[Jeedom V3.1] Problèmes avec la mise à jour
Re: [Jeedom V3.1] Problèmes avec la mise à jour
j'ai visiblement un probleme different vue que la mise a jour ne se finalise pas sur mon jeedom DIY.
j'ai testé plusieur fois a plusieur moment et mon serveur Jeedom a bien access a internet.
voici le log si quelqu'un a une idée je suis plus que preneur
[START UPDATE]
****Install/update jeedom from 3.0.9 (2017-09-26 11:50:29)****
Configuration : level : -1, mode : , version : , onlyThisVersion :
Send begin of update event...OK
Check rights...
OK
[START BACKUP]
***************Start of Jeedom backup at 2017-09-26 11:50:29***************
Send begin backup event...OK
Check database...Warning: Using a password on the command line interface can be insecure.
OK
Backup database...Warning: Using a password on the command line interface can be insecure.
OK
Persist cache :
OK
Create archive...
OK
Clean old backup...OK
Limit the total size of backups to 1500 Mo...
Remove : /usr/share/nginx/www/jeedom/core/php/../../backup/backup-DUMX-3.0.9-2017-09-26-00h59.tar.gz
OK
Name of backup : /usr/share/nginx/www/jeedom/core/php/../../backup/backup-DUMX-3.0.9-2017-09-26-11h50.tar.gz
Send end backup event...OK
Backup duration : 18s
***************Fin de la sauvegarde de Jeedom***************
[END BACKUP SUCCESS]
Disable all task.
... OK
Disable all scenario
................................. OK
Clean temporary file (tmp)...OK
Download url : https://github.com/jeedom/core/archive/releas.zip
Download in progress...--2017-09-26 11:50:51-- https://github.com/jeedom/core/archive/releas.zip
Resolving github.com (github.com)... 192.30.253.112, 192.30.253.113
Connecting to github.com (github.com)|192.30.253.112|:443... connected.
HTTP request sent, awaiting response...
302 Found
Location: https://codeload.github.com/jeedom/core/zip/releas [following]
--2017-09-26 11:50:51-- https://codeload.github.com/jeedom/core/zip/releas
Resolving codeload.github.com (codeload.github.com)... 192.30.253.120, 192.30.253.121
Connecting to codeload.github.com (codeload.github.com)|192.30.253.120|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2017-09-26 11:50:52 ERROR 404: Not Found.
Enable scenario : OK
Enable task : OK
Error during install : Download failed please retry laterDetails : Array
[END UPDATE ERROR]
PHP Fatal error: Uncaught exception 'Exception' with message 'Download failed please retry later' in /usr/share/nginx/www/jeedom/install/install.php:160
Stack trace:
#0 {main}
thrown in /usr/share/nginx/www/jeedom/install/install.php on line 160
[START UPDATE]
Check rights...
OK
[START BACKUP]
OK
OK
Persist cache :
OK
Create archive...
OK
OK
Disable all task.
... OK
302 Found
Enable task : OK
[END UPDATE ERROR]
Stack trace:
#0 {main}
Jeedom (DIY)
Protocole Domotique : Blea, ESPEasy, Mochad X10, RfLink, RFXcom, Xiaomi Home, Z-Wave
Autres : SMS, Harmony Hub, Sonos, Amazon Dash, Camera, Netatmo, RTS, etc...
SI tu est sur que le plugin fonctionne, créé juste un fichier info.json dans le dossier plugin_info du CurrentCost et tout va réapparaître.
"id" : "CurrentCost",
"name" : "CurrentCost",
"licence" : "AGPL",
"author" : "Thomas MARTINEZ",
"require" : "2.4",
"category" : "organization"
Lenovo M720 Tiny - VMWare Debian 9 Jeedom DIY
Zwave - Bluetooth
Alexa Echo - Harmony Elite
Zwave - Bluetooth
bon j'ai supprimé le plugin obsolete (datatransfert) et j'ai tjs l'info dans la log plugin, snif
Idem même après un reboot et en plus il est bavard ça log souvent
Jeedom
La rétention de l'information est une forme de constipation du savoir.
Documentation - Trucs & Astuces - Charte
Le process de mise a jour essaye de télécharger le fichier releas.zip qui n'existe pas. La solution a été donnée dans les commentaires précédents.Mike27140 a écrit : ↑26 sept. 2017, 11:55Bonjour,
[START UPDATE]
Check rights...
OK
[START BACKUP]
OK
OK
Persist cache :
OK
Create archive...
OK
OK
Disable all task.
... OK
302 Found
Enable task : OK
[END UPDATE ERROR]
Stack trace:
#0 {main}
RPI3 avec disque dur
MySensors : téléinfo, Température-humidité-ouverture
ESPEasy : Relais contact sec garage, Relais VMC
DIY Wifi : Capteur de consommation avec pinces ampèremétriques
Xiaomi : Roborock S50
BLEA : Mi Flora
BLEA : Mi Flora
Merci pour le tuyau BetyOops !BetyOops a écrit : ↑26 sept. 2017, 11:56SI tu est sur que le plugin fonctionne, créé juste un fichier info.json dans le dossier plugin_info du CurrentCost et tout va réapparaître.
{ "id" : "CurrentCost", "name" : "CurrentCost", "licence" : "AGPL", "author" : "Thomas MARTINEZ", "require" : "2.4", "category" : "organization" }
* Jeedom VM sur Synology DS916+ 8Go/24To / Zwave AEON GEN5 / RfxTrx433E *
Matériel complet --> http://forum.jeedom.fr/memberlist.php?m ... ile&u=1001 <--
Idem pour moi, que faire SVP ?
[START UPDATE]
****Install/update jeedom from 3.0.9 (2017-09-26 12:46:03)****
Check rights...OK
[START BACKUP]
***************Start of Jeedom backup at 2017-09-26 12:46:04***************
Check database...
OK
Backup database...
OK
Persist cache :
OK
Create archive...
OK
Limit the total size of backups to 500 Mo...
Remove : /var/www/html/core/php/../../backup/backup-kvb14-3.0.9-2017-09-26-06h59.tar.gz
OK
Name of backup : /var/www/html/core/php/../../backup/backup-kvb14-3.0.9-2017-09-26-12h46.tar.gz
Backup duration : 36s
Disable all task OK
Disable all scenario............
Download in progress...converted 'https://github.com/jeedom/core/archive/releas.zip' (ANSI_X3.4-1968) -> 'https://github.com/jeedom/core/archive/releas.zip' (UTF-8)
--2017-09-26 10:46:44-- https://github.com/jeedom/core/archive/releas.zip
Resolving github.com (github.com)... 192.30.253.113, 192.30.253.112
Connecting to github.com (github.com)|192.30.253.113|:443... connected.
HTTP request sent, awaiting response... 302 Found
converted 'https://codeload.github.com/jeedom/core/zip/releas' (ANSI_X3.4-1968) -> 'https://codeload.github.com/jeedom/core/zip/releas' (UTF-8)
--2017-09-26 10:46:45-- https://codeload.github.com/jeedom/core/zip/releas
2017-09-26 10:46:45 ERROR 404: Not Found.
Enable task : OK
[END UPDATE ERROR]
PHP Fatal error: Uncaught exception 'Exception' with message 'Download failed please retry later' in /var/www/html/install/install.php:160
Stack trace:
#0 {main}
thrown in /var/www/html/install/install.php on line 160
[START UPDATE]
Check rights...OK
[START BACKUP]
Check database...
OK
Backup database...
OK
Persist cache :
OK
Create archive...
OK
OK
Disable all task OK
Enable task : OK
[END UPDATE ERROR]
Stack trace:
#0 {main}
La réponse a été donnée page 2 à 8h41kvb a écrit : ↑26 sept. 2017, 12:51Bonjour,
[START UPDATE]
Check rights...OK
[START BACKUP]
Check database...
OK
Backup database...
OK
Persist cache :
OK
Create archive...
OK
OK
Disable all task OK
Enable task : OK
[END UPDATE ERROR]
Stack trace:
#0 {main}
BLEA : Mi Flora
BLEA : Mi Flora
Bon,
à part la mise à jour qui persiste à être affichée, j'ai résolu mes autres problèmes:
j'ai créé un fichier info.json pour le plugin maxcube
j'ai migré mon install vers apache
Entre temps il y a bien eu une dizaine de plugins à mettre à jour. Tous sans problème.
Je n'ai pas parcouru toutes les fonctionnalités (juste la timeline) mais ça semble ok.
Bravo pour le boulot.
Jeedom sur vm esxi stretch
Principaux plugins: eibd, homebridge, maxcube, icalendar
OK merci, mais où et comment il faut modifier cette commande ?snow51 a écrit : ↑26 sept. 2017, 12:52La réponse a été donnée page 2 à 8h41kvb a écrit : ↑26 sept. 2017, 12:51Bonjour,
[START UPDATE]
Check rights...OK
[START BACKUP]
Check database...
OK
Backup database...
OK
Persist cache :
OK
Create archive...
OK
OK
Disable all task OK
Enable task : OK
[END UPDATE ERROR]
Stack trace:
#0 {main}
Désolé mais je ne sais pas, c'est pas si évident que ça !
Un simple reboot, tout est rentré dans l'ordre.benj29 a écrit : ↑26 sept. 2017, 11:50Bonjour,
Update de Jeedom en 3.1 ce matin, tout semble bon.
Jusqu'au moment où je me rends compte que toutes mes températures Xiaomi sont décalées de 2h en avance !
Retour vers le futur, Xiaomi ? Non... tout jeedom en fait. Que ce soit mes températures de nodemcu, l'état des mes capteurs chacon etc...
Suis-je le seul ? (à 11h45 il est 13h45).
Je précise que l'heure de mon Jeedom est bien à 11h45... (en haut à droite).
Si cela peut aider du monde dans le même cas.
Merci cela à corrigé le problemesnow51 a écrit : ↑26 sept. 2017, 09:41Pour ceux qui ont le soucis de mise à jour qui ne s'effectue pas il faut modifier le fichier install/install.php
$url = 'https://github.com/jeedom/core/archive/releas.zip';
devrait être
$url = 'https://github.com/jeedom/core/archive/' . config::byKey('core::branch') . '.zip';
Jeedom (DIY)
effectivement petite recherche de maj ce midi et de nombreux plugin sont mis à jour, tout est nickel de mon coté à part les restes du vieux plugin supprimé mais qui pollue pas mal les logs car tres bavard.
Bravo pour le job réalisé
Dans quels logs ? Et tu peux en copier un bout stpsteph034 a écrit :effectivement petite recherche de maj ce midi et de nombreux plugin sont mis à jour, tout est nickel de mon coté à part les restes du vieux plugin supprimé mais qui pollue pas mal les logs car tres bavard.
From Tapatruc !
@Sshafi, j'ai le même bug. Le plugin supprimé via le centre de mise à jour.Sshafi a écrit : ↑26 sept. 2017, 13:55Dans quels logs ? Et tu peux en copier un bout stpsteph034 a écrit :effectivement petite recherche de maj ce midi et de nombreux plugin sont mis à jour, tout est nickel de mon coté à part les restes du vieux plugin supprimé mais qui pollue pas mal les logs car tres bavard.
From Tapatruc !
C'est dans le log plugin Même après un reboot ça continue
Visiblement toutes les données du plugin supprimé sont présentes dans la base encore.
Jeedom
oui c'est bien cela, c'est dans la log Plugin, même message pour moi, sur le même plugin.
J'ai supprimé moi aussi celui ci via le centre de mise à jour (il n'y a que là qu'il était encore visible) et malgré moi aussi un reboot, tjs bcp de logs indiquant l'erreur.
Avec un outil comme filezilla sur pc ou cyberduck sur mac tu te connectes en sftp a ta box jeedom et tu vas modifier le fichier dans /var/www/install/
BLEA : Mi Flora
BLEA : Mi Flora
bon mes messages sur le fofo marche une fois sur deux .
donc je reprend toujours aucun affichage sur aucune page que se soit dash plugin log y'a que la page de mise a jour qui marche et a moitie .
tous marche par domo-widget .
je peut vous donner aucun logs vu que la page et vide .
@kvb : essaye avant de faire une maj jeedom seulement forcée stp
From Tapatruc !
From Tapatruc !
