Bonsoir à toutes et à tous,
Super intéressant à première vue, ce plugin me pose, à moi aussi, quelques soucis ;
Installation toute fraiche de Jeedom, un ConBee (le raspbee en version USB). Phoscon & Deconz voient bien tous mes capteurs (ouverture, température, ...) et en détectent tous les changements d'état et remontées d'information (température, humidité, ...).
Lorsque je dumpe les capteurs, j'obtiens bien les informations statutaires et les états/valeurs de mes capteurs ;
{"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"d7e1ce06cbe415f9a3859f59a63dae37","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"daylight":false,"lastupdated":"2019-02-25T17:42:15","status":190},"swversion":"1.0","type":"Daylight","uniqueid":"00:00:00:00:00:00:00:00-01"},"10":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"1f434899ca922c1edbdb250cace3b2bd","manufacturername":"LUMI","modelid":"lumi.sensor_ht","name":"Entree","state":{"humidity":3141,"lastupdated":"2019-02-25T12:06:21"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:02:b6:fc:57-01-0405"},"4":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2100},"ep":1,"etag":"d7e1ce06cbe415f9a3859f59a63dae37","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"Fenetre Escalier","state":{"lastupdated":"2019-02-25T11:47:03","open":false},"type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:bf:97:33-01-0006"},"5":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2100},"ep":1,"etag":"d7e1ce06cbe415f9a3859f59a63dae37","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"Fenetre Cuisine","state":{"lastupdated":"2019-02-25T12:07:23","open":true},"type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:bf:d8:43-01-0006"},"6":{"config":{"battery":100,"on":true,"reachable":true,"temperature":3100},"ep":1,"etag":"4ef144fcb99c37cabc4eac1ab8deb1b9","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"Porte entree etage","state":{"lastupdated":"2019-02-25T11:57:52","open":false},"type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:e2:10:6e-01-0006"},"7":{"config":{"battery":100,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"1f434899ca922c1edbdb250cace3b2bd","manufacturername":"LUMI","modelid":"lumi.sensor_ht","name":"Entree","state":{"lastupdated":"2019-02-25T12:06:21","temperature":2539},"type":"ZHATemperature","uniqueid":"00:15:8d:00:02:b6:fc:57-01-0402"},"8":{"config":{"battery":100,"on":true,"reachable":true,"temperature":0},"ep":1,"etag":"51524c394c05ea2875f0a2f14e3725e5","manufacturername":"LUMI","modelid":"lumi.sensor_magnet","name":"Porte entree garage","state":{"lastupdated":"2019-02-25T11:54:04","open":true},"type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:c4:97:f1-01-0006"},"9":{"config":{"battery":100,"on":true,"reachable":true,"temperature":0},"ep":1,"etag":"d7e1ce06cbe415f9a3859f59a63dae37","manufacturername":"LUMI","modelid":"lumi.sensor_magnet","name":"Porte chambre parentale","state":{"lastupdated":"2019-02-25T12:00:03","open":true},"type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:c6:b0:53-01-0006"}}
Sauf que ... dans l'interface jeedom, rien, pas d'état de mes portes ni de valeur de mes capteurs :
- temperature.jpg (34.48 Kio) Consulté 4429 fois
Là où, comme indiqué plus haut, dans phoscon :
- Phoscon.jpg (50.78 Kio) Consulté 4429 fois
J'ai lu, plus haut dans le thread, que quelqu'un avait apporté une modification au code du plugin, mais je ne suis pas certain du "ce qu'il faut faire".
Si l'une ou l'un d'entre vous se sent l'âme d'un donneur de coup de main, ben ... merci !
Bonne soirée,
Olivier en Bretagne
