(résolu) Pb instalation dépendances Espeasy
- franx
je n'arrive pas à installer les dépendances du plugin Espeasy
je ne maitrise pas vraiment le SSH.
Voici les logs de l'installation
Début de l'installation
converted 'https://raw.githubusercontent.com/lunar ... /nodejs.sh' (ANSI_X3.4-1968) -> 'https://raw.githubusercontent.com/lunar ... /nodejs.sh' (UTF-8)
--2018-07-03 11:21:21-- https://raw.githubusercontent.com/lunar ... /nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.120.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.120.133|:443... connected.
Length: 1458 (1.4K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 8.41M=0s
2018-07-03 11:21:21 (8.41 MB/s) - 'dependencies.sh' saved [1458/1458]
Nodejs non installé
Hit http://security.debian.org jessie/updates InRelease
Ign http://http.us.debian.org jessie InRelease
Ign http://httpredir.debian.org jessie InRelease
Get:1 http://httpredir.debian.org jessie-updates InRelease [145 kB]
Hit http://http.us.debian.org jessie Release.gpg
Hit http://httpredir.debian.org jessie Release.gpg
Get:2 https://repo.solid-build.xyz ./ InRelease [354 B]
Ign https://repo.solid-build.xyz ./ InRelease
Get:3 https://repo.solid-build.xyz ./ Release.gpg [481 B]
Get:4 https://repo.solid-build.xyz ./ Release
Get:5 https://repo.solid-build.xyz ./ Release [982 B]
Hit http://security.debian.org jessie/updates/main Sources
Hit http://security.debian.org jessie/updates/main armhf Packages
Hit http://security.debian.org jessie/updates/main Translation-en
Get:6 http://httpredir.debian.org jessie-updates/main Sources [17.2 kB]
Get:7 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [11.8 kB]
Get:8 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [3688 B]
Err https://repo.solid-build.xyz ./ Release
Hit http://http.us.debian.org jessie/non-free armhf Packages
Hit http://http.us.debian.org jessie/non-free Translation-en
Get:9 http://httpredir.debian.org jessie/main Sources [7063 kB]
Get:10 http://httpredir.debian.org jessie/main armhf Packages [6675 kB]
Get:11 http://httpredir.debian.org jessie/main Translation-en [4581 kB]
Fetched 162 kB in 1min 15s (2148 B/s)
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repo.solid-build.xyz ./ Release: The following signatures were invalid: KEYEXPIRED 1508672008
W: Failed to fetch https://repo.solid-build.xyz/debian/jes ... /./Release
W: Some index files failed to download. They have been ignored, or old ones used instead.
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
dependencies.sh: 32: [: armv7l: unexpected operator
Utilisation du dépot officiel
## Installing the NodeSource Node.js 8.x LTS Carbon repo...
## Populating apt-get cache...
+ apt-get update
Hit http://httpredir.debian.org jessie-updates InRelease
Get:1 https://repo.solid-build.xyz ./ InRelease [354 B]
Get:2 https://repo.solid-build.xyz ./ Release.gpg [481 B]
Get:4 https://repo.solid-build.xyz ./ Release [982 B]
Get:5 http://httpredir.debian.org jessie-updates/main Sources [17.2 kB]
Get:6 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [11.8 kB]
Get:7 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [3688 B]
Get:8 http://httpredir.debian.org jessie/main Sources [7063 kB]
Get:9 http://httpredir.debian.org jessie/main armhf Packages [6675 kB]
Get:10 http://httpredir.debian.org jessie/main Translation-en [4581 kB]
Fetched 17.0 kB in 1min 11s (238 B/s)
Error executing command, exiting
dependencies.sh: 1: dependencies.sh: nodejs: not found
Version actuelle :
dependencies.sh: 54: dependencies.sh: npm: not found
chown: cannot access 'node_modules': No such file or directory
Fin de l'installation
Merci de votre aide
Franx
Mon install: Mini plus avec disque ssd Msata
Zwave, RfxCom, PLC Bus, Xiaomi,
0K . 100% 8.41M=0s
Nodejs non installé
+ apt-get update
Version actuelle :
Merci de votre aide
Franx
Franx
Re: Pb instalation dépendances Espeasy
d'après les logs c'est nodejs qu'il n'arrive pas à installer.
j'ai eu ce problème (résolu en SSH)
mais je serais bien incapable de t'aider et de retrouvé ce que j'ai fait !
RPI3 avec mSATA
tu a un problème de signature des packet
tu fait en SSH sous root
et après tu relance t'es dépendance
curl https://repo.solid-build.xyz/debian/jessie/bsp-imx6/Release.key | sudo apt-key add -
- franx
Merci pour ta réponse,
je galère pour arriver a me connecter en ssh sur mon jeedom.
des que j'y arrive je test ça
Franx
il y a eu une mise à jour sur le plugin espeasy, tu peux toujours faire la mise à jour et retester....on c'est jamais.
RPI3 avec mSATA
- franx
La mise a jour n'a rien changer pour moi.
il faut que j'arrive a me connecter en SSH mais je n'y comprend pas grand chose. ça ne passe pas avec jeedom et Mjeedom96
Franx
utilise putty
- franx
ok pour Putty mais j'ultilise quoi comme nom d'utilisateur et mot de passe ?
Franx
- franx
Voila ce que me donne l'onglet Health
Linux linux 3.14.79-fslc-imx6-sr #1 SMP Wed Sep 13 12:05:55 UTC 2017 armv7l GNU/Linux [8.9]
Franx
sa me donne pas grande chose
juste que sa tourne sur ARM un Raspberry ?
tu la installer comment ton jeedom ?
- franx
C'est une box mini + avec un disque ssd . j'ai tout reinstallé il y a 2 mois environs avec une image Miniplus V 3.1.7 jessie
Franx
ok donc par défaut c'est
pseudo: root
password: debian
pseudo: root
password: debian
c'est les images réalisé par bronche ?
il y a les codes dans son fichier lisez moi
ça semble être en SSH debian et debian et pour root debian
Une image pour humingboard Mini plus - Jessie et Jeedom 3.1.7 (SSH: debian / debian - root / debian - jeedom admin -admin)
RPI3 avec mSATA
- franx
Merci à tous les 2, j’essaie ça demain
Franx
- franx
Franx
- franx
on avance, j'arrive a me connecter en ssh avec debian debian avec putty.
par contre comment je sais si je suis en root avec ce login ?
Franx
Ba, là tu ne dois pas y être.
Quand tu fais un sudo...... Il va te demander le MDP Root.
Mais, quand tu auras résolu ton problème, il serait souhaitable de modifier les MDP.
RPI3 avec mSATA
- franx
C'est ok pour la connexion en SSH, j'ai passé la commande curl https://repo.solid-build.xyz/debian/jes ... elease.key | sudo apt-key add -
Il m'a redemandé le mdp a la fin pour le sudo, Nickel.
par contre j'ai relancé les dépendances apres mais l'install n'aboutit pas.
je vous joint les logs
Accueil
Analyse
Outils
Plugins
1
08:57:14
Gestion
Mode inclusion
Configuration
Santé
Mes espeasy
Aucun espeasy détecté, démarrer un node pour ajout
Configuration du plugin
ESPeasy (espeasy) - stable
Etat
StatutActifAction
Version2018-07-03 01:18:21 Version Jeedom2.4
Auteurlunarok LicenseAGPL
Log
Niveau de log localAucunDefautDebugInfoWarningError
Logs
Dépendances
Nom Statut Installation Dernière installation
Local NOK 2018-06-19 22:28:09
Démon
Nom Statut Configuration (Re)Démarrer Arrêter Gestion automatique Dernier lancement
Local NOK NOK Gestion automatique désactivée Inconnue
Configuration
IP Controleur à saisir dans ESPeasy (onglet config) : 192.168.0.145
Port Controleur à saisir dans ESPeasy (onglet config) : 8121
Publish template à saisir dans ESPeasy (onglet tools, puis bouton advanced) :device=%sysname%&taskid=%id%&cmd=%valname%&value=%value%
Fonctionnalités
interactNon
cronNon
cron5Non
cron15Non
cron30Non
cronHourlyNon
cronDailyNon
Log du plugin
Rechercher
--2018-07-05 06:51:06-- https://raw.githubusercontent.com/lunar ... /nodejs.sh
0K . 100% 10.1M=0s
2018-07-05 06:51:06 (10.1 MB/s) - 'dependencies.sh' saved [1458/1458]
Nodejs non installé
Hit https://repo.solid-build.xyz ./ Release.gpg
Hit http://httpredir.debian.org jessie-updates/main Sources
Get:2 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [11.8 kB]
Get:3 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [3688 B]
Hit https://repo.solid-build.xyz ./ Sources
Hit https://repo.solid-build.xyz ./ Packages
Hit http://httpredir.debian.org jessie/main Sources
Get:4 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:5 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:6 https://repo.solid-build.xyz ./ Translation-en [351 B]
Hit http://httpredir.debian.org jessie/main armhf Packages
Get:7 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:8 https://repo.solid-build.xyz ./ Translation-en [351 B]
Ign https://repo.solid-build.xyz ./ Translation-en
Hit http://httpredir.debian.org jessie/main Translation-en
Fetched 15.5 kB in 32s (484 B/s)
+ apt-get update
Get:2 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:3 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:5 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [11.8 kB]
Fetched 15.5 kB in 32s (477 B/s)
Version actuelle :
Accueil
Analyse
Outils
Plugins
1
08:57:14
Gestion
Mode inclusion
Configuration
Santé
Mes espeasy
Etat
StatutActifAction
Log
Logs
Dépendances
Démon
Configuration
Fonctionnalités
interactNon
cronNon
cron5Non
cron15Non
cron30Non
cronHourlyNon
cronDailyNon
Log du plugin
Rechercher
0K . 100% 10.1M=0s
Nodejs non installé
+ apt-get update
Version actuelle :
Franx
