Idem chez moi à l'instant... que des nouveaux équipements avec de nouvelles commandes qu'il va falloir remettre dans les scénarios
[2019-04-24 17:55:54][ERROR][zigate](MainThread) : Failed to get network state
Exception in thread Thread-2:
File "/usr/lib/python3.5/threading.py", line 914, in _bootstrap_inner
self.run()
File "/usr/lib/python3.5/threading.py", line 862, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.5/dist-packages/zigate/core.py", line 368, in need_discovery
if device.need_discovery():
File "/usr/local/lib/python3.5/dist-packages/zigate/core.py", line 2771, in need_discovery
self.load_template()
File "/usr/local/lib/python3.5/dist-packages/zigate/core.py", line 2837, in load_template
self._bind_report()
File "/usr/local/lib/python3.5/dist-packages/zigate/core.py", line 2242, in _bind_report
self._zigate.bind_addr(self.addr, endpoint_id, 0x0006)
File "/usr/local/lib/python3.5/dist-packages/zigate/core.py", line 986, in bind_addr
return self.bind(ieee, endpoint, cluster, dst_addr, dst_endpoint)
File "/usr/local/lib/python3.5/dist-packages/zigate/core.py", line 974, in bind
File "/usr/local/lib/python3.5/dist-packages/zigate/core.py", line 958, in _bind_unbind
dst_addr_mode = self._choose_addr_mode(dst_addr)
File "/usr/local/lib/python3.5/dist-packages/zigate/core.py", line 938, in _choose_addr_mode
if len(addr_ieee) == 4:
TypeError: object of type 'NoneType' has no len()
File "/var/www/html/plugins/zigate/core/class/../../resources/zigated/zigated.py", line 328, in <module>
version = z.get_version_text()
File "/usr/local/lib/python3.5/dist-packages/zigate/core.py", line 778, in get_version_text
v = self.get_version(refresh)['version']
TypeError: 'NoneType' object is not subscriptable
[2019-04-24 17:56:46][ERROR][zigate](MainThread) : Failed to get network state
self.run()
self._bind_report()
[2019-04-24 17:57:05][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2019-04-24 17:56:33
[2019-04-24 17:57:08][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2019-04-24 17:56:33
[2019-04-24 17:57:12][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2019-04-24 17:56:33
[2019-04-24 17:57:16][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2019-04-24 17:56:33
[2019-04-24 17:57:32][ERROR][zigate](MainThread) : Failed to get network state
self.run()
self._bind_report()
[2019-04-24 17:58:24][ERROR][zigate](MainThread) : Failed to get network state
self.run()
self._bind_report()
[2019-04-24 18:00:50][ERROR][zigate](MainThread) : Failed to get network state
self.run()
self._bind_report()
[2019-04-24 18:01:04][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2019-04-24 18:00:37
[2019-04-24 18:02:23][ERROR][zigate](MainThread) : Failed to get network state
self.run()
self._bind_report()
[2019-04-24 18:02:36][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2019-04-24 18:02:10
[2019-04-24 18:02:41][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2019-04-24 18:02:10
[2019-04-24 18:02:47][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2019-04-24 18:02:10
[2019-04-24 18:03:52][ERROR][root](Thread-1) : Error on send request to jeedom, return code 500 - Internal Server Error
[2019-04-24 18:03:53][ERROR] : Erreur sur la fonction deamon_start du plugin : [MySQL] Error code : 23000 (1062). Duplicate entry '651-current_level' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `html` = :html, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2019-04-24 18:03:54][ERROR][zigate](ZiGate-Decode data) : Command 0x0030 failed Failed (ZigBee event codes) 128 : b''
[2019-04-24 18:03:57][ERROR][zigate](ZiGate-Decode data) : Command 0x0120 failed Failed (ZigBee event codes) 21 : b''
[2019-04-24 18:03:57][ERROR][zigate](ZiGate-Decode data) : Command 0x0030 failed Failed (ZigBee event codes) 128 : b''
[2019-04-24 18:03:59][ERROR][zigate](ZiGate-Decode data) : Command 0x0120 failed Failed (ZigBee event codes) 21 : b''
[2019-04-24 18:06:20][ERROR][zigate](ZiGate-Decode data) : RESPONSE 0x8702 - APS Data Confirm Fail : status:212, source_endpoint:1, dst_endpoint:1, dst_address_mode:2, dst_address:95e5, sequence:141, lqi:210
[2019-04-24 18:13:13][ERROR][zigate](ZiGate-Decode data) : RESPONSE 0x8702 - APS Data Confirm Fail : status:240, source_endpoint:1, dst_endpoint:1, dst_address_mode:2, dst_address:6512, sequence:145, lqi:0
[2019-04-24 18:13:59][ERROR][zigate](ZiGate-Decode data) : RESPONSE 0x8702 - APS Data Confirm Fail : status:233, source_endpoint:1, dst_endpoint:1, dst_address_mode:2, dst_address:cdb1, sequence:147, lqi:100
