Santé RFLink
Résultat Conseil
Gateway inconnue
Service OK
Dépendances OK
Log RFLink Dep
Début de l'installtion
Reading package lists...
Building dependency tree...
Reading state information...
avrdude is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 31 not upgraded.
mkdir: cannot create directory '/var/www': File exists
rm: cannot remove 'node_modules': Directory not empty
> serialport@2.0.5 install /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport
> node-pre-gyp install --fallback-to-build
ture/1.1.0/package.tgz
npm ERR! tar.unpack untar error /root/.npm/har-validator/2.0.3/package.tgz
npm ERR! tar.unpack untar error /root/.npm/qs/5.2.0/package.tgz
npm ERR! tar.unpack untar error /root/.npm/hawk/3.1.2/package.tgz
npm ERR! Linux 4.1.7-v7+
npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "--unsafe-perm" "request"
npm ERR! node v0.12.7
npm ERR! npm v2.11.3
npm ERR! path /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/request/node_modules/node-uuid/component.json
npm ERR! code ENOENT
npm ERR! errno -2
npm ERR! enoent ENOENT, open '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/request/node_modules/node-uuid/component.json'
npm ERR! enoent This is most likely not a problem with npm itself
npm ERR! enoent and is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! Please include the following file with any support request:
npm ERR! /usr/share/nginx/www/jeedom/plugins/rflink/node/npm-debug.log
chown: cannot access 'node_modules': No such file or directory
Fin de l'installtion
make: Entering directory '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build'
CXX(target) Release/obj.target/serialport/src/serialport.o
CXX(target) Release/obj.target/serialport/src/serialport_unix.o
CXX(target) Release/obj.target/serialport/src/serialport_poller.o
SOLINK_MODULE(target) Release/obj.target/serialport.node
COPY Release/serialport.node
COPY /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build/Release/node-v14-linux-arm/serialport.node
TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build'
serialport@2.0.5 node_modules/serialport
├── bindings@1.2.1
├── sf@0.1.7
├── async@0.9.0
├── debug@2.2.0 (ms@0.7.1)
├── optimist@0.6.1 (wordwrap@0.0.3, minimist@0.0.10)
└── nan@2.0.9
request@2.67.0 node_modules/request
├── is-typedarray@1.0.0
├── aws-sign2@0.6.0
├── forever-agent@0.6.1
├── caseless@0.11.0
├── stringstream@0.0.5
├── oauth-sign@0.8.0
├── tunnel-agent@0.4.2
├── isstream@0.1.2
├── json-stringify-safe@5.0.1
├── extend@3.0.0
├── node-uuid@1.4.7
├── combined-stream@1.0.5 (delayed-stream@1.0.0)
├── qs@5.2.0
├── mime-types@2.1.8 (mime-db@1.20.0)
├── tough-cookie@2.2.1
├── form-data@1.0.0-rc3 (async@1.5.0)
├── bl@1.0.0 (readable-stream@2.0.5)
├── http-signature@1.1.0 (assert-plus@0.1.5, jsprim@1.2.2, sshpk@1.7.1)
├── har-validator@2.0.3 (pinkie-promise@2.0.0, commander@2.9.0, chalk@1.1.1, is-my-json-valid@2.12.3)
└── hawk@3.1.2 (cryptiles@2.0.5, sntp@1.0.9, boom@2.10.1, hoek@2.16.3)
avrdude: Version 6.1, compiled on Jul 7 2015 at 10:29:47
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/var/www/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB21
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: wiring_open(): releasing DTR/RTS
avrdude: wiring_open(): asserting DTR/RTS
avrdude: ser_recv(): programmer is not responding
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: ser_recv(): programmer is not respoavrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
Thanks
