May 5 17:17:09 localhost kernel: [ 0.827906] usb 1-1: new high-speed USB device number 2 using dwc_otg
May 5 17:17:09 localhost kernel: [ 0.828170] dwc_otg: Indeed it is in host mode hprt0 = 00001101
May 5 17:17:09 localhost kernel: [ 1.089671] hub 1-1:1.0: USB hub found
May 5 17:17:09 localhost kernel: [ 1.089968] hub 1-1:1.0: 4 ports detected
May 5 17:17:09 localhost kernel: [ 1.267918] raid6: int64x1 508 MB/s
May 5 17:17:09 localhost kernel: [ 1.368100] usb 1-1.3: new full-speed USB device number 3 using dwc_otg
May 5 17:17:09 localhost kernel: [ 1.437906] raid6: int64x2 819 MB/s
May 5 17:17:09 localhost kernel: [ 1.448117] usb 1-1.3: device descriptor read/64, error -32
May 5 17:17:09 localhost kernel: [ 1.607838] raid6: int64x4 1297 MB/s
May 5 17:17:09 localhost kernel: [ 1.638166] usb 1-1.3: device descriptor read/64, error -32
May 5 17:17:09 localhost kernel: [ 1.777848] raid6: int64x8 1392 MB/s
May 5 17:17:09 localhost kernel: [ 1.828096] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
May 5 17:17:09 localhost kernel: [ 1.908113] usb 1-1.3: device descriptor read/64, error -32
May 5 17:17:09 localhost kernel: [ 1.947890] raid6: neonx1 886 MB/s
May 5 17:17:09 localhost kernel: [ 2.098162] usb 1-1.3: device descriptor read/64, error -32
May 5 17:17:09 localhost kernel: [ 2.117846] raid6: neonx2 1445 MB/s
May 5 17:17:09 localhost kernel: [ 2.133848] random: nonblocking pool is initialized
May 5 17:17:09 localhost kernel: [ 2.287850] raid6: neonx4 1884 MB/s
May 5 17:17:09 localhost kernel: [ 2.297838] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
May 5 17:17:09 localhost kernel: [ 2.457863] raid6: neonx8 1885 MB/s
May 5 17:17:09 localhost kernel: [ 2.457867] raid6: using algorithm neonx8 (1885 MB/s)
May 5 17:17:09 localhost kernel: [ 2.457871] raid6: using intx1 recovery algorithm
May 5 17:17:09 localhost kernel: [ 2.458314] xor: measuring software checksum speed
May 5 17:17:09 localhost kernel: [ 2.557829] 8regs : 2846.000 MB/sec
May 5 17:17:09 localhost kernel: [ 2.605953] switch_vpu_mem_pd: viu_vd1 OFF
May 5 17:17:09 localhost kernel: [ 2.605958] switch_vpu_mem_pd: afbc_dec OFF
May 5 17:17:09 localhost kernel: [ 2.605962] switch_vpu_mem_pd: di_post OFF
May 5 17:17:09 localhost kernel: [ 2.605966] switch_vpu_mem_pd: viu_vd2 OFF
May 5 17:17:09 localhost kernel: [ 2.657844] 8regs_prefetch: 2612.000 MB/sec
May 5 17:17:09 localhost kernel: [ 2.717842] usb 1-1.3: device not accepting address 5, error -71
May 5 17:17:09 localhost kernel: [ 2.757846] 32regs : 3467.200 MB/sec
May 5 17:17:09 localhost kernel: [ 2.828109] usb 1-1.4: new full-speed USB device number 7 using dwc_otg
May 5 17:17:09 localhost kernel: [ 2.857830] 32regs_prefetch: 2881.600 MB/sec
May 5 17:17:09 localhost kernel: [ 2.857837] xor: using function: 32regs (3467.200 MB/sec)
May 5 17:17:09 localhost kernel: [ 2.867864] bio: create slab <bio-1> at 1
May 5 17:17:09 localhost kernel: [ 2.868485] Btrfs loaded
May 5 17:17:09 localhost kernel: [ 2.868558] BTRFS: selftest: Running btrfs free space cache tests
May 5 17:17:09 localhost kernel: [ 2.868563] BTRFS: selftest: Running extent only tests
May 5 17:17:09 localhost kernel: [ 2.868580] BTRFS: selftest: Running bitmap only tests
May 5 17:17:09 localhost kernel: [ 2.868596] BTRFS: selftest: Running bitmap and extent tests
May 5 17:17:09 localhost kernel: [ 2.868617] BTRFS: selftest: Free space cache tests finished
May 5 17:17:09 localhost kernel: [ 2.868620] BTRFS: selftest: Running extent buffer operation tests
May 5 17:17:09 localhost kernel: [ 2.868624] BTRFS: selftest: Running btrfs_split_item tests
May 5 17:17:09 localhost kernel: [ 2.868661] BTRFS: selftest: Running find delalloc tests
May 5 17:17:09 localhost kernel: [ 3.117032] BTRFS: selftest: Running btrfs_get_extent tests
May 5 17:17:09 localhost kernel: [ 3.117214] BTRFS: selftest: Running hole first btrfs_get_extent test
May 5 17:17:09 localhost kernel: [ 3.168232] usb 1-1.3: new full-speed USB device number 8 using dwc_otg
May 5 17:17:09 localhost kernel: [ 3.270035] cdc_acm 1-1.3:1.0: This device cannot do calls on its own. It is not a modem.
May 5 17:17:09 localhost kernel: [ 3.271802] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
May 5 17:17:09 localhost kernel: [ 4.278854] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
May 5 17:17:09 localhost kernel: [ 4.722083] fuse init (API version 7.22)
May 5 17:17:09 localhost kernel: [ 4.731844] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
May 5 17:17:09 localhost kernel: [ 4.731923] cectx c810023c.aocec: aml_cec_class_devnode(): mode is 1b6
May 5 17:17:09 localhost kernel: [ 5.012972] cectx c810023c.aocec: aml_cec_class_devnode(): mode is 1b6
May 5 17:17:09 localhost kernel: [ 5.013246] cectx c810023c.aocec: aml_cec_class_devnode(): mode is 1b6
May 5 17:17:09 localhost kernel: [ 5.013681] cectx c810023c.aocec: aml_cec_class_devnode(): mode is 1b6
May 5 17:17:09 localhost kernel: [ 5.030875] Driver for 1-wire Dallas network protocol.
May 5 17:17:09 localhost kernel: [ 5.225883] usbcore: registered new interface driver ftdi_sio
May 5 17:17:09 localhost kernel: [ 5.225936] usbserial: USB Serial support registered for FTDI USB Serial Device
May 5 17:17:09 localhost kernel: [ 5.226040] ftdi_sio 1-1.4:1.0: FTDI USB Serial Device converter detected
May 5 17:17:09 localhost kernel: [ 5.226101] usb 1-1.4: Detected FT232RL
May 5 17:17:09 localhost kernel: [ 5.226107] usb 1-1.4: Number of endpoints 2
May 5 17:17:09 localhost kernel: [ 5.226112] usb 1-1.4: Endpoint 1 MaxPacketSize 64
May 5 17:17:09 localhost kernel: [ 5.226117] usb 1-1.4: Endpoint 2 MaxPacketSize 64
May 5 17:17:09 localhost kernel: [ 5.226122] usb 1-1.4: Setting MaxPacketSize 64
May 5 17:17:09 localhost kernel: [ 5.226466] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB0
May 5 17:17:09 localhost kernel: [ 5.281063] ionvideo open
May 5 17:17:09 localhost kernel: [ 5.477881] ionvideo_stop_generating!!!!
May 5 17:17:09 localhost kernel: [ 5.477945] ionvideo release
May 5 17:17:09 localhost kernel: [ 5.491447] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
May 5 17:17:09 localhost kernel: [ 5.537767] Adding 131068k swap on /var/swap. Priority:-1 extents:1 across:131068k SS
May 5 17:17:09 localhost kernel: [ 9.918085] libphy: stmmac-0:00 - Link is Up - 1000/Full
May 5 17:17:09 localhost kernel: [ 13.791784] vout_serve: vmode set to 1080p60hz
jeedom@odroidc2:/var/log$ sudo lsusb
Bus 001 Device 007: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 008: ID 0658:0200 Sigma Designs, Inc.
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
