![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
J'ai commandé pleins de boutons, ça simplifie vraiment la domotique de rajouter des boutons physique !
En plus ça fonctionne bien, c'est pas compliqué à mettre en place, et les délai sont plus qu'acceptables !
Début de l'installation
Reading package lists...
Building dependency tree...
Reading state information...
libpcap-dev is already the newest version.
tcpdump is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 159 not upgraded.
Version actuelle : v5.12.0
Ok, version suffisante
/var/www/html/plugins/dashbutton/node
`-- request@2.81.0
+-- aws-sign2@0.6.0
+-- aws4@1.6.0
+-- caseless@0.12.0
+-- combined-stream@1.0.5
| `-- delayed-stream@1.0.0
+-- extend@3.0.1
+-- forever-agent@0.6.1
+-- form-data@2.1.4
| `-- asynckit@0.4.0
+-- har-validator@4.2.1
| +-- ajv@4.11.8
| | +-- co@4.6.0
| | `-- json-stable-stringify@1.0.1
| | `-- jsonify@0.0.0
| `-- har-schema@1.0.5
+-- hawk@3.1.3
| +-- boom@2.10.1
| +-- cryptiles@2.0.5
| +-- hoek@2.16.3
| `-- sntp@1.0.9
+-- http-signature@1.1.1
| +-- assert-plus@0.2.0
| +-- jsprim@1.4.0
| | +-- assert-plus@1.0.0
| | +-- extsprintf@1.0.2
| | +-- json-schema@0.2.3
| | `-- verror@1.3.6
| `-- sshpk@1.13.1
| +-- asn1@0.2.3
| +-- bcrypt-pbkdf@1.0.1
| +-- dashdash@1.14.1
| | `-- assert-plus@1.0.0
| +-- ecc-jsbn@0.1.1
| +-- getpass@0.1.7
| +-- jsbn@0.1.1
| `-- tweetnacl@0.14.5
+-- is-typedarray@1.0.0
+-- isstream@0.1.2
+-- json-stringify-safe@5.0.1
+-- mime-types@2.1.15
| `-- mime-db@1.27.0
+-- oauth-sign@0.8.2
+-- performance-now@0.2.0
+-- qs@6.4.0
+-- safe-buffer@5.1.1
+-- stringstream@0.0.5
+-- tough-cookie@2.3.2
| `-- punycode@1.4.1
+-- tunnel-agent@0.6.0
`-- uuid@3.1.0
npm WARN enoent ENOENT: no such file or directory, open '/var/www/html/plugins/dashbutton/node/package.json'
npm WARN node No description
npm WARN node No repository field.
npm WARN node No README data
npm WARN node No license field.
> socketwatcher@0.3.0 install /var/www/html/plugins/dashbutton/node/node_modules/socketwatcher
> node-gyp rebuild
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/5.12.0"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/var/www/html/plugins/dashbutton/node/node_modules/socketwatcher/.node-gyp"
make: Entering directory '/var/www/html/plugins/dashbutton/node/node_modules/socketwatcher/build'
CXX(target) Release/obj.target/socketwatcher/socket_watcher.o
SOLINK_MODULE(target) Release/obj.target/socketwatcher.node
COPY Release/socketwatcher.node
make: Leaving directory '/var/www/html/plugins/dashbutton/node/node_modules/socketwatcher/build'
> pcap@2.0.0 install /var/www/html/plugins/dashbutton/node/node_modules/pcap
> node-gyp rebuild
gyp WARN EACCES attempting to reinstall using temporary dev dir "/var/www/html/plugins/dashbutton/node/node_modules/pcap/.node-gyp"
make: Entering directory '/var/www/html/plugins/dashbutton/node/node_modules/pcap/build'
CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
CXX(target) Release/obj.target/pcap_binding/pcap_session.o
SOLINK_MODULE(target) Release/obj.target/pcap_binding.node
COPY Release/pcap_binding.node
make: Leaving directory '/var/www/html/plugins/dashbutton/node/node_modules/pcap/build'
+-- node-dash-button@0.6.1
| +-- pcap@2.0.0 (git+https://github.com/mranney/node_pcap.git#b4eb828fbfb3ad9a253351aa38cb41c203589712)
| | +-- nan@2.6.2
| | `-- socketwatcher@0.3.0
| `-- underscore@1.8.3
`-- request@2.81.0
