[Plugin Tiers] Xiaomi Home
impossible pour moi de voir la gateway remonter dans le plugin.
configuration ok du gateway, dépendances et daemon ok.
J'ai un jeedom mini+
Logs :
Unhandled exception in thread started by <function xiaomiconnector at 0x764accb0>
File "/var/www/html/plugins/xiaomihome/resources/xiaomihomed/xiaomihomed.py", line 106, in xiaomiconnector
globals.CONNECTOR = XiaomiConnector(data_callback=cb_aquara)
File "/var/www/html/plugins/xiaomihome/resources/xiaomihomed/devices/aquara.py", line 23, in __init__
self.socket = self._prepare_socket()
File "/var/www/html/plugins/xiaomihome/resources/xiaomihomed/devices/aquara.py", line 39, in _prepare_socket
sock.setsockopt(socket.IPPROTO_IP, socket.IP_ADD_MEMBERSHIP, mreq)
File "/usr/lib/python2.7/socket.py", line 224, in meth
return getattr(self._sock,name)(*args)
socket.error: [Errno 105] No buffer space available
Unhandled exception in thread started by <function xiaomiconnector at 0x76433cb0>
Unhandled exception in thread started by <function xiaomiconnector at 0x75ef7c70>
Unhandled exception in thread started by <function xiaomiconnector at 0x75f43c70>
Unhandled exception in thread started by <function xiaomiconnector at 0x76426c70>
Unhandled exception in thread started by <function xiaomiconnector at 0x75f10c70>
Unhandled exception in thread started by <function xiaomiconnector at 0x75f0ec70>
Unhandled exception in thread started by <function xiaomiconnector at 0x763e1c70>
Unhandled exception in thread started by <function xiaomiconnector at 0x763dac70>
Unhandled exception in thread started by <function xiaomiconnector at 0x763d3c70>
je ne sais pas ou rentré le token/password et autre adresse Ip.
j'ai pourtant fouillé dans le forum.
Merci pour votre aide
Logs :
Nirobert39, Sur ton Jeedom dans le plugin tu dois déjà voir la gateway.
(depuis le menu Jeedom : Plugins / Protocoles domotiques / Xiaomi Home )
En cliquant, donc, sur l'icone de ta gateway tu verras les parametres type Token et Adresse IP et comment remplir tout cela (c'est écrit).
La doc devrait aussi t'aider (tjrs utile ça) :
https://lunarok.github.io/jeedom_xiaomihome/
Hervé
Mon matériel domotique
HerveK, le problème c'est que ma gateway ne remonte pas dans le plugin.
Jeedom semble ne pas la détecter.
Ma box est connectée à ma freebox et la gateway réponds bien via l'application Mi Home.
A mon idée ... :
https://lunarok.github.io/jeedom_xiaomihome/wifi.html
Hervé
Merci, peut être une méthode + simple pour un novice?
Rentres l'adresse IP de ta gateway , sauvegardes .
Là tu devrais voir le Token
Tu resauvegardes
Je te dis cela de mémoire ...
si je dis une bétise , merci à tous et chacun de me reprendre.
Tu resauvegardes
Hervé
La doc à suivre pour la Gateway c'est plutôt celle-ci : https://lunarok.github.io/jeedom_xiaomihome/aqara.html
Exact Merci Tristan
Envoyé de mon MI 5s Plus en utilisant Tapatalk
Hervé
C'est vrai que mon lien n'était ... vraiment pas le bon . (1000 excuses)
Avec celui de Tristan, NoRobert devrait s'en sortir.
Longtemps que j'ai intégré mes Gateways . Relire la Doc à ce niveau vient de me rafraichir les idées .
Hervé
merci à vous pour vos réponses, j'avais déjà lu est suivi la doc indiquée par Tristan.
Mais ma gateway ne remonte pas. j'ai fait plusieurs essais avec installation et désinstallation, relance du plugin, des services...aucune remontée de ma gateway.
Et je ne comprends pas pourquoi
ton daemon est pas bon, suffit de regarde ton log
y a buffer space error
t'as bien rebooter ? si pi, t'as essayer une autre SD ?
Oui j'ai redemarré.
je suis sur jeedom mini+ carte sd d'origine.
j'ai refait une carte SD avec une image de backup mais j'ai toujours le même message buffer space error.
Comment je peux corriger cette erreur svp?
- m.georgein
Juste pour dire MERCI à Lunarok pour la mise à jour du plugin avec 'Ceiling 1", moins de 24 h pour la mise à jour !!!
Avec 244 pages de forum je n'ose pas imaginer la maintenance de ce plugin !!! Alors encore merci et bravo, tout fonctionne parfaitement.
Plateforme :
NUCNUC6i5SYK en VM STRETCH
Version Jeedom 4.0.9
Version PHP 7.0.33-0+deb9u1
Version OS Linux debian9 4.9.0-8-amd64 #1 SMP Debian 4.9.130-2 (2018-10-27) x86_64 GNU/Linux [9.6]
Version database 10.1.26-MariaDB-0+deb9u1
Je découvre jeedom, et j'ai acheté le plugin pour xiaomi, auparavant j'étais sous domoticz.
J ai un petit soucis au niveau de la latence. quand j'appuie sur mon bouton (aqua Xiaomi switch) mon ampoule yeelight s'allume au moins 5-7sec après.
Quelqu'un sait comment je peux faire pour réduire ce temps ?
Je possède un raspi3, et voici mon code tout simple pour l'appui du bouton,
SI #[Salle de bain][Bouton Clic][Clic]# == "click" ALORS #[Salle de bain][Ampoule SDB][Toggle]# - Options : Array ( [background] => 1 [enable] => 1 )
Sur Jeedom 3.1.7 Stable Smart
je n arrive à installer les dépendances toujours en Nok je vois bien les erreur dans mon log ci dessous je ne sais quoi faire pour résoudre mon problème. Merci de m'aider
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
---> faut déjà régler ca, t'as autre chose qui gène
Merci j avais vu mais je ne sais quoi faire une commande en SSH ? laquelle ? Merci
SSH sur Smart fait perdre le support.
En tout cas rien à voir avec le plugin, cherche sur le forum, reboot aussi car si c'est un process qui bloque ca pourrait le delocker
