[Plugin Tiers] Loxone
bossensky
Re: [Plugin Tiers] Loxone
Message par bossensky » 04 févr. 2019, 15:54
Bonjour Lunarok,
Je viens de refaire le test avec une installation neuve en Debian 9 et j'ai la même erreur encore, ci-dessous mon log, merci d'avance.
Début de l'installation
--2019-02-04 15:46:07-- https://raw.githubusercontent.com/lunar ... /nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.120.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.120.133|:443... connected.
Length: 1489 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 66.0M=0s
2019-02-04 15:46:08 (66.0 MB/s) - 'dependencies.sh' saved [1489/1489]
dependencies.sh: 3: [: /tmp/jeedom/loxone/dependancy: unexpected operator
Nodejs non installé
Ign:1 http://ftp.fr.debian.org/debian stretch InRelease
Hit:2 http://security.debian.org/debian-security stretch/updates InRelease
Hit:3 http://ftp.fr.debian.org/debian stretch-updates InRelease
Hit:4 http://ftp.fr.debian.org/debian stretch Release
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version (9.20161125).
lsb-release set to manually installed.
E: Unable to locate package npm
dependencies.sh: 37: [: x86_64: unexpected operator
Utilisation du dépot officiel
## Installing the NodeSource Node.js 8.x LTS Carbon repo...
## Populating apt-get cache...
+ apt-get update
Hit:1 http://security.debian.org/debian-security stretch/updates InRelease
Ign:2 http://ftp.fr.debian.org/debian stretch InRelease
## Confirming "stretch" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_8.x/dis ... ch/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
## Creating apt sources list file for the NodeSource Node.js 8.x LTS Carbon repo...
+ echo 'deb https://deb.nodesource.com/node_8.x stretch main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src https://deb.nodesource.com/node_8.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
Get:4 https://deb.nodesource.com/node_8.x stretch InRelease [4647 B]
Hit:5 http://ftp.fr.debian.org/debian stretch Release
Get:6 https://deb.nodesource.com/node_8.x stretch/main Sources [762 B]
Get:8 https://deb.nodesource.com/node_8.x stretch/main amd64 Packages [1009 B]
Fetched 6418 B in 0s (7316 B/s)
## Run `sudo apt-get install -y nodejs` to install Node.js 8.x LTS Carbon and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
nodejs
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 13.6 MB of archives.
After this operation, 64.3 MB of additional disk space will be used.
Get:1 https://deb.nodesource.com/node_8.x stretch/main amd64 nodejs amd64 8.15.0-1nodesource1 [13.6 MB]
debconf: (This frontend requires a controlling tty.)
Fetched 13.6 MB in 5s (2500 kB/s)
Selecting previously unselected package nodejs.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 57531 files and directories currently installed.)
Preparing to unpack .../nodejs_8.15.0-1nodesource1_amd64.deb ...
Unpacking nodejs (8.15.0-1nodesource1) ...
Setting up nodejs (8.15.0-1nodesource1) ...
Processing triggers for man-db (2.7.6.1-2) ...
Version actuelle : v8.15.0
> websocket@1.0.28 install /var/www/html/plugins/loxone/resources/node_modules/websocket
> (node-gyp rebuild 2> builderror.log) || (exit 0)
make: Entering directory '/var/www/html/plugins/loxone/resources/node_modules/websocket/build'
CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
SOLINK_MODULE(target) Release/obj.target/bufferutil.node
COPY Release/bufferutil.node
CXX(target) Release/obj.target/validation/src/validation.o
SOLINK_MODULE(target) Release/obj.target/validation.node
COPY Release/validation.node
make: Leaving directory '/var/www/html/plugins/loxone/resources/node_modules/websocket/build'
> lxcommunicator@0.9.0 postinstall /var/www/html/plugins/loxone/resources/node_modules/lxcommunicator
> node ./browserify.js
Creating browserified module...
Creating debug module
Creating release module
Saving debug module
Saving release module
LxCommunicator~Browser.js and LxCommunicator~Browser.min.js has been created!
npm notice created a lockfile as package-lock.json. You should commit this file.
added 274 packages from 277 contributors and audited 1282 packages in 28.71s
found 0 vulnerabilities
Fin de l'installation
iopaza
Message par iopaza » 17 mars 2019, 17:33
J'avais pas vraiment eu le temps de regarder le plugin, en tout cas bravo.
Je viens de regarder au niveau de la récupération des commandes infos de chaque pièce, et qui sont bien crées et c'est génial.
Cependant, je m'aperçois que tout ce qui vient de mon extension n'est pas créé. Es-ce que j'ai oublié quelque chose ou bien c'est en cours d'ajout?
Jeedom mini+ et Rpi2
-RFXCOM --> 4 modules/-ZWAVE --> 15 modules/-KNX --> 3 modules/-LOXONE et EXTENSION/-IPX V4 et Extension, Fil pilote/- HUE --> 2 modules/-MILIGHT et ARILUX/-ORVIBO
-LEGRAND CPL (non utilisé)
tigroux06
Message par tigroux06 » 17 avr. 2019, 17:44
Bonjour Lunarok
D'abord merci pour ton plugin.
Je viens d'installer le plugin Loxone mais je n'arrive pas à le faire fonctionner.
J'ai crée une entré virtuel sur Loxone avec le port UDP 7778.
Mais la connexion ne s’établit pas. Je ne vois rien dans les logs d'assez parlant.
J'ai ce message:
Echec de la requête HTTP : http://192.168.40.250/data/LoxAPP3.json cURL error : Connection timed out after 30000 milliseconds
Je sais pas si tu as besoin de plus d'informations
lunarok
Message par lunarok » 17 avr. 2019, 20:49
Ton Jeedom n'arrive meme pas à joindre le Loxone là. Tu es sur de l'IP ??? .40.250 et le jeedom ?
tigroux06
Message par tigroux06 » 17 avr. 2019, 22:31
Oui Loxone 192.168.40.250 et Jeedom 192.168.40.100
lunarok
Message par lunarok » 17 avr. 2019, 22:34
Là il te dit que depuis Jeedom il n'arrive pas à joindre Loxone. Et c'est réseau, connection timeout
tigroux06
Message par tigroux06 » 17 avr. 2019, 23:37
Le test http qu'effectue Jeedom se fait sur le port 80 du Loxone?
lunarok
Message par lunarok » 18 avr. 2019, 07:56
Oui, quand aucun port n'est précisé en http c'est 80 le standard, c'est le port d'écoute loxone
tigroux06
Message par tigroux06 » 18 avr. 2019, 08:29
Ah je vais regarder je l'avais peut être changé.
Si je l'ai changé je dois le mettre où ?
Après l'adresse IP avec : ?
Cela ne va pas gêner pour l'udp ensuite ?
lunarok
Message par lunarok » 18 avr. 2019, 10:11
J'ai jamais vu d'option pour mettre le Loxone sur un autre port que 80. Comment tu t'y connectes exactement avec quelle adresse dans l'app mobile par exemple ?
J'ai plutot l'impression que ton problème est réseau entre les 2 vu que ni le http ni l'udp marche. Pourquoi un réseau .40.x ? tu as des vlan ou autres ?
tigroux06
Message par tigroux06 » 18 avr. 2019, 23:44
Je me connecte avec l'adresse 192.168.40.250:7777
Non je n'ai pas de vlan pour le moment mais j'ai juste changé mon IP réseau et mon DHCP.
Jmc57
Message par Jmc57 » 12 août 2019, 17:48
Merci pour ce plugin Lunarok.
Je suis un total debutant dans jeedom.
J'utilise LOXONE.
Mais je n'arrive pas du tout a faire fonctionner le plugin, peut etre que je ne le paramètre pas correctement.
J'ai mis mon adresse IP de mon miniserver ainsi que le port UDP que j'ai défini dans l'entrée virtuelle UDP sur loxone et mes identifiants et quand je sauvegarde il est écrit "[MySQL] Error code : 22001 (1406). Data too long for column 'name' at row 1 : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert" en rouge.
Voila les logs si ca peut etre utile :
--2019-08-12 17:45:03-- https://raw.githubusercontent.com/lunar ... /nodejs.sh
Résolution de raw.githubusercontent.com (raw.githubusercontent.com)… 151.101.120.133
Connexion à raw.githubusercontent.com (raw.githubusercontent.com)|151.101.120.133|:443… connecté.
requête HTTP transmise, en attente de la réponse… 200 OK
Taille : 1489 (1,5K) [text/plain]
Sauvegarde en : « dependencies.sh »
0K . 100% 19,8M=0s
2019-08-12 17:45:04 (19,8 MB/s) — « dependencies.sh » sauvegardé [1489/1489]
Version actuelle : 10
Atteint :1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Atteint :2 http://archive.raspberrypi.org/debian buster InRelease
Atteint :3 https://deb.nodesource.com/node_8.x buster InRelease
lsb-release est déjà la version la plus récente (10.2019051400+rpi1).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 7 non mis à jour.
Ok, version suffisante
dependencies.sh: 59: dependencies.sh: npm: not found
chown: impossible d'accéder à 'node_modules': Aucun fichier ou dossier de ce type
Pour information, mon miniserver et le rpi avec jeedom et sur le même routeur.
Si quelqu'un peut m'aider ca serait sympa. Merci beaucoup.
lunarok
Message par lunarok » 12 août 2019, 18:55
C'est quoi qui est installer comme Raspbian ? Parceque la l'install a l'air bien vieille
Jmc57
Message par Jmc57 » 13 août 2019, 07:36
C’est un raspbian version 10 (buster)
lunarok
Message par lunarok » 13 août 2019, 09:47
Les plugins avec nodejs ne sont pas encore prêts pour buster, il faut rester globalement sur stretch pour le moment avec Jeedom.
Et plus grave l'erreur MySQL n'est pas normale
Jmc57
Message par Jmc57 » 13 août 2019, 10:04
Je vais refaire toute l’installation En stretch et on va voir si ça fonctionne.
Je vous tiens au courant
Jmc57
Message par Jmc57 » 13 août 2019, 14:44
Je viens de refaire l'install en stretch.
je viens de mettre loxone si je reste en local il m'indique toujours la même chose en rouge.
Par contre si je me mets avec l'adresse externe (dns.loxonecloud.com/(numero de série) il arrive à sauvegarder et la dépendance et le demon se met sur OK.
J'ai quelques commandes et équipements qui apparaissent mais que je ne peux pas utiliser et rien faire avec eux.
Pour information, sur loxone j'ai créé un entrée virtuelle UDP avec l'adresse qu'il y a dans votre plugin.
lunarok
Message par lunarok » 13 août 2019, 16:18
Quelle IP en locale ? Quel message d'erreur en rouge ? Des logs ?
Il va falloir être un peu plus verbeux car là je peux rien faire.
Vous avez lu la doc du plugin ensuite pour voir comment interfacer les 2 quels sont les modes à mettre en route ?
L'entrée virtuelle c'est le début, il faut ensuite configurer dans Jeedom ce qu'on veut lui envoyer à Loxone.
Et pareil depuis Loxone vers Jeedom.
Jmc57
Message par Jmc57 » 13 août 2019, 18:47
L'ip en locale est le 192.168.0.180.
Le message en rouge est "[MySQL] Error code : 23000 (1062). Duplicate entry '5-Eclairage Couloir 5' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert"
et sur le log ca marque "Successfully executed 'dev/sps/enablebinstatusupdate' with code 200 and value 1
Successfully executed 'dev/sps/enablebinstatusupdate' with code 200 and value 1"
Et j'ai l'impression que je n'ai qu'une partie de mes équipements.
J'ai bien lu la doc et même les pages à laquelle elle nous renvoie, mais je n'arrive pas à créer de capteur numerique ou analogique comme il nous l'explique, car dans le moniteur UDP je ne peut rien faire.
Comme j'ai dit je suis débutant et j'avance pas mal à tatons.
Jmc57
Message par Jmc57 » 18 août 2019, 12:04
Je n’arrive toujours pas à utiliser le plugin Loxone correctement.
J’ai bien créer des sorties et des entrées virtuelles sur Loxone mais je n’ai rien qui apparaît sur jeedom.
Quand je regarde sur jeedom sur le mode santé. Il me dit que Loxone est ok.
Je pense qu’il y a peut être un problème avec les dépendances car il n’y a jamais eu d’installation la date et l’heure marque sont juste quand j’ai installé le plugin.
C’est sûrement possible que ça est un rapport avec le problème de mysql qui est affiché en rouge (j’ai copié dans le message précédent ce qui était écrit) après pour moi ça ne veut pas dire grand chose.
Est ce que quelqu’un peut m’aider?
