mika-nt28
Message par mika-nt28 » 24 juin 2019, 14:15
Non je ne les garde pas quand j'en ai plus besoin
Je vais quand meme regarder
Edit
Effectivement je l'ai
Edit2
La commande "Ouverture" de l'equipement "entrée" est une info.
Elle est bien remonté par la freebox comme ceci
[2019-06-24 14:18:04][DEBUG] : { "result" : [ { "data" : [ { "ep_id" : 6, "history" : [ { "timestamp" : 1561188409, "value" : "0" }, { "timestamp" : 1561188423, "value" : "1" }, { "timestamp" : 1561188457, "value" : "0" }, { "timestamp" : 1561188462, "value" : "1" }, { "timestamp" : 1561188487, "value" : "0" }, { "timestamp" : 1561188681, "value" : "1" }, { "timestamp" : 1561190136, "value" : "0" }, { "timestamp" : 1561191011, "value" : "1" }, { "timestamp" : 1561191030, "value" : "0" }, { "timestamp" : 1561191126, "value" : "1" }, { "timestamp" : 1561324004, "value" : "0" }, { "timestamp" : 1561324123, "value" : "1" }, { "timestamp" : 1561324293, "value" : "0" }, { "timestamp" : 1561324297, "value" : "1" }, { "timestamp" : 1561324334, "value" : "0" }, { "timestamp" : 1561324341, "value" : "1" }, { "timestamp" : 1561324352, "value" : "0" }, { "timestamp" : 1561324356, "value" : "1" }, { "timestamp" : 1561324395, "value" : "0" }, { "timestamp" : 1561324400, "value" : "1" }, { "timestamp" : 1561359099, "value" : "0" }, { "timestamp" : 1561359285, "value" : "1" }, { "timestamp" : 1561359454, "value" : "0" }, { "timestamp" : 1561359463, "value" : "1" }, { "timestamp" : 1561360382, "value" : "0" }, { "timestamp" : 1561360387, "value" : "1" }, { "timestamp" : 1561363741, "value" : "0" }, { "timestamp" : 1561363744, "value" : "1" }, { "timestamp" : 1561363776, "value" : "0" }, { "timestamp" : 1561363780, "value" : "1" }, { "timestamp" : 1561365392, "value" : "0" }, { "timestamp" : 1561366043, "value" : "1" }, { "timestamp" : 1561366202, "value" : "0" }, { "timestamp" : 1561366252, "value" : "1" }, { "timestamp" : 1561366299, "value" : "0" }, { "timestamp" : 1561366477, "value" : "1" }, { "timestamp" : 1561366573, "value" : "0" }, { "timestamp" : 1561366601, "value" : "1" }, { "timestamp" : 1561367189, "value" : "0" }, { "timestamp" : 1561367202, "value" : "1" }, { "timestamp" : 1561367231, "value" : "0" }, { "timestamp" : 1561367264, "value" : "1" }, { "timestamp" : 1561374611, "value" : "0" }, { "timestamp" : 1561374615, "value" : "1" }, { "timestamp" : 1561376227, "value" : "0" }, { "timestamp" : 1561376281, "value" : "1" }, { "timestamp" : 1561377169, "value" : "0" }, { "timestamp" : 1561377177, "value" : "1" }, { "timestamp" : 1561377600, "value" : "0" }, { "timestamp" : 1561377603, "value" : "1" } ], "label" : "Ouverture", "name" : "trigger", "refresh" : 2000, "signal_id" : 6, "ui" : { "access" : "r", "display" : "icon", "icon_url" : "/resources/images/home/pictos/porte_%.png", "status_text_range" : [ "Ouvert", "Fermé" ] }, "value" : true, "value_type" : "bool" }, { "ep_id" : 7, "history" : [ ], "label" : "Couvercle", "name" : "cover", "refresh" : 2000, "signal_id" : 7, "ui" : { "access" : "r", "display" : "warning", "icon_url" : "/resources/images/home/pictos/warning.png", "status_text_range" : [ "Couvercle fermé", "Couvercle ouvert" ] }, "value" : false, "value_type" : "bool" }, { "ep_id" : 9, "label" : "Batterie faible", "name" : "battery_warning", "refresh" : 2000, "signal_id" : 9, "ui" : { "access" : "r", "display" : "warning", "icon_url" : "/resources/images/home/pictos/batt_0.png", "range" : [ 0, 10 ], "unit" : "%" }, "value" : 100, "value_type" : "int" }, { "ep_id" : 0, "label" : "", "name" : "alarm1", "refresh" : 2000, "signal_id" : 3, "slot_id" : 0, "ui" : null, "value" : true, "value_type" : "bool" }, { "ep_id" : 1, "label" : "", "name" : "alarm2", "refresh" : 2000, "signal_id" : 4, "slot_id" : 1, "ui" : null, "value" : true, "value_type" : "bool" } ], "ep_type" : "signal", "group" : { "icon_url" : "", "label" : "Entrée" }, "icon_url" : "/resources/images/home/pictos/detecteur_ouverture.png", "label" : "entrée", "node_id" : 11, "type" : "alarm_sensor" } ], "success" : true }
duch
Message par duch » 24 juin 2019, 18:05
ok compris donc en l'étât c'est pas explotiable pour déclencher une action, il faudrait avoir la chance que le capteur soit déclenché au moment même où le démon tourne ce qui est peu probable...
dommage :(
mika-nt28
Message par mika-nt28 » 25 juin 2019, 09:02
Je comprend pas on remonte l'etat actuel pas le changement?
duch
Message par duch » 25 juin 2019, 09:08
en fait il faudrait qu'on fasse le test ensemble en live pour que tu vois le problème, si j'ouvre la porte :
- rien ne se passe dans les logs
- l'état 0 ne remonte jamais, même après 5 minutes (à vérifier toutefois)
- il ne change que si on fait "rechercher les tiles"
mika-nt28
Message par mika-nt28 » 25 juin 2019, 09:27
C'est etrange
La commande "Rechecher les Tiles" est une requet qui remonté tous les tiles pour la creation.
Par contre on vois bien dans tes log qu'il sont tous appeler independament et que dans l'historique il y a une valeur qui change.
Je vais verifer du coup ma fonction de retour si je n'ai pas fait de boulette
duch
Message par duch » 25 juin 2019, 09:33
Je viens d'ouvrir la porte à 9:32, teste la commande "ouverture", elle est encore à 1
je laisse la porte ouverte pendant quelques minutes
mika-nt28
Message par mika-nt28 » 25 juin 2019, 09:34
Je pense avoir trouvé le bug dans la mise a jours automatique.
J'ai poussé une correction sur le market
duch
Message par duch » 25 juin 2019, 10:00
plugin mis à jour et ouverture toujours à 1
mika-nt28
Message par mika-nt28 » 25 juin 2019, 12:22
duch a écrit :
25 juin 2019, 10:00
J'ai rajouté quelques log sur ta machine pour essayé de comprendre le probleme.
On retrouve bien les appel a la freebox mais a ce que tu dit jeedom ne se met pas a jours.
duch
Message par duch » 25 juin 2019, 12:32
une image valant mieux qu'un long discours, là à 12:31 je viens d'ouvrir la porte et ouverture = 1
Capture d’écran 2019-06-25 à 12.31.38.png (600.36 Kio) Consulté 1823 fois
mika-nt28
Message par mika-nt28 » 25 juin 2019, 13:56
Est ce que tu peux faire un essais la j'ai fait une modification chez toi je pense que ca regle le probleme
duch
Message par duch » 25 juin 2019, 14:11
ok là ça fonctionne mais uniquement sur la boucle du démon, ce qui semble malheureusement logique
mika-nt28
Message par mika-nt28 » 25 juin 2019, 14:31
duch a écrit :
25 juin 2019, 14:11
Bah a l'heure actuel il n'y a que comme ca que le plugin se met a jours.
J’espère un jours avoir le temps de comprendre comment le websocket de la freebox fonctionnent et de le mettre en place
koleos
Message par koleos » 25 juin 2019, 21:19
Chez moi, il détecte bien tous mes volets somfy (avec le bon nom), par contre, les commandes ne fonctionnent pas du tout.
J'ai 2 types de volets, RTS et IO.
Pour les IO, j'ai 2 commandes:
- Consigne d'ouverture : me renvoie toujours 0, pas moyen de donner une consigne, donc KO
- Stop : pas d'effet quand mes volets sont en mouvement, me retourne commande exécutée avec succès donc KO
Pour les volets RTS, même chose aucune commande ne fonctionne, par contre j'ai d'autres commandes:
- Bas,
- Etat,
- Haut,
- Stop
Voici une petite partie des logs, il y a bcps de chose:
[2019-06-25 21:11:55][DEBUG] : opening session
[2019-06-25 21:11:55][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/downloads/stats/([])
[2019-06-25 21:11:55][DEBUG] : {"success":true,"result":{"throttling_rate":{"rx_rate":0,"tx_rate":0},"nb_tasks_stopped":0,"dht_stats":{"enabled":false,"node_count_ipv6":0,"enabled_ipv6":false,"node_count":0},"nb_tasks_checking":0,"nb_tasks_queued":0,"blocklist_hits":0,"blocklist_entries":0,"nb_tasks_extracting":0,"nb_tasks_done":0,"nb_tasks_stopping":0,"nzb_config_status":{"status":"ok","error":"none"},"conn_ready":true,"nb_peer":0,"throttling_mode":"normal","nb_tasks_active":0,"nb_tasks_seeding":0,"nb_tasks_error":0,"tx_rate":0,"nb_tasks_repairing":0,"nb_tasks":0,"nb_rss":0,"nb_tasks_downloading":0,"nb_rss_items_unread":0,"rx_rate":0,"throttling_is_scheduled":false}}
[2019-06-25 21:11:55][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v6/home/tileset/7([])
[2019-06-25 21:11:55][DEBUG] : {   "result" : [       {         "action" : "store_slider",         "data" : [             {               "ep_id" : 3,               "label" : "Consigne d'ouverture",               "name" : "position",               "refresh" : 2000,               "signal_id" : 4,               "slot_id" : 3,               "ui" : {                   "access" : "rw",                   "display" : "icon",                   "icon_range" : [                       0,                       11,                       22,                       33,                       44,                       55,                       66,                       77,                       88,                       95                     ],                   "icon_url" : "/resources/images/home/pictos/volet_%.png",                   "unit" : "%"                 },               "value" : 0,               "value_type" : "int"             },             {               "ep_id" : 1,               "label" : "Stop",               "name" : "stop",               "slot_id" : 1,               "ui" : {                   "access" : "w",                   "display" : "button"                 },               "value" : null,               "value_type" : "void"             }           ],         "group" : {             "icon_url" : "",             "label" : "Cuisine"           },         "label" : "Volet Droit",         "node_id" : 7,         "type" : "info"       }     ],   "success" : true }
[2019-06-25 21:11:55][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v6/home/tileset/9([])
[2019-06-25 21:11:55][DEBUG] : {   "result" : [       {         "action" : "store",         "data" : [             {               "ep_id" : 3,               "label" : "État",               "name" : "state",               "refresh" : 2000,               "signal_id" : 3,               "ui" : {                   "access" : "r",                   "display" : "text",                   "icon_url" : "/resources/images/home/pictos/volet_3.png",                   "status_text_range" : [                       "Ouvert",                       "Fermé"                     ]                 },               "value" : false,               "value_type" : "bool"             },             {               "ep_id" : 0,               "label" : "Haut",               "name" : "up",               "slot_id" : 0,               "ui" : {                   "access" : "w",                   "display" : "button"                 },               "value" : null,               "value_type" : "void"             },             {               "ep_id" : 1,               "label" : "Stop",               "name" : "stop",               "slot_id" : 1,               "ui" : {                   "access" : "w",                   "display" : "button"                 },               "value" : null,               "value_type" : "void"             },             {               "ep_id" : 2,               "label" : "Bas",               "name" : "down",               "slot_id" : 2,               "ui" : {                   "access" : "w",                   "display" : "button"                 },               "value" : null,               "value_type" : "void"             }           ],         "group" : {             "icon_url" : "",             "label" : "Chambre"           },         "label" : "Volet Somfy RTS Bleu",         "node_id" : 9,         "type" : "info"       }     ],   "success" : true }
[2019-06-25 21:11:55][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v6/home/tileset/8([])
[2019-06-25 21:11:55][DEBUG] : {   "result" : [       {         "action" : "store",         "data" : [             {               "ep_id" : 3,               "label" : "État",               "name" : "state",               "refresh" : 2000,               "signal_id" : 3,               "ui" : {                   "access" : "r",                   "display" : "text",                   "icon_url" : "/resources/images/home/pictos/volet_3.png",                   "status_text_range" : [                       "Ouvert",                       "Fermé"                     ]                 },               "value" : true,               "value_type" : "bool"             },             {               "ep_id" : 0,               "label" : "Haut",               "name" : "up",               "slot_id" : 0,               "ui" : {                   "access" : "w",                   "display" : "button"                 },               "value" : null,               "value_type" : "void"             },             {               "ep_id" : 1,               "label" : "Stop",               "name" : "stop",               "slot_id" : 1,               "ui" : {                   "access" : "w",                   "display" : "button"                 },               "value" : null,               "value_type" : "void"             },             {               "ep_id" : 2,               "label" : "Bas",               "name" : "down",               "slot_id" : 2,               "ui" : {                   "access" : "w",                   "display" : "button"                 },               "value" : null,               "value_type" : "void"             }           ],         "group" : {             "icon_url" : "",             "label" : "Chambre"           },         "label" : "Volet Somfy RTS Jaune",         "node_id" : 8,         "type" : "info"       }     ],   "success" : true }
[2019-06-25 21:11:55][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/connection/([])
[2019-06-25 21:11:55][DEBUG] : {"success":true,"result":{"type":"ethernet","rate_down":18400,"bytes_up":1050992683,"ipv4_port_range":[0,65535],"rate_up":1970,"bandwidth_up":600000000,"ipv6":"2a01:e0a:1e6:18e0::1","bandwidth_down":10000000000,"media":"ftth","state":"up","bytes_down":13092281687,"ipv4":"82.64.95.100"}}
[2019-06-25 21:11:55][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/connection/xdsl/([])
[2019-06-25 21:11:55][DEBUG] : {"msg":"Impossible de récupérer l'état de la connexion: Ce service n'est pas disponible actuellement","success":false,"error_code":"service_down"}
[2019-06-25 21:11:55][DEBUG] : success KO
[2019-06-25 21:11:55][DEBUG] : error_code exists
[2019-06-25 21:11:55][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/storage/disk/([])
[2019-06-25 21:11:55][DEBUG] : {"success":true,"result":[{"type":"sata","total_bytes":1000000000000,"connector":0,"id":1000,"active_duration":0,"partitions":[{"fstype":"raid","total_bytes":0,"label":"Volume 1000Go","id":1000,"internal":false,"fsck_result":"no_run_yet","state":"umounted","disk_id":1000,"free_bytes":0,"used_bytes":0,"path":"L1ZvbHVtZSAxMDAwR28="}],"idle_duration":3622,"state":"disabled","idle":true,"spinning":false,"model":"WDC WD10JUCX-56WPNY0","table_type":"raid","temp":41,"serial":"WD-WX71A5863Z6P","firmware":"02.01A02"},{"type":"raid","total_bytes":1000000000000,"connector":0,"id":2000,"active_duration":0,"partitions":[{"fstype":"ext4","total_bytes":984340000000,"label":"Freebox","id":2000,"internal":false,"fsck_result":"no_run_yet","state":"mounted","disk_id":2000,"free_bytes":976170000000,"used_bytes":8150000000,"path":"L0ZyZWVib3g="}],"idle_duration":0,"state":"enabled","idle":false,"spinning":false,"model":"","table_type":"superfloppy","temp":0,"serial":"","firmware":""}]}
[2019-06-25 21:11:55][DEBUG] : Occupation [sata] - 1000: 0/0 => NAN%
[2019-06-25 21:11:55][DEBUG] : Occupation [raid] - 2000: 8150000000/984340000000 => 0.83%
[2019-06-25 21:11:55][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v6/home/adapters/HomeAdapters([])
[2019-06-25 21:11:55][DEBUG] : {   "error_code" : "not_found",   "msg" : "no such object",   "success" : false }
[2019-06-25 21:11:55][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/lan/browser/pub/4([])
[2019-06-25 21:11:55][DEBUG] : {"msg":"Erreur interne","success":false,"error_code":"internal_error"}
[2019-06-25 21:11:55][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/system/([])
[2019-06-25 21:11:55][DEBUG] : {"success":true,"result":{"temp_hdd0":41,"temp_sw":41,"user_main_storage":"Freebox","temp_cpu_cp_slave":74,"mac":"34:27:92:63:35:90","temp_cpu_cp_master":72,"box_flavor":"light","fan_rpm":1383,"temp_cpu_ap":62,"temp_cpum":43,"disk_status":"active","temp_cpub":45,"uptime":"8 jours 22 heures 38 minutes 32 secondes","uptime_val":772712,"board_name":"fbxgw7r","box_authenticated":true,"serial":"957602J184901844","firmware_version":"4.0.7"}}
[2019-06-25 21:11:55][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/wifi/config/([])
[2019-06-25 21:11:55][DEBUG] : {"success":true,"result":{"enabled":false,"mac_filter_state":"disabled"}}
[2019-06-25 21:11:55][DEBUG] : L'état du wifi est 0
[2019-06-25 21:11:55][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/call/log/([])
[2019-06-25 21:11:55][DEBUG] : {"success":true,"result":[{"number":"0985700934","type":"missed","id":25,"duration":32,"datetime":1561387314,"contact_id":0,"line_id":0,"name":"0985700934","new":true},{"number":"0960459439","type":"missed","id":24,"duration":35,"datetime":1561376746,"contact_id":0,"line_id":0,"name":"0960459439","new":true},{"number":"0953544822","type":"missed","id":23,"duration":35,"datetime":1561364007,"contact_id":0,"line_id":0,"name":"0953544822","new":true},{"number":"0172686934","type":"missed","id":22,"duration":29,"datetime":1561052750,"contact_id":0,"line_id":0,"name":"0172686934","new":true},{"number":"0954128294","type":"missed","id":21,"duration":35,"datetime":1561048214,"contact_id":0,"line_id":0,"name":"0954128294","new":true},{"number":"0144290269","type":"missed","id":20,"duration":5,"datetime":1561025618,"contact_id":0,"line_id":0,"name":"0144290269","new":true},{"number":"0973121469","type":"missed","id":19,"duration":35,"datetime":1561015501,"contact_id":0,"line_id":0,"name":"0973121469","new":true},{"number":"0171644294","type":"missed","id":18,"duration":29,"datetime":1560859899,"contact_id":0,"line_id":0,"name":"0171644294","new":true},{"number":"+491711526327","type":"missed","id":17,"duration":8,"datetime":1560847528,"contact_id":0,"line_id":0,"name":"+491711526327","new":true},{"number":"0178900940","type":"missed","id":16,"duration":19,"datetime":1558436383,"contact_id":0,"line_id":0,"name":"0178900940","new":true},{"number":"0975145912","type":"missed","id":15,"duration":34,"datetime":1558348915,"contact_id":0,"line_id":0,"name":"0975145912","new":true},{"number":"0178900940","type":"missed","id":14,"duration":19,"datetime":1557230349,"contact_id":0,"line_id":0,"name":"0178900940","new":true},{"number":"0178900940","type":"missed","id":13,"duration":10,"datetime":1557230314,"contact_id":0,"line_id":0,"name":"0178900940","new":true},{"number":"0178900940","type":"missed","id":12,"duration":7,"datetime":1557230272,"contact_id":0,"line_id":0,"name":"0178900940","new":true},{"number":"0146352707","type":"missed","id":11,"duration":34,"datetime":1557142943,"contact_id":0,"line_id":0,"name":"0146352707","new":true},{"number":"0146352725","type":"missed","id":10,"duration":35,"datetime":1557137168,"contact_id":0,"line_id":0,"name":"0146352725","new":true},{"number":"0171701226","type":"missed","id":9,"duration":35,"datetime":1556805678,"contact_id":0,"line_id":0,"name":"0171701226","new":true},{"number":"0746269015","type":"missed","id":8,"duration":25,"datetime":1554128420,"contact_id":0,"line_id":0,"name":"0746269015","new":true},{"number":"0746437804","type":"missed","id":7,"duration":25,"datetime":1554114658,"contact_id":0,"line_id":0,"name":"0746437804","new":true},{"number":"0746670739","type":"missed","id":6,"duration":25,"datetime":1554108761,"contact_id":0,"line_id":0,"name":"0746670739","new":true},{"number":"0985700381","type":"missed","id":5,"duration":35,"datetime":1553772585,"contact_id":0,"line_id":0,"name":"0985700381","new":true},{"number":"0148551647","type":"missed","id":4,"duration":20,"datetime":1551793258,"contact_id":0,"line_id":0,"name":"0148551647","new":true},{"number":"0139155857","type":"missed","id":3,"duration":25,"datetime":1551711628,"contact_id":0,"line_id":0,"name":"0139155857","new":true},{"number":"0148551647","type":"missed","id":2,"duration":28,"datetime":1551349145,"contact_id":0,"line_id":0,"name":"0148551647","new":true},{"number":"0130867272","type":"missed","id":1,"duration":35,"datetime":1550767053,"contact_id":0,"line_id":0,"name":"0130867272","new":true}]}
[2019-06-25 21:11:56][DEBUG] : Connexion GET sur la l'adresse mafreebox.free.fr/api/v6/home/tileset/6([])
[2019-06-25 21:11:56][DEBUG] : {   "result" : [       {         "action" : "store_slider",         "data" : [             {               "ep_id" : 3,               "label" : "Consigne d'ouverture",               "name" : "position",               "refresh" : 2000,               "signal_id" : 4,               "slot_id" : 3,               "ui" : {                   "access" : "rw",                   "display" : "icon",                   "icon_range" : [                       0,                       11,                       22,                       33,                       44,                       55,                       66,                       77,                       88,                       95                     ],                   "icon_url" : "/resources/images/home/pictos/volet_%.png",                   "unit" : "%"                 },               "value" : 0,               "value_type" : "int"             },             {               "ep_id" : 1,               "label" : "Stop",               "name" : "stop",               "slot_id" : 1,               "ui" : {                   "access" : "w",                   "display" : "button"                 },               "value" : null,               "value_type" : "void"             }           ],         "group" : {             "icon_url" : "",             "label" : "Cuisine"           },         "label" : "Volet Gauche",         "node_id" : 6,         "type" : "info"       }     ],   "success" : true }
[2019-06-25 21:11:56][DEBUG] : closing session
[2019-06-25 21:12:33][DEBUG] : Connexion sur la freebox pour Stop
[2019-06-25 21:12:33][DEBUG] : Connexion PUT sur la l'adresse mafreebox.free.fr/api/v6/home/endpoints/7/1/(null)
[2019-06-25 21:12:33][DEBUG] : {   "error_code" : "bad_json",   "msg" : "Bad json",   "success" : false }
[2019-06-25 21:12:33][DEBUG] : success KO
[2019-06-25 21:12:33][DEBUG] : error_code exists
[2019-06-25 21:12:37][DEBUG] : Connexion sur la freebox pour Stop
[2019-06-25 21:12:37][DEBUG] : Connexion PUT sur la l'adresse mafreebox.free.fr/api/v6/home/endpoints/7/1/(null)
[2019-06-25 21:12:37][DEBUG] : {   "error_code" : "bad_json",   "msg" : "Bad json",   "success" : false }
[2019-06-25 21:12:37][DEBUG] : success KO
[2019-06-25 21:12:37][DEBUG] : error_code exists
[2019-06-25 21:12:42][DEBUG] : Connexion sur la freebox pour Stop
[2019-06-25 21:12:42][DEBUG] : Connexion PUT sur la l'adresse mafreebox.free.fr/api/v6/home/endpoints/7/1/(null)
[2019-06-25 21:12:42][DEBUG] : {   "error_code" : "bad_json",   "msg" : "Bad json",   "success" : false }
[2019-06-25 21:12:42][DEBUG] : success KO
[2019-06-25 21:12:42][DEBUG] : error_code exists
[2019-06-25 21:14:02][DEBUG] : Connexion sur la freebox pour Haut
[2019-06-25 21:14:02][DEBUG] : Connexion PUT sur la l'adresse mafreebox.free.fr/api/v6/home/endpoints/9/0/(null)
[2019-06-25 21:14:02][DEBUG] : {   "error_code" : "bad_json",   "msg" : "Bad json",   "success" : false }
[2019-06-25 21:14:02][DEBUG] : success KO
[2019-06-25 21:14:02][DEBUG] : error_code exists
[2019-06-25 21:14:03][DEBUG] : Connexion sur la freebox pour Stop
[2019-06-25 21:14:03][DEBUG] : Connexion PUT sur la l'adresse mafreebox.free.fr/api/v6/home/endpoints/9/1/(null)
[2019-06-25 21:14:03][DEBUG] : {   "error_code" : "bad_json",   "msg" : "Bad json",   "success" : false }
[2019-06-25 21:14:03][DEBUG] : success KO
[2019-06-25 21:14:03][DEBUG] : error_code exists
mika-nt28
Message par mika-nt28 » 26 juin 2019, 09:13
koleos a écrit :
25 juin 2019, 21:19
- Bas,
- Etat,
- Haut,
- Stop
Merci pour le retour, visiblement il ya un probleme dans le json que j'envoie
Je regarde ca
EDIT
Peux tu mettre a jours la beta et lancé un test.
Je ne gerais pas les commande defaut
Jeandhom
Message par Jeandhom » 26 juin 2019, 11:54
J'ai la commande "Liste Appels Manques" qui est chargée, en mode provoqué, de me lancer un scénario.
Or depuis ta dernière stable, mon scénario se lance 2 fois par minute alors qu'il n'y a aucun appel manqué.
[2019-06-26 11:41:49][SCENARIO] Start : Scenario execute automatiquement sur evenement venant de : [Freebox][Telephone][Liste Appels Manques].
[2019-06-26 11:41:49][SCENARIO] Exécution du sous-élément de type [action] : action
[2019-06-26 11:41:49][SCENARIO] Exécution de la commande [Maison][JPI SendSMS][MonTel] avec comme option(s) : {"background":"0","title":"","message":""}
[2019-06-26 11:41:53][SCENARIO] Fin correcte du scénario
[2019-06-26 11:42:21][SCENARIO] Start : Scenario execute automatiquement sur evenement venant de : [Freebox][Telephone][Liste Appels Manques].
[2019-06-26 11:42:21][SCENARIO] Exécution du sous-élément de type [action] : action
[2019-06-26 11:42:21][SCENARIO] Exécution de la commande [Maison][JPI SendSMS][MonTel] avec comme option(s) : {"background":"0","title":"","message":""}
[2019-06-26 11:42:25][SCENARIO] Fin correcte du scénario
[2019-06-26 11:42:53][SCENARIO] Start : Scenario execute automatiquement sur evenement venant de : [Freebox][Telephone][Liste Appels Manques].
[2019-06-26 11:42:53][SCENARIO] Exécution du sous-élément de type [action] : action
[2019-06-26 11:42:53][SCENARIO] Exécution de la commande [Maison][JPI SendSMS][MonTel] avec comme option(s) : {"background":"0","title":"","message":""}
[2019-06-26 11:42:58][SCENARIO] Fin correcte du scénario
[2019-06-26 11:43:25][SCENARIO] Start : Scenario execute automatiquement sur evenement venant de : [Freebox][Telephone][Liste Appels Manques].
[2019-06-26 11:43:25][SCENARIO] Exécution du sous-élément de type [action] : action
[2019-06-26 11:43:25][SCENARIO] Exécution de la commande [Maison][JPI SendSMS][MonTel] avec comme option(s) : {"background":"0","title":"","message":""}
[2019-06-26 11:43:29][SCENARIO] Fin correcte du scénario
[2019-06-26 11:43:57][SCENARIO] Start : Scenario execute automatiquement sur evenement venant de : [Freebox][Telephone][Liste Appels Manques].
[2019-06-26 11:43:57][SCENARIO] Exécution du sous-élément de type [action] : action
[2019-06-26 11:43:57][SCENARIO] Exécution de la commande [Maison][JPI SendSMS][MonTel] avec comme option(s) : {"background":"0","title":"","message":""}
[2019-06-26 11:44:01][SCENARIO] Fin correcte du scénario
mika-nt28
Message par mika-nt28 » 26 juin 2019, 12:11
La liste des appel est mise a jours a chaque boucle de verification
C'etait deja le cas avant mais peut etre qu'il y avait un bug
toughleavy
Message par toughleavy » 26 juin 2019, 13:11
Depuis la mise à jour du plugin FreeboxOS stable ce jour (update du 2019-06-26 05:34:33) mon Player à disparu. Tout le reste semble opérationnel.
Je suis détenteur d'une FBX One et jusqu'à présent tout fonctionnait parfaitement.
J'ai tenté une désinstallation et installation sans succès sur deux plateformes différentes (VM QEMU et RPI3) .
Core Jeedom à jour.
Merci de votre aide si quelqu'un à une idée.
Cordialement
Jeandhom
Message par Jeandhom » 26 juin 2019, 13:18
Bon, j'ai ajouté
à l’événement et c'est OK maintenant.
WinZs
Message par WinZs » 27 juin 2019, 00:40
suite à la mise à jour du plugin (2019-06-26 05:34:33) ,j'ai "perdu" la télécommande et impossible de retrouver comment la recréer.
Ce plugin est vraiment génial , et j'avais plein de scripts, scénarios , et snips qui se basait sur cette télécommande pour fonctionner.
J'ai réinstallé le plugin, refais un appairage, activer les permissions (contrôle du player et modif des réglages) dans l'interface de gestion de ma freebox revolution V6 .
J'ai essayé de cliquer sur "rechercher le tiles" du plugin rien ne se passe ;j'ai juste adsl,airplay,disque dur, home adapter (c'est quoi ça d'ailleurs c'est pour les capteurs de la freebox delta , enfin c'est ce que je comprends en lisant les messages précédents sur le forum,Une maj de la doc serait bienvenue :oops:) , réseaux, système, téléchargements, téléphone.
J'ai rien du tout dans les logs
Je ne retrouve pas ou était le réglage que nicocalv montre dans son screenshoot ou il faut saisir entre autre le code de télécommande
Merci de votre aide
Jeedom 3.3.26 sur rpi3
plugin freebox os 2019-06-26 05:34:33
Freebox revolution V6 os V4.0
nicocalv a écrit :
14 juin 2019, 15:20
Décidément , je reviens avec un autre de tes plugin.
Impossible de créer une télécommande Freebox Os, pourtant avant aucun problème.
L'IP et la code télécommande sont bien renseigné.
En pièces jointe, le screen de mon problème.
