Plugin blea
mika-nt28
Re: Plugin blea
Message par mika-nt28 » 20 nov. 2017, 09:34
Je viens d'acheter une smartplug.
Elle a ete détécté sans soucis et a fonctionné imédiatement.
Mais maintenant je n'arrive plus a activé ou non la prise
Dans les log j'ai ca
This is a smartplug device
[2017-11-20 09:25:32][DEBUG] : Send to jeedom : {u'devices': {u'E0:0': {'name': u'SMP-B16-FR', 'source': 'local', 'rawdata': "[(1, 'Flags', u'06'), (2, 'Incomplete 16b Services', u'f0ff'), (9, 'Complete Local Name', u'SMP-B16-FR'), (10, 'Tx Power', u'00'), (18, '0x12', u'10001000'), (255, 'Manufacturer', u'')]", 'rssi': -77, 'type': 'smartplug', 'id': u'E0:E5:0', 'present': 1}, u'C4:7C: {'name': u'Flower mate', 'source': 'local', 'rawdata': "[(1, 'Flags', u'06'), (2, 'Incomplete 16b Services', u'95fe'), (22, '16b Service Data', u''), (9, 'Complete Local Name', u'Flower mate')]", 'rssi': -69, 'type': 'miflora', 'id': u'C4:50', 'present': 1}}}
et si je lance un ordre
[2017-11-20 09:29:51][DEBUG] : Client connected to [127.0.0.1:56610]
[2017-11-20 09:29:51][DEBUG] : Message read from socket: {"apikey":"","cmd":"action","device":{"id":""},"command":{"name":"smp-b16-fr","handle":"0x2b","value":"0f06030001000005ffff","device":{"id":"","delay":"120","needsrefresh":1,"name":"smartplug"}}}
[2017-11-20 09:29:51][DEBUG] : Client disconnected from [127.0.0.1:56610]
[2017-11-20 09:29:51][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2017-11-20 09:29:51][DEBUG] : Received command from jeedom : action
[2017-11-20 09:29:51][DEBUG] : Attempt an action on a device
[2017-11-20 09:29:51][DEBUG] : Thread Launched
[2017-11-20 09:29:51][DEBUG] : Creating a new connection for
[2017-11-20 09:29:51][DEBUG] : Connecting :  with bluetooth 0
[2017-11-20 09:29:53][DEBUG] : Failed to connect to peripheral, addr type: public attempt 1
[2017-11-20 09:29:55][DEBUG] : Failed to connect to peripheral addr type: public attempt 2
[2017-11-20 09:29:57][DEBUG] : Connected...
[2017-11-20 09:29:57][DEBUG] : Writing Characteristic...
[2017-11-20 09:29:57][DEBUG] : Characteristic written...
[2017-11-20 09:29:57][DEBUG] : {'rsp': ['wr']}
[2017-11-20 09:29:57][DEBUG] : Value 0f06030001000005ffff written in handle 0x2b
[2017-11-20 09:29:57][DEBUG] : Refreshing ...
[2017-11-20 09:29:57][DEBUG] : Already a connection for  use it
[2017-11-20 09:29:57][DEBUG] : Subscribing to notification :
[2017-11-20 09:29:57][DEBUG] : Delegated
[2017-11-20 09:29:57][DEBUG] : Subscribing for 2
[2017-11-20 09:29:58][DEBUG] : Disconnecting...
[2017-11-20 09:29:58][DEBUG] : Disconnected...
[2017-11-20 09:29:58][DEBUG] : Device disconnected
[2017-11-20 09:29:58][DEBUG] : [(1, 'Flags', u'06'), (2, 'Incomplete 16b Services', u'f0ff'), (255, 'Manufacturer', u'0107')] True public
[2017-11-20 09:29:58][DEBUG] : It's a unknown packet and I known this device so I send
J'ai l'impression que la clef bleutooth refuse les ecritures
paul gueguen
Re: Plugin blea
Message par paul gueguen » 20 nov. 2017, 12:51
savez vous comment récupérer l'état d'un yeelight bed via ce plugin.
je peux la con troller mais impossible de savoir si elle est déja allumée ou pas.
Cordialement
Dams
Re: Plugin blea
Message par Dams » 21 nov. 2017, 06:59
J'ai mon demon local qui s'arrête souvent avec le port de la clef bluetooth qui se déconfigure. Il est sur un PI3 avec une clef sena.
Voici les log en debug:
: Exception on scanner (trying to resolve by myself 6): Failed to execute mgmt cmd 'scanend'
Can't init device hci0: Connection timed out (110)
[2017-11-21 06:55:20][WARNING] : Exception on scanner (trying to resolve by myself 7): Failed to execute mgmt cmd 'scanend'
[2017-11-21 06:55:31][WARNING] : Exception on scanner (trying to resolve by myself 8): Failed to execute mgmt cmd 'scanend'
[2017-11-21 06:55:42][ERROR] : Exception on scanner (didn't resolve there is an issue with bluetooth) : Failed to execute mgmt cmd 'scanend'
[2017-11-21 06:55:42][INFO] : Shutting down due to errors
[2017-11-21 06:55:42][DEBUG] : Send to jeedom :  {'source': 'local', 'learn_mode': 0}
[2017-11-21 06:55:42][INFO] : Starting new HTTP connection (1): 127.0.0.1
[2017-11-21 06:55:42][DEBUG] : "POST /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxx HTTP/1.1" 200 0
[2017-11-21 06:55:44][DEBUG] : Shutdown
[2017-11-21 06:55:44][DEBUG] : Removing PID file /tmp/blead.pid
[2017-11-21 06:55:44][DEBUG] : Closing all potential bluetooth connection
[2017-11-21 06:55:44][DEBUG] : LoopNetServer Thread stopped
[2017-11-21 06:55:44][DEBUG] : Exit 0
Comment puis-je résoudre se problème?
Merci de votre aide
Swr
Re: Plugin blea
Message par Swr » 24 nov. 2017, 23:02
christlep a écrit :
19 nov. 2017, 12:47
Salut à tous,
@sarakha : J'ai recu mon amazfit Bip, et voici ce que me donne les données brutes :
Résultat de la commande : [(1, 'Flags', u'04'), (2, 'Incomplete 16b Services', u'e0fe'), (9, 'Complete Local Name', u'Amazfit Bip Watch'), (22, '16b Service Data', u'e0fe00000000'), (255, 'Manufacturer', u'5701001fb9843198b6e40d37439e657d462a9302ea0ed089c771')]
On sais jamais, si tu pouvais en faire quelque chose.
Merci à tous
chris
De mon coté la Amazfit Bip est reconnue, comme un type inconnu, cependant le signal est reçu et la synchro fonctionne avec le smartphone
Swr
Re: Plugin blea
Message par Swr » 24 nov. 2017, 23:03
christlep a écrit :
19 nov. 2017, 12:47
Salut à tous,
Merci à tous
chris
De mon coté la Amazfit Bip est reconnue, comme un type inconnu, cependant le signal est reçu et la synchro fonctionne avec le smartphone, donc OK
jipay59
Re: Plugin blea
Message par jipay59 » 26 nov. 2017, 15:56
Petite question, j'ai acheter une enceinte xiaomi et sans faire attention, j'ai pris la bluetooth 4.2, ma clé ne la voit pas car elle est en 4.0 (Orico), je suppose que c'est pas le même protocole ... ma question est quelqu'un a réussi a ajouter cette enceinte sur jeedom via ce plugin ? si oui comment ? car il n'existe pas de clé bluetooth 4.2, enfin si une mais elle n'a pas l'air fiable, merci pour vos retours...
Fabrice
Modérateur
Re: Plugin blea
Message par Fabrice » 26 nov. 2017, 21:12
Ce n'est pas ce plugin qu'il faut utiliser pour y connecter une enceinte Bluetooth, mais le plugin "PulseAudio", qui pour le coup, est fait pour cela.
- Jeedom : 3.3.36
jipay59
Re: Plugin blea
Message par jipay59 » 26 nov. 2017, 22:38
Euh oui autant pour moi, je voulais dire Pulse Audio, mais oui du coup je suis hors sujet par rapport a bléa, je vais changer de topic, désolé, merci pour ta réponse en tout cas
Bastien
Re: Plugin blea
Message par Bastien » 26 nov. 2017, 22:55
Bonjour je souhaite acheter le diffuseur d huile essentielle xiaomi viomi est ce que quelqu'un l à testé avec Blea
Envoyé de mon MI 5s Plus en utilisant Tapatalk
xavax
Re: Plugin blea
Message par xavax » 30 nov. 2017, 17:16
Bonjour, savez vous s’il est possible ou sera possible d’utiliser le bouton pour lancer des scénarios avec le bracelet miband 2 ? Par exemple un scénario pour un double appui ou appli long
Merci d’avance
sheep300
Re: Plugin blea
Message par sheep300 » 03 déc. 2017, 00:27
bonjour
je posse un flower care (miflora) en version 2.7.0 situé a la base dune plante dehors.
depuis que les temperatures arrive dans le négatif je constate que la temperature affiche : 655x.x (ex : 6550.3°c) des que ca descend en dessous de 0.
est ce normal ?
y'a t'il une méthode de calcul a faire ?
dans les logs pas d'erreurs.
merci ^^
Damien
olivier42
Re: Plugin blea
Message par olivier42 » 06 déc. 2017, 10:59
Auriez vous une valeur affichée + la valeur réelle ? (je pense à un bit en + dans les données pour indiquer le signe négatif)
sheep300
Re: Plugin blea
Message par sheep300 » 06 déc. 2017, 11:12
olivier42 a écrit :Bonjour,
J ai pas réussi à trouver de cohérence entre la valeur indiqué et la température réel pas vraiment de proportionnalité
Damien
olivier42
Re: Plugin blea
Message par olivier42 » 06 déc. 2017, 11:19
sheep300 a écrit :
06 déc. 2017, 11:12
Il n'y aura pas de proportionnalité, c'est du binaire. Donnez moi le deux valeurs, j'essaierai de trouver :)
cadavor
Re: Plugin blea
Message par cadavor » 06 déc. 2017, 12:25
sheep300 a écrit :
03 déc. 2017, 00:27
bonjour
est ce normal ?
merci ^^
Comme ça, a brûle-pourpoint, je dirais :
Si valeur > 3276.7 alors valeur = valeur - 6553.4
Exemple : 6550.3 => -3.1
Jeedom Stable 3.3
NUC Z83 + Aeotec Z-Stick Gen5
sheep300
Re: Plugin blea
Message par sheep300 » 06 déc. 2017, 13:14
cadavor a écrit :
sheep300 a écrit :
03 déc. 2017, 00:27
bonjour
est ce normal ?
merci ^^
J'essaierai ça vient d'où la valeur 6553,4 ?
Damien
Nibb31
Re: Plugin blea
Message par Nibb31 » 06 déc. 2017, 13:56
En informatique, les valeurs entiers sont codés sur 16-bits (0 à 65 535) qui sont codés de façon à aller de -32 768 à 32 767
Zwave + RFXCom433E + Hue
sheep300
Re: Plugin blea
Message par sheep300 » 06 déc. 2017, 14:04
Nibb31 a écrit :En informatique, les valeurs entiers sont codés sur 16-bits (0 à 65 535) qui sont codés de façon à aller de -32 768 à 32 767
Merci pour l'explication j'essaierai ça ce soir
Damien
sheep300
Re: Plugin blea
Message par sheep300 » 06 déc. 2017, 14:07
Damien
sheep300
Re: Plugin blea
Message par sheep300 » 06 déc. 2017, 14:09
Damien
