[Plugin Tiers][Sujet Principal] MyHOME Zigbee legrand
Didier3L
Re: Clé zigbee legrand
Message par Didier3L » 22 juin 2016, 13:12
Merci Apages 8-) 8-)
je commence à tester ce soir ... :arrow:
Didier3L
Message par Didier3L » 22 juin 2016, 20:01
supprimé
Didier3L
Message par Didier3L » 22 juin 2016, 20:06
Avec Management - Commande management
J'ai testé Scan
http.error
[Wed Jun 22 18:10:13.627240 2016] [:error] [pid 66] [client 172.17.0.1:59972] PHP Warning: Illegal string offset 'what' in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 768, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:10:13.627293 2016] [:error] [pid 66] [client 172.17.0.1:59972] PHP Notice: Uninitialized string offset: 0 in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 768, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:10:13.627314 2016] [:error] [pid 66] [client 172.17.0.1:59972] PHP Warning: Illegal string offset 'dim' in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 769, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:10:13.627335 2016] [:error] [pid 66] [client 172.17.0.1:59972] PHP Notice: Uninitialized string offset: 0 in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 769, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:10:13.627419 2016] [:error] [pid 66] [client 172.17.0.1:59972] PHP Notice: Undefined variable: category in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 806, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:10:13.627441 2016] [:error] [pid 66] [client 172.17.0.1:59972] PHP Notice: Undefined variable: category in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 809, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:10:13.627461 2016] [:error] [pid 66] [client 172.17.0.1:59972] PHP Notice: Undefined variable: category in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 812, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:10:13.627482 2016] [:error] [pid 66] [client 172.17.0.1:59972] PHP Notice: Undefined variable: category in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 815, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:10:13.627503 2016] [:error] [pid 66] [client 172.17.0.1:59972] PHP Notice: Undefined variable: category in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 818, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:10:13.627524 2016] [:error] [pid 66] [client 172.17.0.1:59972] PHP Notice: Undefined variable: who in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 822, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
myhome
[2016-06-22 20:10:13][myhome][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *13*65*## [format] => BUS_COMMAND [mode] => UNKNOWN [media] => ZIGBEE [type] => MANAGEMENT [value] => SCAN [dimension] => [param] => [id] => [unit] => [date] => 2016-06-22 20:10:13 )
[2016-06-22 20:10:13][myhome][DEBUG] : Jeemyhome_Aucun équipement trouvé pour : NULL Création de l'equipement
[2016-06-22 20:10:13][myhome][ERROR] : Information manquante pour ajouter l'équipement : Array ( [trame] => *13*65*## [format] => BUS_COMMAND [mode] => UNKNOWN [media] => ZIGBEE [type] => MANAGEMENT [value] => SCAN [dimension] => NULL [param] => NULL [id] => NULL [unit] => NULL [date] => 2016-06-22 20:10:13 )
[2016-06-22 20:10:13][myhome][DEBUG] : Jeemyhome_Aucun équipement trouvé pour : NULL Erreur lors de la création de l'équipement
[2016-06-22 20:10:13][myhome][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *#*1## [format] => ACK [mode] => UNKNOWN [media] => ZIGBEE [type] => SCENE [value] => [dimension] => [param] => [id] => [unit] => [date] => 2016-06-22 20:10:13 )
[2016-06-22 20:10:13][myhome][DEBUG] : Jeemyhome_Trame non interprétée
[2016-06-22 20:10:26][myhome][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *#13**67*7## [format] => UNKNOWN [mode] => UNKNOWN [media] => ZIGBEE [type] => UNKNOWN [value] => [dimension] => [param] => [id] => [unit] => [date] => 2016-06-22 20:10:26 )
[2016-06-22 20:10:26][myhome][DEBUG] : Jeemyhome_Aucun équipement trouvé pour : NULL Création de l'equipement
[2016-06-22 20:10:26][myhome][ERROR] : Information manquante pour ajouter l'équipement : Array ( [trame] => *#13**67*7## [format] => UNKNOWN [mode] => UNKNOWN [media] => ZIGBEE [type] => UNKNOWN [value] => NULL [dimension] => NULL [param] => NULL [id] => NULL [unit] => NULL [date] => 2016-06-22 20:10:26 )
[2016-06-22 20:10:26][myhome][DEBUG] : Jeemyhome_Aucun équipement trouvé pour : NULL Erreur lors de la création de l'équipement
Didier3L
Message par Didier3L » 22 juin 2016, 20:41
J'ai créé un équipement 6814 avec comme ID 6814 qui correspond au code de ma prise 0 883 37
J'ai mis en équipement Light - commande de lumière.
Toutes les commandes se sont bien créés 8-)
Test ON ok 8-)
Test OFF ok 8-)
Light Statut Reques ok 8-)
La prise recoit bien les commandes 8-)
Par contre des erreurs dans les logs :
Commande ON
http.erreur
[Wed Jun 22 18:38:48.777564 2016] [:error] [pid 4973] [client 172.17.0.1:35781] PHP Warning: Illegal string offset 'what' in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 768, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:38:48.777608 2016] [:error] [pid 4973] [client 172.17.0.1:35781] PHP Notice: Uninitialized string offset: 0 in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 768, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:38:48.777630 2016] [:error] [pid 4973] [client 172.17.0.1:35781] PHP Warning: Illegal string offset 'dim' in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 769, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:38:48.777650 2016] [:error] [pid 4973] [client 172.17.0.1:35781] PHP Notice: Uninitialized string offset: 0 in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 769, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:38:48.777744 2016] [:error] [pid 4973] [client 172.17.0.1:35781] PHP Notice: Undefined variable: category in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 806, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:38:48.777766 2016] [:error] [pid 4973] [client 172.17.0.1:35781] PHP Notice: Undefined variable: category in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 809, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:38:48.777786 2016] [:error] [pid 4973] [client 172.17.0.1:35781] PHP Notice: Undefined variable: category in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 812, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:38:48.777807 2016] [:error] [pid 4973] [client 172.17.0.1:35781] PHP Notice: Undefined variable: category in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 815, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:38:48.777827 2016] [:error] [pid 4973] [client 172.17.0.1:35781] PHP Notice: Undefined variable: category in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 818, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:38:48.777848 2016] [:error] [pid 4973] [client 172.17.0.1:35781] PHP Notice: Undefined variable: who in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 822, referer: http://192.168.1.10:9080/index.php?v=d& ... e&p=myhome
[Wed Jun 22 18:38:48.804201 2016] [:error] [pid 6090] [client 127.0.0.1:60964] PHP Fatal error: Uncaught Error: Call to a member function event() on boolean in /var/www/html/plugins/myhome/core/class/myhome.class.php:495
Stack trace:
#0 /var/www/html/plugins/myhome/core/class/myhome.class.php(431): myhome::updateStatusLight(Array, true)
#1 /var/www/html/plugins/myhome/core/php/jeemyhome.php(65): myhome::updateStatus(Array)
#2 {main}
thrown in /var/www/html/plugins/myhome/core/class/myhome.class.php on line 495
myhome OK 8-)
[2016-06-22 20:38:48][myhome][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *1*1*681401#9## [format] => BUS_COMMAND [mode] => UNICAST [media] => ZIGBEE [type] => light [value] => ON [dimension] => [param] => [id] => 6814 [unit] => 01 [date] => 2016-06-22 20:38:48 )
[2016-06-22 20:38:48][myhome][DEBUG] : Jeemyhome_BUS_COMMAND
[2016-06-22 20:38:48][myhome][DEBUG] : Update Status Light
[2016-06-22 20:38:48][myhome][DEBUG] : statusid : status01 date : 1466620728
[2016-06-22 20:38:48][myhome][DEBUG] : mise a jour du status : ON
[2016-06-22 20:38:48][myhome][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *#*1## [format] => ACK [mode] => UNKNOWN [media] => ZIGBEE [type] => SCENE [value] => [dimension] => [param] => [id] => [unit] => [date] => 2016-06-22 20:38:48 )
[2016-06-22 20:38:48][myhome][DEBUG] : Jeemyhome_Trame non interprétée
Greg0307
Message par Greg0307 » 22 juin 2016, 21:08
apages a écrit :Bonjour a tous les deux.
La première version est disponible sur le market sous le nom Myhome.
Il s'agit bien entendu d'une version "beta" car je n'ai pas pu tester les différents cas de figure de type commande ou statuts car je n'ai qu'un 88338 et un 88337.
@greg0307, pourrais-tu rajouter dans ta signature les équipements que tu possèdes ?
Merci pour vos retours.
salut voici pour la signature et j'essaie le plugin dans la foulée merci
Raspberry pi
LEGRAND 88328, commande 67223, inter 88306
Rfx, sonde oregon, store rts.
Comptage CM 180
Schneider wiser
Dongle use Zigbee Xstick
Didier3L
Message par Didier3L » 22 juin 2016, 21:29
Greg0307 a écrit :salut voici pour la signature et j'essaie le plugin dans la foulée merci
Raspberry pi
Comptage CM 180
Schneider wiser
Panneau de contrôle de l’utilisateur / Profil / Éditer la signature
Greg0307
Message par Greg0307 » 22 juin 2016, 21:33
Tout est ok de mon côté.
Les cdes ce sont ajoutés automatiquement et fonctionnent
Didier3L
Message par Didier3L » 22 juin 2016, 22:06
Greg0307 a écrit :Tout est ok de mon côté.
Les équipements dans le plugin Mes Equipements Myhome se sont créés automatiquement :?:
Greg0307
Message par Greg0307 » 22 juin 2016, 22:23
oui par contre je n'arrive pas à afficher le retour d'état sur widget
Raspberry pi
Comptage CM 180
Schneider wiser
Didier3L
Message par Didier3L » 23 juin 2016, 11:39
Oui moi aussi je n'arrive pas à faire un retour sur un widget.
Par contre, peux tu passer en mode DEBUG et regarder si tu as des messages d'erreur comme moi :?:
apages
Clé zigbee legrand
Message par apages » 23 juin 2016, 11:50
Concernant les messages d'erreur je vais regarder, mais je pense qu'il existe aussi sur boxio
Je vais rajouter des contrôles
Sinon pouvez-vous faire un état précis de ce qui marche et ce qui marche pas
Pour le widget, lequel utilise vous ?
raspberry pi3 et raspberry pi JEEDOM V3.1.3 avec module Legrand USB-CPL et RFXCOM433
Legrand : 10 inter VR avec derogation : 67255, 1 inter VR sans derogation : 67251,1 Selecteur Programmable CPL : 67449, 3 Sortie de cable CPL : 67445
Didier3L
Message par Didier3L » 23 juin 2016, 13:20
j'utilise Eclairage_On_Off que j'ai affecté sur la commande Light Statut Request de mon Équipement 6814.
Mais j'ai peut être pas fait comme il fallait :oops:
apages
Message par apages » 23 juin 2016, 13:22
Non effectivement
Il fau supprimer toute les commandes
Choisir le template d'équipement lumière et affecter le widget a la commande de type info qui s'appel statuts
Didier3L
Message par Didier3L » 23 juin 2016, 18:53
J'ai essayé toutes les commandes pour un interrupteur/variateur 0 672 27
Tout fonctionne à l’exception de :
OFF at X speed
[2016-06-23 18:48:59][myhome][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *1*0##SPEED#*723301801#9## [format] => UNKNOWN [mode] => UNKNOWN [media] => ZIGBEE [type] => UNKNOWN [value] => [dimension] => [param] => [id] => [unit] => [date] => 2016-06-23 18:48:59 )
[2016-06-23 18:48:59][myhome][DEBUG] : Jeemyhome_Aucun équipement trouvé pour : NULL Création de l'equipement
[2016-06-23 18:48:59][myhome][ERROR] : Information manquante pour ajouter l'équipement : Array ( [trame] => *1*0##SPEED#*723301801#9## [format] => UNKNOWN [mode] => UNKNOWN [media] => ZIGBEE [type] => UNKNOWN [value] => NULL [dimension] => NULL [param] => NULL [id] => NULL [unit] => NULL [date] => 2016-06-23 18:48:59 )
[2016-06-23 18:48:59][myhome][DEBUG] : Jeemyhome_Aucun équipement trouvé pour : NULL Erreur lors de la création de l'équipement
[2016-06-23 18:48:59][myhome][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *#*0## [format] => NACK [mode] => UNKNOWN [media] => ZIGBEE [type] => SCENE [value] => [dimension] => [param] => [id] => [unit] => [date] => 2016-06-23 18:48:59 )
[2016-06-23 18:48:59][myhome][DEBUG] : Jeemyhome_Trame non interprétée
ON at X speed
[2016-06-23 18:49:43][myhome][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *1*1##SPEED#*723301801#9## [format] => UNKNOWN [mode] => UNKNOWN [media] => ZIGBEE [type] => UNKNOWN [value] => [dimension] => [param] => [id] => [unit] => [date] => 2016-06-23 18:49:43 )
[2016-06-23 18:49:43][myhome][DEBUG] : Jeemyhome_Aucun équipement trouvé pour : NULL Création de l'equipement
[2016-06-23 18:49:43][myhome][ERROR] : Information manquante pour ajouter l'équipement : Array ( [trame] => *1*1##SPEED#*723301801#9## [format] => UNKNOWN [mode] => UNKNOWN [media] => ZIGBEE [type] => UNKNOWN [value] => NULL [dimension] => NULL [param] => NULL [id] => NULL [unit] => NULL [date] => 2016-06-23 18:49:43 )
[2016-06-23 18:49:43][myhome][DEBUG] : Jeemyhome_Aucun équipement trouvé pour : NULL Erreur lors de la création de l'équipement
[2016-06-23 18:49:43][myhome][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *#*0## [format] => NACK [mode] => UNKNOWN [media] => ZIGBEE [type] => SCENE [value] => [dimension] => [param] => [id] => [unit] => [date] => 2016-06-23 18:49:43 )
[2016-06-23 18:49:43][myhome][DEBUG] : Jeemyhome_Trame non interprétée
Get/Set dimming level and speed
[2016-06-23 18:51:12][myhome][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *#1*723301801#9*#1*#SLIDER*#SPEED### [format] => UNKNOWN [mode] => UNKNOWN [media] => ZIGBEE [type] => UNKNOWN [value] => [dimension] => [param] => [id] => [unit] => [date] => 2016-06-23 18:51:12 )
[2016-06-23 18:51:12][myhome][DEBUG] : Jeemyhome_Aucun équipement trouvé pour : NULL Création de l'equipement
[2016-06-23 18:51:12][myhome][ERROR] : Information manquante pour ajouter l'équipement : Array ( [trame] => *#1*723301801#9*#1*#SLIDER*#SPEED### [format] => UNKNOWN [mode] => UNKNOWN [media] => ZIGBEE [type] => UNKNOWN [value] => NULL [dimension] => NULL [param] => NULL [id] => NULL [unit] => NULL [date] => 2016-06-23 18:51:12 )
[2016-06-23 18:51:12][myhome][DEBUG] : Jeemyhome_Aucun équipement trouvé pour : NULL Erreur lors de la création de l'équipement
[2016-06-23 18:51:12][myhome][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *#*0## [format] => NACK [mode] => UNKNOWN [media] => ZIGBEE [type] => SCENE [value] => [dimension] => [param] => [id] => [unit] => [date] => 2016-06-23 18:51:12 )
[2016-06-23 18:51:12][myhome][DEBUG] : Jeemyhome_Trame non interprétée
Didier3L
Message par Didier3L » 23 juin 2016, 19:05
Non effectivement
Pour le retour d’état, je n'ai pas trouvé la commande de type info qui s'appelle statuts :idea:
Didier3L
Message par Didier3L » 23 juin 2016, 19:22
@Greg
tes équipements se sont créés tous seul dans la partie gauche :?:
apages
Message par apages » 23 juin 2016, 19:38
ah effectivement, j'ai oublié de la mettre dans le Template
bon en fait, il suffit de créer une nouvelle commande de type info/autre
tu l'appel comme tu veux
le seul truc obligatoire est la trame: tu mets status01
Didier3L
Message par Didier3L » 24 juin 2016, 17:54
apages a écrit :ah effectivement, j'ai oublié de la mettre dans le Template
Parfait ça marche 8-)
Greg0307
Message par Greg0307 » 25 juin 2016, 08:39
Didier3L a écrit :@Greg
oui
Raspberry pi
Comptage CM 180
Schneider wiser
Didier3L
Message par Didier3L » 25 juin 2016, 10:03
Et bien pour moi, aucun équipement ne c'est crée
J'ai dû les créer manuellement
