Bah non rien de plus, VLC OK mais pas d'image jeedom
Voici ma config
Et mes logs
Create/Update Service Name : Dafang Protocole : rtsp IP : 192.168.1.45 Emplacement : /tmp Port : 8554 Delay : 2 Size : 1920x1080 URL : /unicast Horodatage : 1 Utilisateur :
########### Création/Mise à jour du service ##########
########### Fin ##########
########### Logs du service IPCAM_360 ##########
ffmpeg version 3.2.9-1~deb9u1 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 6.3.0 (Raspbian 6.3.0-18+rpi1) 20170516 configuration: --prefix=/usr --extra-version='1~deb9u1' --toolchain=hardened --libdir=/usr/lib/arm-linux-gnueabihf --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libebur128 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared libavutil 55. 34.101 / 55. 34.101 libavcodec 57. 64.101 / 57. 64.101 libavformat 57. 56.101 / 57. 56.101 libavdevice 57. 1.100 / 57. 1.100 libavfilter 6. 65.100 / 6. 65.100 libavresample 3. 1. 0 / 3. 1. 0 libswscale 4. 2.100 / 4. 2.100 libswresample 2. 3.100 / 2. 3.100 libpostproc 54. 1.100 / 54. 1.100 [rtsp @ 0x22a85d0] max delay reached. need to consume packet [rtsp @ 0x22a85d0] RTP: missed 3 packets [rtsp @ 0x22a85d0] RTP: dropping old packet received too late Last message repeated 2 times [rtsp @ 0x22a85d0] max delay reached. need to consume packet [rtsp @ 0x22a85d0] RTP: missed 21 packets [rtsp @ 0x22a85d0] RTP: dropping old packet received too late
########### Etat du service IPCAM_360 ##########
RTSP.ajax.php rtsp-service-IPCAM_360.service - LSB: RTSP Daemon for IPCAM_360 Loaded: loaded (/etc/init.d/rtsp-service-IPCAM_360; generated; vendor preset: enabled) Active: active (running) since Sun 2018-01-28 16:10:12 CET; 4min 9s ago Docs: man:systemd-sysv-generator(8) Process: 10315 ExecStart=/etc/init.d/rtsp-service-IPCAM_360 start (code=exited, status=0/SUCCESS) CGroup: /system.slice/rtsp-service-IPCAM_360.service |-10320 sh /usr/sbin/rtsp.sh rtsp 192.168.1.45 /tmp IPCAM_360 8554 2 /unicast 1920x1080 1 `-18155 /usr/bin/avconv -i rtsp://192.168.1.45:8554/unicast -s 1920x1080 -frames:v 1 -an -vf drawtext=fontfile=/usr/share/fonts/truetype/dejavu/DejaVuSans-Bold.ttf: text='2018-01-28T16\:14\:14': fontcolor=black@0.8: x=50: y=60 -y /tmp/snapshot_IPCAM_360.jpg Jan 28 16:10:11 JEEDOM_MAISON systemd[1]: Starting LSB: RTSP Daemon for IPCAM_360... Jan 28 16:10:11 JEEDOM_MAISON rtsp-service-IPCAM_360[10315]: Starting RTSP Daemon for IPCAM_360... Jan 28 16:10:12 JEEDOM_MAISON systemd[1]: Started LSB: RTSP Daemon for IPCAM_360.
Honnêtement je vois pas ce qui bloque?
