[Plugin Tiers][Sujet Principal] Rflink : passerelle RF433 multi-protocoles
dj_janker
Re: [Sujet officiel] Rflink : passerelle RF433 multi-protoco
Message par dj_janker » 10 févr. 2016, 18:11
lunarok a écrit :non, ca c'est les logs _node
ça? :oops:
Début de l'installtion
Reading package lists...
Building dependency tree...
Reading state information...
The following extra packages will be installed:
  libelf1 libftdi1
Suggested packages:
  avrdude-doc
  avrdude libelf1 libftdi1
0 upgraded, 3 newly installed, 0 to remove and 103 not upgraded.
Need to get 613 kB of archives.
After this operation, 2083 kB of additional disk space will be used.
Get:1 http://apt.adafruit.com/raspbian/ wheezy/main avrdude armhf 6.1-3 [294 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libftdi1 armhf 0.20-1 [19.0 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libelf1 armhf 0.152-1+wheezy1 [300 kB]
debconf: (This frontend requires a controlling tty.)
Fetched 613 kB in 1s (322 kB/s)
Selecting previously unselected package libftdi1:armhf.
(Reading database ... 89128 files and directories currently installed.)
Unpacking libftdi1:armhf (from .../libftdi1_0.20-1_armhf.deb) ...
Selecting previously unselected package libelf1.
Unpacking libelf1 (from .../libelf1_0.152-1+wheezy1_armhf.deb) ...
Selecting previously unselected package avrdude.
Unpacking avrdude (from .../avrdude_6.1-3_armhf.deb) ...
Processing triggers for man-db ...
Setting up libftdi1:armhf (0.20-1) ...
Setting up libelf1 (0.152-1+wheezy1) ...
Setting up avrdude (6.1-3) ...
mkdir: cannot create directory `/var/www': File exists
> serialport@2.0.6 install /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport
> node-pre-gyp install --fallback-to-build
child_process: customFds option is deprecated, use stdio instead.
make: Entering directory '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build'
  CXX(target) Release/obj.target/serialport/src/serialport.o
  CXX(target) Release/obj.target/serialport/src/serialport_unix.o
  CXX(target) Release/obj.target/serialport/src/serialport_poller.o
  SOLINK_MODULE(target) Release/obj.target/serialport.node
  SOLINK_MODULE(target) Release/obj.target/serialport.node: Finished
  COPY Release/serialport.node
  COPY /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build/Release/node-v14-linux-arm/serialport.node
  TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build'
serialport@2.0.6 node_modules/serialport
├── bindings@1.2.1
├── sf@0.1.7
├── async@0.9.0
├── debug@2.2.0 (ms@0.7.1)
├── nan@2.0.9
└── optimist@0.6.1 (wordwrap@0.0.3, minimist@0.0.10)
request@2.69.0 node_modules/request
├── is-typedarray@1.0.0
├── aws-sign2@0.6.0
├── forever-agent@0.6.1
├── caseless@0.11.0
├── stringstream@0.0.5
├── tunnel-agent@0.4.2
├── oauth-sign@0.8.1
├── isstream@0.1.2
├── json-stringify-safe@5.0.1
├── extend@3.0.0
├── node-uuid@1.4.7
├── combined-stream@1.0.5 (delayed-stream@1.0.0)
├── qs@6.0.2
├── aws4@1.2.1 (lru-cache@2.7.3)
├── tough-cookie@2.2.1
├── mime-types@2.1.9 (mime-db@1.21.0)
├── form-data@1.0.0-rc3 (async@1.5.2)
├── bl@1.0.1 (readable-stream@2.0.5)
├── har-validator@2.0.6 (pinkie-promise@2.0.0, chalk@1.1.1, commander@2.9.0, is-my-json-valid@2.12.4)
├── hawk@3.1.3 (cryptiles@2.0.5, sntp@1.0.9, boom@2.10.1, hoek@2.16.3)
└── http-signature@1.1.1 (assert-plus@0.2.0, jsprim@1.2.2, sshpk@1.7.3)
Fin de l'installtion
julien35
Message par julien35 » 10 févr. 2016, 20:29
Comme les autres, depuis la mise à jour Jeedom et plugin, j'ai un problème de prise en compte des températures remontées par mes thermomètres.
J'ai donc recréé un équipement, en supprimant l'ancien équipement, J'ai la création automatique d'un équipement mais pas la création des valeurs temp. et humid.. Peut être cela est il lié.
J'ai donc la gestion du chauffage de la maison qui est HS.
redvoodoochild
Message par redvoodoochild » 10 févr. 2016, 21:02
Les Logs "Rflink" sont quasiment identique au "rflink_node" :
09-02-2016 10:56:02 | info | Send Value : 20;A0;Oregon TempHygro;ID=2DA9;TEMP=00b8;HUM=49;HSTATUS=0;BAT=OK;
09-02-2016 10:56:06 | info | Send Value : 20;A1;Alecto V4;ID=5278;TEMP=00c4;HUM=47;
09-02-2016 10:56:41 | info | Send Value : 20;A2;Alecto V4;ID=5278;TEMP=00c4;HUM=47;
09-02-2016 10:57:16 | info | Send Value : 20;A3;Alecto V4;ID=5278;TEMP=00c4;HUM=47;
09-02-2016 10:57:20 | info | Send Value : 20;A4;Oregon TempHygro;ID=2DA9;TEMP=00b7;HUM=49;HSTATUS=0;BAT=OK;
09-02-2016 10:57:51 | info | Send Value : 20;A5;Alecto V4;ID=5278;TEMP=00c4;HUM=47;
09-02-2016 10:57:59 | info | Send Value : 20;A6;Oregon TempHygro;ID=2DA9;TEMP=00b7;HUM=49;HSTATUS=0;BAT=OK;
09-02-2016 10:58:26 | info | Send Value : 20;A7;Alecto V4;ID=5278;TEMP=00c4;HUM=47;
09-02-2016 10:58:38 | info | Send Value : 20;A8;Oregon TempHygro;ID=2DA9;TEMP=00b7;HUM=49;HSTATUS=0;BAT=OK;
09-02-2016 10:59:01 | info | Send Value : 20;A9;Alecto V4;ID=5278;TEMP=00c4;HUM=47;
09-02-2016 10:59:17 | info | Send Value : 20;AA;Oregon TempHygro;ID=2DA9;TEMP=00b7;HUM=49;HSTATUS=0;BAT=OK;
09-02-2016 10:59:36 | info | Send Value : 20;AB;Alecto V4;ID=5278;TEMP=00c4;HUM=47;
09-02-2016 10:59:56 | info | Send Value : 20;AC;Oregon TempHygro;ID=2DA9;TEMP=00b7;HUM=49;HSTATUS=0;BAT=OK;
09-02-2016 11:00:11 | info | Send Value : 20;AD;Alecto V4;ID=5278;TEMP=00c4;HUM=47;
09-02-2016 11:00:35 | info | Send Value : 20;AE;Oregon TempHygro;ID=2DA9;TEMP=00b7;HUM=49;HSTATUS=0;BAT=OK;
09-02-2016 11:00:46 | info | Send Value : 20;AF;Alecto V4;ID=5278;TEMP=00c4;HUM=47;
09-02-2016 11:01:21 | info | Send Value : 20;B0;Alecto V4;ID=5278;TEMP=00c4;HUM=47;
fred59190
Message par fred59190 » 10 févr. 2016, 21:05
salut j'ai le meme probleme:
sudo cat /dev/ttyACM1
20;0D;Oregon TempHygro;ID=2D7B;TEMP=00e6;HUM=55;HSTATUS=1;BAT=OK;
les sondes communiquent mais ne s ajoute pas a rflink jeedom, aucune sonde alors que je suis en inclusion
meme en mettant l id en manuel quelqu un a une idée?
lunarok
Message par lunarok » 10 févr. 2016, 21:32
Toujours pas de log rflink. C'est pas parce qu'il y'a peu de différences que j'en ai pas besoin au contraire.
Le problème étant pas reproduit j'ai besoin des 2 logs pour comparer. Et si vous avez des erreurs dans nginx.err
redvoodoochild
Message par redvoodoochild » 10 févr. 2016, 21:52
Je viens de comprendre.. désolé.
Le log Rflink :
[2016-02-10 21:45:28][rflink][INFO] : Arrêt du service rflink
[2016-02-10 21:46:05][rflink][INFO] : Arrêt du service rflink
[2016-02-10 21:46:05][rflink][INFO] : Lancement du démon rflink
[2016-02-10 21:46:05][rflink][DEBUG] : Lancement démon rflink : nice -n 19 nodejs /usr/share/nginx/www/jeedom/plugins/rflink/node/rflink.js http://192.168.1.150:80/core/api/jeeApi.php?api=xxxxxxxxxxxxxxxx /dev/ttyACM0 "none" 1 1 1
[2016-02-10 21:46:05][rflink][INFO] : Démon rflink lancé
[2016-02-10 21:46:17][rflink][DEBUG] : Protocole Oregon TempHygro ID 2DA9
[2016-02-10 21:46:40][rflink][DEBUG] : Protocole Alecto V4 ID 5278
[2016-02-10 21:46:56][rflink][DEBUG] : Protocole Oregon TempHygro ID 2DA9
[2016-02-10 21:47:15][rflink][DEBUG] : Protocole Alecto V4 ID 5278
[2016-02-10 21:47:50][rflink][DEBUG] : Protocole Alecto V4 ID 5278
[2016-02-10 21:48:21][rflink][DEBUG] : Protocole Oregon TempHygro ID 2DA9
[2016-02-10 21:48:32][rflink][DEBUG] : Protocole Alecto V4 ID 5278
[2016-02-10 21:49:00][rflink][DEBUG] : Protocole Oregon TempHygro ID 2DA9
[2016-02-10 21:49:07][rflink][DEBUG] : Protocole Alecto V4 ID 5278
[2016-02-10 21:49:25][rflink][DEBUG] : Protocole NewKaku ID 164cb83
[2016-02-10 21:49:39][rflink][DEBUG] : Protocole Oregon TempHygro ID 2DA9
[2016-02-10 21:49:42][rflink][DEBUG] : Protocole Alecto V4 ID 5278
[2016-02-10 21:50:17][rflink][DEBUG] : Protocole Alecto V4 ID 5278
[2016-02-10 21:50:18][rflink][DEBUG] : Protocole Oregon TempHygro ID 2DA9
nginx.err
2016/02/10 21:45:34 [error] 484#0: *619 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: 192.168.1.170, server: , request: "POST /core/ajax/jeedom.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "jeedom", referrer: "http://jeedom/index.php?v=d&p=reboot"
2016/02/10 21:45:51 [crit] 524#0: *1 connect() to unix:/var/run/php5-fpm.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.1.170, server: , request: "POST /core/ajax/event.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "jeedom", referrer: "http://jeedom/index.php?v=d&p=reboot"
2016/02/10 21:45:55 [error] 524#0: *4 FastCGI sent in stderr: "PHP message: PHP Warning:  unlink(/tmp/restart_mysql): No such file or directory in /usr/share/nginx/www/jeedom/core/class/DB.class.php on line 47" while reading response header from upstream, client: 192.168.1.170, server: , request: "POST /core/ajax/event.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "jeedom", referrer: "http://jeedom/index.php?v=d&p=reboot"
2016/02/10 21:47:35 [error] 524#0: *276 FastCGI sent in stderr: "PHP message: PHP Fatal error:  Uncaught exception 'PDOException' with message 'SQLSTATE[HY000] [2002] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)' in /usr/share/nginx/www/jeedom/core/class/DB.class.php:50
Stack trace:
#0 /usr/share/nginx/www/jeedom/core/class/DB.class.php(50): PDO->__construct('mysql:host=loca...', 'jeedom', '42b46cf2acd7968', Array)
#1 /usr/share/nginx/www/jeedom/core/class/DB.class.php(63): DB->__construct()
#2 /usr/share/nginx/www/jeedom/core/class/DB.class.php(94): DB::getConnection()
#3 /usr/share/nginx/www/jeedom/core/class/config.class.php(128): DB::Prepare('SELECT `value`
...', Array, 0)
#4 /usr/share/nginx/www/jeedom/core/class/log.class.php(39): config::byKey('log::engine')
#5 /usr/share/nginx/www/jeedom/core/class/log.class.php(68): log::getLogger('jeeEvent')
#6 /usr/share/nginx/www/jeedom/core/api/jeeApi.php(133): log::add('jeeEvent', 'error', 'SQLSTATE[HY000]...')
#7 {main}
  thrown in /usr/share/nginx/www/jeedom/core/class/DB.class.p" while reading response header from upstream, client: 192.168.1.150, server: , request: "PUT /core/api/jeeApi.php?api=xxxxxxxxxxxx&messagetype=saveValue&type=rflink HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "192.168.1.150:80"
lunarok
Message par lunarok » 10 févr. 2016, 22:52
J'ai repoussé une release qui devrait etre dispo demain matin.
Est-ce que tous ceux qui ont le soucis ont ce genre de logs ? parceque là 'SQLSTATE[HY000] [2002] Can't connect to local MySQL server through socket ' MySQL est indispo pendant l'appel, donc forcément il enregistre rien
A voir si il y a pas d'autres logs d'erreurs au niveau MySQL
nordix
Message par nordix » 10 févr. 2016, 23:55
Lunarock, l'erreur est dans l'appel à Jeedom API y a pas d'adresse IP. Il essaye d'appeler http://Jeedom/xxxx ça peut pas fonctionner.
Edit: En fait ne pense pas que ce soit lié le log est trompeur.
Envoyé de mon LG-D852 en utilisant Tapatalk
srpropper
Message par srpropper » 11 févr. 2016, 09:07
J'installé la nouvelle version et ont les mêmes problèmes, les commandes ne sont pas créées.
Ceci est la RFLINK log:
Welcome to minicom 2.7
OPCIONES: I18n
Compilado en Jan  1 2014, 09:30:18.
Port /dev/ttyACM0
Presione CTRL-A Z para obtener ayuda sobre teclas especiales
20;1D;Alecto V1;ID=0128;TEMP=00a9;HUM=61;BAT=OK;
20;1E;Mebus;ID=f901;TEMP=00b5;
20;1F;Alecto V1;ID=0128;WINSP=0008;BAT=OK;
20;20;Alecto V1;ID=0128;WINDIR=0005;WINGS=000a;BAT=OK;
20;21;Alecto V1;ID=0128;WINSP=0008;BAT=OK;
20;22;Alecto V1;ID=0128;WINDIR=0005;WINGS=000a;BAT=OK;
20;23;Alecto V1;ID=0128;WINSP=0008;BAT=OK;
20;24;Alecto V1;ID=0128;WINDIR=0005;WINGS=000a;BAT=OK;
20;25;Mebus;ID=f901;TEMP=00b5;
20;26;Alecto V1;ID=0128;WINSP=0008;BAT=OK;
20;27;Alecto V1;ID=0128;WINDIR=0005;WINGS=0008;BAT=OK;
20;28;Alecto V1;ID=0128;WINSP=0008;BAT=OK;
20;29;Alecto V1;ID=0128;WINDIR=0005;WINGS=0008;BAT=OK;
20;2A;Alecto V1;ID=0128;WINSP=0008;BAT=OK;
20;2B;Alecto V1;ID=0128;WINDIR=0005;WINGS=0008;BAT=OK;
lunarok
Message par lunarok » 11 févr. 2016, 09:08
@srpropper : les logs hors plugins ne m'intéressent pas, ce dont j'ai besoin c'est les logs rflink dans Jeedom
srpropper
Message par srpropper » 11 févr. 2016, 09:17
lunarok a écrit :@srpropper : les logs hors plugins ne m'intéressent pas, ce dont j'ai besoin c'est les logs rflink dans Jeedom
Ce sont eux qui vous avez besoin?
*************rflink_dep*************
+-- request@2.69.0
| +-- aws-sign2@0.6.0
| +-- aws4@1.2.1
| | `-- lru-cache@2.7.3
| +-- bl@1.0.2
| | `-- readable-stream@2.0.5
| |   +-- core-util-is@1.0.2
| |   +-- inherits@2.0.1
| |   +-- isarray@0.0.1
| |   +-- process-nextick-args@1.0.6
| |   +-- string_decoder@0.10.31
| |   `-- util-deprecate@1.0.2
| +-- caseless@0.11.0
| +-- combined-stream@1.0.5
| | `-- delayed-stream@1.0.0
| +-- extend@3.0.0
| +-- forever-agent@0.6.1
| +-- form-data@1.0.0-rc3
| | `-- async@1.5.2
| +-- har-validator@2.0.6
| | +-- chalk@1.1.1
| | | +-- ansi-styles@2.1.0
| | | +-- escape-string-regexp@1.0.4
| | | +-- has-ansi@2.0.0
| | | | `-- ansi-regex@2.0.0
| | | +-- strip-ansi@3.0.0
| | | `-- supports-color@2.0.0
| | +-- commander@2.9.0
| | | `-- graceful-readlink@1.0.1
| | +-- is-my-json-valid@2.12.4
| | | +-- generate-function@2.0.0
| | | +-- generate-object-property@1.2.0
| | | | `-- is-property@1.0.2
| | | +-- jsonpointer@2.0.0
| | | `-- xtend@4.0.1
| | `-- pinkie-promise@2.0.0
| |   `-- pinkie@2.0.4
| +-- hawk@3.1.3
| | +-- boom@2.10.1
| | +-- cryptiles@2.0.5
| | +-- hoek@2.16.3
| | `-- sntp@1.0.9
| +-- http-signature@1.1.1
| | +-- assert-plus@0.2.0
| | +-- jsprim@1.2.2
| | | +-- extsprintf@1.0.2
| | | +-- json-schema@0.2.2
| | | `-- verror@1.3.6
| | `-- sshpk@1.7.3
| |   +-- asn1@0.2.3
| |   +-- dashdash@1.12.2
| |   +-- ecc-jsbn@0.1.1
| |   +-- jodid25519@1.0.2
| |   +-- jsbn@0.1.0
| |   `-- tweetnacl@0.13.3
| +-- is-typedarray@1.0.0
| +-- isstream@0.1.2
| +-- json-stringify-safe@5.0.1
| +-- mime-types@2.1.9
| | `-- mime-db@1.21.0
| +-- node-uuid@1.4.7
| +-- oauth-sign@0.8.1
| +-- qs@6.0.2
| +-- stringstream@0.0.5
| +-- tough-cookie@2.2.1
| `-- tunnel-agent@0.4.2
`-- serialport@2.0.6
  +-- node-pre-gyp@0.6.18
  | +-- npmlog@2.0.0
  | | `-- are-we-there-yet@1.0.5
  | |     +-- inherits@2.0.1
  | |     +-- isarray@0.0.1
  | +-- request@2.67.0
  | | +-- aws-sign2@0.6.0
  | | +-- bl@1.0.0
  | | |   +-- inherits@2.0.1
  | | |   +-- isarray@0.0.1
  | | +-- caseless@0.11.0
  | | +-- extend@3.0.0
  | | +-- har-validator@2.0.3
  | | | +-- chalk@1.1.1
  | | | | +-- has-ansi@2.0.0
  | | | +-- commander@2.9.0
  | | | +-- is-my-json-valid@2.12.3
  | | | | `-- xtend@4.0.1
  | | +-- hawk@3.1.2
  | | | +-- boom@2.10.1
  | | | +-- cryptiles@2.0.5
  | | | +-- hoek@2.16.3
  | | | `-- sntp@1.0.9
  | | +-- http-signature@1.1.0
  | | | +-- jsprim@1.2.2
  | | | | `-- verror@1.3.6
  | | | `-- sshpk@1.7.1
  | | |   +-- asn1@0.2.3
  | | |   +-- ecc-jsbn@0.1.1
  | | |   `-- jsbn@0.1.0
  | | +-- isstream@0.1.2
  | | +-- node-uuid@1.4.7
  | +-- rimraf@2.4.4
  | | `-- glob@5.0.15
  | |   `-- inherits@2.0.1
  | +-- tar@2.2.1
  | | `-- inherits@2.0.1
  | `-- tar-pack@3.1.2
  |   +-- fstream@1.0.8
  |   | `-- inherits@2.0.1
  |   +-- fstream-ignore@1.0.3
  |   | `-- inherits@2.0.1
  |     +-- inherits@2.0.1
  |     +-- isarray@0.0.1
  `-- node-pre-gyp-github@1.1.1
    +-- commander@2.9.0
    `-- request@2.67.0
      +-- aws-sign2@0.6.0
      +-- bl@1.0.0
      |   +-- inherits@2.0.1
      |   +-- isarray@0.0.1
      +-- caseless@0.11.0
      +-- extend@3.0.0
      | +-- chalk@1.1.1
      | | +-- has-ansi@2.0.0
      | | `-- xtend@4.0.1
      +-- hawk@3.1.2
      | +-- boom@2.10.1
      | +-- cryptiles@2.0.5
      | +-- hoek@2.16.3
      | `-- sntp@1.0.9
      | +-- jsprim@1.2.2
      | | `-- verror@1.3.6
      | `-- sshpk@1.7.1
      |   +-- asn1@0.2.3
      |   +-- ecc-jsbn@0.1.1
      |   `-- jsbn@0.1.0
      +-- isstream@0.1.2
      +-- node-uuid@1.4.7
npm WARN ENOENT ENOENT: no such file or directory, open '/usr/share/nginx/www/jeedom/plugins/rflink/node/package.json'
npm WARN EPACKAGEJSON node No description
npm WARN EPACKAGEJSON node No repository field.
npm WARN EPACKAGEJSON node No README data
npm WARN EPACKAGEJSON node No license field.
*************rflink_node*************
11-02-2016 09:13:04 | info | Send Value : 20;9C;Alecto V1;ID=0128;WINSP=0010;BAT=OK;
11-02-2016 09:13:04 | debug | Got response Value: 200
11-02-2016 09:13:04 | debug | 20;9D;Alecto V1;ID=0128;WINDIR=0007;WINGS=0026;BAT=OK;
11-02-2016 09:13:04 | info | Send Value : 20;9D;Alecto V1;ID=0128;WINDIR=0007;WINGS=0026;BAT=OK;
11-02-2016 09:13:05 | debug | 20;9E;Alecto V1;ID=0128;WINSP=0010;BAT=OK;
11-02-2016 09:13:05 | info | Send Value : 20;9E;Alecto V1;ID=0128;WINSP=0010;BAT=OK;
11-02-2016 09:13:05 | debug | Got response Value: 200
11-02-2016 09:13:05 | debug | 20;9F;Alecto V1;ID=0128;WINDIR=0007;WINGS=0026;BAT=OK;
11-02-2016 09:13:05 | info | Send Value : 20;9F;Alecto V1;ID=0128;WINDIR=0007;WINGS=0026;BAT=OK;
11-02-2016 09:13:35 | debug | 20;A0;Alecto V1;ID=0128;WINSP=0010;BAT=OK;
11-02-2016 09:13:35 | info | Send Value : 20;A0;Alecto V1;ID=0128;WINSP=0010;BAT=OK;
11-02-2016 09:13:35 | debug | Got response Value: 200
11-02-2016 09:13:35 | debug | 20;A1;Alecto V1;ID=0128;WINDIR=0005;WINGS=0014;BAT=OK;
11-02-2016 09:13:35 | info | Send Value : 20;A1;Alecto V1;ID=0128;WINDIR=0005;WINGS=0014;BAT=OK;
11-02-2016 09:13:35 | debug | 20;A2;Alecto V1;ID=0128;WINSP=0010;BAT=OK;
11-02-2016 09:13:35 | info | Send Value : 20;A2;Alecto V1;ID=0128;WINSP=0010;BAT=OK;
11-02-2016 09:13:35 | debug | 20;A3;Alecto V1;ID=0128;WINDIR=0005;WINGS=0014;BAT=OK;
11-02-2016 09:13:35 | info | Send Value : 20;A3;Alecto V1;ID=0128;WINDIR=0005;WINGS=0014;BAT=OK;
11-02-2016 09:13:36 | debug | 20;A4;Alecto V1;ID=0128;WINSP=0010;BAT=OK;
11-02-2016 09:13:36 | info | Send Value : 20;A4;Alecto V1;ID=0128;WINSP=0010;BAT=OK;
11-02-2016 09:13:36 | debug | Got response Value: 200
11-02-2016 09:13:36 | debug | 20;A5;Alecto V1;ID=0128;WINDIR=0005;WINGS=0014;BAT=OK;
11-02-2016 09:13:36 | info | Send Value : 20;A5;Alecto V1;ID=0128;WINDIR=0005;WINGS=0014;BAT=OK;
*************nginx.error*************
2016/02/10 09:33:04 [error] 480#0: *56256 connect() to unix:/var/run/php5-fpm.sock failed (11: Resource temporarily unavailable) while connecting to upstream, client: 192.168.11.40, server: , request: "GET /jeedom/core/api/jeeApi.php?api=xxxxxxxxxxxxxxxxxxxxxxx&messagetype=saveGateway&type=rflink&status=0 HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "192.168.11.40:80"
2016/02/10 09:33:04 [error] 480#0: *56258 connect() to unix:/var/run/php5-fpm.sock failed (11: Resource temporarily unavailable) while connecting to upstream, client: 192.168.11.40, server: , request: "GET /jeedom/core/api/jeeApi.php?api=xxxxxxxxxxxxxxxxxxxxxxx&messagetype=saveGateway&type=rflink&status=0 HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "192.168.11.40:80"
2016/02/10 09:33:04 [error] 480#0: *56260 connect() to unix:/var/run/php5-fpm.sock failed (11: Resource temporarily unavailable) while connecting to upstream, client: 192.168.11.40, server: , request: "GET /jeedom/core/api/jeeApi.php?api=xxxxxxxxxxxxxxxxxxxxxxx&messagetype=saveGateway&type=rflink&status=0 HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "192.168.11.40:80"
2016/02/10 09:33:04 [error] 480#0: *56262 connect() to unix:/var/run/php5-fpm.sock failed (11: Resource temporarily unavailable) while connecting to upstream, client: 192.168.11.40, server: , request: "GET /jeedom/core/api/jeeApi.php?api=xxxxxxxxxxxxxxxxxxxxxxx&messagetype=saveGateway&type=rflink&status=0 HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "192.168.11.40:80"
2016/02/10 09:33:04 [error] 480#0: *56264 connect() to unix:/var/run/php5-fpm.sock failed (11: Resource temporarily unavailable) while connecting to upstream, client: 192.168.11.40, server: , request: "GET /jeedom/core/api/jeeApi.php?api=xxxxxxxxxxxxxxxxxxxxxxx&messagetype=saveGateway&type=rflink&status=0 HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "192.168.11.40:80"
2016/02/10 09:33:04 [error] 480#0: *56266 connect() to unix:/var/run/php5-fpm.sock failed (11: Resource temporarily unavailable) while connecting to upstream, client: 192.168.11.40, server: , request: "GET /jeedom/core/api/jeeApi.php?api=xxxxxxxxxxxxxxxxxxxxxxx&messagetype=saveGateway&type=rflink&status=0 HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "192.168.11.40:80"
2016/02/10 09:33:04 [error] 480#0: *56268 connect() to unix:/var/run/php5-fpm.sock failed (11: Resource temporarily unavailable) while connecting to upstream, client: 192.168.11.40, server: , request: "GET /jeedom/core/api/jeeApi.php?api=xxxxxxxxxxxxxxxxxxxxxxx&messagetype=saveGateway&type=rflink&status=0 HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "192.168.11.40:80"
2016/02/10 09:33:04 [error] 480#0: *56270 connect() to unix:/var/run/php5-fpm.sock failed (11: Resource temporarily unavailable) while connecting to upstream, client: 192.168.11.40, server: , request: "GET /jeedom/core/api/jeeApi.php?api=xxxxxxxxxxxxxxxxxxxxxxx&messagetype=saveGateway&type=rflink&status=0 HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "192.168.11.40:80"
2016/02/10 09:53:27 [error] 482#0: *57933 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 192.168.11.20, server: , request: "GET /jeedom/core/img/desktop_themes/bootable.png HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "192.168.11.40", referrer: "http://192.168.11.40/jeedom/index.php?v=d&p=profils"
Antrax
Message par Antrax » 11 févr. 2016, 09:20
Alors pour ma part.
les log RFLINK là ou il y a tout les log jeedom , avec log en mode DEBUG
[2016-02-11 09:17:08][rflink][DEBUG] : Commande TEMP value 004a
[2016-02-11 09:17:08][rflink][DEBUG] : Protocole Mebus ID a502
[2016-02-11 09:17:11][rflink][DEBUG] : Commande TEMP value 00c7
[2016-02-11 09:17:11][rflink][DEBUG] : Commande HUM value 47
[2016-02-11 09:17:11][rflink][DEBUG] : Protocole Alecto V4 ID 5c18
[2016-02-11 09:17:17][rflink][DEBUG] : Commande TEMP value 00c3
[2016-02-11 09:17:17][rflink][DEBUG] : Protocole Mebus ID e601
[2016-02-11 09:17:25][rflink][DEBUG] : Commande TEMP value 00c6
[2016-02-11 09:17:25][rflink][DEBUG] : Commande HUM value 41
[2016-02-11 09:17:25][rflink][DEBUG] : Protocole Alecto V4 ID 5928
[2016-02-11 09:17:33][rflink][DEBUG] : Commande TEMP value 0042
[2016-02-11 09:17:33][rflink][DEBUG] : Commande BAT value LOW
[2016-02-11 09:17:33][rflink][DEBUG] : Protocole Auriol ID 001F
[2016-02-11 09:17:34][rflink][DEBUG] : Commande TEMP value 00cb
[2016-02-11 09:17:34][rflink][DEBUG] : Commande HUM value 40
[2016-02-11 09:17:34][rflink][DEBUG] : Protocole Alecto V4 ID 52d8
[2016-02-11 09:17:44][rflink][DEBUG] : Commande TEMP value 0049
[2016-02-11 09:17:44][rflink][DEBUG] : Protocole Mebus ID a502
[2016-02-11 09:17:46][rflink][DEBUG] : Commande TEMP value 00c7
[2016-02-11 09:17:46][rflink][DEBUG] : Commande HUM value 47
[2016-02-11 09:17:46][rflink][DEBUG] : Protocole Alecto V4 ID 5c18
[2016-02-11 09:17:52][rflink][DEBUG] : Commande TEMP value 00c3
[2016-02-11 09:17:52][rflink][DEBUG] : Protocole Mebus ID e601
[2016-02-11 09:18:00][rflink][DEBUG] : Commande TEMP value 00c6
[2016-02-11 09:18:00][rflink][DEBUG] : Commande HUM value 41
[2016-02-11 09:18:00][rflink][DEBUG] : Protocole Alecto V4 ID 592
Les logs dans le plugin RFLINK:
02-2016 09:16:50 | debug | 20;0C;Alecto V4;ID=5928;TEMP=00c6;HUM=41;
11-02-2016 09:16:50 | info | Send Value : 20;0C;Alecto V4;ID=5928;TEMP=00c6;HUM=41;
11-02-2016 09:16:50 | debug | Got response Value: 200
11-02-2016 09:17:08 | debug | 20;0D;Mebus;ID=a502;TEMP=004a;
11-02-2016 09:17:08 | info | Send Value : 20;0D;Mebus;ID=a502;TEMP=004a;
11-02-2016 09:17:08 | debug | Got response Value: 200
11-02-2016 09:17:11 | debug | 20;0E;Alecto V4;ID=5c18;TEMP=00c7;HUM=47;
11-02-2016 09:17:11 | info | Send Value : 20;0E;Alecto V4;ID=5c18;TEMP=00c7;HUM=47;
11-02-2016 09:17:11 | debug | Got response Value: 200
11-02-2016 09:17:17 | debug | 20;0F;Mebus;ID=e601;TEMP=00c3;
11-02-2016 09:17:17 | info | Send Value : 20;0F;Mebus;ID=e601;TEMP=00c3;
11-02-2016 09:17:17 | debug | Got response Value: 200
11-02-2016 09:17:25 | debug | 20;10;Alecto V4;ID=5928;TEMP=00c6;HUM=41;
11-02-2016 09:17:25 | info | Send Value : 20;10;Alecto V4;ID=5928;TEMP=00c6;HUM=41;
11-02-2016 09:17:25 | debug | Got response Value: 200
11-02-2016 09:17:33 | debug | 20;11;Auriol;ID=001F;TEMP=0042;BAT=LOW;
11-02-2016 09:17:33 | info | Send Value : 20;11;Auriol;ID=001F;TEMP=0042;BAT=LOW;
11-02-2016 09:17:33 | debug | Got response Value: 200
11-02-2016 09:17:34 | debug | 20;12;Alecto V4;ID=52d8;TEMP=00cb;HUM=40;
11-02-2016 09:17:34 | info | Send Value : 20;12;Alecto V4;ID=52d8;TEMP=00cb;HUM=40;
11-02-2016 09:17:34 | debug | Got response Value: 200
11-02-2016 09:17:44 | debug | 20;13;Mebus;ID=a502;TEMP=0049;
11-02-2016 09:17:44 | info | Send Value : 20;13;Mebus;ID=a502;TEMP=0049;
11-02-2016 09:17:44 | debug | Got response Value: 200
11-02-2016 09:17:46 | debug | 20;14;Alecto V4;ID=5c18;TEMP=00c7;HUM=47;
11-02-2016 09:17:46 | info | Send Value : 20;14;Alecto V4;ID=5c18;TEMP=00c7;HUM=47;
11-02-2016 09:17:46 | debug | Got response Value: 200
11-02-2016 09:17:52 | debug | 20;15;Mebus;ID=e601;TEMP=00c3;
11-02-2016 09:17:52 | info | Send Value : 20;15;Mebus;ID=e601;TEMP=00c3;
11-02-2016 09:17:52 | debug | Got response Value: 200
11-02-2016 09:18:00 | debug | 20;16;Alecto V4;ID=5928;TEMP=00c6;HUM=41;
11-02-2016 09:18:00 | info | Send Value : 20;16;Alecto V4;ID=5928;TEMP=00c6;HUM=41;
11-02-2016 09:18:00 | debug | Got response Value: 200
11-02-2016 09:18:19 | debug | 20;17;Mebus;ID=a502;TEMP=0049;
11-02-2016 09:18:19 | info | Send Value : 20;17;Mebus;ID=a502;TEMP=0049;
11-02-2016 09:18:19 | debug | Got response Value: 200
11-02-2016 09:18:21 | debug | 20;18;Alecto V4;ID=5c18;TEMP=00c7;HUM=47;
11-02-2016 09:18:21 | info | Send Value : 20;18;Alecto V4;ID=5c18;TEMP=00c7;HUM=47;
11-02-2016 09:18:21 | debug | Got response Value: 200
11-02-2016 09:18:27 | debug | 20;19;Mebus;ID=e601;TEMP=00c3;
11-02-2016 09:18:27 | info | Send Value : 20;19;Mebus;ID=e601;TEMP=00c3;
11-02-2016 09:18:27 | debug | Got response Value: 200
11-02-2016 09:18:35 | debug | 20;1A;Alecto V4;ID=5928;TEMP=00c6;HUM=41;
11-02-2016 09:18:35 | info | Send Value : 20;1A;Alecto V4;ID=5928;TEMP=00c6;HUM=41;
11-02-2016 09:18:35 | debug | Got response Value: 200
11-02-2016 09:18:44 | debug | 20;1B;Auriol;ID=002D;TEMP=00cb;BAT=OK;
11-02-2016 09:18:44 | info | Send Value : 20;1B;Auriol;ID=002D;TEMP=00cb;BAT=OK;
11-02-2016 09:18:44 | debug | Got response Value: 200
11-02-2016 09:18:44 | debug | 20;1C;Alecto V4;ID=52d8;TEMP=00cb;HUM=40;
11-02-2016 09:18:44 | info | Send Value : 20;1C;Alecto V4;ID=52d8;TEMP=00cb;HUM=40;
11-02-2016 09:18:53 | debug | 20;1D;Mebus;ID=a502;TEMP=0049;
11-02-2016 09:18:53 | info | Send Value : 20;1D;Mebus;ID=a502;TEMP=0049;
11-02-2016 09:18:53 | debug | Got response Value: 200
11-02-2016 09:18:56 | debug | 20;1E;Alecto V4;ID=5c18;TEMP=00c7;HUM=47;
11-02-2016 09:18:56 | info | Send Value : 20;1E;Alecto V4;ID=5c18;TEMP=00c7;HUM=47;
11-02-2016 09:18:56 | debug | Got response Value: 200
11-02-2016 09:19:01 | debug | 20;1F;Mebus;ID=e601;TEMP=00c3;
11-02-2016 09:19:01 | info | Send Value : 20;1F;Mebus;ID=e601;TEMP=00c3;
11-02-2016 09:19:01 | debug | Got response Value: 200
Dis moi si il te faut autre chose. Je peux te donner facilement accès au serveur si tu le souhaite. ;)
Antrax
Message par Antrax » 11 févr. 2016, 09:24
et je n'ai pas d'erreur dans le nginx.error.
lunarok
Message par lunarok » 11 févr. 2016, 09:25
Et là il y a une nouvelle version avec plus de logs
Antrax
Message par Antrax » 11 févr. 2016, 09:35
lunarok a écrit :Et là il y a une nouvelle version avec plus de logs
J'ai updater avec le push de 2016-02-11 09:13:38.
pour l'instant je ne vois que celui là.
redvoodoochild
Message par redvoodoochild » 11 févr. 2016, 10:32
Hello.
Donc le log rflink :
[2016-02-11 10:26:03][rflink][INFO] : Lancement du démon rflink
[2016-02-11 10:26:03][rflink][DEBUG] : Lancement démon rflink : nice -n 19 nodejs /usr/share/nginx/www/jeedom/plugins/rflink/node/rflink.js http://192.168.1.150:80/core/api/jeeApi.php?api=xxxxxxxxxxxxxxxx /dev/ttyACM0 "none" 1 1 1
[2016-02-11 10:26:03][rflink][INFO] : Démon rflink lancé
[2016-02-11 10:26:17][rflink][DEBUG] : Commande TEMP value 00b6
[2016-02-11 10:26:17][rflink][DEBUG] : Commande HUM value 42
[2016-02-11 10:26:17][rflink][DEBUG] : Commande HSTATUS value 0
[2016-02-11 10:26:17][rflink][DEBUG] : Commande BAT value OK
[2016-02-11 10:26:17][rflink][DEBUG] : Protocole Oregon TempHygro ID 2DA9
[2016-02-11 10:26:19][rflink][DEBUG] : Commande TEMP value 00bf
[2016-02-11 10:26:19][rflink][DEBUG] : Commande HUM value 41
[2016-02-11 10:26:19][rflink][DEBUG] : Protocole Alecto V4 ID 5278
[2016-02-11 10:26:54][rflink][DEBUG] : Commande TEMP value 00bf
[2016-02-11 10:26:54][rflink][DEBUG] : Commande HUM value 41
[2016-02-11 10:26:54][rflink][DEBUG] : Protocole Alecto V4 ID 5278
[2016-02-11 10:26:56][rflink][DEBUG] : Commande TEMP value 00b6
[2016-02-11 10:26:56][rflink][DEBUG] : Commande HUM value 42
[2016-02-11 10:26:56][rflink][DEBUG] : Commande HSTATUS value 0
[2016-02-11 10:26:56][rflink][DEBUG] : Commande BAT value OK
[2016-02-11 10:26:56][rflink][DEBUG] : Protocole Oregon TempHygro ID 2DA9
[2016-02-11 10:27:29][rflink][DEBUG] : Commande TEMP value 00bf
[2016-02-11 10:27:29][rflink][DEBUG] : Commande HUM value 41
[2016-02-11 10:27:29][rflink][DEBUG] : Protocole Alecto V4 ID 5278
Pas de log dans nginx.error
dj_janker
Message par dj_janker » 11 févr. 2016, 10:47
@lunarok il se peut que le plugin utilise la vieille clef api de 20 caractères, plutôt que le nouveau 48, pour lancer le démon?
Enviado desde mi JY-S3 mediante Tapatalk
julien35
Message par julien35 » 11 févr. 2016, 12:12
C'est ok pour moi avec la version disponible en mise à jour.
Merci pour la réactivité.
lunarok
Message par lunarok » 11 févr. 2016, 12:29
Cool merci du retour.
Si tout est bon je vais attaquer les rflink esp
Antrax
Message par Antrax » 11 févr. 2016, 13:00
lunarok a écrit :Cool merci du retour.
Je confirme, la remonté des sondes sur le dashboard.
Merci beaucoup lunarok!! ;)
