Bonjour, j'ai acheté une clé Huawei E220 (logo vodafone) elle est reconnue au branchement, mais lorsque je selectionne le port et que je sauvegarde, j'ai ceci dans leslogs:
[2016-09-14 13:40:07][INFO] : Lancement démon sms : /usr/bin/python /var/www/html/plugins/sms/resources/smsd/smsd.py --device=/dev/ttyUSB1 --loglevel=debug --socketport=55002 --serialrate=115200 --pin=1234 --textmode=no --smsc=None --sockethost=127.0.0.1 --callback=
http://127.0.0.1:80/plugins/sms/core/php/jeeSMS.php --apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[2016-09-14 13:40:07][INFO] : Start smsd
[2016-09-14 13:40:07][INFO] : Log level : debug
[2016-09-14 13:40:07][INFO] : Socket port : 55002
[2016-09-14 13:40:07][INFO] : Socket host : 127.0.0.1
[2016-09-14 13:40:07][INFO] : PID file : /tmp/smsd.pid
[2016-09-14 13:40:07][INFO] : Device : /dev/ttyUSB1
[2016-09-14 13:40:07][INFO] : Apikey : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[2016-09-14 13:40:07][INFO] : Callback :
[2016-09-14 13:40:07][INFO] : Cycle : 5.0
[2016-09-14 13:40:07][INFO] : Serial rate : 115200
[2016-09-14 13:40:07][INFO] : Pin : 1234
[2016-09-14 13:40:07][INFO] : Text mode : no
[2016-09-14 13:40:07][INFO] : SMSC : None
[2016-09-14 13:40:07][DEBUG] : Writing PID 4800 to /tmp/smsd.pid
[2016-09-14 13:40:07][DEBUG] : Init request module v2.4.3
[2016-09-14 13:40:07][INFO] : Starting new HTTP connection (1): 127.0.0.1
[2016-09-14 13:40:07][DEBUG] : "GET /plugins/sms/core/php/jeeSMS.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 None
[2016-09-14 13:40:07][DEBUG] : Socket interface started
[2016-09-14 13:40:07][DEBUG] : LoopNetServer Thread started
[2016-09-14 13:40:07][DEBUG] : Start listening...
[2016-09-14 13:40:07][DEBUG] : Listening on: [127.0.0.1:55002]
[2016-09-14 13:40:07][DEBUG] : Connecting to GSM Modem...
[2016-09-14 13:40:07][DEBUG] : Text mode false
[2016-09-14 13:40:07][DEBUG] : Enter pin code : 1234
[2016-09-14 13:40:07][INFO] : Connecting to modem on port /dev/ttyUSB1 at 115200bps
[2016-09-14 13:40:07][DEBUG] : write: ATZ
[2016-09-14 13:40:17][ERROR] : Exception: Timeout
[2016-09-14 13:40:17][DEBUG] : Send to jeedom : {'message': 'Timeout', 'number': 'none'}
[2016-09-14 13:40:17][INFO] : Starting new HTTP connection (1): 127.0.0.1
[2016-09-14 13:40:17][DEBUG] : "POST /plugins/sms/core/php/jeeSMS.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 None
[2016-09-14 13:40:17][ERROR] : Exit 1 because this exeption is fatal
[2016-09-14 13:40:17][DEBUG] : Shutdown
[2016-09-14 13:40:17][DEBUG] : Removing PID file /tmp/smsd.pid
[2016-09-14 13:40:18][DEBUG] : LoopNetServer Thread stopped
[2016-09-14 13:40:18][DEBUG] : Exit 0
du coup ça ne marche pas...
Que dois-faire? Je suis sous jeedom raspberry pi 3 jessie.
Merci d'avance,
