j'ai acheté la double prise, mais malgrés le faite de l'avoir mise sur une IP fixe, et d'avoir les 2 ID, la prise ne fonctionne pas avec le plugin.
j'ai la version 2019-02-19 04:26:30 du plugin.
Voici le log sur un ON et un OFF (répétition de la commande sur 6x):
[2019-02-22 23:10:09][DEBUG] : CFGcanal:6
[2019-02-22 23:10:09][DEBUG] : Commande : {"t":"1550873409","devId":"66376420ecfabc2a897d","dps":{"1":true},"uid":""}
[2019-02-22 23:10:09][DEBUG] : try to connect to : 192.168.0.69 6668
[2019-02-22 23:10:09][DEBUG] : Connect OK
[2019-02-22 23:10:10][DEBUG] : Return Out size: 0
[2019-02-22 23:10:10][DEBUG] : return empty
[2019-02-22 23:10:10][DEBUG] : Commande : {"gwId":"66376420ecfabc2a897d","devId":"66376420ecfabc2a897d"}
[2019-02-22 23:10:10][DEBUG] : try to connect to : 192.168.0.69 6668
[2019-02-22 23:10:10][DEBUG] : Connect OK
[2019-02-22 23:10:10][DEBUG] : Return Out size: 173
[2019-02-22 23:10:10][DEBUG] : return OK :0
[2019-02-22 23:10:10][DEBUG] : length:157
[2019-02-22 23:10:10][DEBUG] : len of decoded returned mess:145
[2019-02-22 23:10:10][DEBUG] : return decoded : {"devId":"66376420ecfabc2a897d","dps":{"1":false,"2":false,"9":0,"10":0,"18":0,"19":0,"20":2296,"21":1,"22":596,"23":28361,"24":15968,"25":1310}}
[2019-02-22 23:10:10][DEBUG] : Read Json OK
[2019-02-22 23:10:10][DEBUG] : Not null
[2019-02-22 23:10:10][DEBUG] : OFF
[2019-02-22 23:10:12][DEBUG] : CFGcanal:6
[2019-02-22 23:10:12][DEBUG] : Commande : {"t":"1550873412","devId":"66376420ecfabc2a897d","dps":{"1":false},"uid":""}
[2019-02-22 23:10:12][DEBUG] : try to connect to : 192.168.0.69 6668
[2019-02-22 23:10:12][DEBUG] : Connect OK
[2019-02-22 23:10:12][DEBUG] : Return Out size: 0
[2019-02-22 23:10:12][DEBUG] : return empty
[2019-02-22 23:10:12][DEBUG] : Commande : {"gwId":"66376420ecfabc2a897d","devId":"66376420ecfabc2a897d"}
[2019-02-22 23:10:12][DEBUG] : Return Out size: 173
[2019-02-22 23:10:12][DEBUG] : return OK :0
[2019-02-22 23:10:12][DEBUG] : length:157
[2019-02-22 23:10:12][DEBUG] : len of decoded returned mess:145
[2019-02-22 23:10:12][DEBUG] : return decoded : {"devId":"66376420ecfabc2a897d","dps":{"1":false,"2":false,"9":0,"10":0,"18":0,"19":0,"20":2296,"21":1,"22":596,"23":28361,"24":15968,"25":1310}}
[2019-02-22 23:10:12][DEBUG] : Read Json OK
[2019-02-22 23:10:12][DEBUG] : Not null
[2019-02-22 23:10:12][DEBUG] : OFF
