Je n'arrivais pas à remonter les infos d'une de mes ampoules, j'ai donc relancer l'installation de mes dépendances, depuis le Démon est KO et les dépendances sont KO.
Voici les logs
dtls_debug.h:95:61: warning: unused parameter ‘length’ [-Wunused-parameter]
static inline void hexdump(const unsigned char *packet, int length)
dtls_debug.h: In function ‘dump’:
dtls_debug.h:98:40: warning: unused parameter ‘buf’ [-Wunused-parameter]
static inline void dump(unsigned char *buf, size_t len)
dtls_debug.h:98:52: warning: unused parameter ‘len’ [-Wunused-parameter]
dtls_debug.h: In function ‘dtls_dsrv_hexdump_log’:
dtls_debug.h:102:29: warning: unused parameter ‘level’ [-Wunused-parameter]
dtls_dsrv_hexdump_log(log_t level, const char *name, const unsigned char *buf, size_t length, int extend)
dtls_debug.h:102:48: warning: unused parameter ‘name’ [-Wunused-parameter]
dtls_debug.h:102:75: warning: unused parameter ‘buf’ [-Wunused-parameter]
dtls_debug.h:102:87: warning: unused parameter ‘length’ [-Wunused-parameter]
dtls_debug.h:102:99: warning: unused parameter ‘extend’ [-Wunused-parameter]
dtls_debug.h: In function ‘dtls_dsrv_log_addr’:
dtls_debug.h:106:26: warning: unused parameter ‘level’ [-Wunused-parameter]
dtls_dsrv_log_addr(log_t level, const char *name, const session_t *addr)
dtls_debug.h:106:45: warning: unused parameter ‘name’ [-Wunused-parameter]
dtls_debug.h:106:68: warning: unused parameter ‘addr’ [-Wunused-parameter]
gcc -Wall -pedantic -std=c99 -D COAP_DEBUG_FD=stderr -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -DNDEBUG -DDTLSv12 -DWITH_SHA256 -DDTLS_CHECK_CONTENTTYPE -I. -c -o peer.o peer.c
In file included from peer.c:20:0:
dtls_debug.h: In function ‘hexdump’:
dtls_debug.h:95:49: warning: unused parameter ‘packet’ [-Wunused-parameter]
gcc -Wall -pedantic -std=c99 -D COAP_DEBUG_FD=stderr -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -DNDEBUG -DDTLSv12 -DWITH_SHA256 -DDTLS_CHECK_CONTENTTYPE -I. -c -o dtls_time.o dtls_time.c
gcc -Wall -pedantic -std=c99 -D COAP_DEBUG_FD=stderr -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -DNDEBUG -DDTLSv12 -DWITH_SHA256 -DDTLS_CHECK_CONTENTTYPE -I. -c -o session.o session.c
gcc -Wall -pedantic -std=c99 -D COAP_DEBUG_FD=stderr -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -DNDEBUG -DDTLSv12 -DWITH_SHA256 -DDTLS_CHECK_CONTENTTYPE -I. -c -o dtls_debug.o dtls_debug.c
In file included from dtls_debug.c:36:0:
make -C aes rijndael.o
make[3] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/aes »
gcc -Wall -std=c99 -pedantic -D COAP_DEBUG_FD=stderr -DNDEBUG -DDTLSv12 -DWITH_SHA256 -c -o rijndael.o rijndael.c
make[3] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/aes »
make -C ecc ecc.o
make[3] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/ecc »
gcc -Wall -std=c99 -pedantic -D COAP_DEBUG_FD=stderr -DTEST_INCLUDE -DNDEBUG -DDTLSv12 -DWITH_SHA256 -c -o ecc.o ecc.c
make[3] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/ecc »
make -C sha2 sha2.o
make[3] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/sha2 »
gcc -Wall -std=c99 -pedantic -D COAP_DEBUG_FD=stderr -DNDEBUG -DDTLSv12 -DWITH_SHA256 -I.. -c -o sha2.o sha2.c
make[3] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/sha2 »
ar cru libtinydtls.a dtls.o crypto.o ccm.o hmac.o netq.o peer.o dtls_time.o session.o dtls_debug.o aes/rijndael.o ecc/ecc.o sha2/sha2.o
ar: le modificateur « u » est ignoré puisque « D » est le défaut (consultez « U »)
ranlib libtinydtls.a
make -C doc
make[3] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/doc »
: Doxyfile >./doxygen.out 2>&1
make[3] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/doc »
for dir in tests doc platform-specific sha2 aes ecc; do \
make -C $dir ; \
done
make[3] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/tests »
gcc -Wall -D COAP_DEBUG_FD=stderr -I.. -DNDEBUG -DDTLSv12 -DWITH_SHA256 -L.. dtls-server.c -ltinydtls -o dtls-server
gcc -Wall -D COAP_DEBUG_FD=stderr -I.. -DNDEBUG -DDTLSv12 -DWITH_SHA256 -L.. ccm-test.c -ltinydtls -o ccm-test
gcc -Wall -D COAP_DEBUG_FD=stderr -I.. -DNDEBUG -DDTLSv12 -DWITH_SHA256 -L.. prf-test.c -ltinydtls -o prf-test
gcc -Wall -D COAP_DEBUG_FD=stderr -I.. -DNDEBUG -DDTLSv12 -DWITH_SHA256 -L.. dtls-client.c -ltinydtls -o dtls-client
make[3] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/tests »
make[3] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/platform-specific »
make[3]: rien à faire pour « clean ».
make[3] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/platform-specific »
make[3]: rien à faire pour « all ».
gcc -Wall -std=c99 -pedantic -D COAP_DEBUG_FD=stderr -DTEST_INCLUDE -DNDEBUG -DDTLSv12 -DWITH_SHA256 -c -o ecc_test.o ecc.c
gcc -Wall -std=c99 -pedantic -D COAP_DEBUG_FD=stderr -DTEST_INCLUDE -DNDEBUG -DDTLSv12 -DWITH_SHA256 -c -o test_helper.o test_helper.c
gcc -Wall -std=c99 -pedantic -D COAP_DEBUG_FD=stderr -DTEST_INCLUDE -DNDEBUG -DDTLSv12 -DWITH_SHA256 testecc.c ecc_test.o test_helper.o -o testecc
testecc.c:116:23: warning: ‘ecdsaTestresultS2’ defined but not used [-Wunused-const-variable=]
static const uint32_t ecdsaTestresultS2[] = { 0x433AAB6F, 0x808250B1, 0xE46F90F4, 0xB342E972, 0x18B2F7E4, 0x2DB981A2, 0x6A288FA4, 0x41CF59DB};
testecc.c:115:23: warning: ‘ecdsaTestresultR2’ defined but not used [-Wunused-const-variable=]
static const uint32_t ecdsaTestresultR2[] = { 0x14146C91, 0xE878724D, 0xCD4FF928, 0xCC24BC04, 0xAC403390, 0x650C0060, 0x4A30B3F1, 0x9C69B726};
testecc.c:112:23: warning: ‘ecdsaTestresultS1’ defined but not used [-Wunused-const-variable=]
static const uint32_t ecdsaTestresultS1[] = { 0x5366B1AB, 0x0F1DBF46, 0xB0C8D3C4, 0xDB755B6F, 0xB9BF9243, 0xE644A8BE, 0x55159A59, 0x6F9E52A6};
testecc.c:111:23: warning: ‘ecdsaTestresultR1’ defined but not used [-Wunused-const-variable=]
static const uint32_t ecdsaTestresultR1[] = { 0xC3B4035F, 0x515AD0A6, 0xBF375DCA, 0x0CC1E997, 0x7F54FDCD, 0x04D3FECA, 0xB9E396B9, 0x515C3D6E};
gcc -Wall -std=c99 -pedantic -D COAP_DEBUG_FD=stderr -DTEST_INCLUDE -DNDEBUG -DDTLSv12 -DWITH_SHA256 testfield.c ecc_test.o test_helper.o -o testfield
testfield.c:99:23: warning: ‘orderResultDoubleMod’ defined but not used [-Wunused-const-variable=]
static const uint32_t orderResultDoubleMod[8] = {0xFC63254F, 0xF3B9CAC2, 0xA7179E84, 0xBCE6FAAD, 0xFFFFFFFF, 0xFFFFFFFF, 0x00000000, 0xFFFFFFFF};
make[2] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls »
Making all in .
make[2] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap »
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-address.lo -MD -MP -MF src/.deps/libcoap_1_la-address.Tpo -c -o src/libcoap_1_la-address.lo `test -f 'src/address.c' || echo './'`src/address.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-address.lo -MD -MP -MF src/.deps/libcoap_1_la-address.Tpo -c src/address.c -fPIE -o src/libcoap_1_la-address.o
mv -f src/.deps/libcoap_1_la-address.Tpo src/.deps/libcoap_1_la-address.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-async.lo -MD -MP -MF src/.deps/libcoap_1_la-async.Tpo -c -o src/libcoap_1_la-async.lo `test -f 'src/async.c' || echo './'`src/async.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-async.lo -MD -MP -MF src/.deps/libcoap_1_la-async.Tpo -c src/async.c -fPIE -o src/libcoap_1_la-async.o
mv -f src/.deps/libcoap_1_la-async.Tpo src/.deps/libcoap_1_la-async.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-block.lo -MD -MP -MF src/.deps/libcoap_1_la-block.Tpo -c -o src/libcoap_1_la-block.lo `test -f 'src/block.c' || echo './'`src/block.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-block.lo -MD -MP -MF src/.deps/libcoap_1_la-block.Tpo -c src/block.c -fPIE -o src/libcoap_1_la-block.o
mv -f src/.deps/libcoap_1_la-block.Tpo src/.deps/libcoap_1_la-block.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-coap_dtls.lo -MD -MP -MF src/.deps/libcoap_1_la-coap_dtls.Tpo -c -o src/libcoap_1_la-coap_dtls.lo `test -f 'src/coap_dtls.c' || echo './'`src/coap_dtls.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-coap_dtls.lo -MD -MP -MF src/.deps/libcoap_1_la-coap_dtls.Tpo -c src/coap_dtls.c -fPIE -o src/libcoap_1_la-coap_dtls.o
In file included from [01m[K./ext/tinydtls/tinydtls.h:28:0[m[K,
from [01m[Ksrc/coap_dtls.c:26[m[K:
[01m[K./ext/tinydtls/dtls_config.h:98:0:[m[K [01;35m[Kwarning: [m[K"PACKAGE_BUGREPORT" redefined
#define PACKAGE_BUGREPORT ""
In file included from [01m[Ksrc/coap_dtls.c:10:0[m[K:
[01m[K./coap_config.h:104:0:[m[K [01;36m[Knote: [m[Kthis is the location of the previous definition
#define PACKAGE_BUGREPORT "libcoap-developers@lists.sourceforge.net"
[01m[K./ext/tinydtls/dtls_config.h:101:0:[m[K [01;35m[Kwarning: [m[K"PACKAGE_NAME" redefined
#define PACKAGE_NAME "tinydtls"
[01m[K./coap_config.h:107:0:[m[K [01;36m[Knote: [m[Kthis is the location of the previous definition
#define PACKAGE_NAME "libcoap"
[01m[K./ext/tinydtls/dtls_config.h:104:0:[m[K [01;35m[Kwarning: [m[K"PACKAGE_STRING" redefined
#define PACKAGE_STRING "tinydtls 0.8.6"
[01m[K./coap_config.h:110:0:[m[K [01;36m[Knote: [m[Kthis is the location of the previous definition
#define PACKAGE_STRING "libcoap 4.1.2"
[01m[K./ext/tinydtls/dtls_config.h:107:0:[m[K [01;35m[Kwarning: [m[K"PACKAGE_TARNAME" redefined
#define PACKAGE_TARNAME "tinydtls"
[01m[K./coap_config.h:113:0:[m[K [01;36m[Knote: [m[Kthis is the location of the previous definition
#define PACKAGE_TARNAME "libcoap"
[01m[K./ext/tinydtls/dtls_config.h:110:0:[m[K [01;35m[Kwarning: [m[K"PACKAGE_URL" redefined
#define PACKAGE_URL ""
[01m[K./coap_config.h:116:0:[m[K [01;36m[Knote: [m[Kthis is the location of the previous definition
#define PACKAGE_URL "https://libcoap.net/"
[01m[K./ext/tinydtls/dtls_config.h:113:0:[m[K [01;35m[Kwarning: [m[K"PACKAGE_VERSION" redefined
#define PACKAGE_VERSION "0.8.6"
[01m[K./coap_config.h:119:0:[m[K [01;36m[Knote: [m[Kthis is the location of the previous definition
#define PACKAGE_VERSION "4.1.2"
mv -f src/.deps/libcoap_1_la-coap_dtls.Tpo src/.deps/libcoap_1_la-coap_dtls.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-coap_event.lo -MD -MP -MF src/.deps/libcoap_1_la-coap_event.Tpo -c -o src/libcoap_1_la-coap_event.lo `test -f 'src/coap_event.c' || echo './'`src/coap_event.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-coap_event.lo -MD -MP -MF src/.deps/libcoap_1_la-coap_event.Tpo -c src/coap_event.c -fPIE -o src/libcoap_1_la-coap_event.o
mv -f src/.deps/libcoap_1_la-coap_event.Tpo src/.deps/libcoap_1_la-coap_event.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-coap_keystore.lo -MD -MP -MF src/.deps/libcoap_1_la-coap_keystore.Tpo -c -o src/libcoap_1_la-coap_keystore.lo `test -f 'src/coap_keystore.c' || echo './'`src/coap_keystore.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-coap_keystore.lo -MD -MP -MF src/.deps/libcoap_1_la-coap_keystore.Tpo -c src/coap_keystore.c -fPIE -o src/libcoap_1_la-coap_keystore.o
mv -f src/.deps/libcoap_1_la-coap_keystore.Tpo src/.deps/libcoap_1_la-coap_keystore.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-coap_time.lo -MD -MP -MF src/.deps/libcoap_1_la-coap_time.Tpo -c -o src/libcoap_1_la-coap_time.lo `test -f 'src/coap_time.c' || echo './'`src/coap_time.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-coap_time.lo -MD -MP -MF src/.deps/libcoap_1_la-coap_time.Tpo -c src/coap_time.c -fPIE -o src/libcoap_1_la-coap_time.o
mv -f src/.deps/libcoap_1_la-coap_time.Tpo src/.deps/libcoap_1_la-coap_time.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-debug.lo -MD -MP -MF src/.deps/libcoap_1_la-debug.Tpo -c -o src/libcoap_1_la-debug.lo `test -f 'src/debug.c' || echo './'`src/debug.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-debug.lo -MD -MP -MF src/.deps/libcoap_1_la-debug.Tpo -c src/debug.c -fPIE -o src/libcoap_1_la-debug.o
mv -f src/.deps/libcoap_1_la-debug.Tpo src/.deps/libcoap_1_la-debug.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-encode.lo -MD -MP -MF src/.deps/libcoap_1_la-encode.Tpo -c -o src/libcoap_1_la-encode.lo `test -f 'src/encode.c' || echo './'`src/encode.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-encode.lo -MD -MP -MF src/.deps/libcoap_1_la-encode.Tpo -c src/encode.c -fPIE -o src/libcoap_1_la-encode.o
mv -f src/.deps/libcoap_1_la-encode.Tpo src/.deps/libcoap_1_la-encode.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-hashkey.lo -MD -MP -MF src/.deps/libcoap_1_la-hashkey.Tpo -c -o src/libcoap_1_la-hashkey.lo `test -f 'src/hashkey.c' || echo './'`src/hashkey.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-hashkey.lo -MD -MP -MF src/.deps/libcoap_1_la-hashkey.Tpo -c src/hashkey.c -fPIE -o src/libcoap_1_la-hashkey.o
mv -f src/.deps/libcoap_1_la-hashkey.Tpo src/.deps/libcoap_1_la-hashkey.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-mem.lo -MD -MP -MF src/.deps/libcoap_1_la-mem.Tpo -c -o src/libcoap_1_la-mem.lo `test -f 'src/mem.c' || echo './'`src/mem.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-mem.lo -MD -MP -MF src/.deps/libcoap_1_la-mem.Tpo -c src/mem.c -fPIE -o src/libcoap_1_la-mem.o
mv -f src/.deps/libcoap_1_la-mem.Tpo src/.deps/libcoap_1_la-mem.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-net.lo -MD -MP -MF src/.deps/libcoap_1_la-net.Tpo -c -o src/libcoap_1_la-net.lo `test -f 'src/net.c' || echo './'`src/net.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-net.lo -MD -MP -MF src/.deps/libcoap_1_la-net.Tpo -c src/net.c -fPIE -o src/libcoap_1_la-net.o
mv -f src/.deps/libcoap_1_la-net.Tpo src/.deps/libcoap_1_la-net.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-option.lo -MD -MP -MF src/.deps/libcoap_1_la-option.Tpo -c -o src/libcoap_1_la-option.lo `test -f 'src/option.c' || echo './'`src/option.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-option.lo -MD -MP -MF src/.deps/libcoap_1_la-option.Tpo -c src/option.c -fPIE -o src/libcoap_1_la-option.o
mv -f src/.deps/libcoap_1_la-option.Tpo src/.deps/libcoap_1_la-option.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-pdu.lo -MD -MP -MF src/.deps/libcoap_1_la-pdu.Tpo -c -o src/libcoap_1_la-pdu.lo `test -f 'src/pdu.c' || echo './'`src/pdu.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-pdu.lo -MD -MP -MF src/.deps/libcoap_1_la-pdu.Tpo -c src/pdu.c -fPIE -o src/libcoap_1_la-pdu.o
mv -f src/.deps/libcoap_1_la-pdu.Tpo src/.deps/libcoap_1_la-pdu.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-resource.lo -MD -MP -MF src/.deps/libcoap_1_la-resource.Tpo -c -o src/libcoap_1_la-resource.lo `test -f 'src/resource.c' || echo './'`src/resource.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-resource.lo -MD -MP -MF src/.deps/libcoap_1_la-resource.Tpo -c src/resource.c -fPIE -o src/libcoap_1_la-resource.o
mv -f src/.deps/libcoap_1_la-resource.Tpo src/.deps/libcoap_1_la-resource.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-str.lo -MD -MP -MF src/.deps/libcoap_1_la-str.Tpo -c -o src/libcoap_1_la-str.lo `test -f 'src/str.c' || echo './'`src/str.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-str.lo -MD -MP -MF src/.deps/libcoap_1_la-str.Tpo -c src/str.c -fPIE -o src/libcoap_1_la-str.o
mv -f src/.deps/libcoap_1_la-str.Tpo src/.deps/libcoap_1_la-str.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-subscribe.lo -MD -MP -MF src/.deps/libcoap_1_la-subscribe.Tpo -c -o src/libcoap_1_la-subscribe.lo `test -f 'src/subscribe.c' || echo './'`src/subscribe.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-subscribe.lo -MD -MP -MF src/.deps/libcoap_1_la-subscribe.Tpo -c src/subscribe.c -fPIE -o src/libcoap_1_la-subscribe.o
mv -f src/.deps/libcoap_1_la-subscribe.Tpo src/.deps/libcoap_1_la-subscribe.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-uri.lo -MD -MP -MF src/.deps/libcoap_1_la-uri.Tpo -c -o src/libcoap_1_la-uri.lo `test -f 'src/uri.c' || echo './'`src/uri.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/libcoap_1_la-uri.lo -MD -MP -MF src/.deps/libcoap_1_la-uri.Tpo -c src/uri.c -fPIE -o src/libcoap_1_la-uri.o
mv -f src/.deps/libcoap_1_la-uri.Tpo src/.deps/libcoap_1_la-uri.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/platform/posix/libcoap_1_la-coap_io.lo -MD -MP -MF src/platform/posix/.deps/libcoap_1_la-coap_io.Tpo -c -o src/platform/posix/libcoap_1_la-coap_io.lo `test -f 'src/platform/posix/coap_io.c' || echo './'`src/platform/posix/coap_io.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/platform/posix/libcoap_1_la-coap_io.lo -MD -MP -MF src/platform/posix/.deps/libcoap_1_la-coap_io.Tpo -c src/platform/posix/coap_io.c -fPIE -o src/platform/posix/libcoap_1_la-coap_io.o
mv -f src/platform/posix/.deps/libcoap_1_la-coap_io.Tpo src/platform/posix/.deps/libcoap_1_la-coap_io.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/platform/posix/libcoap_1_la-prng.lo -MD -MP -MF src/platform/posix/.deps/libcoap_1_la-prng.Tpo -c -o src/platform/posix/libcoap_1_la-prng.lo `test -f 'src/platform/posix/prng.c' || echo './'`src/platform/posix/prng.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/platform/posix/libcoap_1_la-prng.lo -MD -MP -MF src/platform/posix/.deps/libcoap_1_la-prng.Tpo -c src/platform/posix/prng.c -fPIE -o src/platform/posix/libcoap_1_la-prng.o
[01m[Ksrc/platform/posix/prng.c:16:1:[m[K [01;35m[Kwarning: [m[Kno previous prototype for ‘[01m[Kcoap_prng[m[K’ [[01;35m[K-Wmissing-prototypes[m[K]
[01;35m[Kcoap_prng[m[K(unsigned char *buf, size_t len) {
[01;35m[K^~~~~~~~~[m[K
[01m[Ksrc/platform/posix/prng.c:23:1:[m[K [01;35m[Kwarning: [m[Kno previous prototype for ‘[01m[Kcoap_prng_init[m[K’ [[01;35m[K-Wmissing-prototypes[m[K]
[01;35m[Kcoap_prng_init[m[K(void *value) {
[01;35m[K^~~~~~~~~~~~~~[m[K
mv -f src/platform/posix/.deps/libcoap_1_la-prng.Tpo src/platform/posix/.deps/libcoap_1_la-prng.Plo
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/platform/posix/libcoap_1_la-run.lo -MD -MP -MF src/platform/posix/.deps/libcoap_1_la-run.Tpo -c -o src/platform/posix/libcoap_1_la-run.lo `test -f 'src/platform/posix/run.c' || echo './'`src/platform/posix/run.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I ./ext/tinydtls -fPIC -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT src/platform/posix/libcoap_1_la-run.lo -MD -MP -MF src/platform/posix/.deps/libcoap_1_la-run.Tpo -c src/platform/posix/run.c -fPIE -o src/platform/posix/libcoap_1_la-run.o
mv -f src/platform/posix/.deps/libcoap_1_la-run.Tpo src/platform/posix/.deps/libcoap_1_la-run.Plo
/bin/bash ./libtool --tag=CC --mode=link gcc -fPIC -fPIE -I ./include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -version-info 0:0:0 -Wl,--version-script=./libcoap-1.map -pie -L./ext/tinydtls -ltinydtls -o libcoap-1.la -rpath /usr/local/lib src/libcoap_1_la-address.lo src/libcoap_1_la-async.lo src/libcoap_1_la-block.lo src/libcoap_1_la-coap_dtls.lo src/libcoap_1_la-coap_event.lo src/libcoap_1_la-coap_keystore.lo src/libcoap_1_la-coap_time.lo src/libcoap_1_la-debug.lo src/libcoap_1_la-encode.lo src/libcoap_1_la-hashkey.lo src/libcoap_1_la-mem.lo src/libcoap_1_la-net.lo src/libcoap_1_la-option.lo src/libcoap_1_la-pdu.lo src/libcoap_1_la-resource.lo src/libcoap_1_la-str.lo src/libcoap_1_la-subscribe.lo src/libcoap_1_la-uri.lo src/platform/posix/libcoap_1_la-coap_io.lo src/platform/posix/libcoap_1_la-prng.lo src/platform/posix/libcoap_1_la-run.lo
libtool: link: ar cru .libs/libcoap-1.a src/libcoap_1_la-address.o src/libcoap_1_la-async.o src/libcoap_1_la-block.o src/libcoap_1_la-coap_dtls.o src/libcoap_1_la-coap_event.o src/libcoap_1_la-coap_keystore.o src/libcoap_1_la-coap_time.o src/libcoap_1_la-debug.o src/libcoap_1_la-encode.o src/libcoap_1_la-hashkey.o src/libcoap_1_la-mem.o src/libcoap_1_la-net.o src/libcoap_1_la-option.o src/libcoap_1_la-pdu.o src/libcoap_1_la-resource.o src/libcoap_1_la-str.o src/libcoap_1_la-subscribe.o src/libcoap_1_la-uri.o src/platform/posix/libcoap_1_la-coap_io.o src/platform/posix/libcoap_1_la-prng.o src/platform/posix/libcoap_1_la-run.o
ar: `u' modifier ignored since `D' is the default (see `U')
libtool: link: ranlib .libs/libcoap-1.a
libtool: link: ( cd ".libs" && rm -f "libcoap-1.la" && ln -s "../libcoap-1.la" "libcoap-1.la" )
make[2] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap »
Making all in tests
make[2] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/tests »
make[2]: rien à faire pour « all ».
make[2] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/tests »
Making all in examples
make[2] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/examples »
gcc -DHAVE_CONFIG_H -I. -I.. -I ../ext/tinydtls -isystem../include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT client.o -MD -MP -MF .deps/client.Tpo -c -o client.o client.c
mv -f .deps/client.Tpo .deps/client.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I ../ext/tinydtls -isystem../include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT coap_list.o -MD -MP -MF .deps/coap_list.Tpo -c -o coap_list.o coap_list.c
mv -f .deps/coap_list.Tpo .deps/coap_list.Po
/bin/bash ../libtool --tag=CC --mode=link gcc -isystem../include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -L../ext/tinydtls -ltinydtls -o coap-client client.o coap_list.o ../.libs/libcoap-1.la
libtool: link: gcc -isystem../include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -o coap-client client.o coap_list.o -L../ext/tinydtls ../.libs/libcoap-1.a -L./ext/tinydtls -ltinydtls
gcc -DHAVE_CONFIG_H -I. -I.. -I ../ext/tinydtls -isystem../include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT coap-server.o -MD -MP -MF .deps/coap-server.Tpo -c -o coap-server.o coap-server.c
mv -f .deps/coap-server.Tpo .deps/coap-server.Po
/bin/bash ../libtool --tag=CC --mode=link gcc -isystem../include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -L../ext/tinydtls -ltinydtls -o coap-server coap-server.o ../.libs/libcoap-1.la
libtool: link: gcc -isystem../include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -o coap-server coap-server.o -L../ext/tinydtls ../.libs/libcoap-1.a -L./ext/tinydtls -ltinydtls
gcc -DHAVE_CONFIG_H -I. -I.. -I ../ext/tinydtls -isystem../include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -MT coap-rd.o -MD -MP -MF .deps/coap-rd.Tpo -c -o coap-rd.o coap-rd.c
mv -f .deps/coap-rd.Tpo .deps/coap-rd.Po
/bin/bash ../libtool --tag=CC --mode=link gcc -isystem../include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -L../ext/tinydtls -ltinydtls -o coap-rd coap-rd.o ../.libs/libcoap-1.la
libtool: link: gcc -isystem../include/coap/ -pedantic -Wall -Wextra -Wformat-security -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wunused -Wunused-result -Wlogical-op -std=c99 -D COAP_DEBUG_FD=stderr -fdiagnostics-color -D_GNU_SOURCE -DWITH_POSIX -o coap-rd coap-rd.o -L../ext/tinydtls ../.libs/libcoap-1.a -L./ext/tinydtls -ltinydtls
make[2] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/examples »
make[1] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap »
Making install in ext/tinydtls
make[1] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls »
make[2] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/aes »
make[2]: « rijndael.o » est à jour.
make[2] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/aes »
make -C ecc ecc.o
make[2] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/ecc »
make[2]: « ecc.o » est à jour.
make[2] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/ecc »
make -C sha2 sha2.o
make[2] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/sha2 »
make[2]: « sha2.o » est à jour.
make[2] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/sha2 »
make -C doc
make[2] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/doc »
make[2] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/doc »
test -d /usr/local/lib || mkdir -p /usr/local/lib
test -d /usr/local/include/tinydtls || mkdir -p /usr/local/include/tinydtls
cp libtinydtls.a /usr/local/lib/
cp dtls.h hmac.h dtls_debug.h dtls_config.h uthash.h numeric.h crypto.h global.h ccm.h netq.h alert.h utlist.h prng.h peer.h state.h dtls_time.h session.h tinydtls.h /usr/local/include/tinydtls/
make -C $dir install="cp" includedir=/usr/local/include/tinydtls install; \
done
make[2] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/tests »
make[2] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/tests »
make[2]: *** Aucune règle pour fabriquer la cible « html », nécessaire pour « install ». Arrêt.
make[2] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/platform-specific »
make[2] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls/platform-specific »
test -d /usr/local/include/tinydtls/sha2 || mkdir -p /usr/local/include/tinydtls/sha2
cp sha2.h /usr/local/include/tinydtls/sha2
test -d /usr/local/include/tinydtls/aes || mkdir -p /usr/local/include/tinydtls/aes
cp rijndael.h /usr/local/include/tinydtls/aes
test -d /usr/local/include/tinydtls/ecc || mkdir -p /usr/local/include/tinydtls/ecc
cp ecc.h test_helper.h /usr/local/include/tinydtls/ecc
make[1] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/ext/tinydtls »
Making install in .
make[1] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap »
/bin/mkdir -p '/usr/local/lib'
/bin/bash ./libtool --mode=install /usr/bin/install -c libcoap-1.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libcoap-1.lai /usr/local/lib/libcoap-1.la
libtool: install: /usr/bin/install -c .libs/libcoap-1.a /usr/local/lib/libcoap-1.a
libtool: install: chmod 644 /usr/local/lib/libcoap-1.a
libtool: install: ranlib /usr/local/lib/libcoap-1.a
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/sbin" ldconfig -n /usr/local/lib
Libraries have been installed in:
/usr/local/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the '-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the 'LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the 'LD_RUN_PATH' environment variable
during linking
- use the '-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to '/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
/bin/mkdir -p '/usr/local/include/coap/'
/usr/bin/install -c -m 644 include/coap/address.h include/coap/async.h include/coap/bits.h include/coap/block.h include/coap/coap.h include/coap/coap_dtls.h include/coap/coap_event.h include/coap/coap_keystore.h include/coap/coap_io.h include/coap/coap_time.h include/coap/debug.h include/coap/encode.h include/coap/hashkey.h include/coap/libcoap.h include/coap/mem.h include/coap/net.h include/coap/option.h include/coap/pdu.h include/coap/prng.h include/coap/resource.h include/coap/run.h include/coap/str.h include/coap/subscribe.h include/coap/uri.h include/coap/uthash.h include/coap/utlist.h '/usr/local/include/coap/'
/bin/mkdir -p '/usr/local/lib/pkgconfig'
/usr/bin/install -c -m 644 libcoap-1.pc '/usr/local/lib/pkgconfig'
Making install in tests
make[1] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/tests »
make[2]: rien à faire pour « install-exec-am ».
make[2]: rien à faire pour « install-data-am ».
make[1] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/tests »
Making install in examples
make[1] : on entre dans le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/examples »
/bin/mkdir -p '/usr/local/bin'
/bin/bash ../libtool --mode=install /usr/bin/install -c coap-client coap-server coap-rd '/usr/local/bin'
libtool: install: /usr/bin/install -c coap-client /usr/local/bin/coap-client
libtool: install: /usr/bin/install -c coap-server /usr/local/bin/coap-server
libtool: install: /usr/bin/install -c coap-rd /usr/local/bin/coap-rd
make[1] : on quitte le répertoire « /var/www/html/plugins/ikealight/resources/ikealightd/libcoap/examples »
* Installation terminée *
