Module Jeedom pour MagicMirror²
Re: Module Jeedom pour MagicMirror²
lol ba oui mais bon je découvre le truc du coup je m'avance pas
Aller pelte pelte mdrrr
rigole rigole
Comment peut-on mettre une phrase sur deux ligne et rapprocher les températures du nom .
Ex:
Salon: 23
Et pas Salon : 23
Voir photo ci-jointe
Ex:
Salon: 23
Et pas Salon : 23
/* Magic Mirror Config Sample
* By Michael Teeuw http://michaelteeuw.nl
* MIT Licensed.
* For more information how you can configurate this file
* See https://github.com/MichMich/MagicMirror#configuration
var config = {
address: "localhost", // Address to listen on, can be:
// - "localhost", "127.0.0.1", "::1" to listen on loopback interface
// - another specific IPv4/6 to listen on a specific interface
// - "", "0.0.0.0", "::" to listen on any interface
// Default, when address config is left out, is "localhost"
port: 8080,
ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
// or add a specific IPv4 of 192.168.1.5 :
// ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"],
// or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format :
// ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"],
language: "fr",
timeFormat: 24,
units: "metric",
modules: [
module: "",
module: "",
position: "top_bar"
module: "clock",
position: "top_right"
module: "",
header: "US Holidays",
position: "top_left",
config: {
calendars: [
symbol: "calendar-check-o ",
url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
module: "",
position: "lower_third"
module: "",
position: "top_right",
config: {
locationID: "", //ID from http://www.openweathermap.org/help/city_list.txt
appid: "YOUR_OPENWEATHER_API_KEY"
module: "",
header: "Weather Forecast",
config: {
locationID: "5128581", //ID from http://www.openweathermap.org/help/city_list.txt
module: "",
position: "bottom_bar",
config: {
feeds: [
title: "New York Times",
url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml"
showSourceTitle: true,
showPublishDate: true
module: 'MMM-Jeedom',
header: 'Maison',
config: {
updateInterval: 1000,
jeedomAPIKey: "ErcAR7t5LCfA6XGftgyhrtfydsfdrttrNkQshxmT",
jeedomURL: "192.168.0.35",
jeedomPORT: 80,
jeedomHTTPS: false,
jeedomAPIPath: "/core/api/jeeApi.php",
sensors: [
{//first info (value and unit only)
idx: "5004",
sameLine1: true,
{//second info (title, symbol, value and unit)
idx: "3551",
customTitle: "Condition",
symbol: "",
sameLine2: true,
{ //this one display only 1 info on its line
idx: "6013",
symbol: "",
customTitle: "Salon :",
unit : "degres",
{//this one display only 1 info on its line
idx: "6018",
symbol: "",
customTitle: "Chambre :",
unit : "degres",
idx: "7319",
symbol: "",
customTitle: "Exterieur :",
unit : "degres",
idx: "7318",
symbol: "",
customTitle: "Piscine :",
unit : "degres",
{//this one display only 2 info on its line
idx: "5676",
symbol: "",
customTitle: "Horoscope Papa :",
idx: "5686",
symbol: "",
customTitle: "Horoscope Maman :",
idx: "6924",
symbol: "",
customTitle: "lumieres :",
unit : "",
/*************** DO NOT EDIT THE LINE BELOW ***************/
if (typeof module !== "undefined") {module.exports = config;}
Il faut que tu joues avec les css ou que tu mettes les mains dans le code dans la partie getDom du plugin. C'est pas trop prevu pour y mettre des phrases a rallonge.
bon pas grave je ferai autrement^^
par contre serai tu comment mettre le module MMM-FreeBox-Monitor
je n'est pas trouver de git clone
j'ai fait comme ceci mais erreur
Et au passage j'ai pas trouver y a t'il un module pour récupérer les notifs de telegram dans mon cas c'est les photo qui m’intéresse
* MIT Licensed.
var config = {
port: 8080,
language: "fr",
timeFormat: 24,
units: "metric",
modules: [
module: "",
module: "",
position: "top_bar"
module: "clock",
module: 'MMM-FreeBox-Monitor',
position: 'top_left', // This can be any of the regions. Best results in left or right regions.
config: {
mirrorName: "My Magic Mirror",
ip: "http://192.168.0.254"
// See 'Configuration options' for more information.
module: "",
module: "",
config: {
module: "",
config: {
module: "",
config: {
feeds: [
header: 'Maison',
config: {
jeedomAPIKey: "ErcAR7t5LCfA6XGdTjhgjyugyugyurNkQshxmT",
jeedomPORT: 80,
jeedomHTTPS: false,
sensors: [
idx: "5004",
sameLine1: true,
idx: "3551",
customTitle: "Condition :",
symbol: "",
sameLine2: true,
idx: "6013",
symbol: "",
unit : "C",
idx: "6018",
symbol: "",
unit : "C",
idx: "7319",
symbol: "",
unit : "C",
idx: "7318",
symbol: "",
unit : "C",
idx: "5676",
symbol: "",
idx: "5686",
symbol: "",
idx: "6924",
symbol: "",
unit : "",
tu a bien associer le magicmonitor a la freebox ?
bah justement comme je dit je trouve pas mdrr
Voui non mais je pense vais passer par un design noir comme je tes dit a l'école ^^
J'arrive enfin a avoir quelque chose
Pour infos quelques infos qui existe bien sur la doc mais qu'il me parait utile de mettre en avant: pas de version light de rasbian, et ne pas utiliser root pour installer
Comment vous gerer le fait d'avoir un écran qui s'allume s'eteind ? J'ai branché le mien sur une prise ZWave piloté par mon jeedom pour a minima l'éteindre la nuit quand je suis absent .. seulement quand mon écran se rallume il ne récupère pas le signal HDMI du rpi .. je dois reboot le rpi
Au passage j'ai pas mal de symbol que je n'arrive pas a utiliser .. Vous avez le meme souci ? Je n'ai pourtant pas d'erreur de syntaxe a priori .. par exemple le "fas fa-futbol" ou fas fa-weight"
Pour ma part j'ai ajouté ce module a magicmirror https://github.com/Jopyth/MMM-Remote-Control qui me permet d'appeler via une requette http une url qui eteint ou allume l'ecran exemple :BaaTuuC a écrit : ↑21 oct. 2018, 12:47Comment vous gerer le fait d'avoir un écran qui s'allume s'eteind ? J'ai branché le mien sur une prise ZWave piloté par mon jeedom pour a minima l'éteindre la nuit quand je suis absent .. seulement quand mon écran se rallume il ne récupère pas le signal HDMI du rpi .. je dois reboot le rpi
Pour allumer
http://ADRESSEIPDURASP:8080/remote?action=MONITORON
http://ADRESSEIPDURASP:8080/remote?action= MONITOROFF
Snips sur Rasp 3 avec Matrix Voice | Jeedom 3.x en VM proxmox | Sonos Play 1 (x2)
Merci pour l'info je le note.
Le souci c'est plus au niveau hard, j'ai l'impression que mon écran ne capte pas bien le signal de mon écran ..
'jour
l'écran ne capte pas le signal de l'écran... désolé là je ne te suis pas
il affiche "no signal please verify your connection" au bout d'un certain temps. Il perd le signal HDMI quoi .. faut que je regarde dans les menus comment virer la veille .. bon faut déja que je retrouve les boutons
QUi plus est la commande monitorOn du plugin recommandé par Tarlak ne semble rien faire .. alors que off coupe bien ..
Tu as peut être un soucis d'intensité du signal sur le port hdmi du rasp j'avais eu un petit soucis du genre si je me souvient bien, peut être trouvera tu des informations ici : https://www.raspberrypi.org/documentati ... t/video.md
Je capte le signal pendant un moment puis il coupe au bout d'un moment...Tarlak a écrit : ↑21 oct. 2018, 20:27Tu as peut être un soucis d'intensité du signal sur le port hdmi du rasp j'avais eu un petit soucis du genre si je me souvient bien, peut être trouvera tu des informations ici : https://www.raspberrypi.org/documentati ... t/video.md
merci du lien
je regarde ca
A mes debut avec magic mirror j'avais le même soucis avec mon écran, en essayant un autre écran pas de problème, donc j'ai donc bidouillé un peut le fichier de config avec le lient que je t'ai mis afin que l'écran que j'avais prévu fonctionne. Mais une fois que c'est fait il suffit de mettre de coté le fichier config.txt si jamais y a besoin de tout réinstaller à zero
