[Jeedom V3.1] Problèmes avec la mise à jour
Mike27140
Re: [Jeedom V3.1] Problèmes avec la mise à jour
Message par Mike27140 » 26 sept. 2017, 11:55
j'ai visiblement un probleme different vue que la mise a jour ne se finalise pas sur mon jeedom DIY.
j'ai testé plusieur fois a plusieur moment et mon serveur Jeedom a bien access a internet.
voici le log si quelqu'un a une idée je suis plus que preneur :-)
[START UPDATE]
****Install/update jeedom from 3.0.9 (2017-09-26 11:50:29)****
Configuration : level : -1, mode : , version : , onlyThisVersion :
Send begin of update event...OK
Check rights...
OK
[START BACKUP]
***************Start of Jeedom backup at 2017-09-26 11:50:29***************
Send begin backup event...OK
Check database...Warning: Using a password on the command line interface can be insecure.
OK
Backup database...Warning: Using a password on the command line interface can be insecure.
OK
Persist cache :
OK
Create archive...
OK
Clean old backup...OK
Limit the total size of backups to 1500 Mo...
Remove : /usr/share/nginx/www/jeedom/core/php/../../backup/backup-DUMX-3.0.9-2017-09-26-00h59.tar.gz
OK
Name of backup : /usr/share/nginx/www/jeedom/core/php/../../backup/backup-DUMX-3.0.9-2017-09-26-11h50.tar.gz
Send end backup event...OK
Backup duration : 18s
***************Fin de la sauvegarde de Jeedom***************
[END BACKUP SUCCESS]
Disable all task.
... OK
Disable all scenario
................................. OK
Clean temporary file (tmp)...OK
Download url : https://github.com/jeedom/core/archive/releas.zip
Download in progress...--2017-09-26 11:50:51-- https://github.com/jeedom/core/archive/releas.zip
Resolving github.com (github.com)... 192.30.253.112, 192.30.253.113
Connecting to github.com (github.com)|192.30.253.112|:443... connected.
HTTP request sent, awaiting response...
302 Found
Location: https://codeload.github.com/jeedom/core/zip/releas [following]
--2017-09-26 11:50:51-- https://codeload.github.com/jeedom/core/zip/releas
Resolving codeload.github.com (codeload.github.com)... 192.30.253.120, 192.30.253.121
Connecting to codeload.github.com (codeload.github.com)|192.30.253.120|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2017-09-26 11:50:52 ERROR 404: Not Found.
Enable scenario : OK
Enable task : OK
Error during install : Download failed please retry laterDetails : Array
[END UPDATE ERROR]
PHP Fatal error: Uncaught exception 'Exception' with message 'Download failed please retry later' in /usr/share/nginx/www/jeedom/install/install.php:160
Stack trace:
#0 {main}
thrown in /usr/share/nginx/www/jeedom/install/install.php on line 160
Jeedom (DIY)
Protocole Domotique : Blea, ESPEasy, Mochad X10, RfLink, RFXcom, Xiaomi Home, Z-Wave
Autres : SMS, Harmony Hub, Sonos, Amazon Dash, Camera, Netatmo, RTS, etc...
BetyOops
Message par BetyOops » 26 sept. 2017, 11:56
edreams a écrit :
26 sept. 2017, 11:03
@mamadtv: euh tu es sûr ? même un vieux plugin comme currentcost ? car celà fait 3 ans qu'il n'a jamais voulu répondre aux demandes d'utilisateurs sur le topic de ce plugin !
SI tu est sur que le plugin fonctionne, créé juste un fichier info.json dans le dossier plugin_info du CurrentCost et tout va réapparaître.
	"id" : "CurrentCost",
	"name" : "CurrentCost",
	"licence" : "AGPL",
	"author" : "Thomas MARTINEZ",
	"require" : "2.4",
	"category" : "organization"
Lenovo M720 Tiny - VMWare Debian 9 Jeedom DIY
Zwave - Bluetooth
Alexa Echo - Harmony Elite
steph034
Message par steph034 » 26 sept. 2017, 12:00
bon j'ai supprimé le plugin obsolete (datatransfert) et j'ai tjs l'info dans la log plugin, snif
Zerat9w
Message par Zerat9w » 26 sept. 2017, 12:04
Idem même après un reboot et en plus il est bavard ça log souvent
Jeedom
La rétention de l'information est une forme de constipation du savoir.
Documentation - Trucs & Astuces - Charte
snow51
Message par snow51 » 26 sept. 2017, 12:11
[START UPDATE]
Check rights...
OK
[START BACKUP]
OK
OK
Persist cache :
OK
Create archive...
OK
OK
Disable all task.
... OK
302 Found
Enable task : OK
[END UPDATE ERROR]
Stack trace:
#0 {main}
Le process de mise a jour essaye de télécharger le fichier releas.zip qui n'existe pas. La solution a été donnée dans les commentaires précédents.
RPI3 avec disque dur
MySensors : téléinfo, Température-humidité-ouverture
ESPEasy : Relais contact sec garage, Relais VMC
DIY Wifi : Capteur de consommation avec pinces ampèremétriques
Xiaomi : Roborock S50
BLEA : Mi Flora
edreams
Message par edreams » 26 sept. 2017, 12:28
	"licence" : "AGPL",
	"require" : "2.4",
Merci pour le tuyau BetyOops !
* Jeedom VM sur Synology DS916+ 8Go/24To / Zwave AEON GEN5 / RfxTrx433E *
Matériel complet --> http://forum.jeedom.fr/memberlist.php?m ... ile&u=1001 <--
kvb
Message par kvb » 26 sept. 2017, 12:51
Idem pour moi, que faire SVP ?
[START UPDATE]
****Install/update jeedom from 3.0.9 (2017-09-26 12:46:03)****
Check rights...OK
[START BACKUP]
***************Start of Jeedom backup at 2017-09-26 12:46:04***************
Check database...
OK
Backup database...
OK
Persist cache :
OK
Create archive...
OK
Limit the total size of backups to 500 Mo...
Remove : /var/www/html/core/php/../../backup/backup-kvb14-3.0.9-2017-09-26-06h59.tar.gz
OK
Name of backup : /var/www/html/core/php/../../backup/backup-kvb14-3.0.9-2017-09-26-12h46.tar.gz
Backup duration : 36s
Disable all task OK
Disable all scenario............
Download in progress...converted 'https://github.com/jeedom/core/archive/releas.zip' (ANSI_X3.4-1968) -> 'https://github.com/jeedom/core/archive/releas.zip' (UTF-8)
--2017-09-26 10:46:44-- https://github.com/jeedom/core/archive/releas.zip
Resolving github.com (github.com)... 192.30.253.113, 192.30.253.112
Connecting to github.com (github.com)|192.30.253.113|:443... connected.
HTTP request sent, awaiting response... 302 Found
converted 'https://codeload.github.com/jeedom/core/zip/releas' (ANSI_X3.4-1968) -> 'https://codeload.github.com/jeedom/core/zip/releas' (UTF-8)
--2017-09-26 10:46:45-- https://codeload.github.com/jeedom/core/zip/releas
2017-09-26 10:46:45 ERROR 404: Not Found.
Enable task : OK
[END UPDATE ERROR]
PHP Fatal error: Uncaught exception 'Exception' with message 'Download failed please retry later' in /var/www/html/install/install.php:160
Stack trace:
#0 {main}
thrown in /var/www/html/install/install.php on line 160
snow51
Message par snow51 » 26 sept. 2017, 12:52
[START UPDATE]
Check rights...OK
[START BACKUP]
Check database...
OK
Backup database...
OK
Persist cache :
OK
Create archive...
OK
OK
Disable all task OK
Enable task : OK
[END UPDATE ERROR]
Stack trace:
#0 {main}
La réponse a été donnée page 2 à 8h41
BLEA : Mi Flora
Anonyme
Message par Anonyme » 26 sept. 2017, 12:53
caplam
Message par caplam » 26 sept. 2017, 13:01
Bon,
à part la mise à jour qui persiste à être affichée, j'ai résolu mes autres problèmes:
j'ai créé un fichier info.json pour le plugin maxcube
j'ai migré mon install vers apache
Entre temps il y a bien eu une dizaine de plugins à mettre à jour. Tous sans problème.
Je n'ai pas parcouru toutes les fonctionnalités (juste la timeline) mais ça semble ok.
Bravo pour le boulot.
Jeedom sur vm esxi stretch
Principaux plugins: eibd, homebridge, maxcube, icalendar
kvb
Message par kvb » 26 sept. 2017, 13:19
[START UPDATE]
Check rights...OK
[START BACKUP]
Check database...
OK
Backup database...
OK
Persist cache :
OK
Create archive...
OK
OK
Disable all task OK
Enable task : OK
[END UPDATE ERROR]
Stack trace:
#0 {main}
OK merci, mais où et comment il faut modifier cette commande ?
Désolé mais je ne sais pas, c'est pas si évident que ça !
benj29
Message par benj29 » 26 sept. 2017, 13:20
benj29 a écrit :
26 sept. 2017, 11:50
Update de Jeedom en 3.1 ce matin, tout semble bon.
Jusqu'au moment où je me rends compte que toutes mes températures Xiaomi sont décalées de 2h en avance :) !
Retour vers le futur, Xiaomi ? Non... tout jeedom en fait. Que ce soit mes températures de nodemcu, l'état des mes capteurs chacon etc...
Suis-je le seul ? (à 11h45 il est 13h45).
Je précise que l'heure de mon Jeedom est bien à 11h45... (en haut à droite).
Un simple reboot, tout est rentré dans l'ordre.
Si cela peut aider du monde dans le même cas.
Mike27140
Message par Mike27140 » 26 sept. 2017, 13:38
snow51 a écrit :
26 sept. 2017, 09:41
Pour ceux qui ont le soucis de mise à jour qui ne s'effectue pas il faut modifier le fichier install/install.php
$url = 'https://github.com/jeedom/core/archive/releas.zip';
devrait être
$url = 'https://github.com/jeedom/core/archive/' . config::byKey('core::branch') . '.zip';
Merci cela à corrigé le probleme :-)
Jeedom (DIY)
steph034
Message par steph034 » 26 sept. 2017, 13:43
effectivement petite recherche de maj ce midi et de nombreux plugin sont mis à jour, tout est nickel de mon coté à part les restes du vieux plugin supprimé mais qui pollue pas mal les logs car tres bavard.
Bravo pour le job réalisé
Sshafi
Message par Sshafi » 26 sept. 2017, 13:55
steph034 a écrit :effectivement petite recherche de maj ce midi et de nombreux plugin sont mis à jour, tout est nickel de mon coté à part les restes du vieux plugin supprimé mais qui pollue pas mal les logs car tres bavard.
Dans quels logs ? Et tu peux en copier un bout stp
From Tapatruc !
??? Menfin ...
VM ESXi # Aeon Lab Gen5 | RFXtrx433E | ...
Trucs & Astuces
Zerat9w
Message par Zerat9w » 26 sept. 2017, 14:00
From Tapatruc !
@Sshafi, j'ai le même bug. Le plugin supprimé via le centre de mise à jour.
C'est dans le log plugin
Même après un reboot ça continue
Visiblement toutes les données du plugin supprimé sont présentes dans la base encore.
Jeedom
steph034
Message par steph034 » 26 sept. 2017, 14:02
oui c'est bien cela, c'est dans la log Plugin, même message pour moi, sur le même plugin.
J'ai supprimé moi aussi celui ci via le centre de mise à jour (il n'y a que là qu'il était encore visible) et malgré moi aussi un reboot, tjs bcp de logs indiquant l'erreur.
snow51
Message par snow51 » 26 sept. 2017, 14:04
Avec un outil comme filezilla sur pc ou cyberduck sur mac tu te connectes en sftp a ta box jeedom et tu vas modifier le fichier dans /var/www/install/
BLEA : Mi Flora
parrain27240
Message par parrain27240 » 26 sept. 2017, 14:07
bon mes messages sur le fofo marche une fois sur deux .
donc je reprend toujours aucun affichage sur aucune page que se soit dash plugin log y'a que la page de mise a jour qui marche et a moitie .
tous marche par domo-widget .
je peut vous donner aucun logs vu que la page et vide .
Sshafi
Message par Sshafi » 26 sept. 2017, 14:12
@kvb : essaye avant de faire une maj jeedom seulement forcée stp
From Tapatruc !
??? Menfin ...
Trucs & Astuces
Verrouillé
Revenir vers « Utilisation »
