Ce Mi Plant est sur une antenne déporté à base de rpi0w.
L'antenne a bien son cœur en vert.
Pour avoir une remontée d'infos de ce capteur, je dois mettre l'antenne en mode inclusion et faire un refresh sur le capteur.
Sinon quand je fais un refresh normal aucune valeur ne change.
Voici le log lors d'un refresh forcé :
[2019-04-10 10:13:18][DEBUG] : SOCKETHANDLER------Client connected to [10.0.0.9:34660]
[2019-04-10 10:13:18][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey":"MYAPIKEY","cmd":"refresh","device":{"id":"C4:7C:8D:67:2A:A9"},"command":{"device":{"id":"C4:7C:8D:67:2A:A9","delay":"14400","needsrefresh":1,"name":"miflora"},"name":"miflora"}}
[2019-04-10 10:13:18][DEBUG] : SOCKETHANDLER------Client disconnected from [10.0.0.9:34660]
[2019-04-10 10:13:18][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2019-04-10 10:13:18][DEBUG] : SOCKET-READ------Received command from jeedom : refresh
[2019-04-10 10:13:18][DEBUG] : SOCKET-READ------Attempt an action on a device
[2019-04-10 10:13:19][DEBUG] : SOCKET-READ------Action Thread Launched
[2019-04-10 10:13:19][DEBUG] : ACTION------Attempt to refresh values
[2019-04-10 10:13:19][DEBUG] : CONNECTOR------Connecting : C4:7C:8D:67:2A:A9 with bluetooth 0
[2019-04-10 10:13:19][DEBUG] : CONNECTOR------Failed to connect to peripheral C4:7C:8D:67:2A:A9, addr type: public attempt 1
[2019-04-10 10:13:21][DEBUG] : CONNECTOR------Connected... C4:7C:8D:67:2A:A9
[2019-04-10 10:13:21][DEBUG] : CONNECTOR------Reading Characteristic...C4:7C:8D:67:2A:A9
[2019-04-10 10:13:21][DEBUG] : CONNECTOR------Characteristic Readen .... C4:7C:8D:67:2A:A9
[2019-04-10 10:13:21][DEBUG] : CONNECTOR------Writing Characteristic... C4:7C:8D:67:2A:A9
[2019-04-10 10:13:21][DEBUG] : CONNECTOR------Characteristic written... C4:7C:8D:67:2A:A9
[2019-04-10 10:13:21][DEBUG] : {'rsp': ['wr']}
[2019-04-10 10:13:21][DEBUG] : Subscribing to notification : C4:7C:8D:67:2A:A9
[2019-04-10 10:13:21][DEBUG] : Delegated
[2019-04-10 10:13:21][DEBUG] : {'battery': 100, 'firmware': '3.1.9', 'id': u'C4:7C:8D:67:2A:A9'}
[2019-04-10 10:13:21][DEBUG] : Subscribing for 2s
[2019-04-10 10:13:21][DEBUG] : SENDER------Send to jeedom : {u'devices': {u'C4:7C:8D:67:2A:A9': {'battery': 100, 'source': 'RPIZW', 'firmware': '3.1.9', 'id': u'C4:7C:8D:67:2A:A9'}}}
[2019-04-10 10:13:22][DEBUG] : Starting new HTTP connection (1): 10.0.0.9
[2019-04-10 10:13:22][DEBUG] : http://10.0.0.9:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=MYAPIKEY HTTP/1.1" 200 0
[2019-04-10 10:13:22][DEBUG] : CONNECTOR------Disconnecting... C4:7C:8D:67:2A:A9
[2019-04-10 10:13:22][DEBUG] : CONNECTOR------Disconnected...C4:7C:8D:67:2A:A9
[2019-04-10 10:13:22][DEBUG] : Device disconnected
