[Plugin Tiers][Sujet Principal] Pushbullet
Re: [Plugin Tiers][Sujet Principal] Pushbullet
Capture d'ecran du code ligne 844 : https://1drv.ms/i/s!Av7Pb9pv9kKUo-I8F9Vgp_U0lvGE5A
Je pense que l'erreur doit venir d'ici.
Pour info j'ai le plugin camera donc je dois passer par ici et il doit y avoir un objet a null...
Le démon fonctionne là.didaskein a écrit : ↑22 oct. 2017, 10:28Voici le log :
2017-10-22 10:22:34,890 - MainThread - pushbullet:146 - DEBUG - Check PID file
2017-10-22 10:22:34,890 - MainThread - pushbullet:151 - DEBUG - PID file '/var/www/html/plugins/pushbullet/ressources/pushbullet_daemon/../../../../tmp/pushbullet.o.XXXXXXXXXXXXt7xDoqXXXXXa.pid'
2017-10-22 10:22:34,890 - MainThread - pushbullet:160 - DEBUG - Write PID file
2017-10-22 10:22:34,890 - MainThread - pushbullet:167 - DEBUG - Start daemon
2017-10-22 10:22:34,898 - MainThread - pushbullet:92 - DEBUG - Writing PID 27137 to /var/www/html/plugins/pushbullet/ressources/pushbullet_daemon/../../../../tmp/pushbullet.o.XXXXXXXXXXXXt7xDoqXXXXXa.pid
2017-10-22 10:22:35,526 - MainThread - listener:58 - DEBUG - Listener open
2017-10-22 10:22:35,526 - MainThread - listener:67 - DEBUG - Message received:{"type": "nop"}
2017-10-22 10:23:05,528 - MainThread - listener:67 - DEBUG - Message received:{"type": "nop"}
2017-10-22 10:23:16,581 - MainThread - listener:67 - DEBUG - Message received:{"type":"tickle","subtype":"push"}
2017-10-22 10:23:17,085 - MainThread - pushbullet:123 - DEBUG - Return code: 0
2017-10-22 10:23:17,085 - MainThread - pushbullet:124 - DEBUG - Thread finished
2017-10-22 10:23:19,038 - MainThread - listener:67 - DEBUG - Message received:{"type":"tickle","subtype":"push"}
2017-10-22 10:23:19,493 - MainThread - pushbullet:123 - DEBUG - Return code: 0
2017-10-22 10:23:19,493 - MainThread - pushbullet:124 - DEBUG - Thread finished
2017-10-22 10:23:20,816 - MainThread - listener:67 - DEBUG - Message received:{"type":"tickle","subtype":"push"}
2017-10-22 10:23:21,305 - MainThread - pushbullet:123 - DEBUG - Return code: 0
2017-10-22 10:23:21,305 - MainThread - pushbullet:124 - DEBUG - Thread finished
2017-10-22 10:23:35,528 - MainThread - listener:67 - DEBUG - Message received:{"type": "nop"}
2017-10-22 10:24:05,530 - MainThread - listener:67 - DEBUG - Message received:{"type": "nop"}
2017-10-22 10:24:35,541 - MainThread - listener:67 - DEBUG - Message received:{"type": "nop"}
2017-10-22 10:25:05,542 - MainThread - listener:67 - DEBUG - Message received:{"type": "nop"}
2017-10-22 10:25:35,519 - MainThread - listener:67 - DEBUG - Message received:{"type": "nop"}
2017-10-22 10:26:05,542 - MainThread - listener:67 - DEBUG - Message received:{"type": "nop"}
2017-10-22 10:26:35,518 - MainThread - listener:67 - DEBUG - Message received:{"type": "nop"}
Non, ça c'est autre chose. C'est juste un warning, que j'ai déjà réglé mais pas encore publié. Ca génère du log, mais c'est inoffensif.didaskein a écrit : ↑22 oct. 2017, 10:39Capture d'ecran du code ligne 844 : https://1drv.ms/i/s!Av7Pb9pv9kKUo-I8F9Vgp_U0lvGE5A
Yes
https://1drv.ms/u/s!Av7Pb9pv9kKUo-I9jOtQ8-cbKr3pgg
Mais j'ai juste une exception dans les logs. Le plugin pushbullet fonctionne bien chez moi.
A ok merci !zoboton a écrit : ↑22 oct. 2017, 10:43Non, ça c'est autre chose. C'est juste un warning, que j'ai déjà réglé mais pas encore publié. Ca génère du log, mais c'est inoffensif.didaskein a écrit : ↑22 oct. 2017, 10:39Capture d'ecran du code ligne 844 : https://1drv.ms/i/s!Av7Pb9pv9kKUo-I8F9Vgp_U0lvGE5A
didaskein a écrit : ↑22 oct. 2017, 10:45Yes
Il ne fonctionne toujours pas chez moi.
Le fichier PID est créé dans quel répertoire ?2017-10-22 08:46:45,785 - MainThread - pushbullet:160 - DEBUG - Write PID file
2017-10-22 08:46:45,786 - MainThread - pushbullet:164 - ERROR - Unable to write PID file: No such file or directory [2]
Si tu le lances à la main, lance le en sudo.Shakirosebebe22 a écrit : ↑22 oct. 2017, 10:49didaskein a écrit : ↑22 oct. 2017, 10:45Yes
Le fichier PID est créé dans le quel répertoire ?2017-10-22 08:46:45,785 - MainThread - pushbullet:160 - DEBUG - Write PID file
Sinon, ça marche pas .... tu as plus d'info ? Version de python, log, état, capture ... qqchose pour aider quoi.
zoboton a écrit : ↑22 oct. 2017, 10:51Si tu le lances à la main, lance le en sudo.Shakirosebebe22 a écrit : ↑22 oct. 2017, 10:49didaskein a écrit : ↑22 oct. 2017, 10:45Yes
J'ai pas donné la version de python car c'est la même version que didaskein : Python 2.7.13.
Le problème était lié au répertoire de création des fichiers PID.
Sur mon installation, le répertoire tmp dans /var/www/html/ n'existait pas.
Je l'ai créé manuellement et j'ai relancé le démon.
Euh. Là vous m'avez perdu ...
. Voir ma signature
J'attendrai la nouvelle version stable du plugin .
Merci à tous d'aider les incultes
. Voir ma signature
Catmar, débutant, inculte en Linux, python, ssh et autres... mais volontaire
Lyon
Mini+ & Smart avec Zwave,Broadlink et rfxcom avec divers modules
Merci à toute l'équipe et à tous les forumeurs pour vos conseils !
Lyon
Tu n'as pas une installation standard ? Où est installé Jeedom chez toi ?Shakirosebebe22 a écrit : ↑22 oct. 2017, 11:18zoboton a écrit : ↑22 oct. 2017, 10:51Si tu le lances à la main, lance le en sudo.Shakirosebebe22 a écrit : ↑22 oct. 2017, 10:49
Je pense avoir une installation standard de Jeedom :
Raspberry Pi 3 et Raspbian 9 installé sur un disque SSD (partition boot toujours sur carte SD)
Installation effectué comme précisé dans la documentation (3 commandes)
Plugins : Xiaomi, Téléinfo (Arduino nano), MySensors (Boutons, températures,...), Zwave, Pushbullet, Virtuel,...
Ok ... donc peut-être que les dernières versions de jeedom ne créent plus le tmp automatiquement. Je note.
Maintenant, ça fonctionne ?
Oui les échanges fonctionnent dans les deux sens.
Il faut bien appliquer les bons droits sur le répertoire (chmod 775 + chown www-data:www-data) et c'est tout bon.
La correction que tu as appliqué ce matin sur le plugin sera disponible demain matin pour la version classique (non béta) ?
Doit on repasser sur une version classique ou rester sur la version béta ? (Quelles sont les différences ?)
Le correctif est disponible en stable.
Pour les droits du /tmp, un 711 devrait suffir (+ le chown pour le donner à www-data). Je vais ajouter la création du répertoire à l'installation pour ne plus avoir le pb.
Mise à jour effectuée,
Tout refonctionne normalement
Merci zoboton
Merci zoboton
Lyon
Lyon
Tout d'abord, merci pour ce plugin
J'aurais une petite suggestion à faire...
Jeedom et les plugins (officiels ou non) constituent une excellente solution domotique que j'ai choisie en 2016, après avoir abandonné la box HC2 de Fibaro
Mais pour celui qui "débarque", il persiste des "détails" qui nuisent à la perception de cette solution
Ainsi, pour la maj du plugin Pushbullet, en cliquant sur "changelog" on obtient une erreur 404
Pour avoir signalé quelques bugs sur d'autres plugins, je comprends qu'il soit laborieux, voire inutile, de détailler les modifications apportées
C'est pourquoi sur d'autres systèmes/applications, les développeurs indiquent "résolutions de bugs mineurs" et "améliorations diverses"
Je sais que ces réponses n'apportent pas grand chose, mais elles sont néanmoins mieux perçues qu'une erreur 404
Et les plus curieux peuvent consulter le topic ad-hoc sur ce forum
Je constate globalement qu'un effort a été réalisé, puisqu'en cliquant sur "changelog", on obtient de moins en moins d'erreurs 404 et l'on aboutit soit sur la doc du plugin, soit au changelog sur GitHub
Pour info, si l'on cherche la doc depuis le plugin, on obtient également une erreur 404
Jeedom RC V4.0.23
Tu prêches un convaincu. Mais la manière de gérer les docs et les changelog dans Jeedom est devenu incompréhensible (voir ingérable), même pour le développeur consciencieux que je suis.
Donc la doc existe, le changelog existe ... mais j'ai pas encore réussi à faire en sorte qu'ils s'affichent.
Merci d'avoir répondu
Et puisque la doc et le changelog existent, je reste confiant sur la mise en ligne
Jeedom RC V4.0.23
Est il possible de récupérer les connected apps dans le plugin Pushbullet dans Jeedom?
En effet j'ai couplé IFTTT avec pushbullet et IFFT n'apparait pas dans device mais dans app connected.
Et je ne vois pas IFTTT dans pushbullet de mon Jeedom
Avez vous des précisions?
