/jeedom/core/php/../../backup/backup-BOX_bernan-3.1.3-2017-09-28-08h17.tar.gz
OK
Name of backup : /usr/share/nginx/www/jeedom/core/php/../../backup/backup-BOX_bernan-3.1.3-2017-09-28-14h18.tar.gz
Send end backup event...OK
Backup duration : 104s
***************Fin de la sauvegarde de Jeedom***************
[END BACKUP SUCCESS]
Disable all task
OK
Disable all scenario......................
.................... OK
Clean temporary file (tmp)...OK
Download url :
https://github.com/jeedom/core/archive/stable.zip
Download in progress...converted '
https://github.com/jeedom/core/archive/stable.zip' (ANSI_X3.4-1968) -> '
https://github.com/jeedom/core/archive/stable.zip' (UTF-8)
--2017-09-28 14:19:56--
Resolving github.com (github.com)... 192.30.253.113, 192.30.253.112
Connecting to github.com (github.com)|192.30.253.113|:443... connected.
HTTP request sent, awaiting response... 302 Found
https://codeload.github.com/jeedom/core/zip/stable [following]
converted '
https://codeload.github.com/jeedom/core/zip/stable' (ANSI_X3.4-1968) -> '
https://codeload.github.com/jeedom/core/zip/stable' (UTF-8)
Resolving codeload.github.com (codeload.github.com)... 192.30.253.121, 192.30.253.120
Connecting to codeload.github.com (codeload.github.com)|192.30.253.121|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 21204721 (20M) [application/zip]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0K ........ ...
... 14% 403K 44s
3072K ..
...... 29% 383K 37s
6144K ..
. ........ 44% 524K 27s
9216K ........
.. 59% 525K 19s
12288K .....
....... 74% 508K 12s
15360K ....
...... 89% 430K 5s
18432K ..
.. 100% 468K=45s
2017-09-28 14:20:42 (456 KB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [21204721/21204721]
OK
Cleaning folder...OK
Create temporary folder...OK
Unzip in progress...
OK
Moving file...
OK
Remove temporary file...OK
Check jeedom consistency...[START CONSISTENCY]
[END CONSISTENCY]
OK
Check update...OK
***************Jeedom is up to date in 3.1.3***************
Check update
PHP Fatal error: Call to undefined function curl_init() in /usr/share/nginx/www/jeedom/core/class/network.class.php on line 211
