POP_004308 Smoke Detector
kimi1983
Message par kimi1983 » 30 juil. 2015, 19:43
je viens d´inclure le détecteur suivant :
https://www.planete-domotique.com/blog/ ... e-incluse/
et voici un lien vers le manuel :
https://www.google.lu/url?sa=t&rct=j&q= ... 5-PYLNm4yw
Y-a t´il quelqu´un qui a une config Openzwave qui est bon ? voici ce que le module me donne dans Jeedom :
<Node id="11" name="Rauchmelder Büro" location="Büro" basic="4" generic="161" specific="7" type="Routing Smoke Sensor" listening="false" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="0115" name="Z-Wave.Me">
<Product type="0001" id="0001" name="Z-Wave USB Stick" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" after_mark="true" innif="true" mapping="113">
<Instance index="1" />
</CommandClass>
<CommandClass id="48" name="COMMAND_CLASS_SENSOR_BINARY" version="1" request_flags="4" innif="true">
<Value type="bool" genre="user" instance="1" index="0" label="Sensor" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
</CommandClass>
<CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL" version="5" innif="true">
<Value type="decimal" genre="user" instance="1" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="19.9" />
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="113" name="COMMAND_CLASS_ALARM" version="3" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Alarm Type" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="1" label="Alarm Level" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="2" label="SourceNodeId" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="4" label="Smoke" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="128" name="COMMAND_CLASS_BATTERY" version="1" request_flags="4" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Battery Level" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="100" />
</CommandClass>
<CommandClass id="132" name="COMMAND_CLASS_WAKE_UP" version="2" innif="true">
<Value type="int" genre="system" instance="1" index="0" label="Wake-up Interval" units="Seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="604560" />
<Value type="int" genre="system" instance="1" index="1" label="Minimum Wake-up Interval" units="Seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="240" />
<Value type="int" genre="system" instance="1" index="2" label="Maximum Wake-up Interval" units="Seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="15728400" />
<Value type="int" genre="system" instance="1" index="3" label="Default Wake-up Interval" units="Seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="604672" />
<Value type="int" genre="system" instance="1" index="4" label="Wake-up Interval Step" units="Seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="240" />
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4" innif="true">
<Associations num_groups="3">
<Group index="1" max_associations="5" label="Group 1" auto="true">
<Node id="1" />
</Group>
<Group index="2" max_associations="5" label="Group 2" auto="false" />
<Group index="3" max_associations="5" label="Group 3" auto="false" />
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3.67" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.00" />
</CommandClass>
</CommandClasses>
</Node>
kimi1983
Re: POP_004308 Smoke Detector
Message par kimi1983 » 31 juil. 2015, 06:55
Merci pour l'info, voici les éléments manquant :
kimi1983
kimi1983
Message par kimi1983 » 31 juil. 2015, 14:24
Je pense que le Vision Security ZS6101 est du même type.
http://www.visionsecurity.com.tw/loadfi ... o_1_en.pdf
kimi1983
Message par kimi1983 » 31 juil. 2015, 14:45
kimi1983
Message par kimi1983 » 01 août 2015, 19:26
Il ya personne qui peux m´expliquer comment definir ce type de detecteur ?
merci :)
kimi1983
Message par kimi1983 » 02 août 2015, 08:12
Oui mais on parle bien du detecteur, mon recepteur zwave c´est le razberry. comment je peux t´aider ?
kimi1983
Message par kimi1983 » 05 août 2015, 15:18
En tout cas, si le detecteur ne fonctionne pas jusqu'au 21.08, je vais le renvoyé au magasin. Merci pour ton aide.
kimi1983
Message par kimi1983 » 05 août 2015, 19:26
oui les memes ID....
Leon95
Message par Leon95 » 10 août 2015, 17:29
Je viens d'essayer de configurer le même detecteur et je suis un peu perdu avec certaines commandes.
D'abord je confirme il est reconnu comme une clé usb Z-stick sur jeedom (version .199) mais les commandes ont l'air bonnes.
Je ne comprends pas ce qu'est le "SourceNodeId 2".
Sensor serait l'alarme pour indiquer qu'il plus sur son embase ?
Si besoin de plus d'infos, n'hésitez pas.
Merci,
Edit : Sur la doc eedomus, il y a un peu plus d'info : http://doc.eedomus.com/files/z_wave_pop ... manual.pdf
Leon95
Message par Leon95 » 26 août 2015, 14:43
Avez-vous réussi de votre coté à configurer ce module ?
Le mien est toujours reconnu comme une clé Z-stick malgré les dernières mises a jour, et je galere avec les commandes...
broshet
Message par broshet » 03 oct. 2015, 09:00
Je viens d'en installer deux hier soir et j'ai galéré. Ils sont tous les deux inclus (Bouton Test pendant une seconde hors socle)
Par contre, mise a part le paramètre "Sensor" qui varie lorsque le détecteur de fumée sonne (j'ai testé avec de la fumée) rien ne s'actualise (après une nuit de sommeil il me dis que la température est de 23° dans mon garage une nuit d'octobre ...
Lorsque je regarde les paramètres système, je constate que le "wake up interval" est par défaut à 604560 secondes (168 h) ...
Bref, la configuration JEEDOM par défaut n'existe pas et est recconu comme un Z-Stick mais les propriété semblent correctes mais n'évoluent pas .
Est-il prévu de créer une configuration pour ce module POPP 004308 dans Jeedom et y assigner les bons paramètres ?
psykoze
Message par psykoze » 13 oct. 2015, 10:53
du nouveau sur une probable mise à disposition de la configuration de ce détecteur?
J'en possède deux aussi. Pour le moment, les infos qu'ils me donnent ne sont pas très concluantes. il n'y a pas d'actualisation de la T°.
Si besoin de plus de renseignements, je peux aussi fournir plus d'informations.
Jeedom - Installation manuelle sur Raspberry Pi 2B
AEON LABS Contrôleur Z-Wave Aeon Labs Z-Stick S2 - Fibaro FGRM222 (x2) - FGR222 (x1) - FGMS001 (x1) - FGFS-101 (x1)
POP_004308 Smoke Detector (x2) - Broadlink RM Pro - Prises Chacon DIO (x3)
noulo
Message par noulo » 16 oct. 2015, 19:10
Pareil dans zwave je me demandais pourquoi j'avais un z-stick qui apparaissait. En lisant ce post jr viens de comprendre que c'est mon detecteur que je n'ai même pas inclus.
philou15
Message par philou15 » 17 oct. 2015, 11:30
Un petit up car il est en super prix à 20 euro chez planete domotique,
Je pense que je vais craquer mais fonctionne t'il correctement ?
C'est à dire remonté d'"infi sur jeedom en cas d'incendie ?
psykoze
Message par psykoze » 19 oct. 2015, 14:22
J'en ai 2 et ils ont l'air de fonctionner correctement. Pour ce qui est du retour d'information, je ne suis pas très sûr. Il en remonte quelques unes. En cas de fumées, il sonne et le sensor s'actualise mais la T° affichée dans Jeedom n'a pas bougée depuis la mise en route.
J'attends aussi avec impatience la prise en charge de ces détecteurs par Jeedom, mais pour l'instant, aucun retour malheureusement.
broshet
Message par broshet » 19 oct. 2015, 14:25
Même conclusion que Psykoze malheureusement. Aucun retour de la communauté sur l'éventuelle prise en charge de ce type d'appareil dans Jeedom.
broshet
Message par broshet » 19 oct. 2015, 15:00
Ce que je ne comprend pas c'est que le code constructeur POPP est 340 (154 en hexa) et correctement déclaré dans les fichiers Jeedom (https://github.com/jeedom/plugin-openzw ... s/popp_340 et https://github.com/jeedom/plugin-openzw ... /manuf.xml). Ce composant n'existe cependant pas.
De plus, lors de l'inclusion, c'est le constructeur Z-wave.me (277 hexa 115) qui est affecté au module
Avez vous une piste concernant ce déphasage ?
psykoze
Message par psykoze » 27 oct. 2015, 10:10
je viens de faire la mise à jour de la beta et j'ai utilisé la loupe mais pas de changement pour les smoke detector.
Peut être à la prochaine.
MauriceBernard
Message par MauriceBernard » 05 nov. 2015, 15:15
Bonjour tout le monde,
J'ai également le même module.
Je ne sais pas comment, en tentant de réparer le noeud, toutes les informations se sont mises à jour alors que cela faisait plusieurs jours que rien ne se passait... puis depuis, malgré mes tentatives, rien du tout... Quelqu'un aurait une piste ?
