[Plugin Tiers][Sujet Principal] Thermostat ELV/eQ-3/Conrad Max! / MaxCube
Re: [Plugin Tiers][Sujet Principal] Thermostat ELV/eQ-3/Conrad Max! / MaxCube
j'ai publié une version en beta qui n'as plus besoin des droits d'écriture dans /var/www
Coin!
Voila, j'ai installer la bêta, les dépendences s'installe mais je n'arrive pas à démarrer le Demon,
Tu as une idée ?
Au cas ou voici le log.
Tu as une idée ?
+++ dirname /var/www/html/plugins/maxcube/core/class/../../resources/install_maxcube.sh
++ cd /var/www/html/plugins/maxcube/core/class/../../resources
++ pwd
+ ME=/var/www/html/plugins/maxcube/resources
+ touch /tmp/maxcube_in_progress
+ echo 0
+ echo 'Installing maxcube dependencies'
+ sudo apt-get install -y git
Reading package lists...
Building dependency tree...
Reading state information...
git is already the newest version (1:2.11.0-3+deb9u4).
+ echo 10
++ which node
+ BIN=/usr/bin/node
+ '[' /usr/bin/node = '' ']'
++ /usr/bin/node -v
+ actual=v8.16.0
++ sed 's#[.].*##'
++ sed s#v##
++ /usr/bin/node -v
+ major=8
+ echo 'Current version: v8.16.0 (major 8)'
+ echo 30
++ arch
+ '[' x86_64 == armv6l -a 8 -lt 5 ']'
+ '[' 8 -lt 8 ']'
++ which node
+ BIN=/usr/bin/node
++ /usr/bin/node -v
+ new=v8.16.0
+ echo 'new version installed: v8.16.0'
+ echo 50
+ git --version
git version 2.11.0
+ cd /var/www/html/plugins/maxcube/resources/maxcube.js
+ sudo rm -rf node_modules
+ echo 'cache = "/var/www/html/plugins/maxcube/resources/npm-cache"'
+ npm i
> sleep@6.1.0 install /var/www/html/plugins/maxcube/resources/maxcube.js/node_modules/sleep
> node-gyp rebuild
gyp WARN EACCES user "undefined" does not have permission to access the dev dir "/var/www/.node-gyp/8.16.0"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
make: Entering directory '/var/www/html/plugins/maxcube/resources/maxcube.js/node_modules/sleep/build'
CXX(target) Release/obj.target/node_sleep/module_init.o
CXX(target) Release/obj.target/node_sleep/sleep_cpp11.o
CXX(target) Release/obj.target/node_sleep/sleep_posix.o
CXX(target) Release/obj.target/node_sleep/sleep_win.o
SOLINK_MODULE(target) Release/obj.target/node_sleep.node
COPY Release/node_sleep.node
make: Leaving directory '/var/www/html/plugins/maxcube/resources/maxcube.js/node_modules/sleep/build'
npm WARN maxcubeservice@0.0.1 No repository field.
npm WARN maxcubeservice@0.0.1 No license field.
added 99 packages from 109 contributors and audited 193 packages in 37.211s
found 0 vulnerabilities
│ npm update check failed │
│ Try running with sudo or get access │
│ to the local update config store via │
│ sudo chown -R $USER:$(id -gn $USER) /var/www/.config │
+ echo 100
+ rm /tmp/maxcube_in_progress
VM Jeedom sur Synology
Max Cube - Vannes eQ-3 (12x)
Xiaomi Gateway - Xiaomi Aqara (27x) - Xiaomi prise
envoie le log du démon
Coin!
[2019-05-11 00:15:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 00:20:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 00:25:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 00:30:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 00:35:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 00:40:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 00:45:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 00:50:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 00:55:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 00:57:24][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 00:59:23][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 01:00:05][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2019-05-11 00:59:23
[2019-05-11 01:02:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 01:05:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 01:10:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 01:15:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 01:19:34][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 01:45:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 01:50:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 01:55:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 02:00:06][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 02:05:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 02:10:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 02:15:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 02:20:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 02:25:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 02:30:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 02:35:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 02:40:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 02:45:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 02:50:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 02:55:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 03:00:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 03:05:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 03:10:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 03:15:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 03:20:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 03:25:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 03:30:06][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 03:35:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 03:40:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 03:45:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 03:50:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 03:55:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 04:00:06][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 04:05:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 04:10:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 04:15:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 04:20:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 04:25:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 04:30:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 04:35:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 04:40:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 04:45:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 04:50:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 04:55:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 05:00:06][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 05:05:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 05:10:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 05:15:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 05:20:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 05:25:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 05:30:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 05:35:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 05:40:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 05:45:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 05:50:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 05:55:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 06:00:06][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 06:05:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 06:10:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 06:15:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 06:20:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 06:25:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 06:30:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 06:35:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 06:40:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 06:45:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 06:50:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 06:55:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 07:00:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 07:05:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 07:10:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 07:15:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 07:20:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 07:25:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 07:30:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 07:35:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 07:40:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 07:45:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 07:50:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 07:55:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 08:00:06][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 08:05:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 08:10:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 08:15:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 08:20:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 08:25:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 08:30:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 08:35:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 08:40:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 08:45:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 08:50:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 08:55:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 09:00:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 09:01:48][DEBUG] : cd /var/www/html/plugins/maxcube/resources/maxcube.js && bash daemon.sh start /var/www/html/plugins/maxcube/../../log/maxcube_debug 10.0.4.203 62910 7767 - "http://10.0.4.107:80/core/api/jeeApi.php?api=YSb4JYvNrY1yl9patLVhCmMdgNXA0stM&type=maxcube&method=update" temp,valve,setpoint,link_error,battery_low,error,valid,state,mode,panel_locked 1
[2019-05-11 09:01:48][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 09:05:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 09:05:05][DEBUG] : cd /var/www/html/plugins/maxcube/resources/maxcube.js && bash daemon.sh start /var/www/html/plugins/maxcube/../../log/maxcube_debug 10.0.4.203 62910 7767 - "http://10.0.4.107:80/core/api/jeeApi.php?api=YSb4JYvNrY1yl9patLVhCmMdgNXA0stM&type=maxcube&method=update" temp,valve,setpoint,link_error,battery_low,error,valid,state,mode,panel_locked 1
[2019-05-11 09:10:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2019-05-11 09:10:04][DEBUG] : cd /var/www/html/plugins/maxcube/resources/maxcube.js && bash daemon.sh start /var/www/html/plugins/maxcube/../../log/maxcube_debug 10.0.4.203 62910 7767 - "http://10.0.4.107:80/core/api/jeeApi.php?api=YSb4JYvNrY1yl9patLVhCmMdgNXA0stM&type=maxcube&method=update" temp,valve,setpoint,link_error,battery_low,error,valid,state,mode,panel_locked 1
Je redémarrer le cube et la ça fonctionne, tu as de temps à autre le soucis aussi, Est-ce que je fais quelque choses de mal ?
Mon cube est alimenter avec un port usb, serait-il possible qu'il soit sous alimenté ?
J'alimente le cube avec une petite alim externe usb type téléphone portable, aucune idée si ça a un rapport..
Coin!
Et sinon je n'ai jamais eu besoin de restart le cube
Coin!
Je ne serais étonné que si. A tous les coups, l’alim d’origine est trop courte avec ses 500 mA, parce que je dois la rebooter aussi de temps en temps.fensoft a écrit :Et sinon je n'ai jamais eu besoin de restart le cube
Pas encore eu le temps de la changer avec une 1A pour tester, plusieurs projets importants en cours dépendant l’un de l’autre.
DIY ODROID C2 Jeedom PROD - v3.1.7.
DIY RPi2 Jeedom TEST - v3.1.7.
[TUTO] Scénario Lever/Coucher Soleil v2 + Virtuel sans dépendances
Debian Chroot - Installation Auto Jeedom v2.x.x
Bonjour Fen, bonjour scn60
Je reviens sur le forum, car on avance bien dans l'été, ce qui veux dire que on va avoir besoin de chauffage ... et j'ai toujours mon problème de remonté d'information sur les %valves !
tout est à jours, jeedom, et le plugin, et ce qui me met la puce à l'oreille c'est que j'ai des évenement jeevent aussi quand je modifie la consigne de la tête thermostatique
avant d'essayer de faire modif, je voulais être sur que j'aillais pas faire de bétise
merci d'avance messieurs
Nuc Intel - ESXI - VM Jeedom - IPX800 - Xiaomi - Zwave - RFLink
je ne me souviens plus si j'ai poussé ça pour tout le monde, mais oui tu peux tester
Coin!
Je te confirme que tu n'as pas du pousser ca pour tout le monde, après correctif, j'ai de nouveau les remonter des valves !
Bonjour fensoft,
L'hiver arrive et je reviens vers toi avec mon problème de consigne sur le 2eme cube.
Pour rappel, j'ai paramétré 2 cubes dans ton plugin.
je récupère bien des infos de toutes les têtes qui sont connectées (peu importe sur quel cube)
Par contre la modification de consigne ne fonctionne qu'avec les têtes qui sont connectées au dernier des 2 cubes dans la liste...
voilà l'erreur lors de la modification :
SI jamais tu peux regarder, je suis preneur
[2019-10-07T14:55:30+02:00] Heartbeat
[2019-10-07T14:55:30+02:00] Data sent (80%, 49): l
[2019-10-07T14:55:30+02:00] Data received: L [CxPhsgkSGQAXAAAACxPmHwkSGQojAAAACxPiMwkSGQYjAAAA]
[2019-10-07T14:55:30+02:00] statusUpdate
[2019-10-07T14:55:30+02:00] Data sent (undefined%, undefined): l
[2019-10-07T14:55:30+02:00] Data received: L [CxPm0gkSGWQ9ALwACxPxXAkSGQA9AAAACxPmJwkSGQAiAAAACxPvtQkSGWQ9AL8ACxPh3gkSGWQ9AAAACxPw1gkSGWQ9AAAA]
TypeError: Cannot read property 'setpoint' of undefined
at /var/www/html/plugins/maxcube/resources/maxcube.js/maxnodeserver.js:112:50
at Layer.handle [as handle_request] (/var/www/html/plugins/maxcube/resources/maxcube.js/node_modules/express/lib/router/layer.js:95:5)
at next (/var/www/html/plugins/maxcube/resources/maxcube.js/node_modules/express/lib/router/route.js:137:13)
at Route.dispatch (/var/www/html/plugins/maxcube/resources/maxcube.js/node_modules/express/lib/router/route.js:112:3)
at /var/www/html/plugins/maxcube/resources/maxcube.js/node_modules/express/lib/router/index.js:281:22
at param (/var/www/html/plugins/maxcube/resources/maxcube.js/node_modules/express/lib/router/index.js:354:14)
at param (/var/www/html/plugins/maxcube/resources/maxcube.js/node_modules/express/lib/router/index.js:365:14)
at Function.process_params (/var/www/html/plugins/maxcube/resources/maxcube.js/node_modules/express/lib/router/index.js:410:3)
ah oui j'ai oublié, j'essaie de regarder ce soir
Coin!
pas d'erreurs chez moi avec mes deux cubes, je viens de tester à l'instant. tu est sur de ne pas avoir fait d'erreurs dans la config ?
Coin!
Sur non.
Tu veux mon json ?
Tu veux mon json ?
est ce que l'on sait si le plugin est compatible V4 et debian buster ?
On pourrait aussi ouvrir un topic sur la nouvelle plateforme.
Jeedom sur vm esxi stretch
Principaux plugins: eibd, homebridge, maxcube, icalendar
Ça marche quand tu choisis l'un puis l'autre des cubes ? Sinon il me faut un accès ssh pour regarder ça
Envoyé de mon GM1913 en utilisant Tapatalk
Coin!
Oui ca marche qd je met l'un ou l'autre des cubes dans les paramètres. et qd je met les 2, je récupère bien les infos des 2 mais je ne peux changer la consignz que sur le 2eme de la liste...
Je te l'accorde c'est un truc de fou.
Un SSH sur mon jeedom ou sur les cubes ?
je pense a un truc....
Les 2 cubes sont connectés avec des comptes MAX différents. (j'ai pas trouvé pour enregistrer les 2 sur le même)
Ca ne peut pas être ca...
bonjour à tous,
A l'occasion de travaux dans la maison pour une extension avec 2 pieces, de nouveaux radiateurs sont donc ajoutés.
Et donc j'ai besoin de rajouter des valves et thermostat à mon installation actuelle pour les radiateurs dans les nouvelles pièces.
Seulement, Conrad ne les propose plus et le site allemand ELV propose seulement les valves (en rupture)
Savez-vous où je peux en trouver ?
Je cherche au moins 2 thermostats + 2 têtes
