[Plugin Tiers][Sujet Principal] Rflink : passerelle RF433 multi-protocoles
vincecoco
Re: [Sujet officiel] Rflink : passerelle RF433 multi-protoco
Message par vincecoco » 03 janv. 2016, 18:07
Dans la page "Santé" de mon Jeedom j'ai ça pour RFLink :
Santé RFLink
Résultat Conseil
Gateway inconnue
Service OK
Dépendances OK
Log RFLink Dep
Début de l'installtion
Reading package lists...
Building dependency tree...
Reading state information...
avrdude is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 31 not upgraded.
mkdir: cannot create directory '/var/www': File exists
rm: cannot remove 'node_modules': Directory not empty
> serialport@2.0.5 install /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport
> node-pre-gyp install --fallback-to-build
ture/1.1.0/package.tgz
npm ERR! tar.unpack untar error /root/.npm/har-validator/2.0.3/package.tgz
npm ERR! tar.unpack untar error /root/.npm/qs/5.2.0/package.tgz
npm ERR! tar.unpack untar error /root/.npm/hawk/3.1.2/package.tgz
npm ERR! Linux 4.1.7-v7+
npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "--unsafe-perm" "request"
npm ERR! node v0.12.7
npm ERR! npm  v2.11.3
npm ERR! path /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/request/node_modules/node-uuid/component.json
npm ERR! code ENOENT
npm ERR! errno -2
npm ERR! enoent ENOENT, open '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/request/node_modules/node-uuid/component.json'
npm ERR! enoent This is most likely not a problem with npm itself
npm ERR! enoent and is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! Please include the following file with any support request:
npm ERR!     /usr/share/nginx/www/jeedom/plugins/rflink/node/npm-debug.log
chown: cannot access 'node_modules': No such file or directory
Fin de l'installtion
make: Entering directory '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build'
  CXX(target) Release/obj.target/serialport/src/serialport.o
  CXX(target) Release/obj.target/serialport/src/serialport_unix.o
  CXX(target) Release/obj.target/serialport/src/serialport_poller.o
  SOLINK_MODULE(target) Release/obj.target/serialport.node
  COPY Release/serialport.node
  COPY /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build/Release/node-v14-linux-arm/serialport.node
  TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build'
serialport@2.0.5 node_modules/serialport
├── bindings@1.2.1
├── sf@0.1.7
├── async@0.9.0
├── debug@2.2.0 (ms@0.7.1)
├── optimist@0.6.1 (wordwrap@0.0.3, minimist@0.0.10)
└── nan@2.0.9
request@2.67.0 node_modules/request
├── is-typedarray@1.0.0
├── aws-sign2@0.6.0
├── forever-agent@0.6.1
├── caseless@0.11.0
├── stringstream@0.0.5
├── oauth-sign@0.8.0
├── tunnel-agent@0.4.2
├── isstream@0.1.2
├── json-stringify-safe@5.0.1
├── extend@3.0.0
├── node-uuid@1.4.7
├── combined-stream@1.0.5 (delayed-stream@1.0.0)
├── qs@5.2.0
├── mime-types@2.1.8 (mime-db@1.20.0)
├── tough-cookie@2.2.1
├── form-data@1.0.0-rc3 (async@1.5.0)
├── bl@1.0.0 (readable-stream@2.0.5)
├── http-signature@1.1.0 (assert-plus@0.1.5, jsprim@1.2.2, sshpk@1.7.1)
├── har-validator@2.0.3 (pinkie-promise@2.0.0, commander@2.9.0, chalk@1.1.1, is-my-json-valid@2.12.3)
└── hawk@3.1.2 (cryptiles@2.0.5, sntp@1.0.9, boom@2.10.1, hoek@2.16.3)
Log RfLink Flash
avrdude: Version 6.1, compiled on Jul  7 2015 at 10:29:47
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/etc/avrdude.conf"
         User configuration file is "/var/www/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB21
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
avrdude: wiring_open(): releasing DTR/RTS
avrdude: wiring_open(): asserting DTR/RTS
avrdude: ser_recv(): programmer is not responding
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: ser_recv(): programmer is not respoavrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done.  Thank you.
Si ca peut aider.
Thanks
rol-rider
Message par rol-rider » 03 janv. 2016, 18:52
@vincecoco
tu as flasher comment ton mega?
là, on dirait qu'il n'est pas flasher.
dans la page santé tu devrais avoir" nodo radio......gatewayV1.1-R35" (ou34)
la gateway peut être OK sans le "programme dans le mega" .
RPI3 avec mSATA
vincecoco
Message par vincecoco » 03 janv. 2016, 19:16
rol-rider a écrit :@vincecoco
J'ai essayé de le flasher via le plugin RFLink.
Il y a une autre méthode ?
J'ai vidé les logs et tenter de reflasher.
Sur la page du plugin j'ai
 Installation : Le module serialport pour nodejs est nécessaire. La configuration réseau Jeedom doit également être remplie.
J'ai juste la config Jeedom externe qui n'est pas rempli. La local est OK
Dans les logs
rol-rider
Message par rol-rider » 03 janv. 2016, 19:24
ba là il ne répond pas, donc la gateway n'est pas programmé!
tu es sur du port usb?
re sauvegarde le plugin et relance le flash.
tu peux aussi le flasher avec le "RFlinkLoader.exe" du site nodo. (gateway sur le pc)
EDIT:
là, tu as un souci de configuration....
RPI3 avec mSATA
vincecoco
Message par vincecoco » 03 janv. 2016, 19:40
EDIT:
Il me me propose que ce port USB dans le plugin :s
lunarok
Message par lunarok » 03 janv. 2016, 20:21
On t'a répondu hier de mettre ttyACM0 que ttyUSB21 était plutôt une clef zwave
vincecoco
Message par vincecoco » 03 janv. 2016, 20:38
lunarok a écrit :On t'a répondu hier de mettre ttyACM0 que ttyUSB21 était plutôt une clef zwave
Merci Lunarok mais justement comme j'ai mis hier ttyACM0 c'est ma clef zwave. j'ai verifie dans mon plugin zwave.
J'ai changé le port, désactivé/réactivé le plugin mais que ce port de précisé.
A présent tout est KO même les dépendances.
Je regarderai ça demain. Je vis essayé de lister les périphérique USB avant/après branchement de l'arduino pour trouver le bon port et le rentrer à la main.
Il faut que je retrouve la commande.
Merci, je vous tiens au courant
lunarok
Message par lunarok » 03 janv. 2016, 21:09
Elle a été donne dans le fil, lsusb, et dmesg juste après l'avoirnplugger ça marche ausi
vincecoco
Message par vincecoco » 03 janv. 2016, 21:14
lunarok a écrit :Elle a été donne dans le fil, lsusb, et dmesg juste après l'avoirnplugger ça marche ausi
Merci j'allais justement rechercher dans le fil :)
Je vous tiens au courant demain, car il faut que je me connecte en ssh via putty, ma box n'est plus à proximité de mon écran de PC.
vincecoco
Message par vincecoco » 04 janv. 2016, 07:20
Je me suis connecté via Putty cematin.
lusb ne fonctionne pas mais dmesg oui :)
J'ai donc mis /dev/ttyACM1 le (0 étant pr la clef zwave).
Le flash s'est correctement déroulé :D
J'ai ensuite appuyé sur la télécommande de ma prise (qui était déjà allumée), un nouveau noeud RFLink s'est ainsi créé.
J'ai donc la commande, ON qui s'est créé. J'ai appuyé sur la télécommande et le OFF s'est créé. J'ai testé depuis jeedom et ca fonctionne bien.
Il me reste à regarder les virtuelles pour avoir le "pseudo retour d'état" et essayer mes autres prises.
Merci beaucoup à vous pour votre aide !
lunarok
Message par lunarok » 04 janv. 2016, 08:56
Voir plus haut, le pseudo retour d'État est traite dans le plugin, sans virtuel
julien35
Message par julien35 » 04 janv. 2016, 13:09
Petit retour suite au changement de mon cable USB. Depuis hier 17h, aucune coupure, la passerelle et jeedom sont stables.
A confirmer mais la liaison raspberry - rflink demande un cable usb de bonne facture.
vincecoco
Message par vincecoco » 04 janv. 2016, 22:05
J'ai un petit soucis sur mes prises 433 et RFLink.
Sur ma seconde prise, RFLink ne m'a pas créé un nouvel équipement, mais 2 nouvelles Action (On et Off) sur ma première prise détécté.
De ce fait sur le Dashboard, j"ai sur ma Prise Tortue l'équivalent de 2 prises (dont une qui ne se trouve pas dans le salon :s)
Auriez vous une idée ?
wateresist
Message par wateresist » 05 janv. 2016, 07:20
Bonjour @vincecoco
Rflink crée un équipement par rapport à l id de la télécommande avec les actions par bouton. Si tu veux les séparer il faut faire deux virtuels. Un par pièce qui reprend chaque info/action.
vincecoco
Message par vincecoco » 05 janv. 2016, 09:07
wateresist a écrit :Bonjour @vincecoco
Ok merci.
Par contre pour l'allumer dans mon Agenda, je dois passer par le virtuel? ou ce n'est pas nécessaire ?
redvoodoochild
Message par redvoodoochild » 05 janv. 2016, 09:44
Ou alors, créer 2 télécommandes dans rflink et les associer aux prises.
Pour les commander via l'agenda, virtuel ou directement Rflink je pense que ça ne change rien. Le mieux est d'essayer.
lyonel
Message par lyonel » 05 janv. 2016, 10:09
@lunarok
en rfxcom les sondes banggood peuvent remonter le niveau de batterie et le niveau d'emission.
En rflink je ne vois pas cela. Est ce au niveau du plugin ou au niveau du scketch que ce n'est pas supporté?
2016-01-04 17:43:05,737 - MainThread - rfxcmd:2610 - DEBUG - SerWaiting: 11
2016-01-04 17:43:05,738 - MainThread - rfxcmd:2612 - DEBUG - Byte: 0A
2016-01-04 17:43:05,740 - MainThread - rfxcmd:2619 - DEBUG - Message: 0A 52 0D 0C 09 03 00 D9 30 01 79
2016-01-04 17:43:05,741 - MainThread - rfxcmd:301 - DEBUG - Decode : 0A 52 0D 0C 09 03 00 D9 30 01 79
2016-01-04 17:43:05,742 - MainThread - rfxcmd:2542 - DEBUG - Test message: 0A 52 0D 0C 09 03 00 D9 30 01 79
2016-01-04 17:43:05,743 - MainThread - rfxcmd:318 - DEBUG - PacketType: 52
2016-01-04 17:43:05,744 - MainThread - rfxcmd:322 - DEBUG - SubType: 0D
2016-01-04 17:43:05,745 - MainThread - rfxcmd:326 - DEBUG - SeqNbr: 0C
2016-01-04 17:43:05,746 - MainThread - rfxcmd:330 - DEBUG - Id1: 09
2016-01-04 17:43:05,746 - MainThread - rfxcmd:334 - DEBUG - Id2: 03
2016-01-04 17:43:05,747 - MainThread - rfxcmd:339 - DEBUG - Verify correct packet length
2016-01-04 17:43:05,748 - MainThread - rfxcmd:1593 - DEBUG - Decode packetType 0x52 - Start
2016-01-04 17:43:05,750 - Thread-14 - rfx_command:52 - DEBUG - Send data to jeedom : http://127.0.0.1:80/plugins/rfxcom/core ... Rfxcom.php => {'apikey': 'bsxxij29i6n1ib41c070', 'temperature': '21.7', 'humidity': '48', 'subtype': '0D', 'packettype': '52', 'id': '0903', 'time_between_message': '35'}
2016-01-04 17:43:05,750 - MainThread - rfxcmd:1656 - DEBUG - Decode packetType 0x52 - End
2016-01-04 17:43:05,759 - MainThread - rfxcmd:2482 - DEBUG - Decode packetType result :
Subtype = TH13
Seqnbr = 0C
Id = 0903
Temperature = 21.7 C
Humidity = 48%
Humidity Status = Comfort
Battery = 9
Signal level = 7
Time between message = 35
2016-01-04 17:43:05,761 - MainThread - rfxcmd:2806 - DEBUG - Processed: 0A520D0C090300D9300179
Centrale Myfox Evology Zen + Pi2, Jeedom Arduino rflink
9 modules Chacon volets roulant
1 Module Chacon 1000w pour ON/OFF VMC
3 prises Chacon 3500W
10 interrupteurs Chacon sans fils
lunarok
Message par lunarok » 05 janv. 2016, 11:03
Rflink n'envoit pas de niveau d'émission
Pour les batteries il envoit pas un numérique mais juste un niveau, tu as l'info normalement sur l'équipement
Et ça si je veux le mapper en batterie, faudrait gruger en disant low=10% par exemple
wateresist
Message par wateresist » 05 janv. 2016, 12:10
Ok merci.
Le resultat sera le meme mais si un jour tu changes de module tu devras reconfigurer ton thermostat. Je pense que c est bien de passer par des virtuels que ce soit pour des capteurs ou des actionneurs. Ça évitera les reconfigurations et la perte d historique en cas de changement.
rol-rider
Message par rol-rider » 06 janv. 2016, 11:28
Fausse joie ce matin !
Le facteur sonne ! chouette ma commande nodo..............même pas, une commande de Chine faite le 25/12 !
Je ne sais pas si @apocalipse08 à été livré, mais moi, toujours rien !
RPI3 avec mSATA
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 35 invités
