[Plugin Tiers][Sujet Principal] Motion
Re: [Plugin Tiers][Sujet Principal] Motion
Des snap oui. J'ai activé le cadre rouge mais celui-ci n'est pas dans la zone bleu.
Je regarderai si la configuration ce fait bien car la c'est pas la plugin qui fait le boulot mais motion
Bon après divers essais, je n'arrive à rien avec mes Wanscam.
Voila les infos sur l'activité de motion :
Est-ce que quelqu'un à un exemple de config avec wanscam ?
PS : J'ai le plugin caméra qui fonctionne trés bien.
[0:motion] [NTC] [ALL] [Jan 19 06:55:39] motion_startup: Motion 4.2.1+git1faacf1 Started
[0:motion] [NTC] [ALL] [Jan 19 06:55:39] motion_startup: Using log type (ALL) log level (NTC)
[0:motion] [NTC] [ALL] [Jan 19 06:55:39] become_daemon: Motion going to daemon mode
[0:motion] [NTC] [ALL] [Jan 19 06:55:39] motion_startup: Motion running as daemon process
[0:motion] [NTC] [STR] [Jan 19 06:55:39] webu_start_strm: Starting camera 199 stream on port 1935
[0:motion] [NTC] [STR] [Jan 19 06:55:39] webu_strm_ntc: Started camera 199 stream on port 1935
[0:motion] [NTC] [STR] [Jan 19 06:55:39] webu_start_ctrl: Starting webcontrol on port 8080
[0:motion] [NTC] [STR] [Jan 19 06:55:39] webu_start_ctrl: Started webcontrol on port 8080
[0:motion] [NTC] [ENC] [Jan 19 06:55:39] ffmpeg_global_init: ffmpeg libavcodec version 56.1.0 libavformat version 56.1.0
[0:motion] [NTC] [ALL] [Jan 19 06:55:39] translate_init: Language: English
[0:motion] [NTC] [ALL] [Jan 19 06:55:39] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:55:39] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[0:motion] [NTC] [ALL] [Jan 19 06:55:39] main: Waiting for threads to finish, pid: 11553
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:55:39] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:55:39] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:39] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:39] netcam_read_first_header: Removed netcam Keep-Alive flag due to apparent closed HTTP connection.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:39] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:39] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:55:39] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:55:39] vid_start: Netcam failed to open
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:55:39] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:55:39] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:55:39] image_ring_resize: Resizing pre_capture buffer to 1 items
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:55:40] mlp_retry: Retrying until successful connection with camera
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:55:40] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:40] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:40] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:40] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:55:40] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:55:40] vid_start: Netcam failed to open
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:55:40] motion_loop: Thread exiting
[0:motion] [NTC] [ALL] [Jan 19 06:55:40] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:55:40] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:55:40] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:55:40] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:55:40] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:55:40] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:55:40] image_ring_resize: Resizing pre_capture buffer to 1 items
[0:motion] [NTC] [ALL] [Jan 19 06:55:41] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:55:41] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:55:41] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:55:41] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:55:41] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:41] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:41] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:41] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:55:41] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:55:41] vid_start: Netcam failed to open
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:55:41] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:55:41] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:55:41] image_ring_resize: Resizing pre_capture buffer to 1 items
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:55:50] mlp_retry: Retrying until successful connection with camera
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:55:50] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:50] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:50] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:50] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:55:50] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:55:50] vid_start: Netcam failed to open
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:55:50] motion_loop: Thread exiting
[0:motion] [NTC] [ALL] [Jan 19 06:55:50] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:55:50] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:55:50] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:55:50] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:55:50] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:55:50] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:55:50] image_ring_resize: Resizing pre_capture buffer to 1 items
[0:motion] [NTC] [ALL] [Jan 19 06:55:51] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:55:51] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:55:51] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:55:51] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:55:51] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:51] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:51] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:55:51] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:55:51] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:55:51] vid_start: Netcam failed to open
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:55:51] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:55:51] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:55:51] image_ring_resize: Resizing pre_capture buffer to 1 items
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:00] mlp_retry: Retrying until successful connection with camera
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:56:00] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:00] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:00] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:00] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:56:00] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:56:00] vid_start: Netcam failed to open
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:00] motion_loop: Thread exiting
[0:motion] [NTC] [ALL] [Jan 19 06:56:00] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:56:00] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:56:00] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:00] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:00] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:00] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:00] image_ring_resize: Resizing pre_capture buffer to 1 items
[0:motion] [NTC] [ALL] [Jan 19 06:56:01] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:56:01] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:56:01] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:01] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:56:01] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:01] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:01] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:01] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:56:01] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:56:01] vid_start: Netcam failed to open
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:01] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:01] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:01] image_ring_resize: Resizing pre_capture buffer to 1 items
[1:ml1:Motion ext] [NTC] [EVT] [Jan 19 06:56:01] event_newfile: File of type 1 saved to: /var/www/html/tmp/motion/199//01-20190119065601-snapshot.jpg
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:10] mlp_retry: Retrying until successful connection with camera
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:56:10] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:10] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:10] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:10] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:56:10] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:56:10] vid_start: Netcam failed to open
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:10] motion_loop: Thread exiting
[0:motion] [NTC] [ALL] [Jan 19 06:56:10] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:56:10] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:56:10] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:10] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:10] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:10] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:10] image_ring_resize: Resizing pre_capture buffer to 1 items
[0:motion] [NTC] [ALL] [Jan 19 06:56:11] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:56:11] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:56:11] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:11] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:56:11] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:11] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:11] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:11] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:56:11] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:56:11] vid_start: Netcam failed to open
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:11] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:11] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:11] image_ring_resize: Resizing pre_capture buffer to 1 items
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:14] mlp_capture: Video signal lost - Adding grey image
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:20] mlp_retry: Retrying until successful connection with camera
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:56:20] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:20] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:20] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:20] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:56:20] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:56:20] vid_start: Netcam failed to open
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:20] motion_loop: Thread exiting
[0:motion] [NTC] [ALL] [Jan 19 06:56:20] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:56:20] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:56:20] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:20] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:20] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:20] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:20] image_ring_resize: Resizing pre_capture buffer to 1 items
[0:motion] [NTC] [ALL] [Jan 19 06:56:21] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:56:21] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:56:21] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:21] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:56:21] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:21] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:21] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:21] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:56:21] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:56:21] vid_start: Netcam failed to open
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:21] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:21] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:21] image_ring_resize: Resizing pre_capture buffer to 1 items
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:30] mlp_retry: Retrying until successful connection with camera
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:56:30] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:30] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:30] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:30] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:56:30] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:56:30] vid_start: Netcam failed to open
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:30] motion_loop: Thread exiting
[0:motion] [NTC] [ALL] [Jan 19 06:56:30] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:56:30] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:56:30] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:30] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:30] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:30] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:30] image_ring_resize: Resizing pre_capture buffer to 1 items
[0:motion] [NTC] [ALL] [Jan 19 06:56:31] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:56:31] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:56:31] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:31] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:56:31] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:31] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:31] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:31] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:56:31] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:56:31] vid_start: Netcam failed to open
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:31] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:31] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:31] image_ring_resize: Resizing pre_capture buffer to 1 items
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:40] mlp_retry: Retrying until successful connection with camera
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:56:40] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:40] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:40] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:40] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:56:40] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:56:40] vid_start: Netcam failed to open
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:40] motion_loop: Thread exiting
[0:motion] [NTC] [ALL] [Jan 19 06:56:40] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:56:40] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:56:40] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:40] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:40] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:40] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:40] image_ring_resize: Resizing pre_capture buffer to 1 items
[0:motion] [NTC] [ALL] [Jan 19 06:56:41] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:56:41] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:56:41] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:41] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:56:41] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:41] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:41] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:41] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:56:41] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:56:41] vid_start: Netcam failed to open
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:41] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:41] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:41] image_ring_resize: Resizing pre_capture buffer to 1 items
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:50] mlp_retry: Retrying until successful connection with camera
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:56:50] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:50] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:50] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:50] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:56:50] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:56:50] vid_start: Netcam failed to open
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:50] motion_loop: Thread exiting
[0:motion] [NTC] [ALL] [Jan 19 06:56:50] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:56:50] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:56:50] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:50] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:50] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:50] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:50] image_ring_resize: Resizing pre_capture buffer to 1 items
[0:motion] [NTC] [ALL] [Jan 19 06:56:51] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:56:51] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:56:51] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:51] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:56:51] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:51] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:51] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:56:51] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:56:51] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:56:51] vid_start: Netcam failed to open
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:51] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:56:51] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:56:51] image_ring_resize: Resizing pre_capture buffer to 1 items
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:57:00] mlp_retry: Retrying until successful connection with camera
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:57:00] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:57:00] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:57:00] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:57:00] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:57:00] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:57:00] vid_start: Netcam failed to open
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:57:00] motion_loop: Thread exiting
[0:motion] [NTC] [ALL] [Jan 19 06:57:00] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:57:00] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:57:00] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:57:00] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:57:00] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:57:00] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:57:00] image_ring_resize: Resizing pre_capture buffer to 1 items
[0:motion] [NTC] [ALL] [Jan 19 06:57:01] main: Motion thread 1 restart
[0:motion] [NTC] [ALL] [Jan 19 06:57:01] motion_start_thread: Camera ID: 199 is from /etc/motion/camera199.conf
[0:motion] [NTC] [ALL] [Jan 19 06:57:01] motion_start_thread: Camera ID: 199 Camera Name: Motion ext Service: http:
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:57:01] motion_init: Camera 199 started: motion detection Enabled
[1:ml1:Motion ext] [NTC] [VID] [Jan 19 06:57:01] vid_start: Opening Netcam
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:57:01] netcam_start: Network Camera starting for camera (Motion ext)
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:57:01] netcam_setup_html: connected, going on to read image.
[1:ml1:Motion ext] [NTC] [NET] [Jan 19 06:57:01] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1:ml1:Motion ext] [CRT] [NET] [Jan 19 06:57:01] netcam_start: libjpeg decompression failure on first frame - giving up!
[1:ml1:Motion ext] [ERR] [VID] [Jan 19 06:57:01] vid_start: Netcam failed to open
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:57:01] motion_init: Could not fetch initial image from camera
[1:ml1:Motion ext] [WRN] [ALL] [Jan 19 06:57:01] motion_init: Motion continues using width and height from config file(s)
[1:ml1:Motion ext] [NTC] [ALL] [Jan 19 06:57:01] image_ring_resize: Resizing pre_capture buffer to 1 items
selon tes log motion n'arrive pas a ouvir le flux que tu as donné.
quel est la forme que tu as utilisé?
Comme quoi des fois faut pas s'obstiner et faire une pause. Ça fonctionne, j'ai un flux sur le widget.
Maintenant faut que je m'attaque à la détection et au masque.
Super,
Quel etait l'erreur ?
Désolé le poste a ete noyée dans la quantité
Est ce que tu as configure un stream de motion ?
Sans stream le plugin ne sais pas afficher une image
La caméra est une Wanscam HW0045, je n'ai pas trouvé comment récupérer un stream.
Je ne comprend pas.
Est ce qu'avec les paramètre de base tu as de la detection?
Si non pas la peine d'aller plus loin car tu risque de paramétrer quelques chose qui fera défaut
Si oui, pour avoir une image compatible avec le plugin il faut demander a motion de restreamé le flux (Onglet Stream)
Bonjour A tous,
je suis un peu perdu avec motion...
j'ai acheté ce plugin pour essayer de générer une détection sur des caméras qui sont branchées à un DVR.
avec le plugin caméra j'ai bien accès aux snapshots (recommandé) et dans le plugin Homebridge j'ai bien accès aux flux ainsi qu'au snapshots pour chaque channel (8 en tout).
Je me remets a vous pour essayer de voir ou Est-ce que je me trompe dans le paramétrage de mes caméras car je n'arrive pas à accéder ni au flux ni aux snaptshots depuis Motion.
pour information
le flux est accessible sous la forme via VLC:
[url]rtsp://user:mdp@192.168.0.YY:554_RTSP/cam/realmonitor?channel=4&subtype=0[/url]
les snapshots via un navigateur:
http://user:mdp@192.168.0.YY:99/cgi-bin ... channel=4]
pour information
Il faut utilisé le flux rtsp
Merci a toi d'avoir pris le temps de me répondre
je vais insisté sur la commande de flux donc
vu que c'est du rtsp j'ai également coché la case "RTSP connection uses TCP to communicate to the camera. Can prevent image corruption." sans plus de succes pour le moment ...
Je ne suis pas sur qu'il en ai besoin
Bonjour , j'ai installé le plugin motion pour une wanscam hw0043, tout fonctionne bien après paramétrage.
J'ai une question, je voudrais utiliser uniquement la commande détection qui me déclenche plusieurs scenario (lumières en fonction de différents états, alarme, jour/nuit, etc...), et qui me déclenche également un scénario pour démarrer l'enregistrement sur un NAS syno par surveillance station.
Jusque la, tout fonctionne nikel (détection au top et beaucoup moins de fausses détections)
Par contre est ce possible d'enlever l'enregistrement des photos et vidéos sur jeedom car du coup ca fait double emploi avec mon nas, et ca me permettrait d'alléger mon jeedom.
Merci d'avance à tous, et un grand bravo à Mikant28, j'utilise plusieurs de ses plugins!!
il me semble effectivement qu'il y a cette option dans les parametre.
Autrement la taille du dossier snapshot peut etre configurer si elle est a 0 alors plus de snap sur jeedom
Super, merci encore pour ta réactivité..
Je voulais savoir si c'est possible de régler la détection pour éviter les fausses présences liées aux mouvements des ombres des arbres tout en réussissant à détecter une personne.
Je joins une petite séquence vidéo qui montre à quelle vitesse les ombres peuvent bouger.
https://vimeo.com/322411263
DIY sur RPi3
RXFCOM RfxTrx433e
Contrôleur Z-Wave USB G5 AEON LABS W090
MultiSensor AEON DSB05
Fibaro FGS-212
OREGON THN132N (x2)
FOSCAM FI9804W
TABLETTE ARCHOS SMART HOME (pour Webcam et interface tactile)
GOOGLE HOME MINI
RXFCOM RfxTrx433e
Fibaro FGS-212
OREGON THN132N (x2)
FOSCAM FI9804W
GOOGLE HOME MINI
Tous les parametres de motion son disponible.
Regler la sensibilité a la detection est toujours compliqué
- bronche
- Modérateur
- Localisation : Du côté de Issy les Moulineaux la semaine et de Péronne le week-end...
Bonsoir,remyg83 a écrit : ↑03 mars 2019, 10:46Bonjour , j'ai installé le plugin motion pour une wanscam hw0043, tout fonctionne bien après paramétrage.
Je n'ai jamais réussi à faire fonctionner cette caméra avec le plugin.
Une copie de ta page configuration serait la bienvenue.
Amitiés
