J'ai un "soucis" avec mon Yeelight 650.
Depuis Jeedom je n'arrive pas à :
- choisir la couleur RGB du bandeau lumineux
Voici les logs lorsque je choisi la couleur par l'interface
[2019-01-29 17:49:48][DEBUG] : execute : action yeelight rgbAct
[2019-01-29 17:49:48][DEBUG] : Client connected to [127.0.0.1:46108]
[2019-01-29 17:49:48][DEBUG] : Message read from socket: {"apikey":"<MYAPIKEY>","type":"yeelight","cmd":"send","dest":"192.168.1.12","model":"ceiling4","sid":"0x0000000005e38616","short_id":"45","command":"rgb","option":"ff0000","id":"192.168.1.12","sup":""}
[2019-01-29 17:49:48][DEBUG] : Client disconnected from [127.0.0.1:46108]
[2019-01-29 17:49:48][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2019-01-29 17:49:48][DEBUG] : Received command from jeedom : send
[2019-01-29 17:49:48][DEBUG] : Executing action on : ceiling4
[2019-01-29 17:49:48][DEBUG] : {u'apikey': u'<MYAPIKEY>', u'option': u'ff0000', u'short_id': u'45', u'dest': u'192.168.1.12', u'cmd': u'send', u'sup': u'', u'command': u'rgb', u'sid': u'0x0000000005e38616', u'model': u'ceiling4', u'type': u'yeelight', u'id': u'192.168.1.12'}
[2019-01-29 17:49:48][DEBUG] : Bulb<192.168.1.12:55443, type=BulbType.Unknown> > {'params': ['power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'flowing', 'delayoff', 'music_on', 'nl_br', 'active_mode', 'bg_power', 'bg_rgb', 'name'], 'id': 0, 'method': 'get_prop'}
[2019-01-29 17:49:48][DEBUG] : Bulb<192.168.1.12:55443, type=BulbType.Unknown> < {u'id': 0, u'result': [u'on', u'1', u'6500', u'', u'', u'', u'2', u'0', u'0', u'', u'0', u'0', u'on', u'255', u'']}
[2019-01-29 17:49:48][DEBUG] : Bulb<192.168.1.12:55443, type=BulbType.WhiteTemp> > {'params': [16711680, 'smooth', 500], 'id': 1, 'method': 'set_rgb'}
[2019-01-29 17:49:48][DEBUG] : Bulb<192.168.1.12:55443, type=BulbType.WhiteTemp> < {u'id': 1, u'error': {u'message': u'method not supported', u'code': -1}}
[2019-01-29 17:49:48][ERROR] : Exception on socket : {u'message': u'method not supported', u'code': -1}
Est-ce que les messages "Method not supported" sont normaux ? Sinon une piste pour m'aider ?
- je n'arrive pas, depuis jeedom, a éteindre complétement l'allumage principal et laisser juste le bandeau led. (la touche M de la telecommande) ==> Est-ce possible ou pas ?
Merci d'avance de votre aide.
S'il manque des choses pour me répondre, n'hésitez pas à me dire
Coté Santé de mon Jeedom :
- chrome_2019-01-29_17-56-54.png (93.79 Kio) Consulté 1254 fois
- chrome_2019-01-29_17-56-40.png (89.42 Kio) Consulté 1254 fois
