[Plugin Tiers][Sujet Principal] Rflink : passerelle RF433 multi-protocoles
Re: [Sujet officiel] Rflink : passerelle RF433 multi-protoco
dépendances OK
log rflink :
module.js:340
throw err;
Error: Cannot find module 'tough-cookie'
at Function.Module._resolveFilename (module.js:338:15)
at Function.Module._load (module.js:280:25)
at Module.require (module.js:364:17)
at require (module.js:380:17)
at Object. (/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/request/lib/cookies.js:3:13)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
14-11-2015 16:00:30 | error | Impossible de lancer le démon rflink, vérifiez le port
14-11-2015 16:45:11 | error | Erreur sur la fonction cron15 du plugin : Le port : n'existe pas
log rflink_dep :
Début de l'installtion
Reading package lists...
Building dependency tree...
Reading state information...
avrdude is already the newest version.
mkdir: cannot create directory '/var/www': File exists
> serialport@2.0.5 install /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport
> node-pre-gyp install --fallback-to-build
make: Entering directory '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build'
CXX(target) Release/obj.target/serialport/src/serialport.o
CXX(target) Release/obj.target/serialport/src/serialport_unix.o
CXX(target) Release/obj.target/serialport/src/serialport_poller.o
SOLINK_MODULE(target) Release/obj.target/serialport.node
SOLINK_MODULE(target) Release/obj.target/serialport.node: Finished
COPY Release/serialport.node
COPY /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build/Release/node-v11-linux-arm/serialport.node
TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build'
serialport@2.0.5 node_modules/serialport
├── bindings@1.2.1
├── sf@0.1.7
├── async@0.9.0
├── nan@2.0.9
├── debug@2.2.0 (ms@0.7.1)
└── optimist@0.6.1 (wordwrap@0.0.3, minimist@0.0.10)
request@2.65.0 node_modules/request
├── aws-sign2@0.6.0
├── forever-agent@0.6.1
├── caseless@0.11.0
├── stringstream@0.0.5
├── oauth-sign@0.8.0
├── tunnel-agent@0.4.1
├── isstream@0.1.2
├── json-stringify-safe@5.0.1
├── extend@3.0.0
├── node-uuid@1.4.7
├── combined-stream@1.0.5 (delayed-stream@1.0.0)
├── qs@5.2.0
├── mime-types@2.1.7 (mime-db@1.19.0)
├── tough-cookie@2.2.1
├── form-data@1.0.0-rc3 (async@1.5.0)
├── http-signature@0.11.0 (assert-plus@0.1.5, asn1@0.1.11, ctype@0.5.3)
├── bl@1.0.0 (readable-stream@2.0.4)
├── hawk@3.1.1 (cryptiles@2.0.5, sntp@1.0.9, boom@2.10.1, hoek@2.16.3)
└── har-validator@2.0.2 (pinkie-promise@1.0.0, commander@2.9.0, chalk@1.1.1, is-my-json-valid@2.12.3)
Fin de l'installation
quand je relance c'est pareil
log rflink :
module.js:340
throw err;
log rflink_dep :
├── bindings@1.2.1
├── sf@0.1.7
├── async@0.9.0
├── nan@2.0.9
├── aws-sign2@0.6.0
├── caseless@0.11.0
├── isstream@0.1.2
├── extend@3.0.0
├── node-uuid@1.4.7
├── qs@5.2.0
a priori, c'est devenu bon... tout est OK
j'ai acheté des prises DIO 54798 avec une télécommande 54760. J'arrive à voir les commandes dans RFLink mais impossible à les faire fonctionner ensuite. Je précise qu'elles fonctionnent bien avec la télécommande. Lorsque j'appuie sur une commande, les leds de l'arduino mega s'allument bien pourtant. Une personne a t'elle ce modèle de prises, si oui, y a t'il une astuce ?. Mon Rflink fonctionne bien avec d'autres prises Chacon et Dedra plus vieilles. Merci
Tu as quoi dans les logs ?
J'ai ceci dans le log
15-11-2015 16:44:48 | debug | 127.0.0.1
15-11-2015 16:44:48 | info | 10,NewKaku,012b780e,1,ON,
15-11-2015 16:44:48 | debug | Protocole CMD UNKNOWN ID
15-11-2015 16:44:49 | debug | 127.0.0.1
15-11-2015 16:44:49 | info | 10,NewKaku,012b780e,1,OFF,
15-11-2015 16:44:49 | debug | Protocole CMD UNKNOWN ID
un autre qui fonctionne
15-11-2015 16:52:50 | debug | 127.0.0.1
15-11-2015 16:52:50 | info | 10,Kaku,00004c,1,ON,
Non le log quand tu reçois les commandes de la telco
15-11-2015 17:28:23 | debug | Protocole NewKaku ID 012b780e
Tu as la ligne du dessus ou dessous ?
Je suis désolé, je n'ai que cela lorsque j'appuie sur la télécommande, j'ai appuyé sur on et off de la commande 1 et 2. Je devrai avoir quoi comme info , Merci du temps passé.
15-11-2015 18:12:30 | debug | Protocole NewKaku ID 012b780e
15-11-2015 18:12:31 | debug | Protocole NewKaku ID 012b780e
15-11-2015 18:12:32 | debug | Protocole NewKaku ID 012b780e
Tu devrais avoir la ligne de sortie du port série.
Sinon un screen avec tes commandes infos créées stp
J'ai tout effacé et recommencé l'étape, voici
15-11-2015 20:11:39 | debug | Protocole NewKaku ID 012b780e
15-11-2015 20:11:39 | debug | Commande non existante, création SWITCH1:ON sur NewKaku_012b780e
15-11-2015 20:11:40 | debug | Protocole NewKaku ID 012b780e
15-11-2015 20:11:40 | debug | Commande non existante, création SWITCH1:OFF sur NewKaku_012b780e
15-11-2015 20:11:45 | debug | Protocole NewKaku ID 012b780e
15-11-2015 20:11:45 | debug | Commande non existante, création SWITCH2:OFF sur NewKaku_012b780e
15-11-2015 20:11:48 | debug | Protocole NewKaku ID 012b780e
15-11-2015 20:11:48 | debug | Commande non existante, création SWITCH3:ON sur NewKaku_012b780e
15-11-2015 20:11:50 | debug | Protocole NewKaku ID 012b780e
15-11-2015 20:11:50 | debug | Commande non existante, création SWITCH3:OFF sur NewKaku_012b780e
Je n'ai que cela dans le log RFLink
Tu as le log rflink_daemon ? Et un screen avec les commandes créées
je n'ai pas rflink_daemon. J'ai rflink_flash, rflink et rflink_dep en log.
- Capture2.PNG (120.19 Kio) Consulté 1993 fois
- Capture.PNG (60.1 Kio) Consulté 2016 fois
j'ai cela dans le log rflink avec appuie sur la télécommande. mais cela ne fonctionne pas, je dois louper un truc, mais quoi !!! mdr
15-11-2015 22:27:17 | debug | 20;51;NewKaku;ID=012b780e;SWITCH=1;CMD=ON;
15-11-2015 22:27:17 | info | Send Value : 20;51;NewKaku;ID=012b780e;SWITCH=1;CMD=ON;
15-11-2015 22:27:17 | debug | Protocole NewKaku ID 012b780e
15-11-2015 22:27:17 | debug | Got response Value: 200
15-11-2015 22:27:18 | debug | 20;52;NewKaku;ID=012b780e;SWITCH=1;CMD=OFF;
15-11-2015 22:27:18 | info | Send Value : 20;52;NewKaku;ID=012b780e;SWITCH=1;CMD=OFF;
15-11-2015 22:27:18 | debug | Protocole NewKaku ID 012b780e
15-11-2015 22:27:18 | debug | Got response Value: 200
Je comprend plus, là t'as bien des logs normaux alors qu'avant t'as juste une des lignes sur 4 ?
Ta capture de l'équipement il y a quelque chose de pas normal dans les infos aussi, il n'y a pas la valeur
Là si tu testes une de tes commandes tu as toujours l'ID de CMD inconnu ?
Oui, je ne comprends pas non plus.
16-11-2015 05:47:51 | debug | 127.0.0.1
16-11-2015 05:47:51 | info | 10,NewKaku,012b780e,1,ON,
16-11-2015 05:47:51 | debug | server connected
16-11-2015 05:47:51 | info | Response: 10;NewKaku;012b780e;1;ON;
16-11-2015 05:47:51 | debug | server disconnected
16-11-2015 05:47:51 | debug | 20;8A;CMD UNKNOWN;
16-11-2015 05:47:51 | info | Send Value : 20;8A;CMD UNKNOWN;
16-11-2015 05:47:51 | debug | Protocole CMD UNKNOWN ID
16-11-2015 05:47:51 | debug | Got response Value: 200
Excellent, le RFXcom by @Lunarok, belle initiative qui va réjouir tout ceux qui veulent s'équiper du 433Mhz à moindre coût
succès garantie
Envoyé de mon MI PAD en utilisant Tapatalk
![Smile :)](./images/smilies/icon_e_smile.gif)
@breizh22 : donc c'est bien la bonne trame qui est envoyée et recue par la gateway, mais elle en veut pas
Tu peux essayer en mettant un 0 devant le 1 par exemple ? (j'ai vu le cas, où l'info recu faisait l'inverse, on voiyait SWITCH=02;CMD=OFF mais il fallait pas envoyer 02;OFF, mais 2;OFF
@breizh22 : il y a la version 34 que la stunteam a sortie il y a quelques jours, est-ce que c'est cette version que tu as ?
Et la version est visible sur la page santé ca me fait penser (pour ceux qui sauraient pas où la voir)
