I have downloaded the Raspberry Pi image and updated to latest version of Jeedom. I recieve data from mysensor node and weather data.
I cannot get the history module to load any graph. I get the following error javascript error.
“Unable to get property 'chart' of undefined or null reference” in file getJS.php line 151
I can see the data available when exporting to csv.
Can anybody give me a hint to solve this?
Cannot show history and graph
Re: Cannot show history and graph
Have you solved your issue? I have some similar without the js error.
Mes installations Jeedom : DIY sur micro PC Asrock Beebox (après 2 ans sur Raspberry Pi B+) dans maison en France, DIY sur micro PC Debian à mon domicile à Oslo. OS : Debian sans virtualisation.
Not really.
Tried a reinstall and it worked for a few days, but now im stuck again.
I suspect some regional date problems, but I don't have enough knowledge to find the problem.
Do you still get the same javascript error? I don't get Javascript error, but "wheel" is turning for ever.
I just found out now that removing the setup "Display widget statistics" helps for me. If that is active on your installation try to deactivate it and see if it helps.
