Je galère depuis la MAJ du plugin ... voila ce que j'ai fais:
Mon hub est en version 4.15.206 le plugin harmony derniere version.
Je suis sous jessie, j'ai installé python 3.5 comme jbval.
En relançant ls dépendances j'ai ceci:
python3-dev is already the newest version.
python3-pip is already the newest version.
python3-setuptools is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
Requirement already satisfied: requests in /usr/local/lib/python3.5/site-packages (2.21.0)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.5/site-packages (from requests) (2018.11.29)
Requirement already satisfied: urllib3<1.25,>=1.21.1 in /usr/local/lib/python3.5/site-packages (from requests) (1.24.1)
Requirement already satisfied: idna<2.9,>=2.5 in /usr/local/lib/python3.5/site-packages (from requests) (2.8)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.5/site-packages (from requests) (3.0.4)
Requirement already satisfied: asyncio in /usr/local/lib/python3.5/site-packages (3.4.3)
Requirement already satisfied: websockets in /usr/local/lib/python3.5/site-packages (7.0)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.5/site-packages (2.3.10)
Requirement already satisfied: chardet in /usr/local/lib/python3.5/site-packages (from aiohttp) (3.0.4)
Requirement already satisfied: multidict>=4.0.0 in /usr/local/lib/python3.5/site-packages (from aiohttp) (4.5.2)
Requirement already satisfied: async_timeout>=1.2.0 in /usr/local/lib/python3.5/site-packages (from aiohttp) (2.0.1)
Requirement already satisfied: yarl>=1.0.0 in /usr/local/lib/python3.5/site-packages (from aiohttp) (1.2.0)
Requirement already satisfied: idna-ssl>=1.0.0 in /usr/local/lib/python3.5/site-packages (from aiohttp) (1.1.0)
Requirement already satisfied: idna>=2.0 in /usr/local/lib/python3.5/site-packages (from yarl>=1.0.0->aiohttp) (2.8)
* Installation terminée *
puis le scan:
[2019-01-10 20:15:45][ALERT] : ########Recherche de la config en cours########
[2019-01-10 20:15:46][ALERT] : ######### Dispositifs trouvés 192.168.1.12
[2019-01-10 20:15:46][ALERT] : ######### Activités trouvées 192.168.1.12
[2019-01-10 20:15:46][ALERT] : #### Fin de la recherche 192.168.1.12
En faisant la commande: python3 __main__.py --harmony_ip 192.168.1.3 show_current_activity
A votre avis pour solutionner mon problème je dois revenir a la version précédente du plugin harmony ? car malheureusement je peux revenir en arrière que de 3 jours en backup ... donc si quelqu'un a le dossier /var/www/html/plugins/harmonyhub/ je suis preneur!
Ou j'ai loupé autre chose ?
Merci d'avance!
puis le scan:
Merci d'avance!
Si au lieu de faire python3 __main__.py --harmony_ip 192.168.1.3 show_current_activity
tu fais /cheminVersPython/python3 __main__.py --harmony_ip 192.168.1.3 show_current_activity
Tu as le même résultat?
Perso en l'installant à la main il s'est installé dans /usr/local/bin au lieu de /usr/bin (dans /usr/bin j'ai la version 3.4)
Du coup, j'ai refait le lien de la manière suivante :
cd /usr/bin
puis sudo ln -sf /usr/local/bin/python3.6 ./python3
Ca fait pointer le lien symbolique python3 vers la version 3.6 au lieu de la 3.4 qui est dans le dossier /usr/bin
Après avoir fait le lien, j'ai redemarré la console puis relancé l'install des mises à jour de pip :
sudo pip3 install --upgrade pip
sudo pip3 install --upgrade asyncio
Si ça peut aider certains..
cd /usr/bin
Jeedom Mini & Rfxcom
Zwave/X10/Mysensor/Chacon DI-O/CurrentCost Envir/Netatmo
GuillaumeDieppe a écrit : ↑21 déc. 2018, 23:43Mais pourquoi j'ai accepté de mettre à jour le plugin HarmonyHub......
Mon Hub contrôle la pompe a chaleur qui chauffe tout le rdc, donc autant dire que j'étais soulagé hier soir d'avoir réussi à downgrader et tout refaire fonctionner comme avant.
Puis ce soir mise à jour du plugin et là à nouveau le HUB hs, j'ai beau retenter la procédure de downgrad mais rien n'y fait, même en relançant 15 fois les dépendances....
Quelqu'un aurait une idée pour m'aider ? Merci
GuillaumeDieppe a écrit : ↑22 déc. 2018, 00:32j'ai finalement mis le backup général Jeedom d'hier et tout remarche. Je n'ai rien touché sur le Hub
Depuis le souci de Décembre j'ai normalement le dernier firmware Logitech dans mon HUB, mais une ancienne version du plugin Harmony Hub et chaque jour ça me rappelle que le plugin est à mettre à jour.
Où en sommes nous sur la résolution du problème, si je met à jour le plugin Harmony Hub est ce que cela va toujours fonctionner cette fois ?
Jeedom Smart
J'ai fait quelques tests de modifs de scripts pas très concluants hier soir.
Je regarde à nouveau ce WE mais c'est pas gagné.. Je ne vois pas comment différencier le + du - (on remonte en paramètre la nouvelle valeur du curseur et pas un bouton sélectionné)
Pour info, tu peux me préciser la ligne mise en commentaires ?
salutjared a écrit : ↑20 déc. 2018, 15:37Voila comment j'ai fait :
Télécharger les fichiers ici : https://github.com/home-assistant/pyhar ... /pyharmony
Les mettre à la place dans le dossier plugin/harmonyhub/3rdparty/PyHarmony/harmony (faites une copie du dossier si ça vous rassure)
Modifier le fichier __main__.py en supprimant lignes 10 et 11 "from pyharmony" (garder la suite de la ligne)
Vérifier que vous avez bien python3 installé
Installer les dépendances python nécessaires (de mémoire je n'avais pas asyncio, websockets et aiohttp ) en lançant :
pip3 install nom_du_package
Dans le fichier plugin/harmonyhub/core/class/harmonyhub.class.php, remplacer les 4 ou 5 occurence de python par python3
enjoy
Après on est pas à l'abri que logitech bloque le port 8080 dans une future maj...
sur la jeedom smart je ne peut pas editer les .py
sur wincp ou notepad++ j’ai bien une trace de pyharmony mais a la ligne 561
il faut que je supprime quoi exactement (j’ai bien fais une sauvegarde avant pas de risque )
ef main():
"""Main method for the script."""
ligne 561--- parser = argparse.ArgumentParser(description='Pyharmony - Harmony device control',
formatter_class=argparse.ArgumentDefaultsHelpFormatter)
required_flags = parser.add_mutually_exclusive_group(required=True)
# Required flags go here.
required_flags.add_argument('--harmony_ip',
help='IP Address of the Harmony device.')
required_flags.add_argument('--discover',
action='store_true',
help='Scan for Harmony devices.')
Merci jbvaljbval a écrit : ↑10 janv. 2019, 21:00Si au lieu de faire python3 __main__.py --harmony_ip 192.168.1.3 show_current_activity
cd /usr/bin
Du coup j'ai pointé le lien symbolique python3 vers la version 3.5 (pour moi) car je l'avais aussi installé à la main mais toujours pareil ...
J'ai le même résultat en faisant: /usr/bin/python3 __main__.py --harmony_ip 192.168.1.3 show_current_activity
Dis moi tu es sur la dernière version du plugin harmony ou la précédente ?
Si tu es sur la précédente ton dossier /var/www/html/plugins/harmonyhub m'intéresse
Non, j'ai bien la dernière version du plugin.
Tu dis que tu l'as installé à la main, il est dans quel dossier?
perso pour valider j'ai du tester /usr/local/bin/python3.6 __main__.py --harmony_ip 192.168.1.3 show_current_activity (avant de modifier le lien symbolique)
merci pour ton explication très détailléglenan a écrit : ↑24 déc. 2018, 00:24Bonsoir,
J'ai une Jeedom smart et vais donner à ceux qui ont la même box, ma solution et qui fonctionne à moindre frais pour l'instant.
1°) Ne pas installer la MAJ du plugin Harmony Hub du 21/12 17h42
Si vous l'avez déjà fait, revenez en arrière en restaurant votre jeedom avec son dernier backup (j'ai un backup automatique toutes les nuits, choisir le plus récent avant votre maj du plugin).
- En attendant une mise à jour (peut être en janvier) du plugin permettant de laisser votre hub harmony faire ses maj comme il le souhaite, il faut installer une version firmware que Logitech vient de mettre en ligne et qui est annoncée comme réservée aux développeurs.
Le firmware v4.15.210 avec XMPP de ré-activé. Evidemment Logitech déconseille d'utiliser cette version car elle contiendrait une faille de sécurité.
2°) brancher votre HUB en USB sur votre PC
3°) Lancer le logiciel MyHarmony et avant de faire quoi que ce soit, taper Alt+F9. Une page va s'ouvrir pour vous proposer de choisir votre équipement. N'en faite rien allez tout en bas de cette page et choisir la version firmware spécial développeur.
4°) Lancer la MAJ et laisser là se faire jusqu'à la fin.
Voilà, les commandes dans Jeedom sont à nouveau opérationnelles (moi aussi, j'avais un peu trop rapidement fait la MAJ du plugin Harmony Hub).
par contre j'avais fait pas mal de modif depuis ma dernière sauvegarde
aucune possibilité a la jeedom smart de revenir a un ancien plugin sans restaurer une sauvegarde complète ?
Super jbval ca marche!!!jbval a écrit : ↑11 janv. 2019, 11:01Non, j'ai bien la dernière version du plugin.
Ce que j'ai fait:
ln -sf /usr/local/bin/python3.6 ./python3 avant j'avais fait ln -sf /usr/local/bin/python3.5 ./python3
En version 3.6.7 ca marche mais en version 3.5 ne marche pas
Je te remercie pour tous, un truc de moins a faire
tant mieux si ça fonctionne!
Après mon linux est rouillé donc je me dit que j'aurais pu installé plus proprement python 3.6 même à la main pour ne pas avoir 2 version qui cohabitent dans 2 dossiers distincts mais comment...
Franchement c'est ce que je voulais faire mais dans le doute... ça me va comme ca!!
Je te souhaite un bon weekend
Petite question sans doute un peu bête mais peut-on effacer, une fois l'installation faite, le dossier décompressé "Python-x.x.x" ?Le_Poilu a écrit : ↑21 déc. 2018, 21:17
Pour mettre à jour ton python:
remplacer 3.x.x par la version de python que tu souhaites, moi je suis parti sur la 3.6.7 (dernière 3.6 avant 3.7)
sudo apt-get install libssl-dev openssl wget https://www.python.org/ftp/python/3.x.x/Python-3.x.x.tgz tar xzvf Python-3.x.x.tgz cd Python-3.x.x ./configure make sudo make install
L'installation de Python 3.6.7 m'a aussi pris 8% d'espace supplémentaire sur le disque de ma Jeedom, normal ? Y-a-il des dossiers/fichiers obsolètes à supprimer suite à cette mise à jour ?
Merci pour vos conseils
PS: J'ai restauré le dossier du plugin d'une ancienne sauvegarde et maintenant tout est a nouveau fonctionnel
Les fichiers "d'installation" peuvent être supprimés oui.
Je ne sais pas où trouver une version précédente du plugin mais je crois avoir lu quelques pages en amont, que quelqu'un donnait un lien ?speeed a écrit : ↑11 janv. 2019, 11:43merci pour ton explication très détailléglenan a écrit : ↑24 déc. 2018, 00:24Bonsoir,
J'ai supprimé le fichier en tar mais le dossier au même niveau, c'est bien un dossier d'installation ? je peux le supprimer sans risque ?
(Je ne sais pas si ma question est au bon endroit.)
J'ai acheté le plugin récemment et grâce à celui-ci j'ai effectivement accès à mes appareils et activités depuis le dashboard jeedom.
Cependant, ce que je souhaite faire et avoir une remontée d'infos sur l'activité en cours et que c'elle-ci fasse varier l'allumage, la couleur et l'intensité de mes ampoules hue en fonction de l'activité en cours sur ma Harmony.
J'ai essayé de créer un scénario pour cela, mais étant débutant sur Jeedom je ne dois pas faire cela correctement, car ça ne fonctionne pas du tout...
Est-ce que l'un d'entre vous a déjà réalisé un scénario de ce type et pourrais me le montrer pour le reproduire?
Par avance merci pour aide!
Je n'ai pas accès à mon Jeedom pour te détailler mais le principe est le suivant :David_A78 a écrit : ↑15 janv. 2019, 10:41Bonjour à tous,
- Pour ton scénario tu ajoutes le déclencheur "[Salon][Harmony][Activite]"
- Dans le code de ton scénario, tu testes la valeur de ton activité en cours :
SI ([Salon][Harmony][Activite]=='TV')
ALORS Allumer lumière en rouge
SINON SI ([Salon][Harmony][Activite]=='CINEMA')
ALORS Allumer lumière en bleu
Merci Noodom, je vais essayer cela ce soir, effectivement je crois que je n'ai pas pris le problème dans le bon sens du tout.
J'ai mis un déclencheur pour chaque activité et donc un scénario pour chaque!
Est-il possible avec ce plugin de par exemple lors de la mise en pause d'un film d'augmenter la luminosité des lampes et de la tamiser au lancement de la lecture?
Pour la gestion des évènements pour un film, il faut plutôt le gérer au niveau du plugin Jeedom Kodi (avec l'ajout d'une extension Kodi spécifique à Jeedom)
Ok c'est donc gérable depuis une Nvidia shield sur lequel j'installe Kodi et le plugin sur Jeedom?
Est ce que tu sais si il est possible de le faire aussi avec plex?
