voici le log d'une antenne opi zero:
[2017-02-02 08:25:15][INFO] : Start blead
[2017-02-02 08:25:15][INFO] : Log level : debug
[2017-02-02 08:25:15][INFO] : Socket port : 55008
[2017-02-02 08:25:15][INFO] : Socket host :
[2017-02-02 08:25:15][INFO] : Device : hci0
[2017-02-02 08:25:15][INFO] : PID file : /tmp/blead.pid
[2017-02-02 08:25:15][INFO] : Apikey : xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[2017-02-02 08:25:15][INFO] : Callback : http://192.168.0.10:80/plugins/blea/core/php/jeeBlea.php
[2017-02-02 08:25:15][INFO] : Cycle : 0.3
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.dotti
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.fitbit
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.gigaset
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.hector
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.itag
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.jinlin
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.logiswitch
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.miband
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.miband2
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.miflora
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.miscale
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.myfox
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.niu
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.noke
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.nut
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.playbulb
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.smartplug
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.tb05
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.ticatag
[2017-02-02 08:25:15][INFO] : Import de la configuration devices.wistiki
[2017-02-02 08:25:15][DEBUG] : Writing PID 15191 to /tmp/blead.pid
[2017-02-02 08:25:15][DEBUG] : Init request module v2.4.3
[2017-02-02 08:25:16][INFO] : Starting new HTTP connection (1): 192.168.0.10
[2017-02-02 08:25:16][DEBUG] : "GET /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 None
[2017-02-02 08:25:16][DEBUG] : Socket interface started
[2017-02-02 08:25:16][DEBUG] : LoopNetServer Thread started
[2017-02-02 08:25:16][INFO] : Start listening...
[2017-02-02 08:25:16][DEBUG] : Listening on: [:55008]
[2017-02-02 08:25:16][INFO] : Preparing Scanner...
[2017-02-02 08:25:16][DEBUG] : Read Socket Thread Launched
[2017-02-02 08:25:16][DEBUG] : Send to jeedom : {'source': 'opizero2', 'learn_mode': 0}
[2017-02-02 08:25:16][DEBUG] : Read Device Thread Launched
[2017-02-02 08:25:16][DEBUG] : Heartbeat Thread Launched
[2017-02-02 08:25:16][DEBUG] : Send to jeedom : {'started': 1, 'source': 'opizero2'}
[2017-02-02 08:25:16][DEBUG] : "POST /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 None
[2017-02-02 08:25:16][DEBUG] : Client connected to [192.168.0.10:44668]
[2017-02-02 08:25:16][DEBUG] : Message read from socket: {"apikey":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxx","cmd":"add","device":{"id":"E1:5A:D2:79:97:7A","delay":0,"needsrefresh":0,"name":"miband2","refreshlist":[],"islocked":0,"emitterallowed":"local","refresherallowed":"local"}}
[2017-02-02 08:25:16][DEBUG] : Client disconnected from [192.168.0.10:44668]
[2017-02-02 08:25:16][DEBUG] : Client connected to [192.168.0.10:44671]
[2017-02-02 08:25:16][DEBUG] : Message read from socket: {"apikey":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxx","cmd":"add","device":{"id":"D1:17:B5:DB:7F:85","delay":0,"needsrefresh":0,"name":"0","refreshlist":[],"islocked":0,"emitterallowed":"local","refresherallowed":"local"}}
[2017-02-02 08:25:16][DEBUG] : Client disconnected from [192.168.0.10:44671]
[2017-02-02 08:25:16][WARNING] : Exception on scanner (trying to resolve by myself 6): Failed to execute mgmt cmd 'le on'
[2017-02-02 08:25:16][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2017-02-02 08:25:16][DEBUG] : Received command from jeedom : add
[2017-02-02 08:25:16][DEBUG] : Add device : {u'needsrefresh': 0, u'name': u'miband2', u'emitterallowed': u'local', u'delay': 0, u'refresherallowed': u'local', u'islocked': 0, u'refreshlist': [], u'id': u'E1:5A:D2:79:97:7A'}
[2017-02-02 08:25:16][WARNING] : Exception on scanner (trying to resolve by myself 7): Failed to execute mgmt cmd 'le on'
[2017-02-02 08:25:16][DEBUG] : Add device : {u'needsrefresh': 0, u'name': u'0', u'emitterallowed': u'local', u'delay': 0, u'refresherallowed': u'local', u'islocked': 0, u'refreshlist': [], u'id': u'D1:17:B5:DB:7F:85'}
[2017-02-02 08:25:16][WARNING] : Exception on scanner (trying to resolve by myself 8): Failed to execute mgmt cmd 'le on'
[2017-02-02 08:25:16][ERROR] : Exception on scanner (didn't resolve there is an issue with bluetooth) : Failed to execute mgmt cmd 'le on'
[2017-02-02 08:25:16][INFO] : Shutting down due to errors
[2017-02-02 08:25:17][DEBUG] : "POST /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 None
[2017-02-02 08:25:18][DEBUG] : Shutdown
[2017-02-02 08:25:18][DEBUG] : Removing PID file /tmp/blead.pid
[2017-02-02 08:25:18][DEBUG] : Closing all potential bluetooth connection
[2017-02-02 08:25:19][DEBUG] : LoopNetServer Thread stopped
[2017-02-02 08:25:19][DEBUG] : Exit 0
A priori il s'agit d'une erreur avec la librairie bluepy.
J'ai vu que @bbreton avait posé une question sur le github du créateur de la lib.
Je n'ai pas les connaissances pour aller chercher l'erreur; d'autant que pour moi python étant un langage interprété il ne devrait y avoir de problème lié à l'architecture de l'orange pi.
Que faut-il que l'on cherche ?
edit: Par ailleurs j'ai pu configurer une antenne sur un raspi3 avec osmc et ça fait 2 jours que ça tourne sans problème. La portée n'a pas l'air terrible quand même. Pour ceux qui ont des problèmes avec le bt du raspi 3, est ce que vous utilisez le wifi simultanément?
J'ai pu lire par ci par là que sur le rpi3 l'usage simultané du wifi et du bt donnait de mauvais résultats. A mon avis ils doivent partager la même antenne.
